[petsc-users] parallel interpolation?
Matthew Knepley
knepley at gmail.com
Wed Feb 18 09:16:17 CST 2015
On Tue, Feb 17, 2015 at 9:41 AM, Gideon Simpson <gideon.simpson at gmail.com>
wrote:
> This warrants a deeper description. I was thinking about trying to use
> petsc to solve a 1D PDE problem using the equidistribution principle for
> adaptive meshing. Briefly, the idea is that given a function u(x), where x
> is the physical coordinate, a monitor function, w[u(x)]>0, is introduced
> such that
> y(x) = \int_{0}^x w[u(s)] ds /\int_{0}^{xmax} w[u(s)] ds
> where C is a constant, and y is the computational coordinate in [0,1].
> essentially, you want to pick the physical mesh points, x_i such that
> \int_{x_i}^{x_{i+1}} w[u(s)] ds = constant
> then the computational mesh points are uniformly spaced. Solving this can
> be posed as a nonlinear elliptic equation, in general dimension, though it
> simplifies further in 1D. In a paper by Gavish and Ditkowski, for the 1D
> problem, they came up with the idea that you could do the following:
> Given a starting guess on where the physical coordinates should be, let
> F_i = \int_0^{x_i} w[u(s)]ds/\int_0^{x_N} w[u(s)]ds
> Then 0= F_0 < F_1 <… <F_N=1. Rather than try to solve the nonlinear
> system for the x_i such that the successive differences of F_{i+1} - F_i
> are uniformly spaced, they propose to do:
> interpolate (F_i, x_i) onto the uniform mesh for y, and the interpolated
> x_i’s should approximately satisfy the equidistribution principle. This
> can be iterated, to improve the equidistribution.
> Doing the quadrature with distributed vectors is not too hard. The
> question then becomes how to do the interpolation in parallel. As I was
> suggesting in the earlier example, if y_i = i * h, is the uniform mesh, it
> may be that y_i could be on proc 0, but the values of {F_j} that this lies
> between are on proc 1. There is monotonicity at work here, but I’m not
> sure I can really say, when defining ghost points, how things will spread
> out.
I think I am slowly understanding the problem. Tell me where I go wrong.
You have a set of (x, y) points (you label them (F_i, x_i)), which you want
to interpolate, and then
evaluate on a regular grid. The interpolation is not specified, so to be
concrete lets say that you
choose cubic splines, which produces a tridiagonal system, so there is only
communication between
neighbors.
It seems like the right thing to do is partition the domain in parallel
such that y is evenly divided. Then the
communication pattern for your actual PDE is the same as for the
interpolation system, although the
interpolation can be unbalanced. I don't think this will matter compared to
the PDE system. If it does,
then you can redistribute, interpolate, and distribute back.
Does this make sense?
Matt
> On Feb 17, 2015, at 10:11 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Feb 17, 2015 at 8:15 AM, Gideon Simpson <gideon.simpson at gmail.com>
> wrote:
>> I’m gathering from your suggestions that I would need, a priori,
>> knowledge of how many ghost points I would need, is that right?
> We have to be more precise about a priori. You can certainly create a
> VecScatter on the fly every time
> if your communication pattern is changing. However, how will you know what
> needs to be communicated.
> Matt
>> -gideon
>> On Feb 17, 2015, at 9:10 AM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Feb 17, 2015 at 7:46 AM, Gideon Simpson <gideon.simpson at gmail.com
>> > wrote:
>>> Suppose I have data in Vec x and Vec y, and I want to interpolate this
>>> onto Vec xx, storing the values in Vec yy. All vectors have the same
>>> layout. The problem is that, for example, some of the values in xx on
>>> processor 0 may need the values of x and y on processor 1, and so on.
>>> Aside from just using sequential vectors, so that everything is local, is
>>> there a reasonable way to make this computation?
>> At the most basic linear algebra level, you would construct a VecScatter
>> which mapped the pieces you need from other processes into a local vector
>> along with the local portion, and you would use that to calculate values,
>> which you then put back into your owned portion of a global vector. Thus
>> local vectors have halos and global vectors do not.
>> If you halo regions (values you need from other processes) have a common
>> topology, then we have simpler
>> support that will make the VecScatter for you. For example, if your
>> values lie on a Cartesian grid and you
>> just need neighbors within distance k, you can use a DMDA to express this
>> and automatically make the
>> VecScatter. Likewise, if you values lie on an unstructured mesh and you
>> need a distance k adjacency,
>> DMPlex can create the scatter for you.
>> If you are creating the VecScatter yourself, it might be easier to use
>> the new PetscSF instead since it only needs one-sided information, and
>> performs the same job. This is what DMPlex uses to do the communication.
>> Thanks,
>> Matt
>>> -gideon
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150218/b20e6552/attachment-0001.html>
