[petsc-users] Question concerning ilu and bcgs
Sun, Hui
hus003 at ucsd.edu
Wed Feb 18 10:02:47 CST 2015
Yes I've tried other solvers, gmres/ilu does not work, neither does bcgs/ilu. Here are the options:
-pc_type ilu -pc_factor_nonzeros_along_diagonal -pc_factor_levels 0 -pc_factor_reuse_ordering -ksp_ty\
pe bcgs -ksp_rtol 1e-6 -ksp_max_it 10 -ksp_monitor_short -ksp_view
Here is the output:
0 KSP Residual norm 211292
1 KSP Residual norm 13990.2
2 KSP Residual norm 9870.08
3 KSP Residual norm 9173.9
4 KSP Residual norm 9121.94
5 KSP Residual norm 7386.1
6 KSP Residual norm 6222.55
7 KSP Residual norm 7192.94
8 KSP Residual norm 33964
9 KSP Residual norm 33960.4
10 KSP Residual norm 1068.54
KSP Object: 1 MPI processes
type: bcgs
maximum iterations=10, initial guess is zero
tolerances: relative=1e-06, absolute=1e-50, divergence=10000
left preconditioning
using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
type: ilu
ILU: out-of-place factorization
ILU: Reusing reordering from past factorization
0 levels of fill
tolerance for zero pivot 2.22045e-14
using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
matrix ordering: natural
factor fill ratio given 1, needed 1
Factored matrix follows:
Mat Object: 1 MPI processes
type: seqaij
rows=62500, cols=62500
package used to perform factorization: petsc
total: nonzeros=473355, allocated nonzeros=473355
total number of mallocs used during MatSetValues calls =0
not using I-node routines
linear system matrix = precond matrix:
type: seqaij
total: nonzeros=473355, allocated nonzeros=7.8125e+06
Time cost: 0.307149, 0.268402, 0.0990018
From: hong at aspiritech.org [hong at aspiritech.org]
Sent: Wednesday, February 18, 2015 7:49 AM
To: Sun, Hui
Cc: Matthew Knepley; petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Question concerning ilu and bcgs
Have you tried other solvers, e.g., PETSc default gmres/ilu, bcgs/ilu etc.
The matrix is small. If it is ill-conditioned, then pc_type lu would work the best.
Hong
On Wed, Feb 18, 2015 at 9:34 AM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
With options:
-pc_type hypre -pc_hypre_type pilut -pc_hypre_pilut_maxiter 1000 -pc_hypre_pilut_tol 1e-3 -ksp_type bcgs -ksp_rtol 1e-10 -ksp_max_it 10 -ksp_monitor_short -ksp_converged_reason -ksp_view
Here is the full output:
0 KSP Residual norm 1404.62
1 KSP Residual norm 88.9068
2 KSP Residual norm 64.73
3 KSP Residual norm 71.0224
4 KSP Residual norm 69.5044
5 KSP Residual norm 455.458
6 KSP Residual norm 174.876
7 KSP Residual norm 183.031
8 KSP Residual norm 650.675
9 KSP Residual norm 79.2441
10 KSP Residual norm 84.1985
Linear solve did not converge due to DIVERGED_ITS iterations 10
type: bcgs
tolerances: relative=1e-10, absolute=1e-50, divergence=10000
type: hypre
HYPRE Pilut preconditioning
HYPRE Pilut: maximum number of iterations 1000
HYPRE Pilut: drop tolerance 0.001
HYPRE Pilut: default factor row size
type: seqaij
Time cost: 0.756198, 0.662984, 0.105672
From: Matthew Knepley [knepley at gmail.com<mailto:knepley at gmail.com>]
Sent: Wednesday, February 18, 2015 3:30 AM
To: Sun, Hui
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
On Wed, Feb 18, 2015 at 12:33 AM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
I have a matrix system Ax = b, A is of type MatSeqAIJ or MatMPIAIJ, depending on the number of cores.
I try to solve this problem by pc_type ilu and ksp_type bcgs, it does not converge. The options I specify are:
-pc_type hypre -pc_hypre_type pilut -pc_hypre_pilut_maxiter 1000 -pc_hypre_pilut_tol 1e-3 -ksp_type b\
cgs -ksp_rtol 1e-10 -ksp_max_it 1000 -ksp_monitor_short -ksp_converged_reason
1) Run with -ksp_view, so we can see exactly what was used
2) ILUT is unfortunately not a well-defined algorithm, and I believe the parallel version makes different decisions
than the serial version.
Matt
The first a few lines of the output are:
This clearly indicates non-convergence. However, I output the sparse matrix A and vector b to MATLAB, and run the following command:
[L,U] = ilu(A,struct('type','ilutp','droptol',1e-3));
[ux1,fl1,rr1,it1,rv1] = bicgstab(A,b,1e-10,1000,L,U);
And it converges in MATLAB, with flag fl1=0, relative residue rr1=8.2725e-11, and iteration it1=89.5. I'm wondering how can I figure out what's wrong.
Best,
Hui
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150218/1c983eb7/attachment.html>
