[petsc-users] Question concerning ilu and bcgs
Wed Feb 18 12:56:46 CST 2015
On Wed, Feb 18, 2015 at 12:51 PM, Sun, Hui <hus003 at ucsd.edu> wrote:
>  Thank you Dave. In fact I have tried fieldsplit several months ago, and
> today I go back to the previous code and ran it again. How can I tell it is
> doing what I want it to do? Here are the options:
Solver performance is all about tradeoffs, so start from a place where you
completely understand things, and then
make small changes. PCFIELDSPLIT is an exact solver for a saddle point
system using
  -pc_type fieldsplit -pc_fieldsplit_factorization_type full
  -fieldsplit_0_pc_type lu
  -fieldsplit_1_pc_type jacobi
  -fieldsplit_1_ksp_rtol 1e-9
That should converge in one iteration. Then you can look at the time and
see whether the A block or the S block is expensive.
You can substitute AMG for LU for A. You can find a better preconditioner
than Jacobi for the S block. You can use upper
factorization instead of full. etc.
     Matt
>  -pc_type fieldsplit -fieldsplit_0_pc_type jacobi -fieldsplit_1_pc_type
> jacobi  -pc_fieldsplit_type SC\
> HUR -ksp_monitor_short -ksp_converged_reason -ksp_rtol 1e-4
> -fieldsplit_1_ksp_rtol 1e-2 -fieldsplit_0_ksp_rtol 1e-4
> -fieldsplit_1_ksp_max_it 10 -fieldsplit_0_ksp_max_it 10 -ksp_type fgmres
> -ksp_max_it 10 -ksp_view
>  And here is the output:
>   Starting...
>   0 KSP Residual norm 17.314
>   1 KSP Residual norm 10.8324
>   2 KSP Residual norm 10.8312
>   3 KSP Residual norm 10.7726
>   4 KSP Residual norm 10.7642
>   5 KSP Residual norm 10.7634
>   6 KSP Residual norm 10.7399
>   7 KSP Residual norm 10.7159
>   8 KSP Residual norm 10.6602
>   9 KSP Residual norm 10.5756
>  10 KSP Residual norm 10.5224
> Linear solve did not converge due to DIVERGED_ITS iterations 10
> KSP Object: 1 MPI processes
>   type: fgmres
>     GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     GMRES: happy breakdown tolerance 1e-30
>   maximum iterations=10, initial guess is zero
>   tolerances:  relative=0.0001, absolute=1e-50, divergence=10000
>   right preconditioning
>   using UNPRECONDITIONED norm type for convergence test
> PC Object: 1 MPI processes
>   type: fieldsplit
>     FieldSplit with Schur preconditioner, factorization FULL
>     Preconditioner for the Schur complement formed from A11
>     Split info:
>     Split number 0 Defined by IS
>     Split number 1 Defined by IS
>     KSP solver for A00 block
>       KSP Object:      (fieldsplit_0_)       1 MPI processes
>         type: gmres
>         left preconditioning
>         using PRECONDITIONED norm type for convergence test
>       PC Object:      (fieldsplit_0_)       1 MPI processes
>         type: jacobi
>         linear system matrix = precond matrix:
>         Mat Object:        (fieldsplit_0_)         1 MPI processes
>           type: mpiaij
>           rows=20000, cols=20000
>           total: nonzeros=85580, allocated nonzeros=760000
>           total number of mallocs used during MatSetValues calls =0
>             not using I-node (on process 0) routines
>     KSP solver for S = A11 - A10 inv(A00) A01
>       KSP Object:      (fieldsplit_1_)       1 MPI processes
>         type: gmres
>         tolerances:  relative=0.01, absolute=1e-50, divergence=10000
>       PC Object:      (fieldsplit_1_)       1 MPI processes
>         type: jacobi
>         linear system matrix followed by preconditioner matrix:
>         Mat Object:        (fieldsplit_1_)         1 MPI processes
>           type: schurcomplement
>           rows=10000, cols=10000
>             Schur complement A11 - A10 inv(A00) A01
>             A11
> processes
>                 type: mpiaij
>                 total: nonzeros=2110, allocated nonzeros=80000
>                   using I-node (on process 0) routines: found 3739 nodes,
> limit used is 5
>             A10
>               Mat Object:              (a10_)               1 MPI processes
>                 type: mpiaij
>                 rows=10000, cols=20000
>                 total: nonzeros=31560, allocated nonzeros=80000
>             KSP of A00
> processes
>                 type: gmres
> Gram-Schmidt Orthogonalization with no iterative refinement
> divergence=10000
> processes
>                 type: jacobi
> 1 MPI processes
>                   type: mpiaij
>             A01
>               Mat Object:              (a01_)               1 MPI processes
>                 type: mpiaij
>                 rows=20000, cols=10000
>                 total: nonzeros=32732, allocated nonzeros=240000
>           type: mpiaij
>             using I-node (on process 0) routines: found 3739 nodes, limit
> used is 5
>   Mat Object:   1 MPI processes
>     type: nest
>     rows=30000, cols=30000
>       Matrix object:
>         type=nest, rows=2, cols=2
>         MatNest structure:
>         (0,0) : prefix="fieldsplit_0_", type=mpiaij, rows=20000,
> cols=20000
>         (0,1) : prefix="a01_", type=mpiaij, rows=20000, cols=10000
>         (1,0) : prefix="a10_", type=mpiaij, rows=10000, cols=20000
>         (1,1) : prefix="fieldsplit_1_", type=mpiaij, rows=10000,
> cols=10000
>  residual u = 10.3528
>  residual p = 1.88199
>  residual [u,p] = 10.5224
>  L^2 discretization error u = 0.698386
>  L^2 discretization error p = 1.0418
>  L^2 discretization error [u,p] = 1.25423
>  number of processors = 1 0
> Time cost for creating solver context 0.100217 s, and for solving 3.78879
> s, and for printing 0.0908558 s.
> *From:* Dave May [dave.mayhem23 at gmail.com]
> *Sent:* Wednesday, February 18, 2015 10:00 AM
> *To:* Sun, Hui
> *Cc:* Matthew Knepley; petsc-users at mcs.anl.gov; hong at aspiritech.org
> *Subject:* Re: [petsc-users] Question concerning ilu and bcgs
>  Fieldsplit will not work if you just set pc_type fieldsplit and you have
> an operator with a block size if 1. In this case, you will need to define
> the splits using index sets.
>  I cannot believe that defining all the v and p dofs is really hard.
> Certainly it is far easier than trying to understand the difference between
> the petsc, matlab and the hypre implementations of ilut. Even if you did
> happen to find one implemtation of ilu you were "happy" with, as soon as
> you refine the mesh a couple of times the iterations will  increase.
>  I second Matt's opinion - forget about ilu and focus time on trying
> to make fieldsplit work. Fieldsplit will generate spectrally equivalent
> operators of your flow problem, ilu won't
>  Cheers
>   Dave
> On Wednesday, 18 February 2015, Sun, Hui <hus003 at ucsd.edu> wrote:
>>  I tried fieldsplitting several months ago, it didn't work due to the
>> complicated coupled irregular bdry conditions. So I tried direct solver and
>> now I modified the PDE system a little bit so that the ILU/bcgs works in
>> MATLAB. But thank you for the suggestions, although I doubt it would work,
>> maybe I will still try fieldsplitting with my new system.
>> *From:* Matthew Knepley [knepley at gmail.com <http://UrlBlockedError.aspx>]
>> *Sent:* Wednesday, February 18, 2015 8:54 AM
>> *To:* Sun, Hui
>> *Cc:* hong at aspiritech.org <http://UrlBlockedError.aspx>;
>> petsc-users at mcs.anl.gov <http://UrlBlockedError.aspx>
>>    On Wed, Feb 18, 2015 at 10:47 AM, Sun, Hui <hus003 at ucsd.edu
>> <http://UrlBlockedError.aspx>> wrote:
>>>  The matrix is from a 3D fluid problem, with complicated irregular
>>> boundary conditions. I've tried using direct solvers such as UMFPACK,
>>> SuperLU_dist and MUMPS. It seems that SuperLU_dist does not solve for my
>>> linear system; UMFPACK solves the system but would run into memory issue
>>> even with small size matrices and it cannot parallelize; MUMPS does solve
>>> the system but it also fails when the size is big and it takes much time.
>>> That's why I'm seeking an iterative method.
>>>  I guess the direct method is faster than an iterative method for a
>>> small A, but that may not be true for bigger A.
>>  If this is a Stokes flow, you should use PCFIELDSPLIT and multigrid. If
>> it is advection dominated, I know of nothing better
>> than sparse direct or perhaps Block-Jacobi with sparse direct blocks.
>> Since MUMPS solved your system, I would consider
>> using BJacobi/ASM and MUMPS or UMFPACK as the block solver.
>>    Thanks,
>>       Matt
>>> *Sent:* Wednesday, February 18, 2015 8:33 AM
>>> *To:* Sun, Hui
>>>    On Wed, Feb 18, 2015 at 10:31 AM, Sun, Hui <hus003 at ucsd.edu
>>>>  So far I just try around, I haven't looked into literature yet.
>>>>  However, both MATLAB's ilu+gmres and ilu+bcgs work. Is it possible
>>>> that some parameter or options need to be tuned in using PETSc's ilu or
>>>> hypre's ilu? Besides, is there a way to view how good the performance of
>>>> the pc is and output the matrices L and U, so that I can do some test in
>>>> MATLAB?
>>>  1) Its not clear exactly what Matlab is doing
>>>  2) PETSc uses ILU(0) by default (you can set it to use ILU(k))
>>>  3) I don't know what Hypre's ILU can do
>>>  I would really discourage from using ILU. I cannot imagine it is
>>> faster than sparse direct factorization
>>> for your system, such as from SuperLU or MUMPS.
>>>    Thanks,
>>>       Matt
>>>>   Hui
>>>> *Sent:* Wednesday, February 18, 2015 8:09 AM
>>>> *To:* Sun, Hui
>>>>    On Wed, Feb 18, 2015 at 10:02 AM, Sun, Hui <hus003 at ucsd.edu
>>>>>  Yes I've tried other solvers, gmres/ilu does not work, neither does
>>>>> bcgs/ilu. Here are the options:
>>>>> -pc_type ilu -pc_factor_nonzeros_along_diagonal -pc_factor_levels 0
>>>>> -pc_factor_reuse_ordering -ksp_ty\
>>>>> pe bcgs -ksp_rtol 1e-6 -ksp_max_it 10 -ksp_monitor_short -ksp_view
>>>>  Note here that ILU(0) is an unreliable and generally crappy
>>>> preconditioner. Have you looked in the
>>>> literature for the kinds of preconditioners that are effective for your
>>>> problem?
>>>>    Thanks,
>>>>       Matt
>>>>>   Here is the output:
>>>>>   0 KSP Residual norm 211292
>>>>>   1 KSP Residual norm 13990.2
>>>>>   2 KSP Residual norm 9870.08
>>>>>   3 KSP Residual norm 9173.9
>>>>>   4 KSP Residual norm 9121.94
>>>>>   5 KSP Residual norm 7386.1
>>>>>   6 KSP Residual norm 6222.55
>>>>>   7 KSP Residual norm 7192.94
>>>>>   8 KSP Residual norm 33964
>>>>>   9 KSP Residual norm 33960.4
>>>>>  10 KSP Residual norm 1068.54
>>>>>   type: bcgs
>>>>>   tolerances:  relative=1e-06, absolute=1e-50, divergence=10000
>>>>>   type: ilu
>>>>>     ILU: out-of-place factorization
>>>>>     ILU: Reusing reordering from past factorization
>>>>>     0 levels of fill
>>>>>     tolerance for zero pivot 2.22045e-14
>>>>>     using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>>>>>     matrix ordering: natural
>>>>>     factor fill ratio given 1, needed 1
>>>>>       Factored matrix follows:
>>>>>           type: seqaij
>>>>>           rows=62500, cols=62500
>>>>>           package used to perform factorization: petsc
>>>>>           total: nonzeros=473355, allocated nonzeros=473355
>>>>>             not using I-node routines
>>>>>     type: seqaij
>>>>>     total: nonzeros=473355, allocated nonzeros=7.8125e+06
>>>>> Time cost: 0.307149,  0.268402,  0.0990018
>>>>> *From:* hong at aspiritech.org <http://UrlBlockedError.aspx> [
>>>>> hong at aspiritech.org <http://UrlBlockedError.aspx>]
>>>>> *Sent:* Wednesday, February 18, 2015 7:49 AM
>>>>> *To:* Sun, Hui
>>>>>    Have you tried other solvers, e.g., PETSc default gmres/ilu,
>>>>> bcgs/ilu etc.
>>>>> The matrix is small. If it is ill-conditioned, then pc_type lu would
>>>>> work the best.
>>>>>  Hong
>>>>> On Wed, Feb 18, 2015 at 9:34 AM, Sun, Hui <hus003 at ucsd.edu
>>>>>>  With options:
>>>>>>  -pc_type hypre -pc_hypre_type pilut -pc_hypre_pilut_maxiter 1000
>>>>>> -pc_hypre_pilut_tol 1e-3 -ksp_type bcgs -ksp_rtol 1e-10 -ksp_max_it
>>>>>> 10 -ksp_monitor_short -ksp_converged_reason -ksp_view
>>>>>>  Here is the full output:
>>>>>>    0 KSP Residual norm 1404.62
>>>>>>   1 KSP Residual norm 88.9068
>>>>>>   2 KSP Residual norm 64.73
>>>>>>   3 KSP Residual norm 71.0224
>>>>>>   4 KSP Residual norm 69.5044
>>>>>>   5 KSP Residual norm 455.458
>>>>>>   6 KSP Residual norm 174.876
>>>>>>   7 KSP Residual norm 183.031
>>>>>>   8 KSP Residual norm 650.675
>>>>>>   9 KSP Residual norm 79.2441
>>>>>>  10 KSP Residual norm 84.1985
>>>>>>   type: bcgs
>>>>>>   tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
>>>>>>   type: hypre
>>>>>>     HYPRE Pilut preconditioning
>>>>>>     HYPRE Pilut: maximum number of iterations 1000
>>>>>>     HYPRE Pilut: drop tolerance 0.001
>>>>>>     HYPRE Pilut: default factor row size
>>>>>>     type: seqaij
>>>>>> Time cost: 0.756198,  0.662984,  0.105672
>>>>>> *Sent:* Wednesday, February 18, 2015 3:30 AM
>>>>>> *To:* Sun, Hui
>>>>>> *Cc:* petsc-users at mcs.anl.gov <http://UrlBlockedError.aspx>
>>>>>>     On Wed, Feb 18, 2015 at 12:33 AM, Sun, Hui <hus003 at ucsd.edu
>>>>>>>  I have a matrix system Ax = b, A is of type MatSeqAIJ or
>>>>>>> MatMPIAIJ, depending on the number of cores.
>>>>>>>  I try to solve this problem by pc_type ilu and ksp_type bcgs, it
>>>>>>> does not converge. The options I specify are:
>>>>>>> -pc_hypre_pilut_tol 1e-3 -ksp_type b\
>>>>>>> cgs -ksp_rtol 1e-10 -ksp_max_it 1000 -ksp_monitor_short
>>>>>>  1) Run with -ksp_view, so we can see exactly what was used
>>>>>>  2) ILUT is unfortunately not a well-defined algorithm, and I
>>>>>> believe the parallel version makes different decisions
>>>>>>     than the serial version.
>>>>>>    Thanks,
>>>>>>      Matt
>>>>>>>   The first a few lines of the output are:
>>>>>>>  This clearly indicates non-convergence. However, I output the
>>>>>>> sparse matrix A and vector b to MATLAB, and run the following command:
>>>>>>> [L,U] = ilu(A,struct('type','ilutp','droptol',1e-3));
>>>>>>> [ux1,fl1,rr1,it1,rv1] = bicgstab(A,b,1e-10,1000,L,U);
>>>>>>>  And it converges in MATLAB, with flag fl1=0, relative residue
>>>>>>> rr1=8.2725e-11, and iteration it1=89.5. I'm wondering how can I figure out
>>>>>>> what's wrong.
>>>>>>>  Best,
>>>>>>> Hui
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150218/175a8deb/attachment-0001.html>
