[petsc-users] Question concerning ilu and bcgs
Sun, Hui hus003 at ucsd.edu
Wed Feb 18 09:34:54 CST 2015
With options:
-pc_type hypre -pc_hypre_type pilut -pc_hypre_pilut_maxiter 1000 -pc_hypre_pilut_tol 1e-3 -ksp_type bcgs -ksp_rtol 1e-10 -ksp_max_it 10 -ksp_monitor_short -ksp_converged_reason -ksp_view
Here is the full output:
  0 KSP Residual norm 1404.62
  1 KSP Residual norm 88.9068
  2 KSP Residual norm 64.73
  3 KSP Residual norm 71.0224
  4 KSP Residual norm 69.5044
  5 KSP Residual norm 455.458
  6 KSP Residual norm 174.876
  7 KSP Residual norm 183.031
  8 KSP Residual norm 650.675
  9 KSP Residual norm 79.2441
 10 KSP Residual norm 84.1985
Linear solve did not converge due to DIVERGED_ITS iterations 10
KSP Object: 1 MPI processes
  type: bcgs
  maximum iterations=10, initial guess is zero
  tolerances:  relative=1e-10, absolute=1e-50, divergence=10000
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: hypre
    HYPRE Pilut preconditioning
    HYPRE Pilut: maximum number of iterations 1000
    HYPRE Pilut: drop tolerance 0.001
    HYPRE Pilut: default factor row size
  linear system matrix = precond matrix:
  Mat Object:   1 MPI processes
    type: seqaij
    rows=62500, cols=62500
    total: nonzeros=473355, allocated nonzeros=7.8125e+06
    total number of mallocs used during MatSetValues calls =0
      not using I-node routines
Time cost: 0.756198,  0.662984,  0.105672
Sent: Wednesday, February 18, 2015 3:30 AM
To: Sun, Hui
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Question concerning ilu and bcgs
On Wed, Feb 18, 2015 at 12:33 AM, Sun, Hui <hus003 at ucsd.edu<mailto:hus003 at ucsd.edu>> wrote:
I have a matrix system Ax = b, A is of type MatSeqAIJ or MatMPIAIJ, depending on the number of cores.
I try to solve this problem by pc_type ilu and ksp_type bcgs, it does not converge. The options I specify are:
-pc_type hypre -pc_hypre_type pilut -pc_hypre_pilut_maxiter 1000 -pc_hypre_pilut_tol 1e-3 -ksp_type b\
cgs -ksp_rtol 1e-10 -ksp_max_it 1000 -ksp_monitor_short -ksp_converged_reason
1) Run with -ksp_view, so we can see exactly what was used
2) ILUT is unfortunately not a well-defined algorithm, and I believe the parallel version makes different decisions
    than the serial version.
    Matt
The first a few lines of the output are:
This clearly indicates non-convergence. However, I output the sparse matrix A and vector b to MATLAB, and run the following command:
[L,U] = ilu(A,struct('type','ilutp','droptol',1e-3));
[ux1,fl1,rr1,it1,rv1] = bicgstab(A,b,1e-10,1000,L,U);
And it converges in MATLAB, with flag fl1=0, relative residue rr1=8.2725e-11, and iteration it1=89.5. I'm wondering how can I figure out what's wrong.
Best,
Hui
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150218/f0e02176/attachment-0001.html>
