[petsc-users] Efficient Use of GAMG for Poisson Equation with Full Neumann Boundary Conditions
Fabian Gabel gabel.fabian at gmail.com
Tue Feb 17 09:14:50 CST 2015
Dear PETSc team,
I am trying to optimize the solver parameters for the linear system I
get, when I discretize the pressure correction equation Poisson equation
with Neumann boundary conditions) in a SIMPLE-type algorithm using a
finite volume method.
The resulting system is symmetric and positive semi-definite. A basis to
the associated nullspace has been provided to the KSP object.
Using a CG solver with ICC preconditioning the solver needs a lot of
inner iterations to converge (-ksp_monitor -ksp_view output attached for
a case with approx. 2e6 unknowns; the lines beginning with 000XXXX show
the relative residual regarding the initial residual in the outer
iteration no. 1 for the variables u,v,w,p). Furthermore I don't quite
understand, why the solver reports
Linear solve did not converge due to DIVERGED_INDEFINITE_PC
at the later stages of my Picard iteration process (iteration 0001519).
I then tried out CG+GAMG preconditioning with success regarding the
number of inner iterations, but without advantages regarding wall time
(output attached). Also the DIVERGED_INDEFINITE_PC reason shows up
repeatedly after iteration 0001487. I used the following options
-pressure_mg_coarse_sub_pc_type svd
-pressure_mg_levels_ksp_rtol 1e-4
-pressure_mg_levels_ksp_type richardson
-pressure_mg_levels_pc_type sor
-pressure_pc_gamg_agg_nsmooths 1
-pressure_pc_type gamg
I would like to get an opinion on how the solver performance could be
increased further. -log_summary shows that my code spends 80% of the
time solving the linear systems for the pressure correction (STAGE 2:
PRESSCORR). Furthermore, do you know what could be causing the
DIVERGED_INDEFINITE_PC converged reason?
Fabian Gabel
Sender: LSF System <lsfadmin at hpb0005>
Subject: Job 531314: <mg_test> in cluster <lichtenberg> Done
Job <mg_test> was submitted from host <hla0003> by user <gu08vomo> in cluster <lichtenberg>.
Job was executed on host(s) <hpb0005>, in queue <test_mpi2>, as user <gu08vomo> in cluster <lichtenberg>.
</home/gu08vomo> was used as the home directory.
</work/scratch/gu08vomo/thesis/singleblock/128_1_1_seg> was used as the working directory.
Started at Mon Feb 16 11:49:23 2015
Results reported at Mon Feb 16 23:14:32 2015
Your job looked like:
# LSBATCH: User input
#! /bin/sh
#BSUB -J mg_test
#BSUB -o /home/gu08vomo/thesis/mgtest/gamg.128.out.%J
#BSUB -n 1
#BSUB -W 14:00
#BSUB -x
#BSUB -q test_mpi2
#BSUB -a openmpi
module load openmpi/intel/1.8.2
#export PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr
export PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr-ext
export MYWORKDIR=/work/scratch/gu08vomo/thesis/singleblock/128_1_1_seg/
export OUTPUTDIR=/home/gu08vomo/thesis/coupling
export PETSC_OPS="-options_file ops.gamg"
cat ops.gamg
echo "PETSC_DIR="$PETSC_DIR
echo "MYWORKDIR="$MYWORKDIR
cd $MYWORKDIR
mpirun -n 1 ./caffa3d.MB.lnx ${PETSC_OPS}
Successfully completed.
Resource usage summary:
    CPU time :               41126.00 sec.
    Max Memory :             2905 MB
    Average Memory :         2243.40 MB
    Total Requested Memory : -
    Delta Memory :           -
    (Delta: the difference between total requested memory and actual max usage.)
    Max Swap :               3658 MB
    Max Processes :          6
    Max Threads :            11
The output (if any) follows:
Modules: loading gcc/4.8.4
Modules: loading intel/2015
Modules: loading openmpi/intel/1.8.2
-momentum_ksp_type gmres
-log_summary
-options_left
-pressure_ksp_converged_reason
  ENTER PROBLEM NAME (SIX CHARACTERS):
 NAME OF PROBLEM SOLVED control
 CONTROL SETTINGS
 LREAD,LWRITE,LPOST,LTEST,LOUTS,LOUTE,LTIME,LGRAD
 F F T F F F F F
  IMON, JMON, KMON, MMON, RMON,  IPR,  JPR,  KPR,  MPR,NPCOR,NIGRAD
     8     9     8     1     0     2     2     3     1     1     1
  SORMAX,     SLARGE,     ALFA
  0.1000E-07  0.1000E+31  0.9200E+00
 (URF(I),I=1,5)
  0.9000E+00  0.9000E+00  0.9000E+00  0.1000E+00  0.1000E+01
 (SOR(I),I=1,5)
  0.1000E+00  0.1000E+00  0.1000E+00  0.1000E+00  0.1000E+00
 (GDS(I),I=1,5) - BLENDING (CDS-UDS)
  0.1000E+01  0.1000E+01  0.1000E+01  0.1000E+01  0.1000E+01
 LSG
100000
 START SIMPLE RELAXATIONS
Linear solve converged due to CONVERGED_RTOL iterations 2
KSP Object:(pressure_) 1 MPI processes
  type: cg
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=0.1, absolute=1e-50, divergence=10000
  left preconditioning
  has attached null space
  using PRECONDITIONED norm type for convergence test
PC Object:(pressure_) 1 MPI processes
  type: gamg
    MG: type is MULTIPLICATIVE, levels=4 cycles=v
      Cycles per PCApply=1
      Using Galerkin computed coarse grid matrices
  Coarse grid solver -- level -------------------------------
    KSP Object:    (pressure_mg_coarse_)     1 MPI processes
      type: preonly
      maximum iterations=1, initial guess is zero
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      using NONE norm type for convergence test
    PC Object:    (pressure_mg_coarse_)     1 MPI processes
      type: bjacobi
        block Jacobi: number of blocks = 1
        Local solve is same for all blocks, in the following KSP and PC objects:
        KSP Object:        (pressure_mg_coarse_sub_)         1 MPI processes
          type: preonly
        PC Object:        (pressure_mg_coarse_sub_)         1 MPI processes
          type: svd
          linear system matrix = precond matrix:
          Mat Object:           1 MPI processes
            type: seqaij
            rows=26, cols=26
            total: nonzeros=536, allocated nonzeros=536
            total number of mallocs used during MatSetValues calls =0
              not using I-node routines
        type: seqaij
        rows=26, cols=26
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object:    (pressure_mg_levels_1_)     1 MPI processes
      type: richardson
        Richardson: damping factor=1
      maximum iterations=2
      tolerances:  relative=0.0001, absolute=1e-50, divergence=10000
      using nonzero initial guess
    PC Object:    (pressure_mg_levels_1_)     1 MPI processes
      type: sor
        SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
        type: seqaij
        rows=2781, cols=2781
        total: nonzeros=156609, allocated nonzeros=156609
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object:    (pressure_mg_levels_2_)     1 MPI processes
      type: richardson
    PC Object:    (pressure_mg_levels_2_)     1 MPI processes
      type: sor
        type: seqaij
        rows=188698, cols=188698
        total: nonzeros=6.12809e+06, allocated nonzeros=6.12809e+06
  Down solver (pre-smoother) on level 3 -------------------------------
    KSP Object:    (pressure_mg_levels_3_)     1 MPI processes
      type: richardson
    PC Object:    (pressure_mg_levels_3_)     1 MPI processes
      type: sor
        type: seqaij
        rows=2197000, cols=2197000
        total: nonzeros=1.46816e+07, allocated nonzeros=1.46816e+07
    type: seqaij
 0000001  0.1000E+01  0.1000E+01  0.1000E+01  0.1000E+01  0.0000E+00
 0000002  0.9073E+00  0.8614E+00  0.9079E+00  0.6833E+00  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 4
 0000003  0.5342E+00  0.4470E+00  0.5272E+00  0.2646E+00  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 5
 0000004  0.1644E+00  0.1311E+00  0.1656E+00  0.5821E-01  0.0000E+00
 0000005  0.4251E-01  0.3089E-01  0.4307E-01  0.3617E-01  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 6
 0000006  0.2505E-01  0.1344E-01  0.2515E-01  0.2052E-01  0.0000E+00
 0000007  0.1922E-01  0.8700E-02  0.1923E-01  0.1271E-01  0.0000E+00
 0000008  0.1620E-01  0.6938E-02  0.1621E-01  0.1056E-01  0.0000E+00
 0000009  0.1411E-01  0.5867E-02  0.1411E-01  0.6362E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 7
 0000010  0.1264E-01  0.5191E-02  0.1265E-01  0.5396E-02  0.0000E+00
 0000011  0.1143E-01  0.4670E-02  0.1144E-01  0.3307E-02  0.0000E+00
 0000012  0.1051E-01  0.4260E-02  0.1051E-01  0.2662E-02  0.0000E+00
 0000013  0.9719E-02  0.3915E-02  0.9720E-02  0.1725E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 8
 0000014  0.9059E-02  0.3647E-02  0.9063E-02  0.1573E-02  0.0000E+00
 0000015  0.8490E-02  0.3406E-02  0.8490E-02  0.1009E-02  0.0000E+00
 0000016  0.8000E-02  0.3208E-02  0.8004E-02  0.1052E-02  0.0000E+00
 0000017  0.7574E-02  0.3027E-02  0.7574E-02  0.6479E-03  0.0000E+00
 0000018  0.7202E-02  0.2874E-02  0.7205E-02  0.7754E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 9
 0000019  0.6878E-02  0.2735E-02  0.6877E-02  0.4608E-03  0.0000E+00
 0000020  0.6592E-02  0.2616E-02  0.6595E-02  0.6190E-03  0.0000E+00
 0000021  0.6344E-02  0.2507E-02  0.6343E-02  0.3714E-03  0.0000E+00
 0000022  0.6124E-02  0.2414E-02  0.6127E-02  0.3916E-03  0.0000E+00
 0000023  0.5642E-02  0.2369E-02  0.5644E-02  0.3617E-03  0.0000E+00
 0000024  0.5419E-02  0.2297E-02  0.5421E-02  0.2312E-03  0.0000E+00
 0000025  0.5228E-02  0.2091E-02  0.5230E-02  0.2852E-03  0.0000E+00
 0000026  0.5041E-02  0.2013E-02  0.5043E-02  0.1855E-03  0.0000E+00
 0000027  0.4870E-02  0.1943E-02  0.4872E-02  0.2379E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 10
 0000028  0.4714E-02  0.1875E-02  0.4715E-02  0.1561E-03  0.0000E+00
 0000029  0.4570E-02  0.1814E-02  0.4573E-02  0.2141E-03  0.0000E+00
 0000030  0.4442E-02  0.1756E-02  0.4443E-02  0.1441E-03  0.0000E+00
 0000031  0.4327E-02  0.1703E-02  0.4329E-02  0.2068E-03  0.0000E+00
 0000032  0.4227E-02  0.1654E-02  0.4228E-02  0.1483E-03  0.0000E+00
 0000033  0.4140E-02  0.1610E-02  0.4141E-02  0.2102E-03  0.0000E+00
 0000034  0.4066E-02  0.1570E-02  0.4067E-02  0.1236E-03  0.0000E+00
 0000035  0.3790E-02  0.1567E-02  0.3792E-02  0.1364E-03  0.0000E+00
 0000036  0.3687E-02  0.1544E-02  0.3689E-02  0.9388E-04  0.0000E+00
 0000037  0.3600E-02  0.1428E-02  0.3601E-02  0.8595E-04  0.0000E+00
 0000038  0.3511E-02  0.1390E-02  0.3513E-02  0.8999E-04  0.0000E+00
 0000039  0.3428E-02  0.1355E-02  0.3429E-02  0.8086E-04  0.0000E+00
 0000040  0.3351E-02  0.1321E-02  0.3353E-02  0.9217E-04  0.0000E+00
 0000041  0.3282E-02  0.1289E-02  0.3283E-02  0.8273E-04  0.0000E+00
 0000042  0.3221E-02  0.1258E-02  0.3222E-02  0.1002E-03  0.0000E+00
 0000043  0.3168E-02  0.1230E-02  0.3170E-02  0.9158E-04  0.0000E+00
 0000044  0.3126E-02  0.1203E-02  0.3127E-02  0.1128E-03  0.0000E+00
 0000045  0.3094E-02  0.1179E-02  0.3095E-02  0.7344E-04  0.0000E+00
 0000046  0.2900E-02  0.1183E-02  0.2902E-02  0.8077E-04  0.0000E+00
 0000047  0.2837E-02  0.1172E-02  0.2839E-02  0.7287E-04  0.0000E+00
 0000048  0.2778E-02  0.1163E-02  0.2780E-02  0.5482E-04  0.0000E+00
 0000049  0.2730E-02  0.1074E-02  0.2732E-02  0.5861E-04  0.0000E+00
 0000050  0.2680E-02  0.1050E-02  0.2681E-02  0.5116E-04  0.0000E+00
 0000051  0.2633E-02  0.1028E-02  0.2634E-02  0.5965E-04  0.0000E+00
 0000052  0.2592E-02  0.1007E-02  0.2593E-02  0.5476E-04  0.0000E+00
 0000053  0.2558E-02  0.9870E-03  0.2559E-02  0.6632E-04  0.0000E+00
 0000054  0.2533E-02  0.9676E-03  0.2533E-02  0.6257E-04  0.0000E+00
 0000055  0.2517E-02  0.9491E-03  0.2517E-02  0.5373E-04  0.0000E+00
 0000056  0.2374E-02  0.9512E-03  0.2375E-02  0.5294E-04  0.0000E+00
 0000057  0.2330E-02  0.9425E-03  0.2331E-02  0.5063E-04  0.0000E+00
 0000058  0.2289E-02  0.9363E-03  0.2290E-02  0.5137E-04  0.0000E+00
 0000059  0.2249E-02  0.9338E-03  0.2250E-02  0.4776E-04  0.0000E+00
 0000060  0.2219E-02  0.8637E-03  0.2220E-02  0.4961E-04  0.0000E+00
 0000061  0.2187E-02  0.8471E-03  0.2188E-02  0.3806E-04  0.0000E+00
 0000062  0.2160E-02  0.8318E-03  0.2161E-02  0.4753E-04  0.0000E+00
 0000063  0.2140E-02  0.8164E-03  0.2140E-02  0.3909E-04  0.0000E+00
 0000064  0.2128E-02  0.8016E-03  0.2129E-02  0.5139E-04  0.0000E+00
 0000065  0.2128E-02  0.7871E-03  0.2127E-02  0.4852E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 11
 0000066  0.1994E-02  0.7910E-03  0.1996E-02  0.4766E-04  0.0000E+00
 0000067  0.1962E-02  0.7849E-03  0.1963E-02  0.3633E-04  0.0000E+00
 0000068  0.1932E-02  0.7810E-03  0.1933E-02  0.4033E-04  0.0000E+00
 0000069  0.1903E-02  0.7812E-03  0.1904E-02  0.5747E-04  0.0000E+00
 0000070  0.1882E-02  0.7259E-03  0.1883E-02  0.4938E-04  0.0000E+00
 0000071  0.1860E-02  0.7133E-03  0.1861E-02  0.3911E-04  0.0000E+00
 0000072  0.1845E-02  0.7017E-03  0.1845E-02  0.3621E-04  0.0000E+00
 0000073  0.1837E-02  0.6900E-03  0.1837E-02  0.3506E-04  0.0000E+00
 0000074  0.1839E-02  0.6790E-03  0.1839E-02  0.4942E-04  0.0000E+00
 0000075  0.1731E-02  0.6810E-03  0.1733E-02  0.4894E-04  0.0000E+00
 0000076  0.1706E-02  0.6757E-03  0.1707E-02  0.3154E-04  0.0000E+00
 0000077  0.1682E-02  0.6726E-03  0.1683E-02  0.3418E-04  0.0000E+00
 0000078  0.1660E-02  0.6735E-03  0.1661E-02  0.2557E-04  0.0000E+00
 0000079  0.1640E-02  0.6787E-03  0.1640E-02  0.8022E-04  0.0000E+00
 0000080  0.1626E-02  0.6200E-03  0.1627E-02  0.7663E-04  0.0000E+00
 0000081  0.1615E-02  0.6102E-03  0.1615E-02  0.4472E-04  0.0000E+00
 0000082  0.1611E-02  0.6017E-03  0.1611E-02  0.4725E-04  0.0000E+00
 0000083  0.1617E-02  0.5941E-03  0.1617E-02  0.6258E-04  0.0000E+00
 0000084  0.1520E-02  0.5971E-03  0.1521E-02  0.4931E-04  0.0000E+00
 0000085  0.1499E-02  0.5936E-03  0.1500E-02  0.3603E-04  0.0000E+00
 0000086  0.1480E-02  0.5925E-03  0.1481E-02  0.3047E-04  0.0000E+00
 0000087  0.1462E-02  0.5957E-03  0.1463E-02  0.2231E-04  0.0000E+00
 0000088  0.1447E-02  0.6038E-03  0.1448E-02  0.1014E-03  0.0000E+00
 0000089  0.1438E-02  0.5440E-03  0.1438E-02  0.9025E-04  0.0000E+00
 0000090  0.1430E-02  0.5365E-03  0.1430E-02  0.5401E-04  0.0000E+00
 0000091  0.1429E-02  0.5311E-03  0.1429E-02  0.5154E-04  0.0000E+00
 0000092  0.1439E-02  0.5278E-03  0.1438E-02  0.7476E-04  0.0000E+00
 0000093  0.1345E-02  0.5331E-03  0.1346E-02  0.5986E-04  0.0000E+00
 0000094  0.1328E-02  0.5319E-03  0.1329E-02  0.3966E-04  0.0000E+00
 0000095  0.1313E-02  0.5339E-03  0.1314E-02  0.3235E-04  0.0000E+00
 0000096  0.1299E-02  0.5407E-03  0.1300E-02  0.9743E-04  0.0000E+00
 0000097  0.1289E-02  0.4880E-03  0.1290E-02  0.8425E-04  0.0000E+00
 0000098  0.1280E-02  0.4820E-03  0.1280E-02  0.5210E-04  0.0000E+00
 0000099  0.1275E-02  0.4782E-03  0.1276E-02  0.4807E-04  0.0000E+00
 0000100  0.1278E-02  0.4765E-03  0.1278E-02  0.2896E-04  0.0000E+00
 0000101  0.1290E-02  0.4777E-03  0.1290E-02  0.8290E-04  0.0000E+00
 0000102  0.1198E-02  0.4857E-03  0.1199E-02  0.7911E-04  0.0000E+00
 0000103  0.1184E-02  0.4864E-03  0.1185E-02  0.3830E-04  0.0000E+00
 0000104  0.1172E-02  0.4920E-03  0.1173E-02  0.7634E-04  0.0000E+00
 0000105  0.1163E-02  0.4400E-03  0.1163E-02  0.8482E-04  0.0000E+00
 0000106  0.1153E-02  0.4346E-03  0.1153E-02  0.3886E-04  0.0000E+00
 0000107  0.1146E-02  0.4310E-03  0.1146E-02  0.5017E-04  0.0000E+00
 0000108  0.1144E-02  0.4294E-03  0.1144E-02  0.2140E-04  0.0000E+00
 0000109  0.1150E-02  0.4299E-03  0.1150E-02  0.2949E-04  0.0000E+00
 0000110  0.1164E-02  0.4341E-03  0.1164E-02  0.9628E-04  0.0000E+00
 0000111  0.1073E-02  0.4431E-03  0.1074E-02  0.6905E-04  0.0000E+00
 0000112  0.1062E-02  0.4457E-03  0.1062E-02  0.6034E-04  0.0000E+00
 0000113  0.1053E-02  0.3983E-03  0.1054E-02  0.5685E-04  0.0000E+00
 0000114  0.1043E-02  0.3933E-03  0.1044E-02  0.3180E-04  0.0000E+00
 0000115  0.1035E-02  0.3895E-03  0.1036E-02  0.3340E-04  0.0000E+00
 0000116  0.1031E-02  0.3866E-03  0.1031E-02  0.1827E-04  0.0000E+00
 0000117  0.1031E-02  0.3850E-03  0.1031E-02  0.2016E-04  0.0000E+00
 0000118  0.1038E-02  0.3855E-03  0.1038E-02  0.6583E-04  0.0000E+00
 0000119  0.9770E-03  0.3908E-03  0.9775E-03  0.5126E-04  0.0000E+00
 0000120  0.9665E-03  0.3924E-03  0.9670E-03  0.3110E-04  0.0000E+00
 0000121  0.9569E-03  0.3977E-03  0.9574E-03  0.6344E-04  0.0000E+00
 0000122  0.9495E-03  0.3573E-03  0.9500E-03  0.6142E-04  0.0000E+00
 0000123  0.9414E-03  0.3534E-03  0.9418E-03  0.3285E-04  0.0000E+00
 0000124  0.9358E-03  0.3510E-03  0.9361E-03  0.3547E-04  0.0000E+00
 0000125  0.9336E-03  0.3503E-03  0.9339E-03  0.1814E-04  0.0000E+00
 0000126  0.9369E-03  0.3515E-03  0.9371E-03  0.2071E-04  0.0000E+00
 0000127  0.9470E-03  0.3558E-03  0.9472E-03  0.7667E-04  0.0000E+00
 0000128  0.8811E-03  0.3631E-03  0.8815E-03  0.5773E-04  0.0000E+00
 0000129  0.8723E-03  0.3660E-03  0.8727E-03  0.5122E-04  0.0000E+00
 0000130  0.8658E-03  0.3256E-03  0.8661E-03  0.4520E-04  0.0000E+00
 0000131  0.8579E-03  0.3219E-03  0.8583E-03  0.2709E-04  0.0000E+00
 0000132  0.8516E-03  0.3192E-03  0.8519E-03  0.2611E-04  0.0000E+00
 0000133  0.8477E-03  0.3173E-03  0.8480E-03  0.1539E-04  0.0000E+00
 0000134  0.8476E-03  0.3168E-03  0.8479E-03  0.1563E-04  0.0000E+00
 0000135  0.8530E-03  0.3183E-03  0.8532E-03  0.9130E-05  0.0000E+00
 0000136  0.8652E-03  0.3220E-03  0.8654E-03  0.6524E-04  0.0000E+00
 0000137  0.7973E-03  0.3304E-03  0.7977E-03  0.1538E-04  0.0000E+00
 0000138  0.7911E-03  0.2976E-03  0.7915E-03  0.3165E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 12
 0000139  0.7836E-03  0.2938E-03  0.7839E-03  0.7570E-05  0.0000E+00
 0000140  0.7770E-03  0.2906E-03  0.7773E-03  0.1994E-04  0.0000E+00
 0000141  0.7719E-03  0.2875E-03  0.7722E-03  0.6080E-05  0.0000E+00
 0000142  0.7694E-03  0.2845E-03  0.7697E-03  0.1320E-04  0.0000E+00
 0000143  0.7707E-03  0.2819E-03  0.7710E-03  0.6133E-05  0.0000E+00
 0000144  0.7774E-03  0.2798E-03  0.7777E-03  0.1516E-04  0.0000E+00
 0000145  0.7318E-03  0.2843E-03  0.7321E-03  0.2038E-04  0.0000E+00
 0000146  0.7240E-03  0.2870E-03  0.7242E-03  0.7523E-05  0.0000E+00
 0000147  0.7165E-03  0.2926E-03  0.7167E-03  0.1551E-04  0.0000E+00
 0000148  0.7116E-03  0.2662E-03  0.7118E-03  0.2078E-04  0.0000E+00
 0000149  0.7062E-03  0.2631E-03  0.7065E-03  0.8511E-05  0.0000E+00
 0000150  0.7027E-03  0.2605E-03  0.7029E-03  0.1308E-04  0.0000E+00
 0000151  0.7019E-03  0.2581E-03  0.7021E-03  0.6388E-05  0.0000E+00
 0000152  0.7052E-03  0.2561E-03  0.7055E-03  0.8762E-05  0.0000E+00
 0000153  0.7141E-03  0.2548E-03  0.7144E-03  0.2428E-04  0.0000E+00
 0000154  0.6647E-03  0.2607E-03  0.6649E-03  0.1654E-04  0.0000E+00
 0000155  0.6578E-03  0.2644E-03  0.6580E-03  0.1171E-04  0.0000E+00
 0000156  0.6513E-03  0.2707E-03  0.6514E-03  0.2409E-04  0.0000E+00
 0000157  0.6475E-03  0.2416E-03  0.6477E-03  0.2134E-04  0.0000E+00
 0000158  0.6433E-03  0.2389E-03  0.6434E-03  0.1299E-04  0.0000E+00
 0000159  0.6409E-03  0.2369E-03  0.6411E-03  0.1251E-04  0.0000E+00
 0000160  0.6416E-03  0.2352E-03  0.6418E-03  0.7836E-05  0.0000E+00
 0000161  0.6465E-03  0.2343E-03  0.6468E-03  0.7654E-05  0.0000E+00
 0000162  0.6568E-03  0.2343E-03  0.6571E-03  0.3030E-04  0.0000E+00
 0000163  0.6046E-03  0.2413E-03  0.6048E-03  0.2363E-04  0.0000E+00
 0000164  0.5986E-03  0.2455E-03  0.5987E-03  0.2148E-04  0.0000E+00
 0000165  0.5946E-03  0.2219E-03  0.5947E-03  0.1838E-04  0.0000E+00
 0000166  0.5900E-03  0.2195E-03  0.5901E-03  0.1157E-04  0.0000E+00
 0000167  0.5866E-03  0.2177E-03  0.5867E-03  0.1073E-04  0.0000E+00
 0000168  0.5852E-03  0.2160E-03  0.5854E-03  0.6885E-05  0.0000E+00
 0000169  0.5869E-03  0.2150E-03  0.5871E-03  0.6642E-05  0.0000E+00
 0000170  0.5930E-03  0.2148E-03  0.5933E-03  0.2514E-04  0.0000E+00
 0000171  0.5564E-03  0.2193E-03  0.5565E-03  0.2013E-04  0.0000E+00
 0000172  0.5508E-03  0.2224E-03  0.5509E-03  0.1815E-04  0.0000E+00
 0000173  0.5467E-03  0.2041E-03  0.5468E-03  0.1540E-04  0.0000E+00
 0000174  0.5422E-03  0.2020E-03  0.5422E-03  0.9862E-05  0.0000E+00
 0000175  0.5384E-03  0.2002E-03  0.5385E-03  0.9074E-05  0.0000E+00
 0000176  0.5362E-03  0.1987E-03  0.5363E-03  0.5998E-05  0.0000E+00
 0000177  0.5361E-03  0.1977E-03  0.5363E-03  0.5794E-05  0.0000E+00
 0000178  0.5395E-03  0.1973E-03  0.5397E-03  0.4175E-05  0.0000E+00
 0000179  0.5471E-03  0.1980E-03  0.5475E-03  0.2619E-04  0.0000E+00
 0000180  0.5071E-03  0.2039E-03  0.5072E-03  0.2216E-04  0.0000E+00
 0000181  0.5021E-03  0.2079E-03  0.5021E-03  0.1995E-04  0.0000E+00
 0000182  0.4989E-03  0.1861E-03  0.4989E-03  0.1549E-04  0.0000E+00
 0000183  0.4950E-03  0.1842E-03  0.4951E-03  0.1082E-04  0.0000E+00
 0000184  0.4921E-03  0.1828E-03  0.4921E-03  0.8909E-05  0.0000E+00
 0000185  0.4907E-03  0.1816E-03  0.4908E-03  0.6341E-05  0.0000E+00
 0000186  0.4918E-03  0.1811E-03  0.4919E-03  0.5470E-05  0.0000E+00
 0000187  0.4963E-03  0.1814E-03  0.4965E-03  0.2238E-04  0.0000E+00
 0000188  0.4674E-03  0.1854E-03  0.4674E-03  0.1845E-04  0.0000E+00
 0000189  0.4628E-03  0.1883E-03  0.4628E-03  0.1661E-04  0.0000E+00
 0000190  0.4595E-03  0.1715E-03  0.4595E-03  0.1354E-04  0.0000E+00
 0000191  0.4557E-03  0.1698E-03  0.4557E-03  0.9013E-05  0.0000E+00
 0000192  0.4525E-03  0.1684E-03  0.4525E-03  0.7869E-05  0.0000E+00
 0000193  0.4505E-03  0.1673E-03  0.4505E-03  0.5387E-05  0.0000E+00
 0000194  0.4503E-03  0.1667E-03  0.4504E-03  0.4948E-05  0.0000E+00
 0000195  0.4528E-03  0.1667E-03  0.4530E-03  0.3613E-05  0.0000E+00
 0000196  0.4589E-03  0.1679E-03  0.4592E-03  0.2374E-04  0.0000E+00
 0000197  0.4266E-03  0.1730E-03  0.4266E-03  0.6171E-05  0.0000E+00
 0000198  0.4234E-03  0.1582E-03  0.4234E-03  0.1127E-04  0.0000E+00
 0000199  0.4197E-03  0.1565E-03  0.4197E-03  0.3316E-05  0.0000E+00
 0000200  0.4164E-03  0.1551E-03  0.4164E-03  0.7148E-05  0.0000E+00
 0000201  0.4139E-03  0.1537E-03  0.4139E-03  0.2719E-05  0.0000E+00
 0000202  0.4127E-03  0.1526E-03  0.4127E-03  0.4846E-05  0.0000E+00
 0000203  0.4134E-03  0.1518E-03  0.4135E-03  0.2708E-05  0.0000E+00
 0000204  0.4170E-03  0.1515E-03  0.4172E-03  0.7880E-05  0.0000E+00
 0000205  0.3938E-03  0.1550E-03  0.3937E-03  0.9159E-05  0.0000E+00
 0000206  0.3897E-03  0.1581E-03  0.3896E-03  0.7666E-05  0.0000E+00
 0000207  0.3870E-03  0.1446E-03  0.3869E-03  0.4670E-05  0.0000E+00
 0000208  0.3838E-03  0.1431E-03  0.3837E-03  0.4734E-05  0.0000E+00
 0000209  0.3811E-03  0.1418E-03  0.3810E-03  0.3312E-05  0.0000E+00
 0000210  0.3794E-03  0.1407E-03  0.3793E-03  0.3418E-05  0.0000E+00
 0000211  0.3791E-03  0.1398E-03  0.3791E-03  0.2854E-05  0.0000E+00
 0000212  0.3810E-03  0.1393E-03  0.3812E-03  0.2806E-05  0.0000E+00
 0000213  0.3860E-03  0.1394E-03  0.3862E-03  0.1047E-04  0.0000E+00
 0000214  0.3598E-03  0.1437E-03  0.3597E-03  0.8066E-05  0.0000E+00
 0000215  0.3561E-03  0.1473E-03  0.3560E-03  0.7540E-05  0.0000E+00
 0000216  0.3539E-03  0.1322E-03  0.3538E-03  0.6594E-05  0.0000E+00
 0000217  0.3512E-03  0.1309E-03  0.3511E-03  0.4325E-05  0.0000E+00
 0000218  0.3490E-03  0.1298E-03  0.3490E-03  0.4233E-05  0.0000E+00
 0000219  0.3480E-03  0.1288E-03  0.3480E-03  0.3005E-05  0.0000E+00
 0000220  0.3485E-03  0.1282E-03  0.3486E-03  0.3123E-05  0.0000E+00
 0000221  0.3515E-03  0.1279E-03  0.3516E-03  0.2907E-04  0.0000E+00
 0000222  0.3575E-03  0.1295E-03  0.3304E-03  0.1039E-04  0.0000E+00
 0000223  0.3290E-03  0.1332E-03  0.3286E-03  0.9661E-05  0.0000E+00
 0000224  0.3264E-03  0.1222E-03  0.3263E-03  0.5535E-05  0.0000E+00
 0000225  0.3236E-03  0.1209E-03  0.3235E-03  0.7639E-05  0.0000E+00
 0000226  0.3210E-03  0.1199E-03  0.3210E-03  0.4123E-05  0.0000E+00
 0000227  0.3191E-03  0.1189E-03  0.3192E-03  0.6401E-05  0.0000E+00
 0000228  0.3179E-03  0.1182E-03  0.3184E-03  0.3536E-05  0.0000E+00
 0000229  0.3183E-03  0.1178E-03  0.3191E-03  0.5460E-05  0.0000E+00
 0000230  0.3207E-03  0.1179E-03  0.3222E-03  0.8981E-05  0.0000E+00
 0000231  0.3272E-03  0.1199E-03  0.3021E-03  0.7988E-05  0.0000E+00
 0000232  0.3007E-03  0.1239E-03  0.3004E-03  0.4844E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 13
 0000233  0.2986E-03  0.1119E-03  0.2985E-03  0.3669E-05  0.0000E+00
 0000234  0.2961E-03  0.1107E-03  0.2961E-03  0.3434E-05  0.0000E+00
 0000235  0.2939E-03  0.1098E-03  0.2941E-03  0.2831E-05  0.0000E+00
 0000236  0.2923E-03  0.1090E-03  0.2928E-03  0.2822E-05  0.0000E+00
 0000237  0.2916E-03  0.1084E-03  0.2928E-03  0.2436E-05  0.0000E+00
 0000238  0.2925E-03  0.1081E-03  0.2945E-03  0.2485E-05  0.0000E+00
 0000239  0.2954E-03  0.1083E-03  0.2986E-03  0.6093E-05  0.0000E+00
 0000240  0.2778E-03  0.1119E-03  0.2777E-03  0.2336E-05  0.0000E+00
 0000241  0.2757E-03  0.1034E-03  0.2756E-03  0.2734E-05  0.0000E+00
 0000242  0.2733E-03  0.1024E-03  0.2733E-03  0.1892E-05  0.0000E+00
 0000243  0.2711E-03  0.1015E-03  0.2712E-03  0.2148E-05  0.0000E+00
 0000244  0.2693E-03  0.1006E-03  0.2696E-03  0.1791E-05  0.0000E+00
 0000245  0.2683E-03  0.9992E-04  0.2689E-03  0.1877E-05  0.0000E+00
 0000246  0.2683E-03  0.9944E-04  0.2695E-03  0.1740E-05  0.0000E+00
 0000247  0.2700E-03  0.9934E-04  0.2720E-03  0.5772E-05  0.0000E+00
 0000248  0.2751E-03  0.1009E-03  0.2555E-03  0.3819E-05  0.0000E+00
 0000249  0.2542E-03  0.1041E-03  0.2539E-03  0.2138E-05  0.0000E+00
 0000250  0.2524E-03  0.9474E-04  0.2523E-03  0.1990E-05  0.0000E+00
 0000251  0.2503E-03  0.9378E-04  0.2502E-03  0.1732E-05  0.0000E+00
 0000252  0.2484E-03  0.9299E-04  0.2486E-03  0.1767E-05  0.0000E+00
 0000253  0.2469E-03  0.9225E-04  0.2475E-03  0.1616E-05  0.0000E+00
 0000254  0.2463E-03  0.9168E-04  0.2474E-03  0.1650E-05  0.0000E+00
 0000255  0.2469E-03  0.9135E-04  0.2488E-03  0.1546E-05  0.0000E+00
 0000256  0.2492E-03  0.9146E-04  0.2522E-03  0.3458E-05  0.0000E+00
 0000257  0.2350E-03  0.9432E-04  0.2348E-03  0.1551E-05  0.0000E+00
 0000258  0.2332E-03  0.8761E-04  0.2330E-03  0.1620E-05  0.0000E+00
 0000259  0.2311E-03  0.8673E-04  0.2311E-03  0.1416E-05  0.0000E+00
 0000260  0.2292E-03  0.8597E-04  0.2293E-03  0.1510E-05  0.0000E+00
 0000261  0.2277E-03  0.8524E-04  0.2280E-03  0.1397E-05  0.0000E+00
 0000262  0.2267E-03  0.8464E-04  0.2274E-03  0.1440E-05  0.0000E+00
 0000263  0.2267E-03  0.8420E-04  0.2279E-03  0.1378E-05  0.0000E+00
 0000264  0.2280E-03  0.8407E-04  0.2300E-03  0.4225E-05  0.0000E+00
 0000265  0.2321E-03  0.8529E-04  0.2162E-03  0.2246E-05  0.0000E+00
 0000266  0.2151E-03  0.8790E-04  0.2148E-03  0.1591E-05  0.0000E+00
 0000267  0.2135E-03  0.8030E-04  0.2134E-03  0.1471E-05  0.0000E+00
 0000268  0.2117E-03  0.7950E-04  0.2117E-03  0.1359E-05  0.0000E+00
 0000269  0.2101E-03  0.7882E-04  0.2103E-03  0.1394E-05  0.0000E+00
 0000270  0.2089E-03  0.7818E-04  0.2094E-03  0.1300E-05  0.0000E+00
 0000271  0.2083E-03  0.7770E-04  0.2093E-03  0.1337E-05  0.0000E+00
 0000272  0.2087E-03  0.7739E-04  0.2105E-03  0.1261E-05  0.0000E+00
 0000273  0.2106E-03  0.7745E-04  0.2134E-03  0.2525E-05  0.0000E+00
 0000274  0.1988E-03  0.7981E-04  0.1987E-03  0.2166E-05  0.0000E+00
 0000275  0.1968E-03  0.8195E-04  0.1967E-03  0.1555E-05  0.0000E+00
 0000276  0.1956E-03  0.7361E-04  0.1955E-03  0.1699E-05  0.0000E+00
 0000277  0.1940E-03  0.7287E-04  0.1941E-03  0.1368E-05  0.0000E+00
 0000278  0.1927E-03  0.7227E-04  0.1930E-03  0.1618E-05  0.0000E+00
 0000279  0.1918E-03  0.7169E-04  0.1925E-03  0.1369E-05  0.0000E+00
 0000280  0.1918E-03  0.7126E-04  0.1929E-03  0.1553E-05  0.0000E+00
 0000281  0.1928E-03  0.7101E-04  0.1947E-03  0.3926E-05  0.0000E+00
 0000282  0.1963E-03  0.7188E-04  0.1830E-03  0.1588E-05  0.0000E+00
 0000283  0.1821E-03  0.7385E-04  0.1819E-03  0.1420E-05  0.0000E+00
 0000284  0.1807E-03  0.6810E-04  0.1807E-03  0.1245E-05  0.0000E+00
 0000285  0.1792E-03  0.6742E-04  0.1792E-03  0.1247E-05  0.0000E+00
 0000286  0.1778E-03  0.6683E-04  0.1780E-03  0.1193E-05  0.0000E+00
 0000287  0.1768E-03  0.6628E-04  0.1773E-03  0.1187E-05  0.0000E+00
 0000288  0.1763E-03  0.6582E-04  0.1772E-03  0.1152E-05  0.0000E+00
 0000289  0.1766E-03  0.6550E-04  0.1783E-03  0.1137E-05  0.0000E+00
 0000290  0.1782E-03  0.6545E-04  0.1808E-03  0.2284E-05  0.0000E+00
 0000291  0.1684E-03  0.6730E-04  0.1683E-03  0.2099E-05  0.0000E+00
 0000292  0.1667E-03  0.6896E-04  0.1666E-03  0.1336E-05  0.0000E+00
 0000293  0.1656E-03  0.6244E-04  0.1656E-03  0.1410E-05  0.0000E+00
 0000294  0.1643E-03  0.6181E-04  0.1643E-03  0.1176E-05  0.0000E+00
 0000295  0.1632E-03  0.6129E-04  0.1634E-03  0.1331E-05  0.0000E+00
 0000296  0.1624E-03  0.6078E-04  0.1630E-03  0.1154E-05  0.0000E+00
 0000297  0.1624E-03  0.6039E-04  0.1634E-03  0.1264E-05  0.0000E+00
 0000298  0.1632E-03  0.6013E-04  0.1650E-03  0.3295E-05  0.0000E+00
 0000299  0.1662E-03  0.6079E-04  0.1550E-03  0.1318E-05  0.0000E+00
 0000300  0.1543E-03  0.6235E-04  0.1541E-03  0.1209E-05  0.0000E+00
 0000301  0.1531E-03  0.5778E-04  0.1530E-03  0.1041E-05  0.0000E+00
 0000302  0.1518E-03  0.5720E-04  0.1518E-03  0.1059E-05  0.0000E+00
 0000303  0.1506E-03  0.5670E-04  0.1508E-03  0.9945E-06  0.0000E+00
 0000304  0.1498E-03  0.5621E-04  0.1502E-03  0.9973E-06  0.0000E+00
 0000305  0.1493E-03  0.5581E-04  0.1502E-03  0.9551E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 14
 0000306  0.1496E-03  0.5551E-04  0.1511E-03  0.9445E-06  0.0000E+00
 0000307  0.1509E-03  0.5542E-04  0.1532E-03  0.1974E-05  0.0000E+00
 0000308  0.1427E-03  0.5694E-04  0.1426E-03  0.1819E-05  0.0000E+00
 0000309  0.1412E-03  0.5827E-04  0.1411E-03  0.1119E-05  0.0000E+00
 0000310  0.1403E-03  0.5298E-04  0.1403E-03  0.1189E-05  0.0000E+00
 0000311  0.1392E-03  0.5245E-04  0.1392E-03  0.9872E-06  0.0000E+00
 0000312  0.1382E-03  0.5200E-04  0.1385E-03  0.1115E-05  0.0000E+00
 0000313  0.1376E-03  0.5156E-04  0.1382E-03  0.9620E-06  0.0000E+00
 0000314  0.1376E-03  0.5121E-04  0.1385E-03  0.1052E-05  0.0000E+00
 0000315  0.1383E-03  0.5097E-04  0.1399E-03  0.2759E-05  0.0000E+00
 0000316  0.1408E-03  0.5150E-04  0.1314E-03  0.1106E-05  0.0000E+00
 0000317  0.1307E-03  0.5278E-04  0.1306E-03  0.1019E-05  0.0000E+00
 0000318  0.1297E-03  0.4903E-04  0.1297E-03  0.8745E-06  0.0000E+00
 0000319  0.1286E-03  0.4854E-04  0.1286E-03  0.8928E-06  0.0000E+00
 0000320  0.1277E-03  0.4811E-04  0.1278E-03  0.8339E-06  0.0000E+00
 0000321  0.1269E-03  0.4770E-04  0.1273E-03  0.8377E-06  0.0000E+00
 0000322  0.1266E-03  0.4735E-04  0.1273E-03  0.7987E-06  0.0000E+00
 0000323  0.1268E-03  0.4708E-04  0.1281E-03  0.7896E-06  0.0000E+00
 0000324  0.1279E-03  0.4698E-04  0.1300E-03  0.1680E-05  0.0000E+00
 0000325  0.1209E-03  0.4825E-04  0.1209E-03  0.1553E-05  0.0000E+00
 0000326  0.1197E-03  0.4934E-04  0.1197E-03  0.9419E-06  0.0000E+00
 0000327  0.1189E-03  0.4496E-04  0.1189E-03  0.9997E-06  0.0000E+00
 0000328  0.1180E-03  0.4451E-04  0.1181E-03  0.8309E-06  0.0000E+00
 0000329  0.1172E-03  0.4412E-04  0.1174E-03  0.9351E-06  0.0000E+00
 0000330  0.1167E-03  0.4375E-04  0.1171E-03  0.8067E-06  0.0000E+00
 0000331  0.1166E-03  0.4345E-04  0.1175E-03  0.8791E-06  0.0000E+00
 0000332  0.1173E-03  0.4323E-04  0.1187E-03  0.2317E-05  0.0000E+00
 0000333  0.1194E-03  0.4367E-04  0.1114E-03  0.9303E-06  0.0000E+00
 0000334  0.1108E-03  0.4474E-04  0.1107E-03  0.8609E-06  0.0000E+00
 0000335  0.1100E-03  0.4161E-04  0.1100E-03  0.7358E-06  0.0000E+00
 0000336  0.1091E-03  0.4120E-04  0.1091E-03  0.7539E-06  0.0000E+00
 0000337  0.1083E-03  0.4083E-04  0.1084E-03  0.7014E-06  0.0000E+00
 0000338  0.1076E-03  0.4048E-04  0.1080E-03  0.7059E-06  0.0000E+00
 0000339  0.1073E-03  0.4018E-04  0.1080E-03  0.6709E-06  0.0000E+00
 0000340  0.1075E-03  0.3994E-04  0.1087E-03  0.6636E-06  0.0000E+00
 0000341  0.1085E-03  0.3985E-04  0.1103E-03  0.1428E-05  0.0000E+00
 0000342  0.1026E-03  0.4092E-04  0.1025E-03  0.1322E-05  0.0000E+00
 0000343  0.1015E-03  0.4184E-04  0.1015E-03  0.7947E-06  0.0000E+00
 0000344  0.1009E-03  0.3816E-04  0.1009E-03  0.8429E-06  0.0000E+00
 0000345  0.1001E-03  0.3778E-04  0.1001E-03  0.7008E-06  0.0000E+00
 0000346  0.9940E-04  0.3745E-04  0.9960E-04  0.7870E-06  0.0000E+00
 0000347  0.9898E-04  0.3713E-04  0.9939E-04  0.6789E-06  0.0000E+00
 0000348  0.9894E-04  0.3687E-04  0.9970E-04  0.7382E-06  0.0000E+00
 0000349  0.9951E-04  0.3668E-04  0.1007E-03  0.1953E-05  0.0000E+00
 0000350  0.1013E-03  0.3705E-04  0.9447E-04  0.7849E-06  0.0000E+00
 0000351  0.9403E-04  0.3795E-04  0.9393E-04  0.7284E-06  0.0000E+00
 0000352  0.9331E-04  0.3531E-04  0.9329E-04  0.6206E-06  0.0000E+00
 0000353  0.9253E-04  0.3496E-04  0.9256E-04  0.6375E-06  0.0000E+00
 0000354  0.9184E-04  0.3465E-04  0.9197E-04  0.5914E-06  0.0000E+00
 0000355  0.9132E-04  0.3435E-04  0.9162E-04  0.5961E-06  0.0000E+00
 0000356  0.9107E-04  0.3409E-04  0.9167E-04  0.5652E-06  0.0000E+00
 0000357  0.9127E-04  0.3389E-04  0.9229E-04  0.5593E-06  0.0000E+00
 0000358  0.9209E-04  0.3381E-04  0.9368E-04  0.1214E-05  0.0000E+00
 0000359  0.8703E-04  0.3472E-04  0.8698E-04  0.1124E-05  0.0000E+00
 0000360  0.8615E-04  0.3550E-04  0.8612E-04  0.6722E-06  0.0000E+00
 0000361  0.8559E-04  0.3238E-04  0.8560E-04  0.7121E-06  0.0000E+00
 0000362  0.8492E-04  0.3206E-04  0.8499E-04  0.5921E-06  0.0000E+00
 0000363  0.8436E-04  0.3178E-04  0.8454E-04  0.6641E-06  0.0000E+00
 0000364  0.8401E-04  0.3151E-04  0.8437E-04  0.5727E-06  0.0000E+00
 0000365  0.8399E-04  0.3129E-04  0.8465E-04  0.6218E-06  0.0000E+00
 0000366  0.8448E-04  0.3113E-04  0.8555E-04  0.1651E-05  0.0000E+00
 0000367  0.8606E-04  0.3144E-04  0.8018E-04  0.6638E-06  0.0000E+00
 0000368  0.7981E-04  0.3221E-04  0.7973E-04  0.6173E-06  0.0000E+00
 0000369  0.7920E-04  0.2997E-04  0.7919E-04  0.5241E-06  0.0000E+00
 0000370  0.7854E-04  0.2967E-04  0.7857E-04  0.5399E-06  0.0000E+00
 0000371  0.7796E-04  0.2941E-04  0.7808E-04  0.4995E-06  0.0000E+00
 0000372  0.7753E-04  0.2915E-04  0.7780E-04  0.5042E-06  0.0000E+00
 0000373  0.7732E-04  0.2893E-04  0.7785E-04  0.4770E-06  0.0000E+00
 0000374  0.7750E-04  0.2876E-04  0.7839E-04  0.4723E-06  0.0000E+00
 0000375  0.7821E-04  0.2869E-04  0.7960E-04  0.1033E-05  0.0000E+00
 0000376  0.7388E-04  0.2947E-04  0.7385E-04  0.9571E-06  0.0000E+00
 0000377  0.7314E-04  0.3013E-04  0.7313E-04  0.5696E-06  0.0000E+00
 0000378  0.7267E-04  0.2748E-04  0.7269E-04  0.6026E-06  0.0000E+00
 0000379  0.7210E-04  0.2721E-04  0.7217E-04  0.5010E-06  0.0000E+00
 0000380  0.7163E-04  0.2697E-04  0.7180E-04  0.5615E-06  0.0000E+00
 0000381  0.7134E-04  0.2674E-04  0.7167E-04  0.4840E-06  0.0000E+00
 0000382  0.7133E-04  0.2655E-04  0.7191E-04  0.5249E-06  0.0000E+00
 0000383  0.7176E-04  0.2642E-04  0.7270E-04  0.1399E-05  0.0000E+00
 0000384  0.7313E-04  0.2668E-04  0.6810E-04  0.5623E-06  0.0000E+00
 0000385  0.6778E-04  0.2734E-04  0.6772E-04  0.5239E-06  0.0000E+00
 0000386  0.6726E-04  0.2543E-04  0.6726E-04  0.4432E-06  0.0000E+00
 0000387  0.6671E-04  0.2518E-04  0.6674E-04  0.4577E-06  0.0000E+00
 0000388  0.6621E-04  0.2495E-04  0.6633E-04  0.4224E-06  0.0000E+00
 0000389  0.6585E-04  0.2474E-04  0.6610E-04  0.4271E-06  0.0000E+00
 0000390  0.6568E-04  0.2455E-04  0.6615E-04  0.4032E-06  0.0000E+00
 0000391  0.6584E-04  0.2441E-04  0.6663E-04  0.3993E-06  0.0000E+00
 0000392  0.6646E-04  0.2435E-04  0.6767E-04  0.8804E-06  0.0000E+00
 0000393  0.6276E-04  0.2501E-04  0.6275E-04  0.8152E-06  0.0000E+00
 0000394  0.6214E-04  0.2558E-04  0.6213E-04  0.4833E-06  0.0000E+00
 0000395  0.6173E-04  0.2332E-04  0.6176E-04  0.5105E-06  0.0000E+00
 0000396  0.6126E-04  0.2309E-04  0.6133E-04  0.4244E-06  0.0000E+00
 0000397  0.6086E-04  0.2288E-04  0.6102E-04  0.4753E-06  0.0000E+00
 0000398  0.6062E-04  0.2269E-04  0.6091E-04  0.4096E-06  0.0000E+00
 0000399  0.6062E-04  0.2253E-04  0.6113E-04  0.4437E-06  0.0000E+00
 0000400  0.6100E-04  0.2242E-04  0.6181E-04  0.1187E-05  0.0000E+00
 0000401  0.6218E-04  0.2265E-04  0.5787E-04  0.4770E-06  0.0000E+00
 0000402  0.5759E-04  0.2321E-04  0.5755E-04  0.4451E-06  0.0000E+00
 0000403  0.5716E-04  0.2158E-04  0.5717E-04  0.3752E-06  0.0000E+00
 0000404  0.5669E-04  0.2136E-04  0.5673E-04  0.3885E-06  0.0000E+00
 0000405  0.5627E-04  0.2117E-04  0.5639E-04  0.3575E-06  0.0000E+00
 0000406  0.5597E-04  0.2099E-04  0.5619E-04  0.3621E-06  0.0000E+00
 0000407  0.5583E-04  0.2083E-04  0.5625E-04  0.3411E-06  0.0000E+00
 0000408  0.5598E-04  0.2071E-04  0.5667E-04  0.3381E-06  0.0000E+00
 0000409  0.5651E-04  0.2066E-04  0.5757E-04  0.7505E-06  0.0000E+00
 0000410  0.5335E-04  0.2123E-04  0.5334E-04  0.6947E-06  0.0000E+00
 0000411  0.5282E-04  0.2171E-04  0.5282E-04  0.4105E-06  0.0000E+00
 0000412  0.5248E-04  0.1978E-04  0.5251E-04  0.4329E-06  0.0000E+00
 0000413  0.5208E-04  0.1959E-04  0.5215E-04  0.3599E-06  0.0000E+00
 0000414  0.5174E-04  0.1942E-04  0.5189E-04  0.4028E-06  0.0000E+00
 0000415  0.5154E-04  0.1925E-04  0.5180E-04  0.3470E-06  0.0000E+00
 0000416  0.5155E-04  0.1912E-04  0.5200E-04  0.3755E-06  0.0000E+00
 0000417  0.5188E-04  0.1902E-04  0.5259E-04  0.1009E-05  0.0000E+00
 0000418  0.5290E-04  0.1922E-04  0.4921E-04  0.4049E-06  0.0000E+00
 0000419  0.4897E-04  0.1970E-04  0.4895E-04  0.3785E-06  0.0000E+00
 0000420  0.4860E-04  0.1831E-04  0.4863E-04  0.3179E-06  0.0000E+00
 0000421  0.4821E-04  0.1813E-04  0.4826E-04  0.3299E-06  0.0000E+00
 0000422  0.4786E-04  0.1796E-04  0.4797E-04  0.3029E-06  0.0000E+00
 0000423  0.4761E-04  0.1781E-04  0.4781E-04  0.3073E-06  0.0000E+00
 0000424  0.4749E-04  0.1767E-04  0.4786E-04  0.2888E-06  0.0000E+00
 0000425  0.4762E-04  0.1757E-04  0.4823E-04  0.2864E-06  0.0000E+00
 0000426  0.4809E-04  0.1753E-04  0.4900E-04  0.6402E-06  0.0000E+00
 0000427  0.4538E-04  0.1802E-04  0.4538E-04  0.5924E-06  0.0000E+00
 0000428  0.4493E-04  0.1843E-04  0.4494E-04  0.3489E-06  0.0000E+00
 0000429  0.4464E-04  0.1678E-04  0.4468E-04  0.3674E-06  0.0000E+00
 0000430  0.4430E-04  0.1662E-04  0.4437E-04  0.3053E-06  0.0000E+00
 0000431  0.4402E-04  0.1647E-04  0.4416E-04  0.3416E-06  0.0000E+00
 0000432  0.4386E-04  0.1633E-04  0.4409E-04  0.2941E-06  0.0000E+00
 0000433  0.4387E-04  0.1622E-04  0.4427E-04  0.3181E-06  0.0000E+00
 0000434  0.4416E-04  0.1614E-04  0.4478E-04  0.8590E-06  0.0000E+00
 0000435  0.4504E-04  0.1631E-04  0.4188E-04  0.3439E-06  0.0000E+00
 0000436  0.4168E-04  0.1672E-04  0.4166E-04  0.3221E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 15
 0000437  0.4136E-04  0.1553E-04  0.4139E-04  0.2695E-06  0.0000E+00
 0000438  0.4103E-04  0.1538E-04  0.4108E-04  0.2805E-06  0.0000E+00
 0000439  0.4073E-04  0.1524E-04  0.4084E-04  0.2568E-06  0.0000E+00
 0000440  0.4052E-04  0.1511E-04  0.4070E-04  0.2610E-06  0.0000E+00
 0000441  0.4043E-04  0.1499E-04  0.4075E-04  0.2447E-06  0.0000E+00
 0000442  0.4055E-04  0.1491E-04  0.4108E-04  0.2429E-06  0.0000E+00
 0000443  0.4095E-04  0.1488E-04  0.4175E-04  0.5465E-06  0.0000E+00
 0000444  0.3863E-04  0.1529E-04  0.3864E-04  0.5055E-06  0.0000E+00
 0000445  0.3825E-04  0.1565E-04  0.3827E-04  0.2968E-06  0.0000E+00
 0000446  0.3801E-04  0.1424E-04  0.3805E-04  0.3121E-06  0.0000E+00
 0000447  0.3772E-04  0.1409E-04  0.3779E-04  0.2593E-06  0.0000E+00
 0000448  0.3749E-04  0.1397E-04  0.3761E-04  0.2900E-06  0.0000E+00
 0000449  0.3735E-04  0.1385E-04  0.3756E-04  0.2495E-06  0.0000E+00
 0000450  0.3736E-04  0.1376E-04  0.3771E-04  0.2697E-06  0.0000E+00
 0000451  0.3762E-04  0.1369E-04  0.3816E-04  0.7320E-06  0.0000E+00
 0000452  0.3838E-04  0.1384E-04  0.3567E-04  0.2923E-06  0.0000E+00
 0000453  0.3549E-04  0.1419E-04  0.3549E-04  0.2743E-06  0.0000E+00
 0000454  0.3523E-04  0.1317E-04  0.3526E-04  0.2286E-06  0.0000E+00
 0000455  0.3495E-04  0.1304E-04  0.3500E-04  0.2386E-06  0.0000E+00
 0000456  0.3470E-04  0.1292E-04  0.3479E-04  0.2178E-06  0.0000E+00
 0000457  0.3452E-04  0.1281E-04  0.3468E-04  0.2218E-06  0.0000E+00
 0000458  0.3445E-04  0.1272E-04  0.3473E-04  0.2075E-06  0.0000E+00
 0000459  0.3455E-04  0.1265E-04  0.3501E-04  0.2061E-06  0.0000E+00
 0000460  0.3490E-04  0.1262E-04  0.3560E-04  0.4667E-06  0.0000E+00
 0000461  0.3291E-04  0.1298E-04  0.3293E-04  0.4315E-06  0.0000E+00
 0000462  0.3259E-04  0.1328E-04  0.3262E-04  0.2525E-06  0.0000E+00
 0000463  0.3239E-04  0.1208E-04  0.3243E-04  0.2652E-06  0.0000E+00
 0000464  0.3215E-04  0.1195E-04  0.3221E-04  0.2203E-06  0.0000E+00
 0000465  0.3195E-04  0.1185E-04  0.3206E-04  0.2462E-06  0.0000E+00
 0000466  0.3183E-04  0.1175E-04  0.3202E-04  0.2118E-06  0.0000E+00
 0000467  0.3185E-04  0.1167E-04  0.3216E-04  0.2287E-06  0.0000E+00
 0000468  0.3207E-04  0.1161E-04  0.3255E-04  0.6244E-06  0.0000E+00
 0000469  0.3273E-04  0.1174E-04  0.3041E-04  0.2486E-06  0.0000E+00
 0000470  0.3026E-04  0.1204E-04  0.3026E-04  0.2338E-06  0.0000E+00
 0000471  0.3003E-04  0.1117E-04  0.3007E-04  0.1941E-06  0.0000E+00
 0000472  0.2979E-04  0.1106E-04  0.2984E-04  0.2031E-06  0.0000E+00
 0000473  0.2958E-04  0.1096E-04  0.2967E-04  0.1849E-06  0.0000E+00
 0000474  0.2943E-04  0.1087E-04  0.2958E-04  0.1886E-06  0.0000E+00
 0000475  0.2937E-04  0.1079E-04  0.2963E-04  0.1760E-06  0.0000E+00
 0000476  0.2947E-04  0.1073E-04  0.2988E-04  0.1751E-06  0.0000E+00
 0000477  0.2977E-04  0.1070E-04  0.3038E-04  0.3988E-06  0.0000E+00
 0000478  0.2807E-04  0.1101E-04  0.2809E-04  0.3686E-06  0.0000E+00
 0000479  0.2780E-04  0.1127E-04  0.2783E-04  0.2150E-06  0.0000E+00
 0000480  0.2762E-04  0.1024E-04  0.2767E-04  0.2255E-06  0.0000E+00
 0000481  0.2742E-04  0.1014E-04  0.2749E-04  0.1872E-06  0.0000E+00
 0000482  0.2725E-04  0.1005E-04  0.2736E-04  0.2092E-06  0.0000E+00
 0000483  0.2716E-04  0.9964E-05  0.2733E-04  0.1799E-06  0.0000E+00
 0000484  0.2718E-04  0.9895E-05  0.2745E-04  0.1941E-06  0.0000E+00
 0000485  0.2737E-04  0.9848E-05  0.2779E-04  0.5332E-06  0.0000E+00
 0000486  0.2795E-04  0.9958E-05  0.2595E-04  0.2115E-06  0.0000E+00
 0000487  0.2582E-04  0.1022E-04  0.2583E-04  0.1994E-06  0.0000E+00
 0000488  0.2563E-04  0.9473E-05  0.2567E-04  0.1649E-06  0.0000E+00
 0000489  0.2543E-04  0.9379E-05  0.2548E-04  0.1731E-06  0.0000E+00
 0000490  0.2525E-04  0.9295E-05  0.2533E-04  0.1570E-06  0.0000E+00
 0000491  0.2512E-04  0.9215E-05  0.2526E-04  0.1606E-06  0.0000E+00
 0000492  0.2508E-04  0.9147E-05  0.2530E-04  0.1494E-06  0.0000E+00
 0000493  0.2516E-04  0.9096E-05  0.2552E-04  0.1488E-06  0.0000E+00
 0000494  0.2542E-04  0.9079E-05  0.2595E-04  0.3410E-06  0.0000E+00
 0000495  0.2396E-04  0.9341E-05  0.2399E-04  0.3152E-06  0.0000E+00
 0000496  0.2373E-04  0.9563E-05  0.2377E-04  0.1831E-06  0.0000E+00
 0000497  0.2359E-04  0.8683E-05  0.2363E-04  0.1919E-06  0.0000E+00
 0000498  0.2341E-04  0.8596E-05  0.2348E-04  0.1593E-06  0.0000E+00
 0000499  0.2327E-04  0.8521E-05  0.2337E-04  0.1779E-06  0.0000E+00
 0000500  0.2320E-04  0.8449E-05  0.2335E-04  0.1528E-06  0.0000E+00
 0000501  0.2321E-04  0.8391E-05  0.2346E-04  0.1648E-06  0.0000E+00
 0000502  0.2338E-04  0.8351E-05  0.2375E-04  0.4558E-06  0.0000E+00
 0000503  0.2388E-04  0.8446E-05  0.2217E-04  0.1801E-06  0.0000E+00
 0000504  0.2205E-04  0.8667E-05  0.2207E-04  0.1701E-06  0.0000E+00
 0000505  0.2189E-04  0.8033E-05  0.2193E-04  0.1402E-06  0.0000E+00
 0000506  0.2172E-04  0.7952E-05  0.2177E-04  0.1476E-06  0.0000E+00
 0000507  0.2157E-04  0.7881E-05  0.2165E-04  0.1335E-06  0.0000E+00
 0000508  0.2147E-04  0.7813E-05  0.2159E-04  0.1368E-06  0.0000E+00
 0000509  0.2143E-04  0.7756E-05  0.2163E-04  0.1269E-06  0.0000E+00
 0000510  0.2150E-04  0.7713E-05  0.2182E-04  0.1265E-06  0.0000E+00
 0000511  0.2173E-04  0.7699E-05  0.2220E-04  0.2919E-06  0.0000E+00
 0000512  0.2048E-04  0.7923E-05  0.2051E-04  0.2697E-06  0.0000E+00
 0000513  0.2029E-04  0.8114E-05  0.2032E-04  0.1561E-06  0.0000E+00
 0000514  0.2016E-04  0.7362E-05  0.2021E-04  0.1634E-06  0.0000E+00
 0000515  0.2002E-04  0.7288E-05  0.2008E-04  0.1356E-06  0.0000E+00
 0000516  0.1990E-04  0.7225E-05  0.1999E-04  0.1514E-06  0.0000E+00
 0000517  0.1983E-04  0.7164E-05  0.1997E-04  0.1300E-06  0.0000E+00
 0000518  0.1985E-04  0.7115E-05  0.2007E-04  0.1400E-06  0.0000E+00
 0000519  0.2000E-04  0.7081E-05  0.2032E-04  0.3901E-06  0.0000E+00
 0000520  0.2044E-04  0.7162E-05  0.1896E-04  0.1534E-06  0.0000E+00
 0000521  0.1886E-04  0.7352E-05  0.1888E-04  0.1453E-06  0.0000E+00
 0000522  0.1873E-04  0.6810E-05  0.1877E-04  0.1193E-06  0.0000E+00
 0000523  0.1858E-04  0.6742E-05  0.1863E-04  0.1259E-06  0.0000E+00
 0000524  0.1846E-04  0.6682E-05  0.1853E-04  0.1135E-06  0.0000E+00
 0000525  0.1837E-04  0.6624E-05  0.1848E-04  0.1166E-06  0.0000E+00
 0000526  0.1834E-04  0.6576E-05  0.1852E-04  0.1079E-06  0.0000E+00
 0000527  0.1840E-04  0.6540E-05  0.1868E-04  0.1077E-06  0.0000E+00
 0000528  0.1860E-04  0.6529E-05  0.1901E-04  0.2500E-06  0.0000E+00
 0000529  0.1753E-04  0.6720E-05  0.1756E-04  0.2309E-06  0.0000E+00
 0000530  0.1736E-04  0.6883E-05  0.1740E-04  0.1331E-06  0.0000E+00
 0000531  0.1726E-04  0.6241E-05  0.1730E-04  0.1392E-06  0.0000E+00
 0000532  0.1713E-04  0.6179E-05  0.1719E-04  0.1155E-06  0.0000E+00
 0000533  0.1704E-04  0.6125E-05  0.1712E-04  0.1289E-06  0.0000E+00
 0000534  0.1698E-04  0.6073E-05  0.1711E-04  0.1106E-06  0.0000E+00
 0000535  0.1700E-04  0.6032E-05  0.1719E-04  0.1191E-06  0.0000E+00
 0000536  0.1713E-04  0.6004E-05  0.1741E-04  0.3343E-06  0.0000E+00
 0000537  0.1751E-04  0.6073E-05  0.1624E-04  0.1307E-06  0.0000E+00
 0000538  0.1615E-04  0.6235E-05  0.1618E-04  0.1242E-06  0.0000E+00
 0000539  0.1604E-04  0.5773E-05  0.1608E-04  0.1015E-06  0.0000E+00
 0000540  0.1592E-04  0.5715E-05  0.1597E-04  0.1076E-06  0.0000E+00
 0000541  0.1581E-04  0.5664E-05  0.1588E-04  0.9664E-07  0.0000E+00
 0000542  0.1574E-04  0.5616E-05  0.1584E-04  0.9949E-07  0.0000E+00
 0000543  0.1571E-04  0.5575E-05  0.1587E-04  0.9179E-07  0.0000E+00
 0000544  0.1577E-04  0.5544E-05  0.1602E-04  0.9173E-07  0.0000E+00
 0000545  0.1595E-04  0.5535E-05  0.1630E-04  0.2143E-06  0.0000E+00
 0000546  0.1502E-04  0.5699E-05  0.1506E-04  0.1980E-06  0.0000E+00
 0000547  0.1488E-04  0.5838E-05  0.1492E-04  0.1136E-06  0.0000E+00
 0000548  0.1479E-04  0.5291E-05  0.1484E-04  0.1188E-06  0.0000E+00
 0000549  0.1469E-04  0.5238E-05  0.1474E-04  0.9850E-07  0.0000E+00
 0000550  0.1460E-04  0.5192E-05  0.1468E-04  0.1099E-06  0.0000E+00
 0000551  0.1456E-04  0.5148E-05  0.1467E-04  0.9419E-07  0.0000E+00
 0000552  0.1458E-04  0.5113E-05  0.1475E-04  0.1013E-06  0.0000E+00
 0000553  0.1469E-04  0.5090E-05  0.1494E-04  0.2869E-06  0.0000E+00
 0000554  0.1502E-04  0.5149E-05  0.1393E-04  0.1115E-06  0.0000E+00
 0000555  0.1386E-04  0.5288E-05  0.1388E-04  0.1063E-06  0.0000E+00
 0000556  0.1376E-04  0.4893E-05  0.1380E-04  0.8653E-07  0.0000E+00
 0000557  0.1365E-04  0.4845E-05  0.1370E-04  0.9199E-07  0.0000E+00
 0000558  0.1356E-04  0.4801E-05  0.1363E-04  0.8234E-07  0.0000E+00
 0000559  0.1350E-04  0.4760E-05  0.1360E-04  0.8498E-07  0.0000E+00
 0000560  0.1348E-04  0.4725E-05  0.1363E-04  0.7814E-07  0.0000E+00
 0000561  0.1354E-04  0.4700E-05  0.1375E-04  0.7821E-07  0.0000E+00
 0000562  0.1369E-04  0.4693E-05  0.1400E-04  0.1840E-06  0.0000E+00
 0000563  0.1289E-04  0.4833E-05  0.1293E-04  0.1700E-06  0.0000E+00
 0000564  0.1277E-04  0.4951E-05  0.1281E-04  0.9704E-07  0.0000E+00
 0000565  0.1270E-04  0.4484E-05  0.1274E-04  0.1014E-06  0.0000E+00
 0000566  0.1261E-04  0.4439E-05  0.1266E-04  0.8407E-07  0.0000E+00
 0000567  0.1254E-04  0.4401E-05  0.1261E-04  0.9371E-07  0.0000E+00
 0000568  0.1251E-04  0.4364E-05  0.1261E-04  0.8028E-07  0.0000E+00
 0000569  0.1252E-04  0.4334E-05  0.1267E-04  0.8627E-07  0.0000E+00
 0000570  0.1262E-04  0.4314E-05  0.1284E-04  0.2466E-06  0.0000E+00
 0000571  0.1291E-04  0.4365E-05  0.1197E-04  0.9520E-07  0.0000E+00
 0000572  0.1190E-04  0.4484E-05  0.1193E-04  0.9103E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 16
 0000573  0.1182E-04  0.4148E-05  0.1186E-04  0.7382E-07  0.0000E+00
 0000574  0.1173E-04  0.4106E-05  0.1178E-04  0.7875E-07  0.0000E+00
 0000575  0.1166E-04  0.4070E-05  0.1172E-04  0.7021E-07  0.0000E+00
 0000576  0.1160E-04  0.4034E-05  0.1169E-04  0.7266E-07  0.0000E+00
 0000577  0.1159E-04  0.4005E-05  0.1172E-04  0.6658E-07  0.0000E+00
 0000578  0.1164E-04  0.3984E-05  0.1183E-04  0.6675E-07  0.0000E+00
 0000579  0.1177E-04  0.3978E-05  0.1204E-04  0.1581E-06  0.0000E+00
 0000580  0.1109E-04  0.4097E-05  0.1112E-04  0.1461E-06  0.0000E+00
 0000581  0.1098E-04  0.4198E-05  0.1102E-04  0.8295E-07  0.0000E+00
 0000582  0.1092E-04  0.3801E-05  0.1096E-04  0.8670E-07  0.0000E+00
 0000583  0.1085E-04  0.3763E-05  0.1090E-04  0.7183E-07  0.0000E+00
 0000584  0.1079E-04  0.3730E-05  0.1085E-04  0.8002E-07  0.0000E+00
 0000585  0.1076E-04  0.3698E-05  0.1085E-04  0.6849E-07  0.0000E+00
 0000586  0.1077E-04  0.3673E-05  0.1091E-04  0.7353E-07  0.0000E+00
 0000587  0.1086E-04  0.3657E-05  0.1105E-04  0.2123E-06  0.0000E+00
 0000588  0.1112E-04  0.3701E-05  0.1030E-04  0.8136E-07  0.0000E+00
 0000589  0.1024E-04  0.3801E-05  0.1027E-04  0.7807E-07  0.0000E+00
 0000590  0.1017E-04  0.3515E-05  0.1021E-04  0.6304E-07  0.0000E+00
 0000591  0.1010E-04  0.3480E-05  0.1014E-04  0.6751E-07  0.0000E+00
 0000592  0.1003E-04  0.3449E-05  0.1009E-04  0.5993E-07  0.0000E+00
 0000593  0.9991E-05  0.3419E-05  0.1007E-04  0.6221E-07  0.0000E+00
 0000594  0.9980E-05  0.3395E-05  0.1010E-04  0.5678E-07  0.0000E+00
 0000595  0.1002E-04  0.3376E-05  0.1019E-04  0.5704E-07  0.0000E+00
 0000596  0.1014E-04  0.3372E-05  0.1038E-04  0.1361E-06  0.0000E+00
 0000597  0.9548E-05  0.3474E-05  0.9580E-05  0.1257E-06  0.0000E+00
 0000598  0.9463E-05  0.3560E-05  0.9496E-05  0.7099E-07  0.0000E+00
 0000599  0.9408E-05  0.3221E-05  0.9447E-05  0.7421E-07  0.0000E+00
 0000600  0.9345E-05  0.3189E-05  0.9391E-05  0.6144E-07  0.0000E+00
 0000601  0.9295E-05  0.3161E-05  0.9355E-05  0.6841E-07  0.0000E+00
 0000602  0.9271E-05  0.3134E-05  0.9354E-05  0.5849E-07  0.0000E+00
 0000603  0.9287E-05  0.3113E-05  0.9407E-05  0.6273E-07  0.0000E+00
 0000604  0.9364E-05  0.3099E-05  0.9535E-05  0.1831E-06  0.0000E+00
 0000605  0.9587E-05  0.3137E-05  0.8881E-05  0.6961E-07  0.0000E+00
 0000606  0.8832E-05  0.3223E-05  0.8858E-05  0.6703E-07  0.0000E+00
 0000607  0.8771E-05  0.2979E-05  0.8807E-05  0.5390E-07  0.0000E+00
 0000608  0.8709E-05  0.2949E-05  0.8748E-05  0.5795E-07  0.0000E+00
 0000609  0.8654E-05  0.2923E-05  0.8706E-05  0.5122E-07  0.0000E+00
 0000610  0.8618E-05  0.2898E-05  0.8689E-05  0.5333E-07  0.0000E+00
 0000611  0.8610E-05  0.2877E-05  0.8714E-05  0.4848E-07  0.0000E+00
 0000612  0.8648E-05  0.2862E-05  0.8799E-05  0.4879E-07  0.0000E+00
 0000613  0.8750E-05  0.2858E-05  0.8962E-05  0.1173E-06  0.0000E+00
 0000614  0.8240E-05  0.2945E-05  0.8271E-05  0.1084E-06  0.0000E+00
 0000615  0.8167E-05  0.3018E-05  0.8199E-05  0.6081E-07  0.0000E+00
 0000616  0.8121E-05  0.2729E-05  0.8157E-05  0.6360E-07  0.0000E+00
 0000617  0.8067E-05  0.2702E-05  0.8110E-05  0.5263E-07  0.0000E+00
 0000618  0.8025E-05  0.2679E-05  0.8081E-05  0.5855E-07  0.0000E+00
 0000619  0.8006E-05  0.2656E-05  0.8081E-05  0.5002E-07  0.0000E+00
 0000620  0.8021E-05  0.2638E-05  0.8128E-05  0.5358E-07  0.0000E+00
 0000621  0.8089E-05  0.2627E-05  0.8240E-05  0.1582E-06  0.0000E+00
 0000622  0.8285E-05  0.2658E-05  0.7672E-05  0.5962E-07  0.0000E+00
 0000623  0.7631E-05  0.2732E-05  0.7655E-05  0.5764E-07  0.0000E+00
 0000624  0.7578E-05  0.2524E-05  0.7612E-05  0.4615E-07  0.0000E+00
 0000625  0.7525E-05  0.2499E-05  0.7562E-05  0.4983E-07  0.0000E+00
 0000626  0.7479E-05  0.2477E-05  0.7527E-05  0.4383E-07  0.0000E+00
 0000627  0.7449E-05  0.2455E-05  0.7513E-05  0.4578E-07  0.0000E+00
 0000628  0.7443E-05  0.2438E-05  0.7536E-05  0.4144E-07  0.0000E+00
 0000629  0.7477E-05  0.2425E-05  0.7612E-05  0.4180E-07  0.0000E+00
 0000630  0.7567E-05  0.2422E-05  0.7754E-05  0.1012E-06  0.0000E+00
 0000631  0.7126E-05  0.2496E-05  0.7155E-05  0.9363E-07  0.0000E+00
 0000632  0.7064E-05  0.2559E-05  0.7094E-05  0.5216E-07  0.0000E+00
 0000633  0.7024E-05  0.2313E-05  0.7058E-05  0.5460E-07  0.0000E+00
 0000634  0.6979E-05  0.2290E-05  0.7018E-05  0.4514E-07  0.0000E+00
 0000635  0.6943E-05  0.2270E-05  0.6994E-05  0.5019E-07  0.0000E+00
 0000636  0.6928E-05  0.2251E-05  0.6996E-05  0.4282E-07  0.0000E+00
 0000637  0.6942E-05  0.2236E-05  0.7038E-05  0.4582E-07  0.0000E+00
 0000638  0.7002E-05  0.2226E-05  0.7136E-05  0.1370E-06  0.0000E+00
 0000639  0.7176E-05  0.2253E-05  0.6642E-05  0.5115E-07  0.0000E+00
 0000640  0.6607E-05  0.2315E-05  0.6630E-05  0.4965E-07  0.0000E+00
 0000641  0.6562E-05  0.2139E-05  0.6593E-05  0.3958E-07  0.0000E+00
 0000642  0.6517E-05  0.2117E-05  0.6551E-05  0.4291E-07  0.0000E+00
 0000643  0.6477E-05  0.2099E-05  0.6522E-05  0.3756E-07  0.0000E+00
 0000644  0.6452E-05  0.2081E-05  0.6511E-05  0.3937E-07  0.0000E+00
 0000645  0.6448E-05  0.2066E-05  0.6532E-05  0.3547E-07  0.0000E+00
 0000646  0.6479E-05  0.2055E-05  0.6598E-05  0.3585E-07  0.0000E+00
 0000647  0.6558E-05  0.2053E-05  0.6723E-05  0.8756E-07  0.0000E+00
 0000648  0.6176E-05  0.2116E-05  0.6203E-05  0.8101E-07  0.0000E+00
 0000649  0.6123E-05  0.2169E-05  0.6152E-05  0.4481E-07  0.0000E+00
 0000650  0.6089E-05  0.1960E-05  0.6121E-05  0.4695E-07  0.0000E+00
 0000651  0.6050E-05  0.1940E-05  0.6087E-05  0.3879E-07  0.0000E+00
 0000652  0.6021E-05  0.1923E-05  0.6067E-05  0.4309E-07  0.0000E+00
 0000653  0.6008E-05  0.1907E-05  0.6069E-05  0.3672E-07  0.0000E+00
 0000654  0.6021E-05  0.1894E-05  0.6107E-05  0.3923E-07  0.0000E+00
 0000655  0.6075E-05  0.1886E-05  0.6194E-05  0.1189E-06  0.0000E+00
 0000656  0.6228E-05  0.1909E-05  0.5763E-05  0.4394E-07  0.0000E+00
 0000657  0.5733E-05  0.1962E-05  0.5755E-05  0.4283E-07  0.0000E+00
 0000658  0.5694E-05  0.1812E-05  0.5723E-05  0.3399E-07  0.0000E+00
 0000659  0.5656E-05  0.1794E-05  0.5688E-05  0.3702E-07  0.0000E+00
 0000660  0.5623E-05  0.1778E-05  0.5663E-05  0.3223E-07  0.0000E+00
 0000661  0.5602E-05  0.1763E-05  0.5655E-05  0.3391E-07  0.0000E+00
 0000662  0.5599E-05  0.1750E-05  0.5674E-05  0.3040E-07  0.0000E+00
 0000663  0.5627E-05  0.1741E-05  0.5733E-05  0.3081E-07  0.0000E+00
 0000664  0.5696E-05  0.1739E-05  0.5843E-05  0.7588E-07  0.0000E+00
 0000665  0.5364E-05  0.1793E-05  0.5390E-05  0.7024E-07  0.0000E+00
 0000666  0.5320E-05  0.1838E-05  0.5346E-05  0.3854E-07  0.0000E+00
 0000667  0.5290E-05  0.1660E-05  0.5320E-05  0.4044E-07  0.0000E+00
 0000668  0.5258E-05  0.1644E-05  0.5291E-05  0.3338E-07  0.0000E+00
 0000669  0.5233E-05  0.1629E-05  0.5275E-05  0.3705E-07  0.0000E+00
 0000670  0.5222E-05  0.1616E-05  0.5278E-05  0.3153E-07  0.0000E+00
 0000671  0.5235E-05  0.1605E-05  0.5312E-05  0.3364E-07  0.0000E+00
 0000672  0.5283E-05  0.1598E-05  0.5388E-05  0.1034E-06  0.0000E+00
 0000673  0.5419E-05  0.1618E-05  0.5012E-05  0.3781E-07  0.0000E+00
 0000674  0.4986E-05  0.1663E-05  0.5007E-05  0.3702E-07  0.0000E+00
 0000675  0.4953E-05  0.1535E-05  0.4980E-05  0.2924E-07  0.0000E+00
 0000676  0.4920E-05  0.1520E-05  0.4950E-05  0.3200E-07  0.0000E+00
 0000677  0.4892E-05  0.1506E-05  0.4929E-05  0.2771E-07  0.0000E+00
 0000678  0.4875E-05  0.1494E-05  0.4922E-05  0.2926E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 17
 0000679  0.4873E-05  0.1483E-05  0.4940E-05  0.2610E-07  0.0000E+00
 0000680  0.4898E-05  0.1475E-05  0.4993E-05  0.2652E-07  0.0000E+00
 0000681  0.4960E-05  0.1474E-05  0.5090E-05  0.6589E-07  0.0000E+00
 0000682  0.4671E-05  0.1519E-05  0.4695E-05  0.6103E-07  0.0000E+00
 0000683  0.4633E-05  0.1558E-05  0.4657E-05  0.3321E-07  0.0000E+00
 0000684  0.4608E-05  0.1407E-05  0.4635E-05  0.3491E-07  0.0000E+00
 0000685  0.4580E-05  0.1393E-05  0.4611E-05  0.2878E-07  0.0000E+00
 0000686  0.4559E-05  0.1380E-05  0.4597E-05  0.3192E-07  0.0000E+00
 0000687  0.4551E-05  0.1369E-05  0.4600E-05  0.2712E-07  0.0000E+00
 0000688  0.4562E-05  0.1360E-05  0.4631E-05  0.2890E-07  0.0000E+00
 0000689  0.4605E-05  0.1354E-05  0.4698E-05  0.9008E-07  0.0000E+00
 0000690  0.4726E-05  0.1371E-05  0.4369E-05  0.3260E-07  0.0000E+00
 0000691  0.4347E-05  0.1409E-05  0.4367E-05  0.3206E-07  0.0000E+00
 0000692  0.4319E-05  0.1301E-05  0.4344E-05  0.2521E-07  0.0000E+00
 0000693  0.4291E-05  0.1288E-05  0.4318E-05  0.2772E-07  0.0000E+00
 0000694  0.4267E-05  0.1276E-05  0.4300E-05  0.2386E-07  0.0000E+00
 0000695  0.4252E-05  0.1265E-05  0.4295E-05  0.2530E-07  0.0000E+00
 0000696  0.4252E-05  0.1256E-05  0.4312E-05  0.2244E-07  0.0000E+00
 0000697  0.4274E-05  0.1250E-05  0.4359E-05  0.2287E-07  0.0000E+00
 0000698  0.4329E-05  0.1249E-05  0.4444E-05  0.5734E-07  0.0000E+00
 0000699  0.4077E-05  0.1288E-05  0.4099E-05  0.5314E-07  0.0000E+00
 0000700  0.4045E-05  0.1321E-05  0.4067E-05  0.2867E-07  0.0000E+00
 0000701  0.4023E-05  0.1192E-05  0.4048E-05  0.3019E-07  0.0000E+00
 0000702  0.3999E-05  0.1180E-05  0.4027E-05  0.2487E-07  0.0000E+00
 0000703  0.3981E-05  0.1169E-05  0.4016E-05  0.2756E-07  0.0000E+00
 0000704  0.3975E-05  0.1160E-05  0.4019E-05  0.2338E-07  0.0000E+00
 0000705  0.3986E-05  0.1152E-05  0.4047E-05  0.2487E-07  0.0000E+00
 0000706  0.4024E-05  0.1147E-05  0.4107E-05  0.7869E-07  0.0000E+00
 0000707  0.4131E-05  0.1161E-05  0.3818E-05  0.2816E-07  0.0000E+00
 0000708  0.3800E-05  0.1194E-05  0.3818E-05  0.2782E-07  0.0000E+00
 0000709  0.3775E-05  0.1102E-05  0.3798E-05  0.2177E-07  0.0000E+00
 0000710  0.3751E-05  0.1091E-05  0.3776E-05  0.2406E-07  0.0000E+00
 0000711  0.3731E-05  0.1081E-05  0.3761E-05  0.2059E-07  0.0000E+00
 0000712  0.3719E-05  0.1072E-05  0.3757E-05  0.2193E-07  0.0000E+00
 0000713  0.3719E-05  0.1064E-05  0.3773E-05  0.1933E-07  0.0000E+00
 0000714  0.3739E-05  0.1059E-05  0.3814E-05  0.1976E-07  0.0000E+00
 0000715  0.3788E-05  0.1058E-05  0.3890E-05  0.5001E-07  0.0000E+00
 0000716  0.3568E-05  0.1091E-05  0.3588E-05  0.4638E-07  0.0000E+00
 0000717  0.3540E-05  0.1119E-05  0.3561E-05  0.2480E-07  0.0000E+00
 0000718  0.3521E-05  0.1010E-05  0.3544E-05  0.2617E-07  0.0000E+00
 0000719  0.3501E-05  0.9994E-06  0.3526E-05  0.2153E-07  0.0000E+00
 0000720  0.3486E-05  0.9907E-06  0.3517E-05  0.2384E-07  0.0000E+00
 0000721  0.3481E-05  0.9824E-06  0.3521E-05  0.2019E-07  0.0000E+00
 0000722  0.3491E-05  0.9759E-06  0.3546E-05  0.2144E-07  0.0000E+00
 0000723  0.3525E-05  0.9717E-06  0.3599E-05  0.6891E-07  0.0000E+00
 0000724  0.3621E-05  0.9840E-06  0.3345E-05  0.2438E-07  0.0000E+00
 0000725  0.3329E-05  0.1012E-05  0.3346E-05  0.2420E-07  0.0000E+00
 0000726  0.3308E-05  0.9335E-06  0.3329E-05  0.1885E-07  0.0000E+00
 0000727  0.3288E-05  0.9241E-06  0.3310E-05  0.2094E-07  0.0000E+00
 0000728  0.3270E-05  0.9159E-06  0.3298E-05  0.1780E-07  0.0000E+00
 0000729  0.3260E-05  0.9081E-06  0.3295E-05  0.1904E-07  0.0000E+00
 0000730  0.3261E-05  0.9017E-06  0.3309E-05  0.1669E-07  0.0000E+00
 0000731  0.3279E-05  0.8971E-06  0.3346E-05  0.3506E-07  0.0000E+00
 0000732  0.3348E-05  0.9051E-06  0.3151E-05  0.4363E-07  0.0000E+00
 0000733  0.3131E-05  0.9248E-06  0.3147E-05  0.3940E-07  0.0000E+00
 0000734  0.3106E-05  0.9482E-06  0.3125E-05  0.2096E-07  0.0000E+00
 0000735  0.3090E-05  0.8551E-06  0.3110E-05  0.2209E-07  0.0000E+00
 0000736  0.3072E-05  0.8465E-06  0.3097E-05  0.1816E-07  0.0000E+00
 0000737  0.3059E-05  0.8390E-06  0.3091E-05  0.1996E-07  0.0000E+00
 0000738  0.3055E-05  0.8319E-06  0.3098E-05  0.1699E-07  0.0000E+00
 0000739  0.3064E-05  0.8262E-06  0.3125E-05  0.1775E-07  0.0000E+00
 0000740  0.3093E-05  0.8225E-06  0.3178E-05  0.5763E-07  0.0000E+00
 0000741  0.3181E-05  0.8335E-06  0.2937E-05  0.2134E-07  0.0000E+00
 0000742  0.2925E-05  0.8571E-06  0.2940E-05  0.2034E-07  0.0000E+00
 0000743  0.2906E-05  0.7907E-06  0.2925E-05  0.1557E-07  0.0000E+00
 0000744  0.2889E-05  0.7827E-06  0.2910E-05  0.1757E-07  0.0000E+00
 0000745  0.2873E-05  0.7757E-06  0.2901E-05  0.1482E-07  0.0000E+00
 0000746  0.2865E-05  0.7691E-06  0.2901E-05  0.1601E-07  0.0000E+00
 0000747  0.2866E-05  0.7635E-06  0.2916E-05  0.1400E-07  0.0000E+00
 0000748  0.2882E-05  0.7596E-06  0.2954E-05  0.3255E-07  0.0000E+00
 0000749  0.2945E-05  0.7667E-06  0.2771E-05  0.3715E-07  0.0000E+00
 0000750  0.2753E-05  0.7835E-06  0.2768E-05  0.3379E-07  0.0000E+00
 0000751  0.2732E-05  0.8034E-06  0.2749E-05  0.1797E-07  0.0000E+00
 0000752  0.2718E-05  0.7243E-06  0.2737E-05  0.1871E-07  0.0000E+00
 0000753  0.2702E-05  0.7169E-06  0.2727E-05  0.1554E-07  0.0000E+00
 0000754  0.2692E-05  0.7106E-06  0.2723E-05  0.1691E-07  0.0000E+00
 0000755  0.2688E-05  0.7045E-06  0.2732E-05  0.1448E-07  0.0000E+00
 0000756  0.2696E-05  0.6996E-06  0.2759E-05  0.1503E-07  0.0000E+00
 0000757  0.2722E-05  0.6963E-06  0.2810E-05  0.5056E-07  0.0000E+00
 0000758  0.2802E-05  0.7061E-06  0.2586E-05  0.1831E-07  0.0000E+00
 0000759  0.2575E-05  0.7262E-06  0.2589E-05  0.1761E-07  0.0000E+00
 0000760  0.2559E-05  0.6697E-06  0.2577E-05  0.1349E-07  0.0000E+00
 0000761  0.2544E-05  0.6630E-06  0.2564E-05  0.1521E-07  0.0000E+00
 0000762  0.2531E-05  0.6570E-06  0.2557E-05  0.1280E-07  0.0000E+00
 0000763  0.2524E-05  0.6513E-06  0.2559E-05  0.1384E-07  0.0000E+00
 0000764  0.2525E-05  0.6466E-06  0.2575E-05  0.1205E-07  0.0000E+00
 0000765  0.2539E-05  0.6432E-06  0.2611E-05  0.2925E-07  0.0000E+00
 0000766  0.2597E-05  0.6496E-06  0.2442E-05  0.3238E-07  0.0000E+00
 0000767  0.2427E-05  0.6638E-06  0.2440E-05  0.2946E-07  0.0000E+00
 0000768  0.2409E-05  0.6807E-06  0.2425E-05  0.1557E-07  0.0000E+00
 0000769  0.2397E-05  0.6135E-06  0.2415E-05  0.1621E-07  0.0000E+00
 0000770  0.2383E-05  0.6072E-06  0.2406E-05  0.1347E-07  0.0000E+00
 0000771  0.2374E-05  0.6018E-06  0.2404E-05  0.1461E-07  0.0000E+00
 0000772  0.2371E-05  0.5966E-06  0.2413E-05  0.1249E-07  0.0000E+00
 0000773  0.2379E-05  0.5924E-06  0.2439E-05  0.1290E-07  0.0000E+00
 0000774  0.2401E-05  0.5896E-06  0.2487E-05  0.4463E-07  0.0000E+00
 0000775  0.2474E-05  0.5981E-06  0.2282E-05  0.1598E-07  0.0000E+00
 0000776  0.2274E-05  0.6152E-06  0.2286E-05  0.1534E-07  0.0000E+00
 0000777  0.2259E-05  0.5672E-06  0.2276E-05  0.1170E-07  0.0000E+00
 0000778  0.2246E-05  0.5615E-06  0.2265E-05  0.1326E-07  0.0000E+00
 0000779  0.2235E-05  0.5565E-06  0.2260E-05  0.1108E-07  0.0000E+00
 0000780  0.2229E-05  0.5516E-06  0.2262E-05  0.1205E-07  0.0000E+00
 0000781  0.2230E-05  0.5476E-06  0.2278E-05  0.1042E-07  0.0000E+00
 0000782  0.2243E-05  0.5447E-06  0.2311E-05  0.2611E-07  0.0000E+00
 0000783  0.2295E-05  0.5503E-06  0.2158E-05  0.2842E-07  0.0000E+00
 0000784  0.2145E-05  0.5624E-06  0.2157E-05  0.2586E-07  0.0000E+00
 0000785  0.2129E-05  0.5768E-06  0.2144E-05  0.1354E-07  0.0000E+00
 0000786  0.2119E-05  0.5196E-06  0.2135E-05  0.1413E-07  0.0000E+00
 0000787  0.2107E-05  0.5143E-06  0.2128E-05  0.1173E-07  0.0000E+00
 0000788  0.2099E-05  0.5097E-06  0.2127E-05  0.1269E-07  0.0000E+00
 0000789  0.2097E-05  0.5053E-06  0.2136E-05  0.1082E-07  0.0000E+00
 0000790  0.2104E-05  0.5017E-06  0.2161E-05  0.1114E-07  0.0000E+00
 0000791  0.2124E-05  0.4993E-06  0.2205E-05  0.3952E-07  0.0000E+00
 0000792  0.2190E-05  0.5066E-06  0.2019E-05  0.1394E-07  0.0000E+00
 0000793  0.2012E-05  0.5211E-06  0.2023E-05  0.1343E-07  0.0000E+00
 0000794  0.1999E-05  0.4804E-06  0.2014E-05  0.1020E-07  0.0000E+00
 0000795  0.1988E-05  0.4756E-06  0.2005E-05  0.1161E-07  0.0000E+00
 0000796  0.1979E-05  0.4713E-06  0.2001E-05  0.9643E-08  0.0000E+00
 0000797  0.1974E-05  0.4672E-06  0.2004E-05  0.1054E-07  0.0000E+00
 0000798  0.1974E-05  0.4638E-06  0.2019E-05  0.9048E-08  0.0000E+00
 0000799  0.1986E-05  0.4613E-06  0.2050E-05  0.2324E-07  0.0000E+00
 0000800  0.2034E-05  0.4662E-06  0.1911E-05  0.2505E-07  0.0000E+00
 0000801  0.1901E-05  0.4765E-06  0.1911E-05  0.2279E-07  0.0000E+00
 0000802  0.1887E-05  0.4887E-06  0.1900E-05  0.1182E-07  0.0000E+00
 0000803  0.1877E-05  0.4401E-06  0.1892E-05  0.1236E-07  0.0000E+00
 0000804  0.1867E-05  0.4356E-06  0.1887E-05  0.1024E-07  0.0000E+00
 0000805  0.1861E-05  0.4317E-06  0.1886E-05  0.1108E-07  0.0000E+00
 0000806  0.1859E-05  0.4279E-06  0.1895E-05  0.9414E-08  0.0000E+00
 0000807  0.1865E-05  0.4249E-06  0.1918E-05  0.9669E-08  0.0000E+00
 0000808  0.1883E-05  0.4228E-06  0.1958E-05  0.3505E-07  0.0000E+00
 0000809  0.1943E-05  0.4291E-06  0.1790E-05  0.1220E-07  0.0000E+00
 0000810  0.1785E-05  0.4414E-06  0.1795E-05  0.1180E-07  0.0000E+00
 0000811  0.1774E-05  0.4069E-06  0.1787E-05  0.8910E-08  0.0000E+00
 0000812  0.1764E-05  0.4028E-06  0.1779E-05  0.1021E-07  0.0000E+00
 0000813  0.1756E-05  0.3992E-06  0.1776E-05  0.8413E-08  0.0000E+00
 0000814  0.1751E-05  0.3957E-06  0.1779E-05  0.9241E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 18
 0000815  0.1752E-05  0.3928E-06  0.1793E-05  0.7878E-08  0.0000E+00
 0000816  0.1763E-05  0.3907E-06  0.1821E-05  0.2065E-07  0.0000E+00
 0000817  0.1806E-05  0.3950E-06  0.1697E-05  0.2215E-07  0.0000E+00
 0000818  0.1688E-05  0.4037E-06  0.1697E-05  0.2014E-07  0.0000E+00
 0000819  0.1675E-05  0.4140E-06  0.1687E-05  0.1034E-07  0.0000E+00
 0000820  0.1667E-05  0.3728E-06  0.1681E-05  0.1085E-07  0.0000E+00
 0000821  0.1659E-05  0.3689E-06  0.1676E-05  0.8973E-08  0.0000E+00
 0000822  0.1653E-05  0.3657E-06  0.1676E-05  0.9695E-08  0.0000E+00
 0000823  0.1651E-05  0.3624E-06  0.1685E-05  0.8213E-08  0.0000E+00
 0000824  0.1657E-05  0.3599E-06  0.1705E-05  0.8418E-08  0.0000E+00
 0000825  0.1673E-05  0.3581E-06  0.1742E-05  0.1158E-07  0.0000E+00
 0000826  0.1596E-05  0.3669E-06  0.1607E-05  0.1083E-07  0.0000E+00
 0000827  0.1586E-05  0.3742E-06  0.1596E-05  0.7507E-08  0.0000E+00
 0000828  0.1577E-05  0.3446E-06  0.1589E-05  0.7629E-08  0.0000E+00
 0000829  0.1569E-05  0.3411E-06  0.1582E-05  0.6937E-08  0.0000E+00
 0000830  0.1562E-05  0.3380E-06  0.1579E-05  0.7335E-08  0.0000E+00
 0000831  0.1560E-05  0.3350E-06  0.1583E-05  0.6834E-08  0.0000E+00
 0000832  0.1563E-05  0.3323E-06  0.1595E-05  0.7172E-08  0.0000E+00
 0000833  0.1575E-05  0.3303E-06  0.1621E-05  0.2186E-07  0.0000E+00
 0000834  0.1618E-05  0.3336E-06  0.1508E-05  0.1126E-07  0.0000E+00
 0000835  0.1502E-05  0.3413E-06  0.1510E-05  0.1387E-07  0.0000E+00
 0000836  0.1491E-05  0.3500E-06  0.1502E-05  0.8056E-08  0.0000E+00
 0000837  0.1484E-05  0.3157E-06  0.1496E-05  0.7164E-08  0.0000E+00
 0000838  0.1477E-05  0.3124E-06  0.1492E-05  0.7094E-08  0.0000E+00
 0000839  0.1473E-05  0.3096E-06  0.1492E-05  0.6975E-08  0.0000E+00
 0000840  0.1473E-05  0.3069E-06  0.1500E-05  0.6761E-08  0.0000E+00
 0000841  0.1480E-05  0.3047E-06  0.1519E-05  0.1721E-07  0.0000E+00
 0000842  0.1511E-05  0.3061E-06  0.1430E-05  0.1065E-07  0.0000E+00
 0000843  0.1422E-05  0.3110E-06  0.1430E-05  0.1082E-07  0.0000E+00
 0000844  0.1412E-05  0.3170E-06  0.1422E-05  0.6243E-08  0.0000E+00
 0000845  0.1405E-05  0.2918E-06  0.1416E-05  0.6179E-08  0.0000E+00
 0000846  0.1398E-05  0.2889E-06  0.1411E-05  0.5854E-08  0.0000E+00
 0000847  0.1393E-05  0.2862E-06  0.1409E-05  0.6054E-08  0.0000E+00
 0000848  0.1391E-05  0.2836E-06  0.1414E-05  0.5841E-08  0.0000E+00
 0000849  0.1395E-05  0.2813E-06  0.1428E-05  0.6001E-08  0.0000E+00
 0000850  0.1407E-05  0.2794E-06  0.1454E-05  0.1902E-07  0.0000E+00
 0000851  0.1448E-05  0.2824E-06  0.1343E-05  0.1004E-07  0.0000E+00
 0000852  0.1339E-05  0.2891E-06  0.1346E-05  0.1187E-07  0.0000E+00
 0000853  0.1330E-05  0.2965E-06  0.1340E-05  0.6665E-08  0.0000E+00
 0000854  0.1324E-05  0.2673E-06  0.1334E-05  0.5804E-08  0.0000E+00
 0000855  0.1318E-05  0.2646E-06  0.1332E-05  0.5863E-08  0.0000E+00
 0000856  0.1314E-05  0.2622E-06  0.1333E-05  0.5700E-08  0.0000E+00
 0000857  0.1315E-05  0.2598E-06  0.1342E-05  0.5624E-08  0.0000E+00
 0000858  0.1322E-05  0.2578E-06  0.1361E-05  0.1703E-07  0.0000E+00
 0000859  0.1352E-05  0.2592E-06  0.1276E-05  0.8550E-08  0.0000E+00
 0000860  0.1269E-05  0.2634E-06  0.1276E-05  0.9154E-08  0.0000E+00
 0000861  0.1261E-05  0.2685E-06  0.1269E-05  0.5499E-08  0.0000E+00
 0000862  0.1254E-05  0.2471E-06  0.1264E-05  0.5399E-08  0.0000E+00
 0000863  0.1248E-05  0.2446E-06  0.1260E-05  0.5132E-08  0.0000E+00
 0000864  0.1244E-05  0.2423E-06  0.1259E-05  0.5271E-08  0.0000E+00
 0000865  0.1242E-05  0.2401E-06  0.1265E-05  0.5076E-08  0.0000E+00
 0000866  0.1246E-05  0.2381E-06  0.1279E-05  0.5205E-08  0.0000E+00
 0000867  0.1258E-05  0.2365E-06  0.1304E-05  0.1684E-07  0.0000E+00
 0000868  0.1297E-05  0.2392E-06  0.1199E-05  0.9604E-08  0.0000E+00
 0000869  0.1196E-05  0.2449E-06  0.1203E-05  0.1095E-07  0.0000E+00
 0000870  0.1188E-05  0.2513E-06  0.1197E-05  0.5800E-08  0.0000E+00
 0000871  0.1183E-05  0.2264E-06  0.1193E-05  0.5044E-08  0.0000E+00
 0000872  0.1178E-05  0.2240E-06  0.1191E-05  0.5098E-08  0.0000E+00
 0000873  0.1175E-05  0.2220E-06  0.1193E-05  0.4946E-08  0.0000E+00
 0000874  0.1176E-05  0.2199E-06  0.1202E-05  0.4866E-08  0.0000E+00
 0000875  0.1183E-05  0.2182E-06  0.1220E-05  0.1590E-07  0.0000E+00
 0000876  0.1211E-05  0.2194E-06  0.1140E-05  0.7266E-08  0.0000E+00
 0000877  0.1135E-05  0.2231E-06  0.1141E-05  0.7940E-08  0.0000E+00
 0000878  0.1127E-05  0.2275E-06  0.1135E-05  0.4866E-08  0.0000E+00
 0000879  0.1122E-05  0.2093E-06  0.1130E-05  0.4842E-08  0.0000E+00
 0000880  0.1116E-05  0.2072E-06  0.1127E-05  0.4538E-08  0.0000E+00
 0000881  0.1113E-05  0.2052E-06  0.1127E-05  0.4687E-08  0.0000E+00
 0000882  0.1112E-05  0.2033E-06  0.1133E-05  0.4467E-08  0.0000E+00
 0000883  0.1116E-05  0.2016E-06  0.1146E-05  0.4601E-08  0.0000E+00
 0000884  0.1127E-05  0.2002E-06  0.1170E-05  0.1505E-07  0.0000E+00
 0000885  0.1163E-05  0.2026E-06  0.1072E-05  0.8973E-08  0.0000E+00
 0000886  0.1071E-05  0.2075E-06  0.1076E-05  0.1010E-07  0.0000E+00
 0000887  0.1064E-05  0.2129E-06  0.1071E-05  0.5154E-08  0.0000E+00
 0000888  0.1059E-05  0.1917E-06  0.1068E-05  0.4444E-08  0.0000E+00
 0000889  0.1054E-05  0.1897E-06  0.1066E-05  0.4523E-08  0.0000E+00
 0000890  0.1052E-05  0.1880E-06  0.1068E-05  0.4342E-08  0.0000E+00
 0000891  0.1053E-05  0.1862E-06  0.1077E-05  0.4281E-08  0.0000E+00
 0000892  0.1059E-05  0.1847E-06  0.1094E-05  0.1460E-07  0.0000E+00
 0000893  0.1086E-05  0.1858E-06  0.1021E-05  0.6301E-08  0.0000E+00
 0000894  0.1016E-05  0.1890E-06  0.1022E-05  0.6948E-08  0.0000E+00
 0000895  0.1010E-05  0.1927E-06  0.1017E-05  0.4307E-08  0.0000E+00
 0000896  0.1005E-05  0.1773E-06  0.1013E-05  0.4361E-08  0.0000E+00
 0000897  0.1000E-05  0.1754E-06  0.1010E-05  0.4015E-08  0.0000E+00
 0000898  0.9971E-06  0.1738E-06  0.1011E-05  0.4185E-08  0.0000E+00
 0000899  0.9964E-06  0.1722E-06  0.1016E-05  0.3938E-08  0.0000E+00
 0000900  0.1000E-05  0.1707E-06  0.1029E-05  0.4083E-08  0.0000E+00
 0000901  0.1010E-05  0.1695E-06  0.1051E-05  0.1348E-07  0.0000E+00
 0000902  0.1044E-05  0.1716E-06  0.9608E-06  0.8269E-08  0.0000E+00
 0000903  0.9598E-06  0.1759E-06  0.9649E-06  0.9248E-08  0.0000E+00
 0000904  0.9535E-06  0.1804E-06  0.9605E-06  0.4604E-08  0.0000E+00
 0000905  0.9494E-06  0.1624E-06  0.9574E-06  0.3946E-08  0.0000E+00
 0000906  0.9454E-06  0.1607E-06  0.9563E-06  0.4032E-08  0.0000E+00
 0000907  0.9435E-06  0.1592E-06  0.9586E-06  0.3833E-08  0.0000E+00
 0000908  0.9445E-06  0.1577E-06  0.9669E-06  0.3782E-08  0.0000E+00
 0000909  0.9506E-06  0.1564E-06  0.9829E-06  0.1329E-07  0.0000E+00
 0000910  0.9751E-06  0.1574E-06  0.9151E-06  0.5529E-08  0.0000E+00
 0000911  0.9119E-06  0.1601E-06  0.9166E-06  0.6114E-08  0.0000E+00
 0000912  0.9060E-06  0.1632E-06  0.9122E-06  0.3822E-08  0.0000E+00
 0000913  0.9017E-06  0.1501E-06  0.9086E-06  0.3937E-08  0.0000E+00
 0000914  0.8975E-06  0.1486E-06  0.9065E-06  0.3560E-08  0.0000E+00
 0000915  0.8948E-06  0.1472E-06  0.9071E-06  0.3744E-08  0.0000E+00
 0000916  0.8944E-06  0.1458E-06  0.9123E-06  0.3479E-08  0.0000E+00
 0000917  0.8979E-06  0.1446E-06  0.9241E-06  0.9970E-08  0.0000E+00
 0000918  0.9162E-06  0.1450E-06  0.8710E-06  0.9224E-08  0.0000E+00
 0000919  0.9384E-06  0.1456E-06  0.8618E-06  0.9266E-08  0.0000E+00
 0000920  0.8616E-06  0.1491E-06  0.8662E-06  0.4096E-08  0.0000E+00
 0000921  0.8566E-06  0.1388E-06  0.8629E-06  0.3589E-08  0.0000E+00
 0000922  0.8524E-06  0.1374E-06  0.8602E-06  0.3755E-08  0.0000E+00
 0000923  0.8489E-06  0.1362E-06  0.8598E-06  0.3422E-08  0.0000E+00
 0000924  0.8472E-06  0.1349E-06  0.8630E-06  0.3543E-08  0.0000E+00
 0000925  0.8480E-06  0.1338E-06  0.8719E-06  0.3240E-08  0.0000E+00
 0000926  0.8533E-06  0.1329E-06  0.8884E-06  0.9504E-08  0.0000E+00
 0000927  0.8765E-06  0.1343E-06  0.8218E-06  0.1012E-07  0.0000E+00
 0000928  0.8192E-06  0.1368E-06  0.8234E-06  0.9230E-08  0.0000E+00
 0000929  0.8140E-06  0.1398E-06  0.8196E-06  0.4322E-08  0.0000E+00
 0000930  0.8101E-06  0.1272E-06  0.8166E-06  0.4745E-08  0.0000E+00
 0000931  0.8064E-06  0.1259E-06  0.8153E-06  0.3906E-08  0.0000E+00
 0000932  0.8040E-06  0.1247E-06  0.8165E-06  0.4260E-08  0.0000E+00
 0000933  0.8035E-06  0.1235E-06  0.8223E-06  0.3556E-08  0.0000E+00
 0000934  0.8066E-06  0.1225E-06  0.8344E-06  0.1170E-07  0.0000E+00
 0000935  0.8238E-06  0.1229E-06  0.7827E-06  0.1175E-07  0.0000E+00
 0000936  0.8440E-06  0.1234E-06  0.7745E-06  0.6060E-08  0.0000E+00
 0000937  0.7746E-06  0.1266E-06  0.7788E-06  0.4770E-08  0.0000E+00
 0000938  0.7701E-06  0.1176E-06  0.7760E-06  0.4748E-08  0.0000E+00
 0000939  0.7664E-06  0.1164E-06  0.7738E-06  0.4310E-08  0.0000E+00
 0000940  0.7632E-06  0.1154E-06  0.7740E-06  0.4277E-08  0.0000E+00
 0000941  0.7616E-06  0.1144E-06  0.7775E-06  0.3895E-08  0.0000E+00
 0000942  0.7623E-06  0.1136E-06  0.7866E-06  0.3702E-08  0.0000E+00
 0000943  0.7669E-06  0.1131E-06  0.8027E-06  0.9073E-08  0.0000E+00
 0000944  0.7885E-06  0.1146E-06  0.7390E-06  0.1202E-07  0.0000E+00
 0000945  0.7369E-06  0.1170E-06  0.7406E-06  0.3184E-08  0.0000E+00
 0000946  0.7325E-06  0.1088E-06  0.7376E-06  0.4493E-08  0.0000E+00
 0000947  0.7288E-06  0.1076E-06  0.7349E-06  0.3015E-08  0.0000E+00
 0000948  0.7254E-06  0.1066E-06  0.7339E-06  0.3952E-08  0.0000E+00
 0000949  0.7233E-06  0.1056E-06  0.7354E-06  0.2889E-08  0.0000E+00
 0000950  0.7229E-06  0.1047E-06  0.7413E-06  0.3414E-08  0.0000E+00
 0000951  0.7257E-06  0.1039E-06  0.7531E-06  0.9865E-08  0.0000E+00
 0000952  0.7417E-06  0.1045E-06  0.7043E-06  0.8863E-08  0.0000E+00
 0000953  0.7600E-06  0.1052E-06  0.6968E-06  0.6094E-08  0.0000E+00
 0000954  0.6972E-06  0.1082E-06  0.7009E-06  0.3993E-08  0.0000E+00
 0000955  0.6932E-06  0.9962E-07  0.6986E-06  0.3230E-08  0.0000E+00
 0000956  0.6899E-06  0.9861E-07  0.6968E-06  0.3532E-08  0.0000E+00
 0000957  0.6871E-06  0.9774E-07  0.6973E-06  0.3007E-08  0.0000E+00
 0000958  0.6856E-06  0.9691E-07  0.7010E-06  0.3178E-08  0.0000E+00
 0000959  0.6862E-06  0.9626E-07  0.7098E-06  0.2726E-08  0.0000E+00
 0000960  0.6904E-06  0.9586E-07  0.7251E-06  0.8003E-08  0.0000E+00
 0000961  0.7103E-06  0.9728E-07  0.6653E-06  0.9751E-08  0.0000E+00
 0000962  0.6637E-06  0.9947E-07  0.6669E-06  0.2721E-08  0.0000E+00
 0000963  0.6597E-06  0.9213E-07  0.6643E-06  0.3465E-08  0.0000E+00
 0000964  0.6564E-06  0.9119E-07  0.6620E-06  0.2572E-08  0.0000E+00
 0000965  0.6534E-06  0.9035E-07  0.6613E-06  0.3099E-08  0.0000E+00
 0000966  0.6516E-06  0.8951E-07  0.6630E-06  0.2479E-08  0.0000E+00
 0000967  0.6512E-06  0.8875E-07  0.6687E-06  0.2739E-08  0.0000E+00
 0000968  0.6537E-06  0.8811E-07  0.6799E-06  0.8606E-08  0.0000E+00
 0000969  0.6685E-06  0.8879E-07  0.6344E-06  0.3530E-08  0.0000E+00
 0000970  0.6319E-06  0.9028E-07  0.6349E-06  0.3947E-08  0.0000E+00
 0000971  0.6279E-06  0.9223E-07  0.6319E-06  0.2534E-08  0.0000E+00
 0000972  0.6248E-06  0.8438E-07  0.6295E-06  0.2492E-08  0.0000E+00
 0000973  0.6218E-06  0.8352E-07  0.6282E-06  0.2365E-08  0.0000E+00
 0000974  0.6197E-06  0.8276E-07  0.6287E-06  0.2406E-08  0.0000E+00
 0000975  0.6187E-06  0.8202E-07  0.6324E-06  0.2292E-08  0.0000E+00
 0000976  0.6201E-06  0.8138E-07  0.6407E-06  0.2366E-08  0.0000E+00
 0000977  0.6248E-06  0.8090E-07  0.6549E-06  0.8120E-08  0.0000E+00
 0000978  0.6445E-06  0.8204E-07  0.5991E-06  0.4632E-08  0.0000E+00
 0000979  0.5984E-06  0.8405E-07  0.6012E-06  0.2560E-08  0.0000E+00
 0000980  0.5948E-06  0.7804E-07  0.5989E-06  0.2479E-08  0.0000E+00
 0000981  0.5920E-06  0.7725E-07  0.5969E-06  0.2356E-08  0.0000E+00
 0000982  0.5895E-06  0.7655E-07  0.5964E-06  0.2301E-08  0.0000E+00
 0000983  0.5881E-06  0.7586E-07  0.5981E-06  0.2257E-08  0.0000E+00
 0000984  0.5882E-06  0.7527E-07  0.6035E-06  0.2149E-08  0.0000E+00
 0000985  0.5911E-06  0.7480E-07  0.6139E-06  0.7012E-08  0.0000E+00
 0000986  0.6056E-06  0.7555E-07  0.5717E-06  0.5073E-08  0.0000E+00
 0000987  0.5699E-06  0.7701E-07  0.5725E-06  0.4914E-08  0.0000E+00
 0000988  0.5664E-06  0.7879E-07  0.5700E-06  0.2419E-08  0.0000E+00
 0000989  0.5637E-06  0.7149E-07  0.5678E-06  0.2354E-08  0.0000E+00
 0000990  0.5611E-06  0.7076E-07  0.5668E-06  0.2233E-08  0.0000E+00
 0000991  0.5594E-06  0.7012E-07  0.5673E-06  0.2237E-08  0.0000E+00
 0000992  0.5588E-06  0.6949E-07  0.5709E-06  0.2114E-08  0.0000E+00
 0000993  0.5605E-06  0.6896E-07  0.5786E-06  0.6608E-08  0.0000E+00
 0000994  0.5714E-06  0.6924E-07  0.5454E-06  0.6574E-08  0.0000E+00
 0000995  0.5845E-06  0.6963E-07  0.5398E-06  0.4493E-08  0.0000E+00
 0000996  0.5400E-06  0.7139E-07  0.5425E-06  0.2788E-08  0.0000E+00
 0000997  0.5369E-06  0.6612E-07  0.5406E-06  0.2394E-08  0.0000E+00
 0000998  0.5343E-06  0.6546E-07  0.5390E-06  0.2545E-08  0.0000E+00
 0000999  0.5321E-06  0.6488E-07  0.5390E-06  0.2270E-08  0.0000E+00
 0001000  0.5309E-06  0.6434E-07  0.5412E-06  0.2351E-08  0.0000E+00
 0001001  0.5312E-06  0.6393E-07  0.5471E-06  0.2105E-08  0.0000E+00
 0001002  0.5340E-06  0.6369E-07  0.5577E-06  0.5746E-08  0.0000E+00
 0001003  0.5483E-06  0.6457E-07  0.5158E-06  0.7048E-08  0.0000E+00
 0001004  0.5145E-06  0.6591E-07  0.5168E-06  0.1984E-08  0.0000E+00
 0001005  0.5115E-06  0.6115E-07  0.5147E-06  0.2608E-08  0.0000E+00
 0001006  0.5090E-06  0.6053E-07  0.5128E-06  0.1905E-08  0.0000E+00
 0001007  0.5067E-06  0.5997E-07  0.5121E-06  0.2343E-08  0.0000E+00
 0001008  0.5052E-06  0.5941E-07  0.5131E-06  0.1851E-08  0.0000E+00
 0001009  0.5048E-06  0.5891E-07  0.5169E-06  0.2086E-08  0.0000E+00
 0001010  0.5065E-06  0.5848E-07  0.5248E-06  0.6333E-08  0.0000E+00
 0001011  0.5172E-06  0.5886E-07  0.4922E-06  0.5693E-08  0.0000E+00
 0001012  0.5295E-06  0.5936E-07  0.4872E-06  0.4384E-08  0.0000E+00
 0001013  0.4877E-06  0.6104E-07  0.4900E-06  0.2492E-08  0.0000E+00
 0001014  0.4849E-06  0.5602E-07  0.4883E-06  0.2059E-08  0.0000E+00
 0001015  0.4827E-06  0.5546E-07  0.4871E-06  0.2234E-08  0.0000E+00
 0001016  0.4807E-06  0.5498E-07  0.4874E-06  0.1936E-08  0.0000E+00
 0001017  0.4797E-06  0.5453E-07  0.4898E-06  0.2042E-08  0.0000E+00
 0001018  0.4800E-06  0.5420E-07  0.4958E-06  0.1787E-08  0.0000E+00
 0001019  0.4828E-06  0.5402E-07  0.5062E-06  0.5344E-08  0.0000E+00
 0001020  0.4964E-06  0.5488E-07  0.4658E-06  0.6126E-08  0.0000E+00
 0001021  0.4649E-06  0.5612E-07  0.4669E-06  0.1761E-08  0.0000E+00
 0001022  0.4622E-06  0.5182E-07  0.4651E-06  0.2196E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 19
 0001023  0.4599E-06  0.5129E-07  0.4635E-06  0.1688E-08  0.0000E+00
 0001024  0.4579E-06  0.5082E-07  0.4630E-06  0.1988E-08  0.0000E+00
 0001025  0.4566E-06  0.5036E-07  0.4642E-06  0.1641E-08  0.0000E+00
 0001026  0.4563E-06  0.4994E-07  0.4681E-06  0.1785E-08  0.0000E+00
 0001027  0.4580E-06  0.4960E-07  0.4757E-06  0.5708E-08  0.0000E+00
 0001028  0.4681E-06  0.5000E-07  0.4447E-06  0.5162E-08  0.0000E+00
 0001029  0.4796E-06  0.5051E-07  0.4401E-06  0.4097E-08  0.0000E+00
 0001030  0.4408E-06  0.5203E-07  0.4428E-06  0.2203E-08  0.0000E+00
 0001031  0.4383E-06  0.4748E-07  0.4414E-06  0.1831E-08  0.0000E+00
 0001032  0.4363E-06  0.4701E-07  0.4404E-06  0.1976E-08  0.0000E+00
 0001033  0.4346E-06  0.4661E-07  0.4409E-06  0.1723E-08  0.0000E+00
 0001034  0.4337E-06  0.4623E-07  0.4434E-06  0.1813E-08  0.0000E+00
 0001035  0.4341E-06  0.4597E-07  0.4492E-06  0.1594E-08  0.0000E+00
 0001036  0.4366E-06  0.4585E-07  0.4591E-06  0.4936E-08  0.0000E+00
 0001037  0.4494E-06  0.4664E-07  0.4210E-06  0.5431E-08  0.0000E+00
 0001038  0.4204E-06  0.4775E-07  0.4221E-06  0.1573E-08  0.0000E+00
 0001039  0.4179E-06  0.4392E-07  0.4205E-06  0.1950E-08  0.0000E+00
 0001040  0.4159E-06  0.4347E-07  0.4192E-06  0.1507E-08  0.0000E+00
 0001041  0.4141E-06  0.4308E-07  0.4189E-06  0.1766E-08  0.0000E+00
 0001042  0.4129E-06  0.4269E-07  0.4200E-06  0.1467E-08  0.0000E+00
 0001043  0.4127E-06  0.4234E-07  0.4238E-06  0.1587E-08  0.0000E+00
 0001044  0.4143E-06  0.4206E-07  0.4311E-06  0.5196E-08  0.0000E+00
 0001045  0.4238E-06  0.4245E-07  0.4021E-06  0.4677E-08  0.0000E+00
 0001046  0.4344E-06  0.4293E-07  0.3979E-06  0.3768E-08  0.0000E+00
 0001047  0.3987E-06  0.4427E-07  0.4005E-06  0.1973E-08  0.0000E+00
 0001048  0.3965E-06  0.4025E-07  0.3993E-06  0.1649E-08  0.0000E+00
 0001049  0.3947E-06  0.3985E-07  0.3985E-06  0.1769E-08  0.0000E+00
 0001050  0.3931E-06  0.3951E-07  0.3990E-06  0.1548E-08  0.0000E+00
 0001051  0.3924E-06  0.3920E-07  0.4014E-06  0.1622E-08  0.0000E+00
 0001052  0.3927E-06  0.3899E-07  0.4070E-06  0.1429E-08  0.0000E+00
 0001053  0.3951E-06  0.3891E-07  0.4162E-06  0.4520E-08  0.0000E+00
 0001054  0.4070E-06  0.3963E-07  0.3807E-06  0.4869E-08  0.0000E+00
 0001055  0.3803E-06  0.4060E-07  0.3819E-06  0.1411E-08  0.0000E+00
 0001056  0.3781E-06  0.3723E-07  0.3805E-06  0.1742E-08  0.0000E+00
 0001057  0.3763E-06  0.3685E-07  0.3793E-06  0.1352E-08  0.0000E+00
 0001058  0.3747E-06  0.3652E-07  0.3791E-06  0.1577E-08  0.0000E+00
 0001059  0.3737E-06  0.3619E-07  0.3803E-06  0.1317E-08  0.0000E+00
 0001060  0.3735E-06  0.3590E-07  0.3839E-06  0.1418E-08  0.0000E+00
 0001061  0.3750E-06  0.3567E-07  0.3906E-06  0.4715E-08  0.0000E+00
 0001062  0.3838E-06  0.3602E-07  0.3638E-06  0.2128E-08  0.0000E+00
 0001063  0.3628E-06  0.3668E-07  0.3642E-06  0.2348E-08  0.0000E+00
 0001064  0.3607E-06  0.3753E-07  0.3627E-06  0.1365E-08  0.0000E+00
 0001065  0.3589E-06  0.3411E-07  0.3613E-06  0.1306E-08  0.0000E+00
 0001066  0.3573E-06  0.3377E-07  0.3607E-06  0.1285E-08  0.0000E+00
 0001067  0.3561E-06  0.3347E-07  0.3612E-06  0.1272E-08  0.0000E+00
 0001068  0.3556E-06  0.3317E-07  0.3636E-06  0.1239E-08  0.0000E+00
 0001069  0.3564E-06  0.3293E-07  0.3686E-06  0.3851E-08  0.0000E+00
 0001070  0.3631E-06  0.3310E-07  0.3475E-06  0.3609E-08  0.0000E+00
 0001071  0.3710E-06  0.3335E-07  0.3440E-06  0.3099E-08  0.0000E+00
 0001072  0.3443E-06  0.3417E-07  0.3457E-06  0.1551E-08  0.0000E+00
 0001073  0.3424E-06  0.3156E-07  0.3445E-06  0.1312E-08  0.0000E+00
 0001074  0.3407E-06  0.3125E-07  0.3436E-06  0.1436E-08  0.0000E+00
 0001075  0.3393E-06  0.3098E-07  0.3436E-06  0.1265E-08  0.0000E+00
 0001076  0.3385E-06  0.3073E-07  0.3451E-06  0.1350E-08  0.0000E+00
 0001077  0.3385E-06  0.3054E-07  0.3490E-06  0.1204E-08  0.0000E+00
 0001078  0.3401E-06  0.3044E-07  0.3559E-06  0.3604E-08  0.0000E+00
 0001079  0.3490E-06  0.3089E-07  0.3291E-06  0.3839E-08  0.0000E+00
 0001080  0.3285E-06  0.3152E-07  0.3297E-06  0.1175E-08  0.0000E+00
 0001081  0.3266E-06  0.2920E-07  0.3285E-06  0.1427E-08  0.0000E+00
 0001082  0.3250E-06  0.2890E-07  0.3273E-06  0.1143E-08  0.0000E+00
 0001083  0.3236E-06  0.2864E-07  0.3269E-06  0.1313E-08  0.0000E+00
 0001084  0.3226E-06  0.2837E-07  0.3276E-06  0.1118E-08  0.0000E+00
 0001085  0.3223E-06  0.2814E-07  0.3302E-06  0.1202E-08  0.0000E+00
 0001086  0.3232E-06  0.2793E-07  0.3353E-06  0.3784E-08  0.0000E+00
 0001087  0.3300E-06  0.2814E-07  0.3145E-06  0.3421E-08  0.0000E+00
 0001088  0.3377E-06  0.2842E-07  0.3113E-06  0.2864E-08  0.0000E+00
 0001089  0.3118E-06  0.2921E-07  0.3131E-06  0.1438E-08  0.0000E+00
 0001090  0.3101E-06  0.2676E-07  0.3120E-06  0.1231E-08  0.0000E+00
 0001091  0.3087E-06  0.2650E-07  0.3113E-06  0.1312E-08  0.0000E+00
 0001092  0.3074E-06  0.2627E-07  0.3116E-06  0.1165E-08  0.0000E+00
 0001093  0.3067E-06  0.2607E-07  0.3132E-06  0.1219E-08  0.0000E+00
 0001094  0.3069E-06  0.2593E-07  0.3171E-06  0.1087E-08  0.0000E+00
 0001095  0.3085E-06  0.2587E-07  0.3239E-06  0.3364E-08  0.0000E+00
 0001096  0.3172E-06  0.2632E-07  0.2979E-06  0.3542E-08  0.0000E+00
 0001097  0.2976E-06  0.2690E-07  0.2987E-06  0.1062E-08  0.0000E+00
 0001098  0.2959E-06  0.2476E-07  0.2976E-06  0.1288E-08  0.0000E+00
 0001099  0.2945E-06  0.2451E-07  0.2966E-06  0.1031E-08  0.0000E+00
 0001100  0.2932E-06  0.2429E-07  0.2963E-06  0.1181E-08  0.0000E+00
 0001101  0.2924E-06  0.2407E-07  0.2971E-06  0.1008E-08  0.0000E+00
 0001102  0.2922E-06  0.2387E-07  0.2997E-06  0.1075E-08  0.0000E+00
 0001103  0.2931E-06  0.2371E-07  0.3047E-06  0.3504E-08  0.0000E+00
 0001104  0.2997E-06  0.2391E-07  0.2848E-06  0.3164E-08  0.0000E+00
 0001105  0.3070E-06  0.2419E-07  0.2818E-06  0.2637E-08  0.0000E+00
 0001106  0.2826E-06  0.2489E-07  0.2837E-06  0.1317E-08  0.0000E+00
 0001107  0.2810E-06  0.2270E-07  0.2828E-06  0.1115E-08  0.0000E+00
 0001108  0.2797E-06  0.2248E-07  0.2822E-06  0.1198E-08  0.0000E+00
 0001109  0.2786E-06  0.2229E-07  0.2825E-06  0.1054E-08  0.0000E+00
 0001110  0.2780E-06  0.2212E-07  0.2842E-06  0.1109E-08  0.0000E+00
 0001111  0.2782E-06  0.2202E-07  0.2880E-06  0.9822E-09  0.0000E+00
 0001112  0.2798E-06  0.2199E-07  0.2945E-06  0.3112E-08  0.0000E+00
 0001113  0.2881E-06  0.2241E-07  0.2699E-06  0.3257E-08  0.0000E+00
 0001114  0.2697E-06  0.2293E-07  0.2706E-06  0.9630E-09  0.0000E+00
 0001115  0.2682E-06  0.2101E-07  0.2697E-06  0.1174E-08  0.0000E+00
 0001116  0.2669E-06  0.2080E-07  0.2688E-06  0.9325E-09  0.0000E+00
 0001117  0.2658E-06  0.2061E-07  0.2687E-06  0.1072E-08  0.0000E+00
 0001118  0.2650E-06  0.2042E-07  0.2695E-06  0.9112E-09  0.0000E+00
 0001119  0.2649E-06  0.2025E-07  0.2720E-06  0.9719E-09  0.0000E+00
 0001120  0.2659E-06  0.2012E-07  0.2768E-06  0.3227E-08  0.0000E+00
 0001121  0.2720E-06  0.2031E-07  0.2580E-06  0.2901E-08  0.0000E+00
 0001122  0.2788E-06  0.2056E-07  0.2553E-06  0.2417E-08  0.0000E+00
 0001123  0.2561E-06  0.2117E-07  0.2571E-06  0.1201E-08  0.0000E+00
 0001124  0.2547E-06  0.1926E-07  0.2563E-06  0.1015E-08  0.0000E+00
 0001125  0.2536E-06  0.1907E-07  0.2558E-06  0.1090E-08  0.0000E+00
 0001126  0.2526E-06  0.1892E-07  0.2562E-06  0.9569E-09  0.0000E+00
 0001127  0.2521E-06  0.1878E-07  0.2579E-06  0.1006E-08  0.0000E+00
 0001128  0.2523E-06  0.1870E-07  0.2615E-06  0.8886E-09  0.0000E+00
 0001129  0.2538E-06  0.1869E-07  0.2675E-06  0.2855E-08  0.0000E+00
 0001130  0.2615E-06  0.1908E-07  0.2446E-06  0.2975E-08  0.0000E+00
 0001131  0.2445E-06  0.1952E-07  0.2453E-06  0.8717E-09  0.0000E+00
 0001132  0.2431E-06  0.1783E-07  0.2445E-06  0.1065E-08  0.0000E+00
 0001133  0.2420E-06  0.1765E-07  0.2437E-06  0.8434E-09  0.0000E+00
 0001134  0.2410E-06  0.1749E-07  0.2436E-06  0.9700E-09  0.0000E+00
 0001135  0.2403E-06  0.1733E-07  0.2445E-06  0.8237E-09  0.0000E+00
 0001136  0.2402E-06  0.1719E-07  0.2468E-06  0.8776E-09  0.0000E+00
 0001137  0.2412E-06  0.1707E-07  0.2513E-06  0.2949E-08  0.0000E+00
 0001138  0.2469E-06  0.1724E-07  0.2339E-06  0.1374E-08  0.0000E+00
 0001139  0.2335E-06  0.1754E-07  0.2342E-06  0.1511E-08  0.0000E+00
 0001140  0.2321E-06  0.1791E-07  0.2332E-06  0.8448E-09  0.0000E+00
 0001141  0.2310E-06  0.1634E-07  0.2324E-06  0.8058E-09  0.0000E+00
 0001142  0.2300E-06  0.1618E-07  0.2321E-06  0.8043E-09  0.0000E+00
 0001143  0.2292E-06  0.1604E-07  0.2324E-06  0.7880E-09  0.0000E+00
 0001144  0.2289E-06  0.1589E-07  0.2340E-06  0.7742E-09  0.0000E+00
 0001145  0.2295E-06  0.1578E-07  0.2373E-06  0.2453E-08  0.0000E+00
 0001146  0.2338E-06  0.1586E-07  0.2236E-06  0.2302E-08  0.0000E+00
 0001147  0.2389E-06  0.1599E-07  0.2214E-06  0.1941E-08  0.0000E+00
 0001148  0.2218E-06  0.1636E-07  0.2225E-06  0.9865E-09  0.0000E+00
 0001149  0.2205E-06  0.1513E-07  0.2217E-06  0.8266E-09  0.0000E+00
 0001150  0.2195E-06  0.1499E-07  0.2212E-06  0.9148E-09  0.0000E+00
 0001151  0.2186E-06  0.1486E-07  0.2213E-06  0.7978E-09  0.0000E+00
 0001152  0.2181E-06  0.1475E-07  0.2223E-06  0.8580E-09  0.0000E+00
 0001153  0.2181E-06  0.1469E-07  0.2248E-06  0.7603E-09  0.0000E+00
 0001154  0.2192E-06  0.1467E-07  0.2294E-06  0.2275E-08  0.0000E+00
 0001155  0.2250E-06  0.1493E-07  0.2119E-06  0.2442E-08  0.0000E+00
 0001156  0.2118E-06  0.1522E-07  0.2124E-06  0.7414E-09  0.0000E+00
 0001157  0.2105E-06  0.1401E-07  0.2116E-06  0.9042E-09  0.0000E+00
 0001158  0.2095E-06  0.1387E-07  0.2109E-06  0.7238E-09  0.0000E+00
 0001159  0.2086E-06  0.1374E-07  0.2107E-06  0.8306E-09  0.0000E+00
 0001160  0.2080E-06  0.1362E-07  0.2111E-06  0.7083E-09  0.0000E+00
 0001161  0.2078E-06  0.1350E-07  0.2128E-06  0.7591E-09  0.0000E+00
 0001162  0.2084E-06  0.1340E-07  0.2162E-06  0.2403E-08  0.0000E+00
 0001163  0.2128E-06  0.1350E-07  0.2027E-06  0.2168E-08  0.0000E+00
 0001164  0.2178E-06  0.1365E-07  0.2006E-06  0.1820E-08  0.0000E+00
 0001165  0.2012E-06  0.1400E-07  0.2018E-06  0.9115E-09  0.0000E+00
 0001166  0.2000E-06  0.1285E-07  0.2012E-06  0.7787E-09  0.0000E+00
 0001167  0.1991E-06  0.1273E-07  0.2007E-06  0.8350E-09  0.0000E+00
 0001168  0.1984E-06  0.1263E-07  0.2009E-06  0.7374E-09  0.0000E+00
 0001169  0.1979E-06  0.1254E-07  0.2020E-06  0.7758E-09  0.0000E+00
 0001170  0.1980E-06  0.1249E-07  0.2046E-06  0.6894E-09  0.0000E+00
 0001171  0.1991E-06  0.1249E-07  0.2090E-06  0.2134E-08  0.0000E+00
 0001172  0.2048E-06  0.1274E-07  0.1921E-06  0.2236E-08  0.0000E+00
 0001173  0.1921E-06  0.1300E-07  0.1927E-06  0.6707E-09  0.0000E+00
 0001174  0.1910E-06  0.1190E-07  0.1920E-06  0.8120E-09  0.0000E+00
 0001175  0.1901E-06  0.1178E-07  0.1914E-06  0.6539E-09  0.0000E+00
 0001176  0.1893E-06  0.1168E-07  0.1912E-06  0.7447E-09  0.0000E+00
 0001177  0.1888E-06  0.1157E-07  0.1918E-06  0.6396E-09  0.0000E+00
 0001178  0.1887E-06  0.1147E-07  0.1935E-06  0.6791E-09  0.0000E+00
 0001179  0.1893E-06  0.1138E-07  0.1968E-06  0.2222E-08  0.0000E+00
 0001180  0.1936E-06  0.1148E-07  0.1838E-06  0.2002E-08  0.0000E+00
 0001181  0.1983E-06  0.1163E-07  0.1819E-06  0.1690E-08  0.0000E+00
 0001182  0.1825E-06  0.1194E-07  0.1831E-06  0.8315E-09  0.0000E+00
 0001183  0.1815E-06  0.1092E-07  0.1826E-06  0.7058E-09  0.0000E+00
 0001184  0.1807E-06  0.1082E-07  0.1822E-06  0.7598E-09  0.0000E+00
 0001185  0.1800E-06  0.1073E-07  0.1824E-06  0.6676E-09  0.0000E+00
 0001186  0.1797E-06  0.1066E-07  0.1836E-06  0.7046E-09  0.0000E+00
 0001187  0.1798E-06  0.1063E-07  0.1861E-06  0.6235E-09  0.0000E+00
 0001188  0.1808E-06  0.1064E-07  0.1903E-06  0.1979E-08  0.0000E+00
 0001189  0.1862E-06  0.1088E-07  0.1743E-06  0.2045E-08  0.0000E+00
 0001190  0.1743E-06  0.1110E-07  0.1748E-06  0.6087E-09  0.0000E+00
 0001191  0.1733E-06  0.1012E-07  0.1742E-06  0.7372E-09  0.0000E+00
 0001192  0.1725E-06  0.1002E-07  0.1737E-06  0.5924E-09  0.0000E+00
 0001193  0.1718E-06  0.9925E-08  0.1736E-06  0.6745E-09  0.0000E+00
 0001194  0.1714E-06  0.9832E-08  0.1742E-06  0.5792E-09  0.0000E+00
 0001195  0.1713E-06  0.9750E-08  0.1758E-06  0.6136E-09  0.0000E+00
 0001196  0.1719E-06  0.9677E-08  0.1789E-06  0.2045E-08  0.0000E+00
 0001197  0.1759E-06  0.9769E-08  0.1667E-06  0.1835E-08  0.0000E+00
 0001198  0.1804E-06  0.9905E-08  0.1650E-06  0.1558E-08  0.0000E+00
 0001199  0.1657E-06  0.1017E-07  0.1662E-06  0.7568E-09  0.0000E+00
 0001200  0.1647E-06  0.9286E-08  0.1657E-06  0.6433E-09  0.0000E+00
 0001201  0.1640E-06  0.9198E-08  0.1654E-06  0.6904E-09  0.0000E+00
 0001202  0.1634E-06  0.9129E-08  0.1657E-06  0.6068E-09  0.0000E+00
 0001203  0.1631E-06  0.9071E-08  0.1667E-06  0.6394E-09  0.0000E+00
 0001204  0.1632E-06  0.9048E-08  0.1691E-06  0.1288E-08  0.0000E+00
 0001205  0.1661E-06  0.9143E-08  0.1595E-06  0.1379E-08  0.0000E+00
 0001206  0.1694E-06  0.9283E-08  0.1580E-06  0.6811E-09  0.0000E+00
 0001207  0.1582E-06  0.8681E-08  0.1587E-06  0.5537E-09  0.0000E+00
 0001208  0.1573E-06  0.8605E-08  0.1581E-06  0.5248E-09  0.0000E+00
 0001209  0.1566E-06  0.8534E-08  0.1577E-06  0.5408E-09  0.0000E+00
 0001210  0.1559E-06  0.8470E-08  0.1578E-06  0.5188E-09  0.0000E+00
 0001211  0.1555E-06  0.8425E-08  0.1585E-06  0.5255E-09  0.0000E+00
 0001212  0.1554E-06  0.8407E-08  0.1603E-06  0.5130E-09  0.0000E+00
 0001213  0.1560E-06  0.8437E-08  0.1635E-06  0.1575E-08  0.0000E+00
 0001214  0.1599E-06  0.8617E-08  0.1513E-06  0.6243E-09  0.0000E+00
 0001215  0.1512E-06  0.8045E-08  0.1515E-06  0.5282E-09  0.0000E+00
 0001216  0.1503E-06  0.7973E-08  0.1509E-06  0.5110E-09  0.0000E+00
 0001217  0.1496E-06  0.7905E-08  0.1504E-06  0.5139E-09  0.0000E+00
 0001218  0.1489E-06  0.7843E-08  0.1503E-06  0.4963E-09  0.0000E+00
 0001219  0.1484E-06  0.7793E-08  0.1506E-06  0.5010E-09  0.0000E+00
 0001220  0.1482E-06  0.7762E-08  0.1518E-06  0.4820E-09  0.0000E+00
 0001221  0.1486E-06  0.7765E-08  0.1542E-06  0.1463E-08  0.0000E+00
 0001222  0.1515E-06  0.7889E-08  0.1447E-06  0.1305E-08  0.0000E+00
 0001223  0.1549E-06  0.8050E-08  0.1433E-06  0.6558E-09  0.0000E+00
 0001224  0.1436E-06  0.7388E-08  0.1441E-06  0.4802E-09  0.0000E+00
 0001225  0.1428E-06  0.7324E-08  0.1436E-06  0.4768E-09  0.0000E+00
 0001226  0.1422E-06  0.7265E-08  0.1433E-06  0.4755E-09  0.0000E+00
 0001227  0.1416E-06  0.7213E-08  0.1434E-06  0.4677E-09  0.0000E+00
 0001228  0.1413E-06  0.7177E-08  0.1442E-06  0.4687E-09  0.0000E+00
 0001229  0.1413E-06  0.7166E-08  0.1460E-06  0.4584E-09  0.0000E+00
 0001230  0.1420E-06  0.7197E-08  0.1492E-06  0.1528E-08  0.0000E+00
 0001231  0.1460E-06  0.7372E-08  0.1372E-06  0.5775E-09  0.0000E+00
 0001232  0.1372E-06  0.6848E-08  0.1376E-06  0.4714E-09  0.0000E+00
 0001233  0.1364E-06  0.6788E-08  0.1370E-06  0.4580E-09  0.0000E+00
 0001234  0.1358E-06  0.6732E-08  0.1366E-06  0.4615E-09  0.0000E+00
 0001235  0.1352E-06  0.6681E-08  0.1365E-06  0.4471E-09  0.0000E+00
 0001236  0.1348E-06  0.6644E-08  0.1369E-06  0.4515E-09  0.0000E+00
 0001237  0.1347E-06  0.6627E-08  0.1381E-06  0.4361E-09  0.0000E+00
 0001238  0.1351E-06  0.6644E-08  0.1405E-06  0.1351E-08  0.0000E+00
 0001239  0.1381E-06  0.6773E-08  0.1313E-06  0.1215E-08  0.0000E+00
 0001240  0.1415E-06  0.6936E-08  0.1299E-06  0.6191E-09  0.0000E+00
 0001241  0.1304E-06  0.6294E-08  0.1308E-06  0.4366E-09  0.0000E+00
 0001242  0.1297E-06  0.6240E-08  0.1304E-06  0.4322E-09  0.0000E+00
 0001243  0.1291E-06  0.6191E-08  0.1301E-06  0.4319E-09  0.0000E+00
 0001244  0.1286E-06  0.6150E-08  0.1303E-06  0.4243E-09  0.0000E+00
 0001245  0.1284E-06  0.6126E-08  0.1311E-06  0.4254E-09  0.0000E+00
 0001246  0.1284E-06  0.6127E-08  0.1329E-06  0.4165E-09  0.0000E+00
 0001247  0.1292E-06  0.6168E-08  0.1359E-06  0.1414E-08  0.0000E+00
 0001248  0.1330E-06  0.6340E-08  0.1245E-06  0.5383E-09  0.0000E+00
 0001249  0.1246E-06  0.5836E-08  0.1249E-06  0.4292E-09  0.0000E+00
 0001250  0.1239E-06  0.5785E-08  0.1244E-06  0.4162E-09  0.0000E+00
 0001251  0.1233E-06  0.5738E-08  0.1241E-06  0.4195E-09  0.0000E+00
 0001252  0.1228E-06  0.5698E-08  0.1240E-06  0.4057E-09  0.0000E+00
 0001253  0.1225E-06  0.5671E-08  0.1244E-06  0.4104E-09  0.0000E+00
 0001254  0.1224E-06  0.5662E-08  0.1256E-06  0.3955E-09  0.0000E+00
 0001255  0.1229E-06  0.5687E-08  0.1278E-06  0.1248E-08  0.0000E+00
 0001256  0.1258E-06  0.5814E-08  0.1191E-06  0.1601E-08  0.0000E+00
 0001257  0.1289E-06  0.5383E-08  0.1179E-06  0.6594E-09  0.0000E+00
 0001258  0.1184E-06  0.5372E-08  0.1187E-06  0.7780E-09  0.0000E+00
 0001259  0.1178E-06  0.5332E-08  0.1184E-06  0.4965E-09  0.0000E+00
 0001260  0.1172E-06  0.5294E-08  0.1182E-06  0.6860E-09  0.0000E+00
 0001261  0.1168E-06  0.5276E-08  0.1184E-06  0.4810E-09  0.0000E+00
 0001262  0.1166E-06  0.5281E-08  0.1192E-06  0.6162E-09  0.0000E+00
 0001263  0.1167E-06  0.5330E-08  0.1209E-06  0.1064E-08  0.0000E+00
 0001264  0.1187E-06  0.5416E-08  0.1140E-06  0.1082E-08  0.0000E+00
 0001265  0.1211E-06  0.4998E-08  0.1129E-06  0.6253E-09  0.0000E+00
 0001266  0.1131E-06  0.4976E-08  0.1134E-06  0.6756E-09  0.0000E+00
 0001267  0.1125E-06  0.4937E-08  0.1130E-06  0.5149E-09  0.0000E+00
 0001268  0.1120E-06  0.4900E-08  0.1127E-06  0.6072E-09  0.0000E+00
 0001269  0.1115E-06  0.4881E-08  0.1128E-06  0.4889E-09  0.0000E+00
 0001270  0.1112E-06  0.4882E-08  0.1133E-06  0.5547E-09  0.0000E+00
 0001271  0.1111E-06  0.4928E-08  0.1146E-06  0.4741E-09  0.0000E+00
 0001272  0.1115E-06  0.5023E-08  0.1169E-06  0.1025E-08  0.0000E+00
 0001273  0.1143E-06  0.4640E-08  0.1082E-06  0.5265E-09  0.0000E+00
 0001274  0.1081E-06  0.4620E-08  0.1083E-06  0.5773E-09  0.0000E+00
 0001275  0.1075E-06  0.4582E-08  0.1079E-06  0.4521E-09  0.0000E+00
 0001276  0.1070E-06  0.4547E-08  0.1076E-06  0.5265E-09  0.0000E+00
 0001277  0.1065E-06  0.4524E-08  0.1075E-06  0.4348E-09  0.0000E+00
 0001278  0.1061E-06  0.4519E-08  0.1077E-06  0.4870E-09  0.0000E+00
 0001279  0.1060E-06  0.4545E-08  0.1086E-06  0.4250E-09  0.0000E+00
 0001280  0.1062E-06  0.4615E-08  0.1103E-06  0.8879E-09  0.0000E+00
 0001281  0.1083E-06  0.4309E-08  0.1035E-06  0.7628E-09  0.0000E+00
 0001282  0.1107E-06  0.4274E-08  0.1025E-06  0.7888E-09  0.0000E+00
 0001283  0.1027E-06  0.4261E-08  0.1030E-06  0.8357E-09  0.0000E+00
 0001284  0.1022E-06  0.4224E-08  0.1027E-06  0.6605E-09  0.0000E+00
 0001285  0.1017E-06  0.4194E-08  0.1025E-06  0.7378E-09  0.0000E+00
 0001286  0.1013E-06  0.4180E-08  0.1026E-06  0.6042E-09  0.0000E+00
 0001287  0.1010E-06  0.4194E-08  0.1032E-06  0.6574E-09  0.0000E+00
 0001288  0.1010E-06  0.4251E-08  0.1045E-06  0.5618E-09  0.0000E+00
 0001289  0.1015E-06  0.4363E-08  0.1068E-06  0.9656E-09  0.0000E+00
 0001290  0.1043E-06  0.3964E-08  0.9816E-07  0.5060E-09  0.0000E+00
 0001291  0.9817E-07  0.3947E-08  0.9838E-07  0.5387E-09  0.0000E+00
 0001292  0.9761E-07  0.3917E-08  0.9802E-07  0.4281E-09  0.0000E+00
 0001293  0.9714E-07  0.3889E-08  0.9772E-07  0.4910E-09  0.0000E+00
 0001294  0.9671E-07  0.3875E-08  0.9767E-07  0.4099E-09  0.0000E+00
 0001295  0.9642E-07  0.3879E-08  0.9797E-07  0.4551E-09  0.0000E+00
 0001296  0.9631E-07  0.3918E-08  0.9888E-07  0.4021E-09  0.0000E+00
 0001297  0.9657E-07  0.3999E-08  0.1006E-06  0.8270E-09  0.0000E+00
 0001298  0.9868E-07  0.3682E-08  0.9391E-07  0.7076E-09  0.0000E+00
 0001299  0.1010E-06  0.3654E-08  0.9298E-07  0.7398E-09  0.0000E+00
 0001300  0.9331E-07  0.3642E-08  0.9356E-07  0.7740E-09  0.0000E+00
 0001301  0.9279E-07  0.3610E-08  0.9328E-07  0.6136E-09  0.0000E+00
 0001302  0.9237E-07  0.3585E-08  0.9311E-07  0.6824E-09  0.0000E+00
 0001303  0.9200E-07  0.3576E-08  0.9326E-07  0.5598E-09  0.0000E+00
 0001304  0.9179E-07  0.3592E-08  0.9387E-07  0.6072E-09  0.0000E+00
 0001305  0.9181E-07  0.3651E-08  0.9521E-07  0.1126E-08  0.0000E+00
 0001306  0.9227E-07  0.3390E-08  0.9742E-07  0.8317E-09  0.0000E+00
 0001307  0.9497E-07  0.3406E-08  0.8911E-07  0.6734E-09  0.0000E+00
 0001308  0.8917E-07  0.3399E-08  0.8936E-07  0.5798E-09  0.0000E+00
 0001309  0.8865E-07  0.3368E-08  0.8904E-07  0.5638E-09  0.0000E+00
 0001310  0.8824E-07  0.3336E-08  0.8878E-07  0.5221E-09  0.0000E+00
 0001311  0.8785E-07  0.3307E-08  0.8876E-07  0.5070E-09  0.0000E+00
 0001312  0.8760E-07  0.3282E-08  0.8907E-07  0.4772E-09  0.0000E+00
 0001313  0.8753E-07  0.3259E-08  0.8996E-07  0.4653E-09  0.0000E+00
 0001314  0.8780E-07  0.3244E-08  0.9161E-07  0.1272E-08  0.0000E+00
 0001315  0.8981E-07  0.3256E-08  0.8527E-07  0.1187E-08  0.0000E+00
 0001316  0.9200E-07  0.3262E-08  0.8441E-07  0.5084E-09  0.0000E+00
 0001317  0.8476E-07  0.3327E-08  0.8498E-07  0.6346E-09  0.0000E+00
 0001318  0.8429E-07  0.3076E-08  0.8474E-07  0.5729E-09  0.0000E+00
 0001319  0.8391E-07  0.3059E-08  0.8460E-07  0.5693E-09  0.0000E+00
 0001320  0.8358E-07  0.3065E-08  0.8476E-07  0.5211E-09  0.0000E+00
 0001321  0.8341E-07  0.3107E-08  0.8534E-07  0.5234E-09  0.0000E+00
 0001322  0.8345E-07  0.3203E-08  0.8660E-07  0.7651E-09  0.0000E+00
 0001323  0.8487E-07  0.2931E-08  0.8161E-07  0.7598E-09  0.0000E+00
 0001324  0.8649E-07  0.2918E-08  0.8086E-07  0.6245E-09  0.0000E+00
 0001325  0.8099E-07  0.2914E-08  0.8118E-07  0.6319E-09  0.0000E+00
 0001326  0.8053E-07  0.2902E-08  0.8090E-07  0.5298E-09  0.0000E+00
 0001327  0.8015E-07  0.2904E-08  0.8071E-07  0.5616E-09  0.0000E+00
 0001328  0.7980E-07  0.2935E-08  0.8075E-07  0.4867E-09  0.0000E+00
 0001329  0.7956E-07  0.3005E-08  0.8115E-07  0.1098E-08  0.0000E+00
 0001330  0.7949E-07  0.2744E-08  0.8211E-07  0.1053E-08  0.0000E+00
 0001331  0.7972E-07  0.2746E-08  0.8380E-07  0.5217E-09  0.0000E+00
 0001332  0.8168E-07  0.2794E-08  0.7744E-07  0.4165E-09  0.0000E+00
 0001333  0.8372E-07  0.2838E-08  0.7665E-07  0.4047E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 20
 0001334  0.7699E-07  0.2660E-08  0.7721E-07  0.3532E-09  0.0000E+00
 0001335  0.7656E-07  0.2645E-08  0.7701E-07  0.2965E-09  0.0000E+00
 0001336  0.7622E-07  0.2638E-08  0.7692E-07  0.3322E-09  0.0000E+00
 0001337  0.7592E-07  0.2650E-08  0.7713E-07  0.2929E-09  0.0000E+00
 0001338  0.7575E-07  0.2688E-08  0.7777E-07  0.3278E-09  0.0000E+00
 0001339  0.7579E-07  0.2764E-08  0.7906E-07  0.6168E-09  0.0000E+00
 0001340  0.7717E-07  0.2513E-08  0.7411E-07  0.6039E-09  0.0000E+00
 0001341  0.7869E-07  0.2497E-08  0.7344E-07  0.5493E-09  0.0000E+00
 0001342  0.7357E-07  0.2490E-08  0.7375E-07  0.5333E-09  0.0000E+00
 0001343  0.7315E-07  0.2474E-08  0.7351E-07  0.4633E-09  0.0000E+00
 0001344  0.7280E-07  0.2470E-08  0.7337E-07  0.4766E-09  0.0000E+00
 0001345  0.7248E-07  0.2486E-08  0.7345E-07  0.4255E-09  0.0000E+00
 0001346  0.7227E-07  0.2532E-08  0.7389E-07  0.8872E-09  0.0000E+00
 0001347  0.7220E-07  0.2351E-08  0.7487E-07  0.8588E-09  0.0000E+00
 0001348  0.7241E-07  0.2351E-08  0.7654E-07  0.5384E-09  0.0000E+00
 0001349  0.7428E-07  0.2390E-08  0.7033E-07  0.4417E-09  0.0000E+00
 0001350  0.7618E-07  0.2429E-08  0.6961E-07  0.7897E-09  0.0000E+00
 0001351  0.6994E-07  0.2435E-08  0.7015E-07  0.8023E-09  0.0000E+00
 0001352  0.6955E-07  0.2414E-08  0.6998E-07  0.6075E-09  0.0000E+00
 0001353  0.6923E-07  0.2405E-08  0.6993E-07  0.2497E-09  0.0000E+00
 0001354  0.6896E-07  0.2217E-08  0.7017E-07  0.2830E-09  0.0000E+00
 0001355  0.6880E-07  0.2192E-08  0.7082E-07  0.2390E-09  0.0000E+00
 0001356  0.6883E-07  0.2168E-08  0.7208E-07  0.7006E-09  0.0000E+00
 0001357  0.7014E-07  0.2169E-08  0.6732E-07  0.7408E-09  0.0000E+00
 0001358  0.7153E-07  0.2184E-08  0.6670E-07  0.5672E-09  0.0000E+00
 0001359  0.6683E-07  0.2187E-08  0.6700E-07  0.4814E-09  0.0000E+00
 0001360  0.6645E-07  0.2177E-08  0.6679E-07  0.4627E-09  0.0000E+00
 0001361  0.6613E-07  0.2172E-08  0.6668E-07  0.4158E-09  0.0000E+00
 0001362  0.6584E-07  0.2177E-08  0.6678E-07  0.3952E-09  0.0000E+00
 0001363  0.6564E-07  0.2192E-08  0.6722E-07  0.4044E-09  0.0000E+00
 0001364  0.6557E-07  0.2019E-08  0.6818E-07  0.4182E-09  0.0000E+00
 0001365  0.6577E-07  0.1995E-08  0.6977E-07  0.7044E-09  0.0000E+00
 0001366  0.6752E-07  0.1998E-08  0.6389E-07  0.6438E-09  0.0000E+00
 0001367  0.6925E-07  0.2000E-08  0.6323E-07  0.5283E-09  0.0000E+00
 0001368  0.6354E-07  0.1993E-08  0.6373E-07  0.5110E-09  0.0000E+00
 0001369  0.6318E-07  0.1973E-08  0.6359E-07  0.4221E-09  0.0000E+00
 0001370  0.6289E-07  0.1954E-08  0.6356E-07  0.4454E-09  0.0000E+00
 0001371  0.6264E-07  0.1937E-08  0.6380E-07  0.3786E-09  0.0000E+00
 0001372  0.6250E-07  0.1923E-08  0.6443E-07  0.3965E-09  0.0000E+00
 0001373  0.6252E-07  0.1913E-08  0.6563E-07  0.8216E-09  0.0000E+00
 0001374  0.6373E-07  0.1900E-08  0.6116E-07  0.8240E-09  0.0000E+00
 0001375  0.6501E-07  0.1871E-08  0.6060E-07  0.3738E-09  0.0000E+00
 0001376  0.6072E-07  0.1870E-08  0.6087E-07  0.3579E-09  0.0000E+00
 0001377  0.6037E-07  0.1884E-08  0.6069E-07  0.3176E-09  0.0000E+00
 0001378  0.6008E-07  0.1917E-08  0.6060E-07  0.5927E-09  0.0000E+00
 0001379  0.5982E-07  0.1777E-08  0.6071E-07  0.5862E-09  0.0000E+00
 0001380  0.5964E-07  0.1775E-08  0.6113E-07  0.5248E-09  0.0000E+00
 0001381  0.5957E-07  0.1803E-08  0.6203E-07  0.5327E-09  0.0000E+00
 0001382  0.6044E-07  0.1848E-08  0.5851E-07  0.6660E-09  0.0000E+00
 0001383  0.6140E-07  0.1717E-08  0.5801E-07  0.2618E-09  0.0000E+00
 0001384  0.5802E-07  0.1711E-08  0.5815E-07  0.3703E-09  0.0000E+00
 0001385  0.5769E-07  0.1702E-08  0.5795E-07  0.2271E-09  0.0000E+00
 0001386  0.5740E-07  0.1697E-08  0.5781E-07  0.3303E-09  0.0000E+00
 0001387  0.5714E-07  0.1706E-08  0.5784E-07  0.2268E-09  0.0000E+00
 0001388  0.5693E-07  0.1730E-08  0.5812E-07  0.3077E-09  0.0000E+00
 0001389  0.5682E-07  0.1782E-08  0.5881E-07  0.6351E-09  0.0000E+00
 0001390  0.5689E-07  0.1604E-08  0.6003E-07  0.4849E-09  0.0000E+00
 0001391  0.5816E-07  0.1610E-08  0.5553E-07  0.3690E-09  0.0000E+00
 0001392  0.5945E-07  0.1618E-08  0.5499E-07  0.4363E-09  0.0000E+00
 0001393  0.5516E-07  0.1614E-08  0.5531E-07  0.5559E-09  0.0000E+00
 0001394  0.5485E-07  0.1596E-08  0.5517E-07  0.3639E-09  0.0000E+00
 0001395  0.5459E-07  0.1582E-08  0.5511E-07  0.4762E-09  0.0000E+00
 0001396  0.5435E-07  0.1571E-08  0.5526E-07  0.3324E-09  0.0000E+00
 0001397  0.5420E-07  0.1567E-08  0.5571E-07  0.4138E-09  0.0000E+00
 0001398  0.5417E-07  0.1572E-08  0.5664E-07  0.6230E-09  0.0000E+00
 0001399  0.5506E-07  0.1569E-08  0.5313E-07  0.6390E-09  0.0000E+00
 0001400  0.5602E-07  0.1553E-08  0.5266E-07  0.4614E-09  0.0000E+00
 0001401  0.5271E-07  0.1550E-08  0.5284E-07  0.4279E-09  0.0000E+00
 0001402  0.5241E-07  0.1555E-08  0.5266E-07  0.3543E-09  0.0000E+00
 0001403  0.5216E-07  0.1444E-08  0.5256E-07  0.3513E-09  0.0000E+00
 0001404  0.5192E-07  0.1438E-08  0.5262E-07  0.3215E-09  0.0000E+00
 0001405  0.5174E-07  0.1445E-08  0.5292E-07  0.3188E-09  0.0000E+00
 0001406  0.5166E-07  0.1474E-08  0.5362E-07  0.3019E-09  0.0000E+00
 0001407  0.5175E-07  0.1533E-08  0.5482E-07  0.7187E-09  0.0000E+00
 0001408  0.5301E-07  0.1389E-08  0.5042E-07  0.6672E-09  0.0000E+00
 0001409  0.5426E-07  0.1418E-08  0.4992E-07  0.4469E-09  0.0000E+00
 0001410  0.5011E-07  0.1429E-08  0.5026E-07  0.4609E-09  0.0000E+00
 0001411  0.4983E-07  0.1431E-08  0.5014E-07  0.3566E-09  0.0000E+00
 0001412  0.4960E-07  0.1448E-08  0.5010E-07  0.4693E-09  0.0000E+00
 0001413  0.4939E-07  0.1325E-08  0.5027E-07  0.4529E-09  0.0000E+00
 0001414  0.4926E-07  0.1326E-08  0.5073E-07  0.4037E-09  0.0000E+00
 0001415  0.4924E-07  0.1354E-08  0.5162E-07  0.2868E-09  0.0000E+00
 0001416  0.5012E-07  0.1390E-08  0.4826E-07  0.4157E-09  0.0000E+00
 0001417  0.5105E-07  0.1280E-08  0.4783E-07  0.2369E-09  0.0000E+00
 0001418  0.4789E-07  0.1273E-08  0.4801E-07  0.2907E-09  0.0000E+00
 0001419  0.4762E-07  0.1265E-08  0.4786E-07  0.1972E-09  0.0000E+00
 0001420  0.4739E-07  0.1260E-08  0.4778E-07  0.2599E-09  0.0000E+00
 0001421  0.4717E-07  0.1267E-08  0.4785E-07  0.1927E-09  0.0000E+00
 0001422  0.4702E-07  0.1285E-08  0.4816E-07  0.2430E-09  0.0000E+00
 0001423  0.4695E-07  0.1326E-08  0.4885E-07  0.4957E-09  0.0000E+00
 0001424  0.4705E-07  0.1198E-08  0.4999E-07  0.4138E-09  0.0000E+00
 0001425  0.4826E-07  0.1206E-08  0.4580E-07  0.3424E-09  0.0000E+00
 0001426  0.4945E-07  0.1219E-08  0.4534E-07  0.3788E-09  0.0000E+00
 0001427  0.4553E-07  0.1214E-08  0.4567E-07  0.4547E-09  0.0000E+00
 0001428  0.4528E-07  0.1200E-08  0.4557E-07  0.3071E-09  0.0000E+00
 0001429  0.4507E-07  0.1190E-08  0.4555E-07  0.3869E-09  0.0000E+00
 0001430  0.4488E-07  0.1183E-08  0.4572E-07  0.2763E-09  0.0000E+00
 0001431  0.4477E-07  0.1182E-08  0.4617E-07  0.3337E-09  0.0000E+00
 0001432  0.4476E-07  0.1190E-08  0.4703E-07  0.5344E-09  0.0000E+00
 0001433  0.4560E-07  0.1187E-08  0.4384E-07  0.5284E-09  0.0000E+00
 0001434  0.4648E-07  0.1173E-08  0.4344E-07  0.3883E-09  0.0000E+00
 0001435  0.4351E-07  0.1169E-08  0.4362E-07  0.3508E-09  0.0000E+00
 0001436  0.4327E-07  0.1171E-08  0.4349E-07  0.2882E-09  0.0000E+00
 0001437  0.4306E-07  0.1083E-08  0.4342E-07  0.2896E-09  0.0000E+00
 0001438  0.4287E-07  0.1080E-08  0.4350E-07  0.2618E-09  0.0000E+00
 0001439  0.4273E-07  0.1088E-08  0.4381E-07  0.2632E-09  0.0000E+00
 0001440  0.4267E-07  0.1116E-08  0.4445E-07  0.4606E-09  0.0000E+00
 0001441  0.4328E-07  0.1050E-08  0.4194E-07  0.4610E-09  0.0000E+00
 0001442  0.4394E-07  0.1065E-08  0.4158E-07  0.3681E-09  0.0000E+00
 0001443  0.4502E-07  0.1113E-08  0.4119E-07  0.3120E-09  0.0000E+00
 0001444  0.4138E-07  0.1024E-08  0.4151E-07  0.3054E-09  0.0000E+00
 0001445  0.4113E-07  0.1028E-08  0.4144E-07  0.2532E-09  0.0000E+00
 0001446  0.4095E-07  0.1046E-08  0.4145E-07  0.2812E-09  0.0000E+00
 0001447  0.4077E-07  0.1090E-08  0.4166E-07  0.5373E-09  0.0000E+00
 0001448  0.4066E-07  0.9867E-09  0.4215E-07  0.5609E-09  0.0000E+00
 0001449  0.4065E-07  0.1007E-08  0.4303E-07  0.4033E-09  0.0000E+00
 0001450  0.4148E-07  0.1040E-08  0.3982E-07  0.5506E-09  0.0000E+00
 0001451  0.4229E-07  0.9688E-09  0.3946E-07  0.2277E-09  0.0000E+00
 0001452  0.3954E-07  0.9665E-09  0.3964E-07  0.2601E-09  0.0000E+00
 0001453  0.3931E-07  0.9643E-09  0.3954E-07  0.1893E-09  0.0000E+00
 0001454  0.3912E-07  0.9677E-09  0.3949E-07  0.2325E-09  0.0000E+00
 0001455  0.3894E-07  0.9836E-09  0.3960E-07  0.1829E-09  0.0000E+00
 0001456  0.3881E-07  0.1013E-08  0.3993E-07  0.4351E-09  0.0000E+00
 0001457  0.3876E-07  0.9143E-09  0.4059E-07  0.2402E-09  0.0000E+00
 0001458  0.3934E-07  0.9177E-09  0.3810E-07  0.2372E-09  0.0000E+00
 0001459  0.3996E-07  0.9258E-09  0.3778E-07  0.1898E-09  0.0000E+00
 0001460  0.4096E-07  0.9493E-09  0.3742E-07  0.2491E-09  0.0000E+00
 0001461  0.3759E-07  0.8897E-09  0.3773E-07  0.2087E-09  0.0000E+00
 0001462  0.3737E-07  0.8911E-09  0.3768E-07  0.1932E-09  0.0000E+00
 0001463  0.3720E-07  0.9025E-09  0.3771E-07  0.1967E-09  0.0000E+00
 0001464  0.3704E-07  0.9305E-09  0.3795E-07  0.4059E-09  0.0000E+00
 0001465  0.3693E-07  0.8568E-09  0.3845E-07  0.4067E-09  0.0000E+00
 0001466  0.3692E-07  0.8666E-09  0.3932E-07  0.3262E-09  0.0000E+00
 0001467  0.3771E-07  0.8868E-09  0.3618E-07  0.3277E-09  0.0000E+00
 0001468  0.3847E-07  0.9167E-09  0.3585E-07  0.1684E-09  0.0000E+00
 0001469  0.3592E-07  0.8330E-09  0.3603E-07  0.1492E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 21
 0001470  0.3572E-07  0.8298E-09  0.3594E-07  0.1335E-09  0.0000E+00
 0001471  0.3554E-07  0.8308E-09  0.3592E-07  0.1430E-09  0.0000E+00
 0001472  0.3538E-07  0.8394E-09  0.3603E-07  0.1336E-09  0.0000E+00
 0001473  0.3526E-07  0.8585E-09  0.3637E-07  0.3159E-09  0.0000E+00
 0001474  0.3521E-07  0.7947E-09  0.3702E-07  0.3268E-09  0.0000E+00
 0001475  0.3577E-07  0.7990E-09  0.3462E-07  0.2971E-09  0.0000E+00
 0001476  0.3635E-07  0.8133E-09  0.3432E-07  0.2490E-09  0.0000E+00
 0001477  0.3433E-07  0.8152E-09  0.3442E-07  0.2815E-09  0.0000E+00
 0001478  0.3414E-07  0.8100E-09  0.3431E-07  0.2052E-09  0.0000E+00
 0001479  0.3396E-07  0.8100E-09  0.3425E-07  0.2355E-09  0.0000E+00
 0001480  0.3380E-07  0.8143E-09  0.3430E-07  0.2066E-09  0.0000E+00
 0001481  0.3367E-07  0.7530E-09  0.3453E-07  0.2197E-09  0.0000E+00
 0001482  0.3360E-07  0.7501E-09  0.3502E-07  0.1796E-09  0.0000E+00
 0001483  0.3362E-07  0.7549E-09  0.3585E-07  0.2946E-09  0.0000E+00
 0001484  0.3442E-07  0.7674E-09  0.3286E-07  0.2768E-09  0.0000E+00
 0001485  0.3519E-07  0.7833E-09  0.3254E-07  0.1565E-09  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 22
 0001486  0.3264E-07  0.7266E-09  0.3274E-07  0.1435E-09  0.0000E+00
 0001487  0.3246E-07  0.7243E-09  0.3267E-07  0.1186E-09  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 21
 0001488  0.3230E-07  0.7254E-09  0.3265E-07  0.1355E-09  0.0000E+00
 0001489  0.3216E-07  0.7342E-09  0.3278E-07  0.1191E-09  0.0000E+00
 0001490  0.3206E-07  0.7520E-09  0.3310E-07  0.2927E-09  0.0000E+00
 0001491  0.3204E-07  0.6940E-09  0.3372E-07  0.2656E-09  0.0000E+00
 0001492  0.3260E-07  0.6976E-09  0.3144E-07  0.2424E-09  0.0000E+00
 0001493  0.3318E-07  0.7078E-09  0.3116E-07  0.2286E-09  0.0000E+00
 0001494  0.3120E-07  0.7066E-09  0.3127E-07  0.2489E-09  0.0000E+00
 0001495  0.3102E-07  0.7005E-09  0.3118E-07  0.1889E-09  0.0000E+00
 0001496  0.3087E-07  0.6978E-09  0.3113E-07  0.2120E-09  0.0000E+00
 0001497  0.3072E-07  0.6983E-09  0.3119E-07  0.1672E-09  0.0000E+00
 0001498  0.3061E-07  0.7043E-09  0.3141E-07  0.2083E-09  0.0000E+00
 0001499  0.3056E-07  0.6523E-09  0.3188E-07  0.1800E-09  0.0000E+00
 0001500  0.3096E-07  0.6532E-09  0.3007E-07  0.2041E-09  0.0000E+00
 0001501  0.3140E-07  0.6589E-09  0.2982E-07  0.1465E-09  0.0000E+00
 0001502  0.3213E-07  0.6754E-09  0.2955E-07  0.2644E-09  0.0000E+00
 0001503  0.2966E-07  0.6745E-09  0.2976E-07  0.2876E-09  0.0000E+00
 0001504  0.2949E-07  0.6649E-09  0.2971E-07  0.2084E-09  0.0000E+00
 0001505  0.2935E-07  0.6605E-09  0.2972E-07  0.2382E-09  0.0000E+00
 0001506  0.2922E-07  0.6570E-09  0.2988E-07  0.1810E-09  0.0000E+00
 0001507  0.2913E-07  0.6606E-09  0.3023E-07  0.1794E-09  0.0000E+00
 0001508  0.2911E-07  0.6088E-09  0.3088E-07  0.2102E-09  0.0000E+00
 0001509  0.2968E-07  0.6114E-09  0.2856E-07  0.2460E-09  0.0000E+00
 0001510  0.3024E-07  0.6226E-09  0.2831E-07  0.2187E-09  0.0000E+00
 0001511  0.2835E-07  0.6206E-09  0.2842E-07  0.1869E-09  0.0000E+00
 0001512  0.2818E-07  0.6171E-09  0.2835E-07  0.1761E-09  0.0000E+00
 0001513  0.2804E-07  0.6150E-09  0.2832E-07  0.1618E-09  0.0000E+00
 0001514  0.2791E-07  0.6170E-09  0.2840E-07  0.1514E-09  0.0000E+00
 0001515  0.2781E-07  0.6219E-09  0.2864E-07  0.1700E-09  0.0000E+00
 0001516  0.2776E-07  0.5721E-09  0.2913E-07  0.1942E-09  0.0000E+00
 0001517  0.2817E-07  0.5722E-09  0.2732E-07  0.1999E-09  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 20
 0001518  0.2859E-07  0.5770E-09  0.2709E-07  0.1549E-09  0.0000E+00
 0001519  0.2928E-07  0.5933E-09  0.2684E-07  0.2372E-09  0.0000E+00
 0001520  0.2695E-07  0.5925E-09  0.2705E-07  0.2528E-09  0.0000E+00
 0001521  0.2679E-07  0.5848E-09  0.2702E-07  0.1850E-09  0.0000E+00
 0001522  0.2667E-07  0.5821E-09  0.2704E-07  0.2094E-09  0.0000E+00
 0001523  0.2655E-07  0.5812E-09  0.2722E-07  0.1619E-09  0.0000E+00
 0001524  0.2647E-07  0.5391E-09  0.2758E-07  0.1575E-09  0.0000E+00
 0001525  0.2644E-07  0.5389E-09  0.2822E-07  0.2209E-09  0.0000E+00
 0001526  0.2700E-07  0.5436E-09  0.2595E-07  0.2190E-09  0.0000E+00
 0001527  0.2753E-07  0.5548E-09  0.2571E-07  0.2042E-09  0.0000E+00
 0001528  0.2576E-07  0.5528E-09  0.2583E-07  0.1924E-09  0.0000E+00
 0001529  0.2561E-07  0.5478E-09  0.2577E-07  0.1622E-09  0.0000E+00
 0001530  0.2548E-07  0.5450E-09  0.2576E-07  0.1611E-09  0.0000E+00
 0001531  0.2536E-07  0.5442E-09  0.2584E-07  0.1380E-09  0.0000E+00
 0001532  0.2527E-07  0.5461E-09  0.2609E-07  0.1136E-09  0.0000E+00
 0001533  0.2523E-07  0.5031E-09  0.2656E-07  0.2079E-09  0.0000E+00
 0001534  0.2562E-07  0.5037E-09  0.2482E-07  0.2234E-09  0.0000E+00
 0001535  0.2602E-07  0.5125E-09  0.2461E-07  0.1661E-09  0.0000E+00
 0001536  0.2666E-07  0.5352E-09  0.2439E-07  0.1396E-09  0.0000E+00
 0001537  0.2449E-07  0.4907E-09  0.2459E-07  0.1330E-09  0.0000E+00
 0001538  0.2435E-07  0.4909E-09  0.2456E-07  0.1032E-09  0.0000E+00
 0001539  0.2423E-07  0.4950E-09  0.2460E-07  0.1223E-09  0.0000E+00
 0001540  0.2412E-07  0.5080E-09  0.2477E-07  0.2013E-09  0.0000E+00
 0001541  0.2405E-07  0.4741E-09  0.2513E-07  0.2221E-09  0.0000E+00
 0001542  0.2403E-07  0.4790E-09  0.2573E-07  0.2345E-09  0.0000E+00
 0001543  0.2456E-07  0.4899E-09  0.2358E-07  0.2380E-09  0.0000E+00
 0001544  0.2506E-07  0.5134E-09  0.2336E-07  0.1124E-09  0.0000E+00
 0001545  0.2341E-07  0.4624E-09  0.2348E-07  0.9293E-10  0.0000E+00
 0001546  0.2327E-07  0.4611E-09  0.2342E-07  0.8935E-10  0.0000E+00
 0001547  0.2316E-07  0.4629E-09  0.2342E-07  0.9010E-10  0.0000E+00
 0001548  0.2305E-07  0.4694E-09  0.2351E-07  0.8917E-10  0.0000E+00
 0001549  0.2297E-07  0.4828E-09  0.2374E-07  0.1933E-09  0.0000E+00
 0001550  0.2293E-07  0.4431E-09  0.2419E-07  0.2235E-09  0.0000E+00
 0001551  0.2330E-07  0.4471E-09  0.2256E-07  0.2029E-09  0.0000E+00
 0001552  0.2368E-07  0.4605E-09  0.2236E-07  0.1581E-09  0.0000E+00
 0001553  0.2237E-07  0.4620E-09  0.2243E-07  0.1793E-09  0.0000E+00
 0001554  0.2224E-07  0.4590E-09  0.2236E-07  0.1273E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 22
 0001555  0.2213E-07  0.4601E-09  0.2233E-07  0.1277E-09  0.0000E+00
 0001556  0.2202E-07  0.4251E-09  0.2237E-07  0.1171E-09  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 23
 0001557  0.2194E-07  0.4239E-09  0.2253E-07  0.1142E-09  0.0000E+00
 0001558  0.2188E-07  0.4279E-09  0.2287E-07  0.1331E-09  0.0000E+00
 0001559  0.2215E-07  0.4341E-09  0.2157E-07  0.1503E-09  0.0000E+00
 0001560  0.2244E-07  0.4442E-09  0.2140E-07  0.1732E-09  0.0000E+00
 0001561  0.2293E-07  0.4121E-09  0.2121E-07  0.1180E-09  0.0000E+00
 0001562  0.2127E-07  0.4085E-09  0.2134E-07  0.1396E-09  0.0000E+00
 0001563  0.2115E-07  0.4066E-09  0.2131E-07  0.9369E-10  0.0000E+00
 0001564  0.2104E-07  0.4076E-09  0.2131E-07  0.1238E-09  0.0000E+00
 0001565  0.2094E-07  0.4143E-09  0.2143E-07  0.9194E-10  0.0000E+00
 0001566  0.2088E-07  0.4278E-09  0.2168E-07  0.2074E-09  0.0000E+00
 0001567  0.2085E-07  0.3923E-09  0.2215E-07  0.1510E-09  0.0000E+00
 0001568  0.2124E-07  0.3954E-09  0.2049E-07  0.1589E-09  0.0000E+00
 0001569  0.2162E-07  0.4047E-09  0.2031E-07  0.1546E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 24
 0001570  0.2033E-07  0.4030E-09  0.2038E-07  0.1521E-09  0.0000E+00
 0001571  0.2021E-07  0.3995E-09  0.2033E-07  0.1251E-09  0.0000E+00
 0001572  0.2011E-07  0.3980E-09  0.2031E-07  0.1293E-09  0.0000E+00
 0001573  0.2001E-07  0.3990E-09  0.2037E-07  0.1026E-09  0.0000E+00
 0001574  0.1994E-07  0.3721E-09  0.2054E-07  0.1145E-09  0.0000E+00
 0001575  0.1989E-07  0.3715E-09  0.2089E-07  0.1468E-09  0.0000E+00
 0001576  0.2017E-07  0.3735E-09  0.1960E-07  0.1346E-09  0.0000E+00
 0001577  0.2046E-07  0.3792E-09  0.1943E-07  0.1184E-09  0.0000E+00
 0001578  0.2094E-07  0.3939E-09  0.1926E-07  0.1065E-09  0.0000E+00
 0001579  0.1933E-07  0.3608E-09  0.1940E-07  0.9467E-10  0.0000E+00
 0001580  0.1921E-07  0.3615E-09  0.1937E-07  0.8095E-10  0.0000E+00
 0001581  0.1912E-07  0.3658E-09  0.1939E-07  0.8947E-10  0.0000E+00
 0001582  0.1903E-07  0.3768E-09  0.1952E-07  0.1608E-09  0.0000E+00
 0001583  0.1897E-07  0.3490E-09  0.1978E-07  0.1681E-09  0.0000E+00
 0001584  0.1895E-07  0.3536E-09  0.2023E-07  0.1701E-09  0.0000E+00
 0001585  0.1934E-07  0.3613E-09  0.1861E-07  0.1655E-09  0.0000E+00
 0001586  0.1971E-07  0.3766E-09  0.1844E-07  0.8575E-10  0.0000E+00
 0001587  0.1847E-07  0.3406E-09  0.1853E-07  0.7400E-10  0.0000E+00
 0001588  0.1837E-07  0.3399E-09  0.1848E-07  0.6935E-10  0.0000E+00
 0001589  0.1827E-07  0.3416E-09  0.1847E-07  0.7180E-10  0.0000E+00
 0001590  0.1819E-07  0.3471E-09  0.1853E-07  0.6967E-10  0.0000E+00
 0001591  0.1812E-07  0.3578E-09  0.1871E-07  0.1510E-09  0.0000E+00
 0001592  0.1809E-07  0.3274E-09  0.1905E-07  0.1630E-09  0.0000E+00
 0001593  0.1837E-07  0.3302E-09  0.1780E-07  0.1510E-09  0.0000E+00
 0001594  0.1864E-07  0.3400E-09  0.1765E-07  0.1312E-09  0.0000E+00
 0001595  0.1910E-07  0.3623E-09  0.1749E-07  0.1166E-09  0.0000E+00
 0001596  0.1756E-07  0.3204E-09  0.1763E-07  0.9429E-10  0.0000E+00
 0001597  0.1746E-07  0.3224E-09  0.1761E-07  0.9123E-10  0.0000E+00
 0001598  0.1738E-07  0.3298E-09  0.1764E-07  0.9071E-10  0.0000E+00
 0001599  0.1730E-07  0.3446E-09  0.1776E-07  0.1817E-09  0.0000E+00
 0001600  0.1725E-07  0.3103E-09  0.1802E-07  0.1796E-09  0.0000E+00
 0001601  0.1723E-07  0.3183E-09  0.1845E-07  0.1704E-09  0.0000E+00
 0001602  0.1761E-07  0.3296E-09  0.1691E-07  0.2158E-09  0.0000E+00
 0001603  0.1796E-07  0.3078E-09  0.1676E-07  0.9296E-10  0.0000E+00
 0001604  0.1679E-07  0.3068E-09  0.1684E-07  0.1048E-09  0.0000E+00
 0001605  0.1669E-07  0.3071E-09  0.1680E-07  0.7661E-10  0.0000E+00
 0001606  0.1661E-07  0.3099E-09  0.1679E-07  0.9424E-10  0.0000E+00
 0001607  0.1653E-07  0.3179E-09  0.1686E-07  0.1284E-09  0.0000E+00
 0001608  0.1647E-07  0.2927E-09  0.1703E-07  0.1430E-09  0.0000E+00
 0001609  0.1644E-07  0.2962E-09  0.1735E-07  0.1163E-09  0.0000E+00
 0001610  0.1670E-07  0.3015E-09  0.1618E-07  0.1120E-09  0.0000E+00
 0001611  0.1697E-07  0.3111E-09  0.1604E-07  0.1460E-09  0.0000E+00
 0001612  0.1739E-07  0.2886E-09  0.1589E-07  0.1013E-09  0.0000E+00
 0001613  0.1596E-07  0.2852E-09  0.1603E-07  0.1151E-09  0.0000E+00
 0001614  0.1587E-07  0.2849E-09  0.1601E-07  0.7881E-10  0.0000E+00
 0001615  0.1579E-07  0.2880E-09  0.1604E-07  0.1023E-09  0.0000E+00
 0001616  0.1572E-07  0.2975E-09  0.1616E-07  0.1409E-09  0.0000E+00
 0001617  0.1567E-07  0.2754E-09  0.1640E-07  0.1071E-09  0.0000E+00
 0001618  0.1585E-07  0.2771E-09  0.1548E-07  0.8826E-10  0.0000E+00
 0001619  0.1602E-07  0.2803E-09  0.1535E-07  0.8731E-10  0.0000E+00
 0001620  0.1634E-07  0.2912E-09  0.1523E-07  0.9633E-10  0.0000E+00
 0001621  0.1525E-07  0.2692E-09  0.1530E-07  0.7097E-10  0.0000E+00
 0001622  0.1516E-07  0.2706E-09  0.1528E-07  0.7930E-10  0.0000E+00
 0001623  0.1509E-07  0.2768E-09  0.1529E-07  0.7018E-10  0.0000E+00
 0001624  0.1501E-07  0.2882E-09  0.1537E-07  0.1533E-09  0.0000E+00
 0001625  0.1496E-07  0.2611E-09  0.1555E-07  0.1426E-09  0.0000E+00
 0001626  0.1493E-07  0.2674E-09  0.1589E-07  0.1280E-09  0.0000E+00
 0001627  0.1519E-07  0.2750E-09  0.1470E-07  0.1544E-09  0.0000E+00
 0001628  0.1544E-07  0.2577E-09  0.1457E-07  0.7125E-10  0.0000E+00
 0001629  0.1458E-07  0.2569E-09  0.1462E-07  0.8636E-10  0.0000E+00
 0001630  0.1449E-07  0.2570E-09  0.1458E-07  0.6106E-10  0.0000E+00
 0001631  0.1442E-07  0.2591E-09  0.1457E-07  0.7809E-10  0.0000E+00
 0001632  0.1435E-07  0.2654E-09  0.1461E-07  0.1039E-09  0.0000E+00
 0001633  0.1429E-07  0.2465E-09  0.1473E-07  0.1189E-09  0.0000E+00
 0001634  0.1425E-07  0.2492E-09  0.1498E-07  0.9484E-10  0.0000E+00
 0001635  0.1444E-07  0.2529E-09  0.1406E-07  0.9285E-10  0.0000E+00
 0001636  0.1463E-07  0.2599E-09  0.1394E-07  0.1184E-09  0.0000E+00
 0001637  0.1495E-07  0.2425E-09  0.1382E-07  0.8045E-10  0.0000E+00
 0001638  0.1386E-07  0.2402E-09  0.1391E-07  0.9416E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 28
 0001639  0.1378E-07  0.2399E-09  0.1390E-07  0.6471E-10  0.0000E+00
 0001640  0.1371E-07  0.2423E-09  0.1391E-07  0.8408E-10  0.0000E+00
 0001641  0.1365E-07  0.2495E-09  0.1400E-07  0.1144E-09  0.0000E+00
 0001642  0.1360E-07  0.2323E-09  0.1419E-07  0.1260E-09  0.0000E+00
 0001643  0.1358E-07  0.2370E-09  0.1451E-07  0.1077E-09  0.0000E+00
 0001644  0.1385E-07  0.2419E-09  0.1335E-07  0.1073E-09  0.0000E+00
 0001645  0.1409E-07  0.2516E-09  0.1323E-07  0.6072E-10  0.0000E+00
 0001646  0.1325E-07  0.2269E-09  0.1329E-07  0.5119E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 33
 0001647  0.1317E-07  0.2266E-09  0.1325E-07  0.4988E-10  0.0000E+00
 0001648  0.1310E-07  0.2281E-09  0.1325E-07  0.5009E-10  0.0000E+00
 0001649  0.1304E-07  0.2321E-09  0.1329E-07  0.5019E-10  0.0000E+00
 0001650  0.1299E-07  0.2398E-09  0.1342E-07  0.1037E-09  0.0000E+00
 0001651  0.1296E-07  0.2188E-09  0.1366E-07  0.1108E-09  0.0000E+00
 0001652  0.1315E-07  0.2205E-09  0.1277E-07  0.1012E-09  0.0000E+00
 0001653  0.1334E-07  0.2266E-09  0.1266E-07  0.8936E-10  0.0000E+00
 0001654  0.1366E-07  0.2413E-09  0.1255E-07  0.8178E-10  0.0000E+00
 0001655  0.1260E-07  0.2143E-09  0.1265E-07  0.6578E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 109
 0001656  0.1252E-07  0.2158E-09  0.1263E-07  0.6462E-10  0.0000E+00
 0001657  0.1246E-07  0.2213E-09  0.1265E-07  0.6375E-10  0.0000E+00
 0001658  0.1240E-07  0.2318E-09  0.1274E-07  0.1268E-09  0.0000E+00
 0001659  0.1236E-07  0.2081E-09  0.1292E-07  0.1245E-09  0.0000E+00
 0001660  0.1235E-07  0.2142E-09  0.1324E-07  0.1191E-09  0.0000E+00
 0001661  0.1261E-07  0.2217E-09  0.1213E-07  0.1486E-09  0.0000E+00
 0001662  0.1285E-07  0.2067E-09  0.1202E-07  0.6487E-10  0.0000E+00
 0001663  0.1204E-07  0.2060E-09  0.1208E-07  0.7328E-10  0.0000E+00
 0001664  0.1197E-07  0.2063E-09  0.1205E-07  0.5373E-10  0.0000E+00
 0001665  0.1191E-07  0.2085E-09  0.1204E-07  0.6613E-10  0.0000E+00
 0001666  0.1185E-07  0.2143E-09  0.1209E-07  0.8977E-10  0.0000E+00
 0001667  0.1181E-07  0.1968E-09  0.1221E-07  0.1001E-09  0.0000E+00
 0001668  0.1178E-07  0.1996E-09  0.1244E-07  0.8278E-10  0.0000E+00
 0001669  0.1197E-07  0.2033E-09  0.1160E-07  0.7959E-10  0.0000E+00
 0001670  0.1215E-07  0.2101E-09  0.1151E-07  0.1026E-09  0.0000E+00
 0001671  0.1245E-07  0.1946E-09  0.1140E-07  0.7119E-10  0.0000E+00
 0001672  0.1145E-07  0.1922E-09  0.1149E-07  0.8065E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 24
 0001673  0.1138E-07  0.1922E-09  0.1148E-07  0.5560E-10  0.0000E+00
 0001674  0.1133E-07  0.1946E-09  0.1150E-07  0.7193E-10  0.0000E+00
 0001675  0.1127E-07  0.2014E-09  0.1159E-07  0.9874E-10  0.0000E+00
 0001676  0.1124E-07  0.1860E-09  0.1176E-07  0.7581E-10  0.0000E+00
 0001677  0.1136E-07  0.1872E-09  0.1110E-07  0.6278E-10  0.0000E+00
 0001678  0.1148E-07  0.1896E-09  0.1101E-07  0.6205E-10  0.0000E+00
 0001679  0.1170E-07  0.1976E-09  0.1092E-07  0.6785E-10  0.0000E+00
 0001680  0.1094E-07  0.1819E-09  0.1098E-07  0.5029E-10  0.0000E+00
 0001681  0.1088E-07  0.1830E-09  0.1096E-07  0.5602E-10  0.0000E+00
 0001682  0.1082E-07  0.1875E-09  0.1096E-07  0.4991E-10  0.0000E+00
 0001683  0.1077E-07  0.1956E-09  0.1102E-07  0.1072E-09  0.0000E+00
 0001684  0.1073E-07  0.1768E-09  0.1116E-07  0.9974E-10  0.0000E+00
 0001685  0.1070E-07  0.1815E-09  0.1140E-07  0.9096E-10  0.0000E+00
 0001686  0.1089E-07  0.1868E-09  0.1054E-07  0.1092E-09  0.0000E+00
 0001687  0.1106E-07  0.1748E-09  0.1045E-07  0.5049E-10  0.0000E+00
 0001688  0.1046E-07  0.1743E-09  0.1048E-07  0.6080E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_ITS iterations 10000
 0001689  0.1040E-07  0.1744E-09  0.1046E-07  0.4334E-10  0.0000E+00
 0001690  0.1034E-07  0.1760E-09  0.1045E-07  0.5514E-10  0.0000E+00
 0001691  0.1029E-07  0.1806E-09  0.1048E-07  0.7314E-10  0.0000E+00
 0001692  0.1025E-07  0.1674E-09  0.1057E-07  0.8353E-10  0.0000E+00
 0001693  0.1022E-07  0.1695E-09  0.1075E-07  0.6754E-10  0.0000E+00
 0001694  0.1035E-07  0.1720E-09  0.1008E-07  0.6603E-10  0.0000E+00
 0001695  0.1049E-07  0.1771E-09  0.1000E-07  0.8360E-10  0.0000E+00
 0001696  0.1071E-07  0.1651E-09  0.9915E-08  0.5701E-10  0.0000E+00
 0001697  0.9942E-08  0.1634E-09  0.9978E-08  0.6631E-10  0.0000E+00
TIME FOR CALCULATION:  0.4107E+05
 L2-NORM ERROR U    VELOCITY  1.073664051466740E-005
 L2-NORM ERROR V    VELOCITY  1.133490448715052E-005
 L2-NORM ERROR W    VELOCITY  1.095392594962641E-005
 L2-NORM ERROR ABS. VELOCITY  1.412168740613489E-005
 L2-NORM ERROR      PRESSURE  1.307959628670870E-003
      *** CALCULATION FINISHED - SEE RESULTS ***
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./caffa3d.MB.lnx on a arch-openmpi-opt-intel-hlr-ext named hpb0005 with 1 processor, by gu08vomo Mon Feb 16 23:14:32 2015
Using Petsc Release Version 3.5.3, Jan, 31, 2015
                         Max       Max/Min        Avg      Total
Time (sec):           4.111e+04      1.00000   4.111e+04
Objects:              2.920e+05      1.00000   2.920e+05
Flops:                1.925e+13      1.00000   1.925e+13  1.925e+13
Flops/sec:            4.684e+08      1.00000   4.684e+08  4.684e+08
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 4.5673e+03  11.1%  6.5910e+06   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 1:        MOMENTUM: 1.5111e+03   3.7%  1.2057e+12   6.3%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 2:        PRESCORR: 3.5028e+04  85.2%  1.8048e+13  93.7%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
ThreadCommRunKer    8486 1.0 6.3159e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNorm                1 1.0 2.2623e-01 1.0 4.39e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 67  0  0  0    19
VecScale               1 1.0 1.8220e-03 1.0 2.20e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 33  0  0  0  1206
VecSet             67886 1.0 6.2601e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecScatterBegin    76376 1.0 2.1529e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize           1 1.0 1.8241e-03 1.0 2.20e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 33  0  0  0  1204
MatAssemblyBegin    3394 1.0 9.6750e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd      3394 1.0 6.2648e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
--- Event Stage 1: MOMENTUM
VecMDot             5721 1.0 1.3349e+01 1.0 2.79e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  2  0  0  0  2091
VecNorm            20994 1.0 2.4870e+01 1.0 9.22e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  8  0  0  0  3709
VecScale           10812 1.0 1.4489e+01 1.0 2.38e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  2  0  0  0  1639
VecCopy            10182 1.0 2.1544e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecSet              5091 1.0 4.6968e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY            15273 1.0 3.9258e+01 1.0 6.71e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   3  6  0  0  0  1709
VecMAXPY           10812 1.0 3.1309e+01 1.0 5.30e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  4  0  0  0  1694
VecNormalize       10812 1.0 2.7416e+01 1.0 7.13e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  6  0  0  0  2599
MatMult            15903 1.0 2.8189e+02 1.0 4.32e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0  19 36  0  0  0  1533
MatSolve           15903 1.0 4.5531e+02 1.0 4.32e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0  30 36  0  0  0   949
MatLUFactorNum      1697 1.0 1.7782e+02 1.0 7.75e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  12  6  0  0  0   436
MatILUFactorSym     1697 1.0 1.4325e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   9  0  0  0  0     0
MatGetRowIJ         1697 1.0 3.5739e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering      1697 1.0 1.4906e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
KSPGMRESOrthog      5721 1.0 2.9044e+01 1.0 5.58e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  5  0  0  0  1922
KSPSetUp            5091 1.0 1.4322e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   9  0  0  0  0     0
KSPSolve            5091 1.0 1.2773e+03 1.0 1.02e+12 1.0 0.0e+00 0.0e+00 0.0e+00  3  5  0  0  0  85 85  0  0  0   801
PCSetUp             1697 1.0 3.3801e+02 1.0 7.75e+10 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  22  6  0  0  0   229
PCApply            15903 1.0 4.5533e+02 1.0 4.32e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0  30 36  0  0  0   949
--- Event Stage 2: PRESCORR
VecMDot            90355 1.0 2.2675e+02 1.0 6.19e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0  2731
VecTDot            75581 1.0 1.4988e+02 1.0 3.32e+11 1.0 0.0e+00 0.0e+00 0.0e+00  0  2  0  0  0   0  2  0  0  0  2216
VecNorm            97143 1.0 7.7793e+01 1.0 2.70e+11 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  3470
VecScale           56001 1.0 2.7295e+01 1.0 4.46e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1633
VecCopy            10182 1.0 1.4394e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet            534887 1.0 3.0325e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY            82284 1.0 2.0990e+02 1.0 3.47e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  2  0  0  0  1655
VecAYPX           154386 1.0 2.0929e+02 1.0 2.53e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  1207
VecMAXPY           95446 1.0 2.8455e+02 1.0 7.00e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  4  0  0  0   1  4  0  0  0  2461
VecAssemblyBegin    5091 1.0 4.4203e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd      5091 1.0 6.8688e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult   95446 1.0 7.3898e+01 1.0 4.46e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   603
VecSetRandom        5091 1.0 4.0516e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize       56001 1.0 5.2125e+01 1.0 1.34e+11 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  2566
MatMult           208690 1.0 2.0945e+03 1.0 3.30e+12 1.0 0.0e+00 0.0e+00 0.0e+00  5 17  0  0  0   6 18  0  0  0  1577
MatMultAdd        118335 1.0 8.0683e+02 1.0 6.36e+11 1.0 0.0e+00 0.0e+00 0.0e+00  2  3  0  0  0   2  4  0  0  0   788
MatMultTranspose  197225 1.0 9.2099e+02 1.0 6.36e+11 1.0 0.0e+00 0.0e+00 0.0e+00  2  3  0  0  0   3  4  0  0  0   691
MatSOR            236670 1.0 9.2102e+03 1.0 9.10e+12 1.0 0.0e+00 0.0e+00 0.0e+00 22 47  0  0  0  26 50  0  0  0   988
MatConvert         10182 1.0 1.6989e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale           15273 1.0 1.1443e+02 1.0 9.85e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0   861
MatResidual       118335 1.0 1.0839e+03 1.0 1.65e+12 1.0 0.0e+00 0.0e+00 0.0e+00  3  9  0  0  0   3  9  0  0  0  1526
MatAssemblyBegin   52607 1.0 9.5365e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd     52607 1.0 6.2471e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
MatGetRow        -966829610 1.0 8.1121e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
MatCoarsen          5091 1.0 3.0592e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatView                6 1.0 4.8399e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAXPY             5091 1.0 6.3822e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
MatMatMult          5091 1.0 7.4095e+02 1.0 8.45e+10 1.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0   114
MatMatMultSym       5091 1.0 5.0252e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatMatMultNum       5091 1.0 2.3840e+02 1.0 8.45e+10 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   354
MatPtAP             5091 1.0 3.9072e+03 1.0 5.04e+11 1.0 0.0e+00 0.0e+00 0.0e+00 10  3  0  0  0  11  3  0  0  0   129
MatPtAPSymbolic     5091 1.0 1.4575e+03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  4  0  0  0  0   4  0  0  0  0     0
MatPtAPNumeric      5091 1.0 2.4496e+03 1.0 5.04e+11 1.0 0.0e+00 0.0e+00 0.0e+00  6  3  0  0  0   7  3  0  0  0   206
MatTrnMatMult       5091 1.0 1.0514e+04 1.0 1.07e+12 1.0 0.0e+00 0.0e+00 0.0e+00 26  6  0  0  0  30  6  0  0  0   102
MatTrnMatMultSym    5091 1.0 4.9609e+03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 12  0  0  0  0  14  0  0  0  0     0
MatTrnMatMultNum    5091 1.0 5.5532e+03 1.0 1.07e+12 1.0 0.0e+00 0.0e+00 0.0e+00 14  6  0  0  0  16  6  0  0  0   193
MatGetSymTrans     10182 1.0 2.5778e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
KSPGMRESOrthog     50910 1.0 2.9287e+02 1.0 8.92e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  5  0  0  0   1  5  0  0  0  3045
KSPSetUp           16970 1.0 8.0605e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve            1697 1.0 3.4988e+04 1.0 1.80e+13 1.0 0.0e+00 0.0e+00 0.0e+00 85 93  0  0  0 100100  0  0  0   514
PCGAMGgraph_AGG     5091 1.0 2.4908e+03 1.0 7.12e+10 1.0 0.0e+00 0.0e+00 0.0e+00  6  0  0  0  0   7  0  0  0  0    29
PCGAMGcoarse_AGG    5091 1.0 1.1338e+04 1.0 1.07e+12 1.0 0.0e+00 0.0e+00 0.0e+00 28  6  0  0  0  32  6  0  0  0    95
PCGAMGProl_AGG      5091 1.0 6.5076e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0   2  0  0  0  0     0
PCGAMGPOpt_AGG      5091 1.0 3.0760e+03 1.0 1.94e+12 1.0 0.0e+00 0.0e+00 0.0e+00  7 10  0  0  0   9 11  0  0  0   631
PCSetUp             3394 1.0 2.1549e+04 1.0 3.59e+12 1.0 0.0e+00 0.0e+00 0.0e+00 52 19  0  0  0  62 20  0  0  0   167
PCSetUpOnBlocks    39445 1.0 4.5932e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply            39445 1.0 1.2072e+04 1.0 1.20e+13 1.0 0.0e+00 0.0e+00 0.0e+00 29 62  0  0  0  34 67  0  0  0   996
--- Event Stage 3: Unknown
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector    67             95    833878448     0
      Vector Scatter     2              2         1304     0
           Index Set     4              7     17581544     0
   IS L to G Mapping     2              2     17577192     0
              Matrix     1             11    490350860     0
   Matrix Null Space     0              1          620     0
       Krylov Solver     0              7    117399992     0
      Preconditioner     0              7       482316     0
              Vector 61096          61082  536882926608     0
           Index Set  5091           5088  29812925696     0
              Matrix  1697           1696  358422464000     0
   Matrix Null Space     1              0            0     0
       Krylov Solver     2              0            0     0
      Preconditioner     2              0            0     0
              Vector 156130          156105  816028335912     0
           Index Set  5091           5091      4032072     0
              Matrix 42425          42416  1154972646516     0
      Matrix Coarsen  5091           5091      3278604     0
       Krylov Solver  5096           5091    153829656     0
      Preconditioner  5096           5091      5335368     0
         PetscRandom  5091           5091      3258240     0
              Viewer     1              0            0     0
Average time to get PetscTime(): 0
#PETSc Option Table entries:
-log_summary
-momentum_ksp_type gmres
-options_left
-pressure_ksp_converged_reason
-pressure_mg_coarse_sub_pc_type svd
-pressure_mg_levels_ksp_rtol 1e-4
-pressure_mg_levels_ksp_type richardson
-pressure_mg_levels_pc_type sor
-pressure_pc_gamg_agg_nsmooths 1
-pressure_pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: PETSC_ARCH=arch-openmpi-opt-intel-hlr-ext PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3 -prefix=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr-ext --with-blas-lapack-dir=/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64/ --with-mpi-dir=/shared/apps/openmpi/1.8.2_intel COPTFLAGS="-O3 -xHost" FOPTFLAGS="-O3 -xHost" CXXOPTFLAGS="-O3 -xHost" --with-debugging=0 --download-hypre --download-ml
Libraries compiled on Sun Feb  1 16:09:22 2015 on hla0003
Machine characteristics: Linux-3.0.101-0.40-default-x86_64-with-SuSE-11-x86_64
Using PETSc directory: /home/gu08vomo/soft/petsc/3.5.3
Using PETSc arch: arch-openmpi-opt-intel-hlr-ext
Using C compiler: /shared/apps/openmpi/1.8.2_intel/bin/mpicc  -fPIC -wd1572 -O3 -xHost  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /shared/apps/openmpi/1.8.2_intel/bin/mpif90  -fPIC -O3 -xHost   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/include -I/home/gu08vomo/soft/petsc/3.5.3/include -I/home/gu08vomo/soft/petsc/3.5.3/include -I/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/include -I/shared/apps/openmpi/1.8.2_intel/include
Using C linker: /shared/apps/openmpi/1.8.2_intel/bin/mpicc
Using Fortran linker: /shared/apps/openmpi/1.8.2_intel/bin/mpif90
Using libraries: -Wl,-rpath,/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -L/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -lpetsc -Wl,-rpath,/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -L/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -lHYPRE -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -lmpi_cxx -lml -lmpi_cxx -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -lX11 -lpthread -lssl -lcrypto -lmpi_usempi_ignore_tkr -lmpi_mpifh -lifport -lifcore -lm -lmpi_cxx -ldl -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -lmpi -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -limf -lsvml -lirng -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc_s -lirc -lpthread -lirc_s -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -ldl
-log_summary
-options_left
There are no unused options.
Sender: LSF System <lsfadmin at hpb0093>
Subject: Job 429762: <mg_test> in cluster <lichtenberg> Done
Job <mg_test> was submitted from host <hla0003> by user <gu08vomo> in cluster <lichtenberg>.
Job was executed on host(s) <hpb0093>, in queue <test_mpi2>, as user <gu08vomo> in cluster <lichtenberg>.
</home/gu08vomo> was used as the home directory.
</home/gu08vomo/scratch/thesis/singleblock/128_1_1_seg> was used as the working directory.
Started at Wed Feb 11 00:08:29 2015
Results reported at Wed Feb 11 10:36:23 2015
Your job looked like:
# LSBATCH: User input
#! /bin/sh
#BSUB -J mg_test
#BSUB -o /home/gu08vomo/thesis/mgtest/icc.128.out.%J
#BSUB -n 1
#BSUB -W 14:00
#BSUB -x
#BSUB -q test_mpi2
#BSUB -a openmpi
module load openmpi/intel/1.8.2
#export PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr
export PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr-ext
export MYWORKDIR=/work/scratch/gu08vomo/thesis/singleblock/128_1_1_seg/
export OUTPUTDIR=/home/gu08vomo/thesis/coupling
export PETSC_OPS="-options_file ops.icc"
cat ops.icc
echo "PETSC_DIR="$PETSC_DIR
echo "MYWORKDIR="$MYWORKDIR
cd $MYWORKDIR
mpirun -n 1 ./caffa3d.MB.lnx ${PETSC_OPS}
Successfully completed.
Resource usage summary:
    CPU time :               37692.72 sec.
    Max Memory :             2031 MB
    Average Memory :         2011.15 MB
    Total Requested Memory : -
    Delta Memory :           -
    (Delta: the difference between total requested memory and actual max usage.)
    Max Swap :               2805 MB
    Max Processes :          6
    Max Threads :            11
The output (if any) follows:
Modules: loading openmpi/intel/1.8.2
-log_summary
-options_left
-ressure_pc_type icc
  ENTER PROBLEM NAME (SIX CHARACTERS):
 NAME OF PROBLEM SOLVED control
 CONTROL SETTINGS
 LREAD,LWRITE,LPOST,LTEST,LOUTS,LOUTE,LTIME,LGRAD
 F F T F F F F F
  IMON, JMON, KMON, MMON, RMON,  IPR,  JPR,  KPR,  MPR,NPCOR,NIGRAD
     8     9     8     1     0     2     2     3     1     1     1
  SORMAX,     SLARGE,     ALFA
  0.1000E-07  0.1000E+31  0.9200E+00
 (URF(I),I=1,5)
  0.9000E+00  0.9000E+00  0.9000E+00  0.1000E+00  0.1000E+01
 (SOR(I),I=1,5)
  0.1000E+00  0.1000E+00  0.1000E+00  0.1000E+00  0.1000E+00
 (GDS(I),I=1,5) - BLENDING (CDS-UDS)
  0.1000E+01  0.1000E+01  0.1000E+01  0.1000E+01  0.1000E+01
 LSG
100000
 START SIMPLE RELAXATIONS
Linear solve converged due to CONVERGED_RTOL iterations 29
KSP Object:(pressure_) 1 MPI processes
  type: cg
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=0.1, absolute=1e-50, divergence=10000
  left preconditioning
  has attached null space
  using PRECONDITIONED norm type for convergence test
PC Object:(pressure_) 1 MPI processes
  type: ilu
    ILU: out-of-place factorization
    0 levels of fill
    tolerance for zero pivot 2.22045e-14
    using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
    matrix ordering: natural
    factor fill ratio given 1, needed 1
      Factored matrix follows:
        Mat Object:         1 MPI processes
          type: seqaij
          rows=2197000, cols=2197000
          package used to perform factorization: petsc
          total: nonzeros=1.46816e+07, allocated nonzeros=1.46816e+07
          total number of mallocs used during MatSetValues calls =0
            not using I-node routines
  linear system matrix = precond matrix:
    type: seqaij
 0000001  0.1000E+01  0.1000E+01  0.1000E+01  0.1000E+01  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 31
 0000002  0.8850E+00  0.8273E+00  0.8851E+00  0.7264E+00  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 40
 0000003  0.2792E+00  0.2452E+00  0.2793E+00  0.2116E+00  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 44
 0000004  0.1129E+00  0.9670E-01  0.1130E+00  0.8806E-01  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 30
 0000005  0.4693E-01  0.3579E-01  0.4696E-01  0.5137E-01  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 37
 0000006  0.2598E-01  0.1605E-01  0.2599E-01  0.3425E-01  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 38
 0000007  0.1929E-01  0.1031E-01  0.1929E-01  0.2470E-01  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 59
 0000008  0.1615E-01  0.8123E-02  0.1615E-01  0.1890E-01  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 39
 0000009  0.1412E-01  0.6815E-02  0.1411E-01  0.1504E-01  0.0000E+00
 0000010  0.1260E-01  0.5890E-02  0.1260E-01  0.1227E-01  0.0000E+00
 0000011  0.1141E-01  0.5197E-02  0.1141E-01  0.1019E-01  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 55
 0000012  0.1044E-01  0.4657E-02  0.1044E-01  0.8576E-02  0.0000E+00
 0000013  0.9639E-02  0.4224E-02  0.9637E-02  0.7288E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 48
 0000014  0.8956E-02  0.3875E-02  0.8955E-02  0.6241E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 70
 0000015  0.8372E-02  0.3578E-02  0.8371E-02  0.5377E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 47
 0000016  0.7864E-02  0.3329E-02  0.7862E-02  0.4655E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 51
 0000017  0.7417E-02  0.3116E-02  0.7416E-02  0.4046E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 53
 0000018  0.7022E-02  0.2929E-02  0.7021E-02  0.3528E-02  0.0000E+00
 0000019  0.6668E-02  0.2766E-02  0.6668E-02  0.3085E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 57
 0000020  0.6351E-02  0.2621E-02  0.6350E-02  0.2704E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 61
 0000021  0.6063E-02  0.2492E-02  0.6063E-02  0.2376E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 82
 0000022  0.5802E-02  0.2376E-02  0.5801E-02  0.2091E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 58
 0000023  0.5563E-02  0.2271E-02  0.5562E-02  0.1843E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 62
 0000024  0.5344E-02  0.2176E-02  0.5343E-02  0.1627E-02  0.0000E+00
 0000025  0.5141E-02  0.2088E-02  0.5141E-02  0.1438E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 85
 0000026  0.4954E-02  0.2008E-02  0.4953E-02  0.1273E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 86
 0000027  0.4780E-02  0.1934E-02  0.4780E-02  0.1128E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 87
 0000028  0.4618E-02  0.1865E-02  0.4618E-02  0.1001E-02  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 88
 0000029  0.4467E-02  0.1801E-02  0.4467E-02  0.8886E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 89
 0000030  0.4326E-02  0.1741E-02  0.4325E-02  0.7898E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 91
 0000031  0.4193E-02  0.1686E-02  0.4192E-02  0.7026E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 92
 0000032  0.4068E-02  0.1633E-02  0.4067E-02  0.6256E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 110
 0000033  0.3950E-02  0.1584E-02  0.3950E-02  0.5576E-03  0.0000E+00
 0000034  0.3838E-02  0.1538E-02  0.3838E-02  0.4974E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 112
 0000035  0.3733E-02  0.1494E-02  0.3733E-02  0.4442E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 124
 0000036  0.3633E-02  0.1453E-02  0.3633E-02  0.3970E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 126
 0000037  0.3538E-02  0.1413E-02  0.3538E-02  0.3552E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 128
 0000038  0.3448E-02  0.1376E-02  0.3448E-02  0.3181E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 130
 0000039  0.3362E-02  0.1340E-02  0.3362E-02  0.2853E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 136
 0000040  0.3280E-02  0.1307E-02  0.3280E-02  0.2561E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 138
 0000041  0.3202E-02  0.1274E-02  0.3202E-02  0.2302E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 143
 0000042  0.3127E-02  0.1243E-02  0.3127E-02  0.2072E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 145
 0000043  0.3055E-02  0.1214E-02  0.3055E-02  0.1868E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 146
 0000044  0.2986E-02  0.1186E-02  0.2986E-02  0.1686E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 148
 0000045  0.2920E-02  0.1159E-02  0.2921E-02  0.1525E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 149
 0000046  0.2857E-02  0.1133E-02  0.2857E-02  0.1381E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 150
 0000047  0.2796E-02  0.1108E-02  0.2796E-02  0.1254E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 151
 0000048  0.2738E-02  0.1084E-02  0.2738E-02  0.1141E-03  0.0000E+00
 0000049  0.2682E-02  0.1061E-02  0.2682E-02  0.1040E-03  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 152
 0000050  0.2627E-02  0.1038E-02  0.2627E-02  0.9501E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 153
 0000051  0.2575E-02  0.1017E-02  0.2575E-02  0.8702E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 154
 0000052  0.2524E-02  0.9962E-03  0.2525E-02  0.7992E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 155
 0000053  0.2476E-02  0.9762E-03  0.2476E-02  0.7359E-04  0.0000E+00
 0000054  0.2429E-02  0.9569E-03  0.2429E-02  0.6795E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 156
 0000055  0.2383E-02  0.9383E-03  0.2383E-02  0.6291E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 157
 0000056  0.2339E-02  0.9202E-03  0.2339E-02  0.5842E-04  0.0000E+00
 0000057  0.2296E-02  0.9028E-03  0.2296E-02  0.5440E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 159
 0000058  0.2255E-02  0.8859E-03  0.2255E-02  0.5081E-04  0.0000E+00
 0000059  0.2215E-02  0.8695E-03  0.2215E-02  0.4759E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 160
 0000060  0.2176E-02  0.8537E-03  0.2176E-02  0.4470E-04  0.0000E+00
 0000061  0.2138E-02  0.8383E-03  0.2138E-02  0.4210E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 161
 0000062  0.2101E-02  0.8233E-03  0.2102E-02  0.3975E-04  0.0000E+00
 0000063  0.2066E-02  0.8088E-03  0.2066E-02  0.3763E-04  0.0000E+00
 0000064  0.2031E-02  0.7947E-03  0.2032E-02  0.3571E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 162
 0000065  0.1998E-02  0.7810E-03  0.1998E-02  0.3397E-04  0.0000E+00
 0000066  0.1965E-02  0.7677E-03  0.1965E-02  0.3239E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 163
 0000067  0.1933E-02  0.7548E-03  0.1933E-02  0.3094E-04  0.0000E+00
 0000068  0.1902E-02  0.7422E-03  0.1902E-02  0.2961E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 164
 0000069  0.1872E-02  0.7299E-03  0.1872E-02  0.2839E-04  0.0000E+00
 0000070  0.1842E-02  0.7180E-03  0.1843E-02  0.2727E-04  0.0000E+00
 0000071  0.1814E-02  0.7064E-03  0.1814E-02  0.2623E-04  0.0000E+00
 0000072  0.1786E-02  0.6950E-03  0.1786E-02  0.2527E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 165
 0000073  0.1759E-02  0.6840E-03  0.1759E-02  0.2437E-04  0.0000E+00
 0000074  0.1732E-02  0.6732E-03  0.1732E-02  0.2354E-04  0.0000E+00
 0000075  0.1706E-02  0.6627E-03  0.1706E-02  0.2276E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 166
 0000076  0.1681E-02  0.6524E-03  0.1681E-02  0.2203E-04  0.0000E+00
 0000077  0.1656E-02  0.6424E-03  0.1656E-02  0.2135E-04  0.0000E+00
 0000078  0.1632E-02  0.6326E-03  0.1632E-02  0.2070E-04  0.0000E+00
 0000079  0.1608E-02  0.6231E-03  0.1608E-02  0.2009E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 167
 0000080  0.1585E-02  0.6138E-03  0.1585E-02  0.1951E-04  0.0000E+00
 0000081  0.1562E-02  0.6046E-03  0.1563E-02  0.1897E-04  0.0000E+00
 0000082  0.1540E-02  0.5957E-03  0.1540E-02  0.1845E-04  0.0000E+00
 0000083  0.1519E-02  0.5870E-03  0.1519E-02  0.1796E-04  0.0000E+00
 0000084  0.1497E-02  0.5785E-03  0.1498E-02  0.1749E-04  0.0000E+00
 0000085  0.1477E-02  0.5702E-03  0.1477E-02  0.1704E-04  0.0000E+00
 0000086  0.1456E-02  0.5620E-03  0.1457E-02  0.1661E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 168
 0000087  0.1436E-02  0.5540E-03  0.1437E-02  0.1620E-04  0.0000E+00
 0000088  0.1417E-02  0.5462E-03  0.1417E-02  0.1581E-04  0.0000E+00
 0000089  0.1398E-02  0.5385E-03  0.1398E-02  0.1543E-04  0.0000E+00
 0000090  0.1379E-02  0.5310E-03  0.1380E-02  0.1507E-04  0.0000E+00
 0000091  0.1361E-02  0.5237E-03  0.1361E-02  0.1472E-04  0.0000E+00
 0000092  0.1343E-02  0.5165E-03  0.1343E-02  0.1438E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 169
 0000093  0.1325E-02  0.5095E-03  0.1326E-02  0.1406E-04  0.0000E+00
 0000094  0.1308E-02  0.5025E-03  0.1308E-02  0.1375E-04  0.0000E+00
 0000095  0.1291E-02  0.4958E-03  0.1291E-02  0.1345E-04  0.0000E+00
 0000096  0.1274E-02  0.4891E-03  0.1275E-02  0.1316E-04  0.0000E+00
 0000097  0.1258E-02  0.4826E-03  0.1258E-02  0.1288E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 170
 0000098  0.1242E-02  0.4762E-03  0.1242E-02  0.1261E-04  0.0000E+00
 0000099  0.1226E-02  0.4699E-03  0.1227E-02  0.1234E-04  0.0000E+00
 0000100  0.1211E-02  0.4638E-03  0.1211E-02  0.1209E-04  0.0000E+00
 0000101  0.1196E-02  0.4577E-03  0.1196E-02  0.1185E-04  0.0000E+00
 0000102  0.1181E-02  0.4518E-03  0.1181E-02  0.1161E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 171
 0000103  0.1166E-02  0.4460E-03  0.1166E-02  0.1138E-04  0.0000E+00
 0000104  0.1152E-02  0.4403E-03  0.1152E-02  0.1115E-04  0.0000E+00
 0000105  0.1138E-02  0.4347E-03  0.1138E-02  0.1093E-04  0.0000E+00
 0000106  0.1124E-02  0.4291E-03  0.1124E-02  0.1072E-04  0.0000E+00
 0000107  0.1110E-02  0.4237E-03  0.1110E-02  0.1052E-04  0.0000E+00
 0000108  0.1097E-02  0.4184E-03  0.1097E-02  0.1032E-04  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 172
 0000109  0.1083E-02  0.4132E-03  0.1083E-02  0.1012E-04  0.0000E+00
 0000110  0.1070E-02  0.4080E-03  0.1070E-02  0.9936E-05  0.0000E+00
 0000111  0.1058E-02  0.4030E-03  0.1058E-02  0.9752E-05  0.0000E+00
 0000112  0.1045E-02  0.3980E-03  0.1045E-02  0.9574E-05  0.0000E+00
 0000113  0.1033E-02  0.3931E-03  0.1033E-02  0.9400E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 173
 0000114  0.1020E-02  0.3883E-03  0.1020E-02  0.9231E-05  0.0000E+00
 0000115  0.1008E-02  0.3836E-03  0.1008E-02  0.9066E-05  0.0000E+00
 0000116  0.9965E-03  0.3789E-03  0.9966E-03  0.8905E-05  0.0000E+00
 0000117  0.9849E-03  0.3743E-03  0.9850E-03  0.8749E-05  0.0000E+00
 0000118  0.9734E-03  0.3698E-03  0.9735E-03  0.8596E-05  0.0000E+00
 0000119  0.9621E-03  0.3654E-03  0.9622E-03  0.8447E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 174
 0000120  0.9510E-03  0.3611E-03  0.9511E-03  0.8302E-05  0.0000E+00
 0000121  0.9401E-03  0.3568E-03  0.9402E-03  0.8160E-05  0.0000E+00
 0000122  0.9293E-03  0.3525E-03  0.9294E-03  0.8022E-05  0.0000E+00
 0000123  0.9187E-03  0.3484E-03  0.9188E-03  0.7887E-05  0.0000E+00
 0000124  0.9082E-03  0.3443E-03  0.9083E-03  0.7755E-05  0.0000E+00
 0000125  0.8979E-03  0.3403E-03  0.8980E-03  0.7626E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 175
 0000126  0.8877E-03  0.3363E-03  0.8878E-03  0.7501E-05  0.0000E+00
 0000127  0.8777E-03  0.3324E-03  0.8778E-03  0.7378E-05  0.0000E+00
 0000128  0.8678E-03  0.3285E-03  0.8679E-03  0.7258E-05  0.0000E+00
 0000129  0.8581E-03  0.3248E-03  0.8582E-03  0.7140E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 176
 0000130  0.8485E-03  0.3210E-03  0.8485E-03  0.7025E-05  0.0000E+00
 0000131  0.8390E-03  0.3173E-03  0.8391E-03  0.6913E-05  0.0000E+00
 0000132  0.8297E-03  0.3137E-03  0.8297E-03  0.6804E-05  0.0000E+00
 0000133  0.8205E-03  0.3101E-03  0.8205E-03  0.6696E-05  0.0000E+00
 0000134  0.8114E-03  0.3066E-03  0.8114E-03  0.6591E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 177
 0000135  0.8025E-03  0.3032E-03  0.8025E-03  0.6489E-05  0.0000E+00
 0000136  0.7936E-03  0.2997E-03  0.7937E-03  0.6388E-05  0.0000E+00
 0000137  0.7849E-03  0.2964E-03  0.7849E-03  0.6290E-05  0.0000E+00
 0000138  0.7763E-03  0.2930E-03  0.7763E-03  0.6193E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 178
 0000139  0.7678E-03  0.2898E-03  0.7678E-03  0.6099E-05  0.0000E+00
 0000140  0.7595E-03  0.2865E-03  0.7595E-03  0.6006E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 179
 0000141  0.7512E-03  0.2833E-03  0.7512E-03  0.5916E-05  0.0000E+00
 0000142  0.7431E-03  0.2802E-03  0.7430E-03  0.5827E-05  0.0000E+00
 0000143  0.7350E-03  0.2771E-03  0.7350E-03  0.5740E-05  0.0000E+00
 0000144  0.7271E-03  0.2740E-03  0.7270E-03  0.5655E-05  0.0000E+00
 0000145  0.7192E-03  0.2710E-03  0.7192E-03  0.5572E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 180
 0000146  0.7115E-03  0.2681E-03  0.7115E-03  0.5490E-05  0.0000E+00
 0000147  0.7039E-03  0.2651E-03  0.7038E-03  0.5410E-05  0.0000E+00
 0000148  0.6963E-03  0.2622E-03  0.6963E-03  0.5331E-05  0.0000E+00
 0000149  0.6889E-03  0.2594E-03  0.6888E-03  0.5254E-05  0.0000E+00
 0000150  0.6815E-03  0.2565E-03  0.6815E-03  0.5178E-05  0.0000E+00
 0000151  0.6743E-03  0.2538E-03  0.6742E-03  0.5104E-05  0.0000E+00
 0000152  0.6671E-03  0.2510E-03  0.6670E-03  0.5031E-05  0.0000E+00
 0000153  0.6600E-03  0.2483E-03  0.6599E-03  0.4960E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 181
 0000154  0.6530E-03  0.2456E-03  0.6529E-03  0.4890E-05  0.0000E+00
 0000155  0.6461E-03  0.2430E-03  0.6460E-03  0.4821E-05  0.0000E+00
 0000156  0.6393E-03  0.2404E-03  0.6392E-03  0.4754E-05  0.0000E+00
 0000157  0.6325E-03  0.2378E-03  0.6324E-03  0.4687E-05  0.0000E+00
 0000158  0.6259E-03  0.2353E-03  0.6258E-03  0.4622E-05  0.0000E+00
 0000159  0.6193E-03  0.2328E-03  0.6192E-03  0.4558E-05  0.0000E+00
 0000160  0.6128E-03  0.2303E-03  0.6127E-03  0.4496E-05  0.0000E+00
 0000161  0.6064E-03  0.2279E-03  0.6062E-03  0.4434E-05  0.0000E+00
 0000162  0.6000E-03  0.2254E-03  0.5999E-03  0.4374E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 182
 0000163  0.5937E-03  0.2231E-03  0.5936E-03  0.4314E-05  0.0000E+00
 0000164  0.5875E-03  0.2207E-03  0.5874E-03  0.4256E-05  0.0000E+00
 0000165  0.5814E-03  0.2184E-03  0.5813E-03  0.4198E-05  0.0000E+00
 0000166  0.5754E-03  0.2161E-03  0.5752E-03  0.4142E-05  0.0000E+00
 0000167  0.5694E-03  0.2138E-03  0.5692E-03  0.4087E-05  0.0000E+00
 0000168  0.5635E-03  0.2116E-03  0.5633E-03  0.4032E-05  0.0000E+00
 0000169  0.5576E-03  0.2094E-03  0.5575E-03  0.3979E-05  0.0000E+00
 0000170  0.5519E-03  0.2072E-03  0.5517E-03  0.3926E-05  0.0000E+00
 0000171  0.5461E-03  0.2050E-03  0.5460E-03  0.3874E-05  0.0000E+00
 0000172  0.5405E-03  0.2029E-03  0.5403E-03  0.3823E-05  0.0000E+00
 0000173  0.5349E-03  0.2008E-03  0.5348E-03  0.3773E-05  0.0000E+00
 0000174  0.5294E-03  0.1987E-03  0.5292E-03  0.3724E-05  0.0000E+00
 0000175  0.5240E-03  0.1966E-03  0.5238E-03  0.3676E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 183
 0000176  0.5186E-03  0.1946E-03  0.5184E-03  0.3628E-05  0.0000E+00
 0000177  0.5132E-03  0.1926E-03  0.5131E-03  0.3582E-05  0.0000E+00
 0000178  0.5080E-03  0.1906E-03  0.5078E-03  0.3535E-05  0.0000E+00
 0000179  0.5028E-03  0.1887E-03  0.5026E-03  0.3490E-05  0.0000E+00
 0000180  0.4976E-03  0.1867E-03  0.4974E-03  0.3446E-05  0.0000E+00
 0000181  0.4925E-03  0.1848E-03  0.4923E-03  0.3402E-05  0.0000E+00
 0000182  0.4875E-03  0.1829E-03  0.4873E-03  0.3359E-05  0.0000E+00
 0000183  0.4825E-03  0.1810E-03  0.4823E-03  0.3316E-05  0.0000E+00
 0000184  0.4776E-03  0.1792E-03  0.4774E-03  0.3274E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 184
 0000185  0.4727E-03  0.1773E-03  0.4725E-03  0.3233E-05  0.0000E+00
 0000186  0.4679E-03  0.1755E-03  0.4677E-03  0.3193E-05  0.0000E+00
 0000187  0.4631E-03  0.1738E-03  0.4629E-03  0.3153E-05  0.0000E+00
 0000188  0.4584E-03  0.1720E-03  0.4582E-03  0.3114E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 185
 0000189  0.4537E-03  0.1702E-03  0.4535E-03  0.3075E-05  0.0000E+00
 0000190  0.4491E-03  0.1685E-03  0.4489E-03  0.3037E-05  0.0000E+00
 0000191  0.4446E-03  0.1668E-03  0.4444E-03  0.2999E-05  0.0000E+00
 0000192  0.4401E-03  0.1651E-03  0.4399E-03  0.2962E-05  0.0000E+00
 0000193  0.4356E-03  0.1634E-03  0.4354E-03  0.2926E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 186
 0000194  0.4312E-03  0.1618E-03  0.4310E-03  0.2890E-05  0.0000E+00
 0000195  0.4268E-03  0.1602E-03  0.4266E-03  0.2855E-05  0.0000E+00
 0000196  0.4225E-03  0.1585E-03  0.4223E-03  0.2820E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 187
 0000197  0.4183E-03  0.1569E-03  0.4180E-03  0.2786E-05  0.0000E+00
 0000198  0.4140E-03  0.1554E-03  0.4138E-03  0.2752E-05  0.0000E+00
 0000199  0.4099E-03  0.1538E-03  0.4096E-03  0.2719E-05  0.0000E+00
 0000200  0.4057E-03  0.1523E-03  0.4055E-03  0.2686E-05  0.0000E+00
 0000201  0.4016E-03  0.1507E-03  0.4014E-03  0.2654E-05  0.0000E+00
 0000202  0.3976E-03  0.1492E-03  0.3974E-03  0.2622E-05  0.0000E+00
 0000203  0.3936E-03  0.1477E-03  0.3934E-03  0.2591E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 188
 0000204  0.3896E-03  0.1462E-03  0.3894E-03  0.2560E-05  0.0000E+00
 0000205  0.3857E-03  0.1448E-03  0.3855E-03  0.2530E-05  0.0000E+00
 0000206  0.3818E-03  0.1433E-03  0.3816E-03  0.2500E-05  0.0000E+00
 0000207  0.3780E-03  0.1419E-03  0.3778E-03  0.2470E-05  0.0000E+00
 0000208  0.3742E-03  0.1405E-03  0.3740E-03  0.2441E-05  0.0000E+00
 0000209  0.3704E-03  0.1391E-03  0.3702E-03  0.2412E-05  0.0000E+00
 0000210  0.3667E-03  0.1377E-03  0.3665E-03  0.2384E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 191
 0000211  0.3631E-03  0.1363E-03  0.3628E-03  0.2356E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 192
 0000212  0.3594E-03  0.1350E-03  0.3592E-03  0.2328E-05  0.0000E+00
 0000213  0.3558E-03  0.1336E-03  0.3556E-03  0.2301E-05  0.0000E+00
 0000214  0.3523E-03  0.1323E-03  0.3520E-03  0.2274E-05  0.0000E+00
 0000215  0.3487E-03  0.1310E-03  0.3485E-03  0.2248E-05  0.0000E+00
 0000216  0.3453E-03  0.1297E-03  0.3450E-03  0.2222E-05  0.0000E+00
 0000217  0.3418E-03  0.1284E-03  0.3416E-03  0.2196E-05  0.0000E+00
 0000218  0.3384E-03  0.1271E-03  0.3382E-03  0.2170E-05  0.0000E+00
 0000219  0.3350E-03  0.1259E-03  0.3348E-03  0.2145E-05  0.0000E+00
 0000220  0.3317E-03  0.1246E-03  0.3314E-03  0.2121E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 193
 0000221  0.3284E-03  0.1234E-03  0.3281E-03  0.2096E-05  0.0000E+00
 0000222  0.3251E-03  0.1222E-03  0.3248E-03  0.2072E-05  0.0000E+00
 0000223  0.3218E-03  0.1210E-03  0.3216E-03  0.2049E-05  0.0000E+00
 0000224  0.3186E-03  0.1198E-03  0.3184E-03  0.2025E-05  0.0000E+00
 0000225  0.3155E-03  0.1186E-03  0.3152E-03  0.2002E-05  0.0000E+00
 0000226  0.3123E-03  0.1174E-03  0.3121E-03  0.1979E-05  0.0000E+00
 0000227  0.3092E-03  0.1163E-03  0.3090E-03  0.1957E-05  0.0000E+00
 0000228  0.3061E-03  0.1151E-03  0.3059E-03  0.1935E-05  0.0000E+00
 0000229  0.3031E-03  0.1140E-03  0.3029E-03  0.1913E-05  0.0000E+00
 0000230  0.3001E-03  0.1129E-03  0.2998E-03  0.1891E-05  0.0000E+00
 0000231  0.2971E-03  0.1118E-03  0.2969E-03  0.1870E-05  0.0000E+00
 0000232  0.2942E-03  0.1107E-03  0.2939E-03  0.1849E-05  0.0000E+00
 0000233  0.2912E-03  0.1096E-03  0.2910E-03  0.1828E-05  0.0000E+00
 0000234  0.2883E-03  0.1085E-03  0.2881E-03  0.1808E-05  0.0000E+00
 0000235  0.2855E-03  0.1074E-03  0.2852E-03  0.1787E-05  0.0000E+00
 0000236  0.2827E-03  0.1064E-03  0.2824E-03  0.1767E-05  0.0000E+00
 0000237  0.2799E-03  0.1053E-03  0.2796E-03  0.1748E-05  0.0000E+00
 0000238  0.2771E-03  0.1043E-03  0.2768E-03  0.1728E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 194
 0000239  0.2743E-03  0.1033E-03  0.2741E-03  0.1709E-05  0.0000E+00
 0000240  0.2716E-03  0.1023E-03  0.2714E-03  0.1690E-05  0.0000E+00
 0000241  0.2689E-03  0.1013E-03  0.2687E-03  0.1671E-05  0.0000E+00
 0000242  0.2663E-03  0.1003E-03  0.2660E-03  0.1653E-05  0.0000E+00
 0000243  0.2636E-03  0.9931E-04  0.2634E-03  0.1635E-05  0.0000E+00
 0000244  0.2610E-03  0.9834E-04  0.2608E-03  0.1616E-05  0.0000E+00
 0000245  0.2584E-03  0.9738E-04  0.2582E-03  0.1599E-05  0.0000E+00
 0000246  0.2559E-03  0.9643E-04  0.2557E-03  0.1581E-05  0.0000E+00
 0000247  0.2534E-03  0.9548E-04  0.2531E-03  0.1564E-05  0.0000E+00
 0000248  0.2509E-03  0.9455E-04  0.2506E-03  0.1547E-05  0.0000E+00
 0000249  0.2484E-03  0.9363E-04  0.2481E-03  0.1530E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 195
 0000250  0.2459E-03  0.9272E-04  0.2457E-03  0.1513E-05  0.0000E+00
 0000251  0.2435E-03  0.9181E-04  0.2433E-03  0.1496E-05  0.0000E+00
 0000252  0.2411E-03  0.9092E-04  0.2409E-03  0.1480E-05  0.0000E+00
 0000253  0.2387E-03  0.9003E-04  0.2385E-03  0.1464E-05  0.0000E+00
 0000254  0.2364E-03  0.8915E-04  0.2361E-03  0.1448E-05  0.0000E+00
 0000255  0.2340E-03  0.8828E-04  0.2338E-03  0.1432E-05  0.0000E+00
 0000256  0.2317E-03  0.8742E-04  0.2315E-03  0.1417E-05  0.0000E+00
 0000257  0.2294E-03  0.8657E-04  0.2292E-03  0.1401E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 196
 0000258  0.2272E-03  0.8573E-04  0.2269E-03  0.1386E-05  0.0000E+00
 0000259  0.2249E-03  0.8490E-04  0.2247E-03  0.1371E-05  0.0000E+00
 0000260  0.2227E-03  0.8407E-04  0.2225E-03  0.1356E-05  0.0000E+00
 0000261  0.2205E-03  0.8325E-04  0.2203E-03  0.1342E-05  0.0000E+00
 0000262  0.2184E-03  0.8244E-04  0.2181E-03  0.1327E-05  0.0000E+00
 0000263  0.2162E-03  0.8164E-04  0.2160E-03  0.1313E-05  0.0000E+00
 0000264  0.2141E-03  0.8085E-04  0.2139E-03  0.1299E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 197
 0000265  0.2120E-03  0.8006E-04  0.2118E-03  0.1285E-05  0.0000E+00
 0000266  0.2099E-03  0.7928E-04  0.2097E-03  0.1271E-05  0.0000E+00
 0000267  0.2078E-03  0.7851E-04  0.2076E-03  0.1258E-05  0.0000E+00
 0000268  0.2058E-03  0.7775E-04  0.2056E-03  0.1244E-05  0.0000E+00
 0000269  0.2038E-03  0.7700E-04  0.2035E-03  0.1231E-05  0.0000E+00
 0000270  0.2018E-03  0.7625E-04  0.2015E-03  0.1218E-05  0.0000E+00
 0000271  0.1998E-03  0.7551E-04  0.1996E-03  0.1205E-05  0.0000E+00
 0000272  0.1978E-03  0.7478E-04  0.1976E-03  0.1192E-05  0.0000E+00
 0000273  0.1959E-03  0.7405E-04  0.1957E-03  0.1179E-05  0.0000E+00
 0000274  0.1939E-03  0.7333E-04  0.1937E-03  0.1167E-05  0.0000E+00
 0000275  0.1920E-03  0.7262E-04  0.1918E-03  0.1154E-05  0.0000E+00
 0000276  0.1902E-03  0.7192E-04  0.1899E-03  0.1142E-05  0.0000E+00
 0000277  0.1883E-03  0.7122E-04  0.1881E-03  0.1130E-05  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 198
 0000278  0.1864E-03  0.7053E-04  0.1862E-03  0.1118E-05  0.0000E+00
 0000279  0.1846E-03  0.6985E-04  0.1844E-03  0.1106E-05  0.0000E+00
 0000280  0.1828E-03  0.6917E-04  0.1826E-03  0.1094E-05  0.0000E+00
 0000281  0.1810E-03  0.6850E-04  0.1808E-03  0.1083E-05  0.0000E+00
 0000282  0.1792E-03  0.6783E-04  0.1790E-03  0.1071E-05  0.0000E+00
 0000283  0.1775E-03  0.6718E-04  0.1773E-03  0.1060E-05  0.0000E+00
 0000284  0.1757E-03  0.6653E-04  0.1755E-03  0.1049E-05  0.0000E+00
 0000285  0.1740E-03  0.6588E-04  0.1738E-03  0.1038E-05  0.0000E+00
 0000286  0.1723E-03  0.6524E-04  0.1721E-03  0.1027E-05  0.0000E+00
 0000287  0.1706E-03  0.6461E-04  0.1704E-03  0.1016E-05  0.0000E+00
 0000288  0.1690E-03  0.6399E-04  0.1688E-03  0.1006E-05  0.0000E+00
 0000289  0.1673E-03  0.6337E-04  0.1671E-03  0.9951E-06  0.0000E+00
 0000290  0.1657E-03  0.6275E-04  0.1655E-03  0.9847E-06  0.0000E+00
 0000291  0.1640E-03  0.6215E-04  0.1639E-03  0.9744E-06  0.0000E+00
 0000292  0.1624E-03  0.6155E-04  0.1623E-03  0.9643E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 199
 0000293  0.1608E-03  0.6095E-04  0.1607E-03  0.9542E-06  0.0000E+00
 0000294  0.1593E-03  0.6036E-04  0.1591E-03  0.9442E-06  0.0000E+00
 0000295  0.1577E-03  0.5978E-04  0.1575E-03  0.9344E-06  0.0000E+00
 0000296  0.1562E-03  0.5920E-04  0.1560E-03  0.9247E-06  0.0000E+00
 0000297  0.1546E-03  0.5862E-04  0.1545E-03  0.9150E-06  0.0000E+00
 0000298  0.1531E-03  0.5806E-04  0.1530E-03  0.9055E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 200
 0000299  0.1516E-03  0.5750E-04  0.1515E-03  0.8961E-06  0.0000E+00
 0000300  0.1502E-03  0.5694E-04  0.1500E-03  0.8868E-06  0.0000E+00
 0000301  0.1487E-03  0.5639E-04  0.1485E-03  0.8776E-06  0.0000E+00
 0000302  0.1472E-03  0.5584E-04  0.1471E-03  0.8685E-06  0.0000E+00
 0000303  0.1458E-03  0.5530E-04  0.1456E-03  0.8595E-06  0.0000E+00
 0000304  0.1444E-03  0.5477E-04  0.1442E-03  0.8506E-06  0.0000E+00
 0000305  0.1430E-03  0.5424E-04  0.1428E-03  0.8419E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 201
 0000306  0.1416E-03  0.5371E-04  0.1414E-03  0.8332E-06  0.0000E+00
 0000307  0.1402E-03  0.5320E-04  0.1400E-03  0.8246E-06  0.0000E+00
 0000308  0.1388E-03  0.5268E-04  0.1387E-03  0.8160E-06  0.0000E+00
 0000309  0.1375E-03  0.5217E-04  0.1373E-03  0.8076E-06  0.0000E+00
 0000310  0.1361E-03  0.5167E-04  0.1360E-03  0.7993E-06  0.0000E+00
 0000311  0.1348E-03  0.5117E-04  0.1346E-03  0.7911E-06  0.0000E+00
 0000312  0.1335E-03  0.5067E-04  0.1333E-03  0.7829E-06  0.0000E+00
 0000313  0.1322E-03  0.5018E-04  0.1320E-03  0.7749E-06  0.0000E+00
 0000314  0.1309E-03  0.4970E-04  0.1308E-03  0.7669E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 202
 0000315  0.1296E-03  0.4922E-04  0.1295E-03  0.7591E-06  0.0000E+00
 0000316  0.1284E-03  0.4874E-04  0.1282E-03  0.7513E-06  0.0000E+00
 0000317  0.1271E-03  0.4827E-04  0.1270E-03  0.7436E-06  0.0000E+00
 0000318  0.1259E-03  0.4780E-04  0.1257E-03  0.7359E-06  0.0000E+00
 0000319  0.1246E-03  0.4734E-04  0.1245E-03  0.7284E-06  0.0000E+00
 0000320  0.1234E-03  0.4688E-04  0.1233E-03  0.7210E-06  0.0000E+00
 0000321  0.1222E-03  0.4643E-04  0.1221E-03  0.7136E-06  0.0000E+00
 0000322  0.1210E-03  0.4598E-04  0.1209E-03  0.7063E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 203
 0000323  0.1199E-03  0.4554E-04  0.1197E-03  0.6991E-06  0.0000E+00
 0000324  0.1187E-03  0.4510E-04  0.1186E-03  0.6919E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 204
 0000325  0.1175E-03  0.4466E-04  0.1174E-03  0.6849E-06  0.0000E+00
 0000326  0.1164E-03  0.4423E-04  0.1163E-03  0.6779E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 205
 0000327  0.1153E-03  0.4380E-04  0.1151E-03  0.6710E-06  0.0000E+00
 0000328  0.1142E-03  0.4338E-04  0.1140E-03  0.6642E-06  0.0000E+00
 0000329  0.1130E-03  0.4296E-04  0.1129E-03  0.6574E-06  0.0000E+00
 0000330  0.1119E-03  0.4255E-04  0.1118E-03  0.6507E-06  0.0000E+00
 0000331  0.1109E-03  0.4213E-04  0.1107E-03  0.6441E-06  0.0000E+00
 0000332  0.1098E-03  0.4173E-04  0.1097E-03  0.6375E-06  0.0000E+00
 0000333  0.1087E-03  0.4132E-04  0.1086E-03  0.6311E-06  0.0000E+00
 0000334  0.1077E-03  0.4092E-04  0.1075E-03  0.6247E-06  0.0000E+00
 0000335  0.1066E-03  0.4053E-04  0.1065E-03  0.6183E-06  0.0000E+00
 0000336  0.1056E-03  0.4014E-04  0.1055E-03  0.6121E-06  0.0000E+00
 0000337  0.1046E-03  0.3975E-04  0.1044E-03  0.6059E-06  0.0000E+00
 0000338  0.1035E-03  0.3937E-04  0.1034E-03  0.5997E-06  0.0000E+00
 0000339  0.1025E-03  0.3899E-04  0.1024E-03  0.5937E-06  0.0000E+00
 0000340  0.1015E-03  0.3861E-04  0.1014E-03  0.5876E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 206
 0000341  0.1006E-03  0.3824E-04  0.1004E-03  0.5817E-06  0.0000E+00
 0000342  0.9958E-04  0.3787E-04  0.9947E-04  0.5758E-06  0.0000E+00
 0000343  0.9862E-04  0.3750E-04  0.9851E-04  0.5700E-06  0.0000E+00
 0000344  0.9766E-04  0.3714E-04  0.9755E-04  0.5643E-06  0.0000E+00
 0000345  0.9671E-04  0.3678E-04  0.9661E-04  0.5586E-06  0.0000E+00
 0000346  0.9578E-04  0.3642E-04  0.9567E-04  0.5529E-06  0.0000E+00
 0000347  0.9485E-04  0.3607E-04  0.9474E-04  0.5473E-06  0.0000E+00
 0000348  0.9393E-04  0.3572E-04  0.9383E-04  0.5418E-06  0.0000E+00
 0000349  0.9302E-04  0.3538E-04  0.9292E-04  0.5364E-06  0.0000E+00
 0000350  0.9212E-04  0.3504E-04  0.9202E-04  0.5310E-06  0.0000E+00
 0000351  0.9123E-04  0.3470E-04  0.9113E-04  0.5256E-06  0.0000E+00
 0000352  0.9035E-04  0.3436E-04  0.9025E-04  0.5203E-06  0.0000E+00
 0000353  0.8947E-04  0.3403E-04  0.8938E-04  0.5151E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 207
 0000354  0.8861E-04  0.3370E-04  0.8851E-04  0.5099E-06  0.0000E+00
 0000355  0.8775E-04  0.3337E-04  0.8766E-04  0.5048E-06  0.0000E+00
 0000356  0.8690E-04  0.3305E-04  0.8681E-04  0.4997E-06  0.0000E+00
 0000357  0.8606E-04  0.3273E-04  0.8597E-04  0.4947E-06  0.0000E+00
 0000358  0.8523E-04  0.3242E-04  0.8514E-04  0.4898E-06  0.0000E+00
 0000359  0.8441E-04  0.3210E-04  0.8432E-04  0.4849E-06  0.0000E+00
 0000360  0.8359E-04  0.3179E-04  0.8350E-04  0.4800E-06  0.0000E+00
 0000361  0.8278E-04  0.3148E-04  0.8270E-04  0.4752E-06  0.0000E+00
 0000362  0.8198E-04  0.3118E-04  0.8190E-04  0.4704E-06  0.0000E+00
 0000363  0.8119E-04  0.3088E-04  0.8111E-04  0.4657E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 208
 0000364  0.8041E-04  0.3058E-04  0.8032E-04  0.4611E-06  0.0000E+00
 0000365  0.7963E-04  0.3028E-04  0.7955E-04  0.4564E-06  0.0000E+00
 0000366  0.7886E-04  0.2999E-04  0.7878E-04  0.4519E-06  0.0000E+00
 0000367  0.7810E-04  0.2970E-04  0.7802E-04  0.4474E-06  0.0000E+00
 0000368  0.7735E-04  0.2941E-04  0.7727E-04  0.4429E-06  0.0000E+00
 0000369  0.7660E-04  0.2913E-04  0.7652E-04  0.4385E-06  0.0000E+00
 0000370  0.7586E-04  0.2885E-04  0.7579E-04  0.4341E-06  0.0000E+00
 0000371  0.7513E-04  0.2857E-04  0.7506E-04  0.4298E-06  0.0000E+00
 0000372  0.7441E-04  0.2829E-04  0.7433E-04  0.4255E-06  0.0000E+00
 0000373  0.7369E-04  0.2802E-04  0.7362E-04  0.4212E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 209
 0000374  0.7298E-04  0.2775E-04  0.7291E-04  0.4170E-06  0.0000E+00
 0000375  0.7228E-04  0.2748E-04  0.7221E-04  0.4129E-06  0.0000E+00
 0000376  0.7158E-04  0.2721E-04  0.7151E-04  0.4088E-06  0.0000E+00
 0000377  0.7089E-04  0.2695E-04  0.7082E-04  0.4047E-06  0.0000E+00
 0000378  0.7021E-04  0.2669E-04  0.7014E-04  0.4007E-06  0.0000E+00
 0000379  0.6953E-04  0.2643E-04  0.6947E-04  0.3967E-06  0.0000E+00
 0000380  0.6886E-04  0.2618E-04  0.6880E-04  0.3927E-06  0.0000E+00
 0000381  0.6820E-04  0.2592E-04  0.6814E-04  0.3888E-06  0.0000E+00
 0000382  0.6755E-04  0.2567E-04  0.6748E-04  0.3850E-06  0.0000E+00
 0000383  0.6690E-04  0.2542E-04  0.6684E-04  0.3811E-06  0.0000E+00
 0000384  0.6625E-04  0.2518E-04  0.6619E-04  0.3774E-06  0.0000E+00
 0000385  0.6562E-04  0.2493E-04  0.6556E-04  0.3736E-06  0.0000E+00
 0000386  0.6499E-04  0.2469E-04  0.6493E-04  0.3699E-06  0.0000E+00
 0000387  0.6436E-04  0.2445E-04  0.6430E-04  0.3662E-06  0.0000E+00
 0000388  0.6374E-04  0.2422E-04  0.6369E-04  0.3626E-06  0.0000E+00
 0000389  0.6313E-04  0.2398E-04  0.6308E-04  0.3590E-06  0.0000E+00
 0000390  0.6253E-04  0.2375E-04  0.6247E-04  0.3555E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 210
 0000391  0.6193E-04  0.2352E-04  0.6187E-04  0.3519E-06  0.0000E+00
 0000392  0.6133E-04  0.2329E-04  0.6128E-04  0.3484E-06  0.0000E+00
 0000393  0.6074E-04  0.2307E-04  0.6069E-04  0.3450E-06  0.0000E+00
 0000394  0.6016E-04  0.2284E-04  0.6011E-04  0.3416E-06  0.0000E+00
 0000395  0.5958E-04  0.2262E-04  0.5953E-04  0.3382E-06  0.0000E+00
 0000396  0.5901E-04  0.2240E-04  0.5896E-04  0.3349E-06  0.0000E+00
 0000397  0.5845E-04  0.2219E-04  0.5840E-04  0.3315E-06  0.0000E+00
 0000398  0.5789E-04  0.2197E-04  0.5784E-04  0.3283E-06  0.0000E+00
 0000399  0.5733E-04  0.2176E-04  0.5729E-04  0.3250E-06  0.0000E+00
 0000400  0.5678E-04  0.2155E-04  0.5674E-04  0.3218E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 211
 0000401  0.5624E-04  0.2134E-04  0.5619E-04  0.3186E-06  0.0000E+00
 0000402  0.5570E-04  0.2113E-04  0.5566E-04  0.3155E-06  0.0000E+00
 0000403  0.5517E-04  0.2093E-04  0.5512E-04  0.3124E-06  0.0000E+00
 0000404  0.5464E-04  0.2073E-04  0.5460E-04  0.3093E-06  0.0000E+00
 0000405  0.5412E-04  0.2052E-04  0.5408E-04  0.3062E-06  0.0000E+00
 0000406  0.5360E-04  0.2033E-04  0.5356E-04  0.3032E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 212
 0000407  0.5309E-04  0.2013E-04  0.5305E-04  0.3002E-06  0.0000E+00
 0000408  0.5258E-04  0.1993E-04  0.5254E-04  0.2973E-06  0.0000E+00
 0000409  0.5208E-04  0.1974E-04  0.5204E-04  0.2943E-06  0.0000E+00
 0000410  0.5158E-04  0.1955E-04  0.5154E-04  0.2914E-06  0.0000E+00
 0000411  0.5109E-04  0.1936E-04  0.5105E-04  0.2886E-06  0.0000E+00
 0000412  0.5060E-04  0.1917E-04  0.5056E-04  0.2857E-06  0.0000E+00
 0000413  0.5011E-04  0.1899E-04  0.5008E-04  0.2829E-06  0.0000E+00
 0000414  0.4964E-04  0.1880E-04  0.4960E-04  0.2801E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 213
 0000415  0.4916E-04  0.1862E-04  0.4913E-04  0.2774E-06  0.0000E+00
 0000416  0.4869E-04  0.1844E-04  0.4866E-04  0.2747E-06  0.0000E+00
 0000417  0.4823E-04  0.1826E-04  0.4820E-04  0.2720E-06  0.0000E+00
 0000418  0.4777E-04  0.1808E-04  0.4774E-04  0.2693E-06  0.0000E+00
 0000419  0.4731E-04  0.1791E-04  0.4728E-04  0.2666E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 216
 0000420  0.4686E-04  0.1774E-04  0.4683E-04  0.2640E-06  0.0000E+00
 0000421  0.4642E-04  0.1756E-04  0.4639E-04  0.2614E-06  0.0000E+00
 0000422  0.4597E-04  0.1739E-04  0.4595E-04  0.2589E-06  0.0000E+00
 0000423  0.4554E-04  0.1722E-04  0.4551E-04  0.2563E-06  0.0000E+00
 0000424  0.4510E-04  0.1706E-04  0.4508E-04  0.2538E-06  0.0000E+00
 0000425  0.4467E-04  0.1689E-04  0.4465E-04  0.2513E-06  0.0000E+00
 0000426  0.4425E-04  0.1673E-04  0.4422E-04  0.2489E-06  0.0000E+00
 0000427  0.4383E-04  0.1657E-04  0.4380E-04  0.2464E-06  0.0000E+00
 0000428  0.4341E-04  0.1641E-04  0.4339E-04  0.2440E-06  0.0000E+00
 0000429  0.4300E-04  0.1625E-04  0.4298E-04  0.2416E-06  0.0000E+00
 0000430  0.4259E-04  0.1609E-04  0.4257E-04  0.2393E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 217
 0000431  0.4218E-04  0.1593E-04  0.4216E-04  0.2369E-06  0.0000E+00
 0000432  0.4178E-04  0.1578E-04  0.4176E-04  0.2346E-06  0.0000E+00
 0000433  0.4139E-04  0.1563E-04  0.4137E-04  0.2323E-06  0.0000E+00
 0000434  0.4099E-04  0.1547E-04  0.4098E-04  0.2300E-06  0.0000E+00
 0000435  0.4061E-04  0.1532E-04  0.4059E-04  0.2278E-06  0.0000E+00
 0000436  0.4022E-04  0.1518E-04  0.4020E-04  0.2255E-06  0.0000E+00
 0000437  0.3984E-04  0.1503E-04  0.3982E-04  0.2233E-06  0.0000E+00
 0000438  0.3946E-04  0.1488E-04  0.3945E-04  0.2212E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 218
 0000439  0.3909E-04  0.1474E-04  0.3907E-04  0.2190E-06  0.0000E+00
 0000440  0.3872E-04  0.1459E-04  0.3870E-04  0.2169E-06  0.0000E+00
 0000441  0.3835E-04  0.1445E-04  0.3834E-04  0.2147E-06  0.0000E+00
 0000442  0.3799E-04  0.1431E-04  0.3797E-04  0.2126E-06  0.0000E+00
 0000443  0.3763E-04  0.1417E-04  0.3761E-04  0.2106E-06  0.0000E+00
 0000444  0.3727E-04  0.1404E-04  0.3726E-04  0.2085E-06  0.0000E+00
 0000445  0.3692E-04  0.1390E-04  0.3691E-04  0.2065E-06  0.0000E+00
 0000446  0.3657E-04  0.1377E-04  0.3656E-04  0.2045E-06  0.0000E+00
 0000447  0.3622E-04  0.1363E-04  0.3621E-04  0.2025E-06  0.0000E+00
 0000448  0.3588E-04  0.1350E-04  0.3587E-04  0.2005E-06  0.0000E+00
 0000449  0.3554E-04  0.1337E-04  0.3553E-04  0.1985E-06  0.0000E+00
 0000450  0.3521E-04  0.1324E-04  0.3520E-04  0.1966E-06  0.0000E+00
 0000451  0.3487E-04  0.1311E-04  0.3487E-04  0.1947E-06  0.0000E+00
 0000452  0.3454E-04  0.1298E-04  0.3454E-04  0.1928E-06  0.0000E+00
 0000453  0.3422E-04  0.1286E-04  0.3421E-04  0.1909E-06  0.0000E+00
 0000454  0.3390E-04  0.1273E-04  0.3389E-04  0.1891E-06  0.0000E+00
 0000455  0.3358E-04  0.1261E-04  0.3357E-04  0.1872E-06  0.0000E+00
 0000456  0.3326E-04  0.1249E-04  0.3325E-04  0.1854E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 219
 0000457  0.3295E-04  0.1236E-04  0.3294E-04  0.1836E-06  0.0000E+00
 0000458  0.3264E-04  0.1224E-04  0.3263E-04  0.1818E-06  0.0000E+00
 0000459  0.3233E-04  0.1213E-04  0.3233E-04  0.1801E-06  0.0000E+00
 0000460  0.3202E-04  0.1201E-04  0.3202E-04  0.1783E-06  0.0000E+00
 0000461  0.3172E-04  0.1189E-04  0.3172E-04  0.1766E-06  0.0000E+00
 0000462  0.3142E-04  0.1178E-04  0.3142E-04  0.1749E-06  0.0000E+00
 0000463  0.3113E-04  0.1166E-04  0.3113E-04  0.1732E-06  0.0000E+00
 0000464  0.3084E-04  0.1155E-04  0.3084E-04  0.1715E-06  0.0000E+00
 0000465  0.3055E-04  0.1144E-04  0.3055E-04  0.1698E-06  0.0000E+00
 0000466  0.3026E-04  0.1133E-04  0.3026E-04  0.1682E-06  0.0000E+00
 0000467  0.2998E-04  0.1122E-04  0.2998E-04  0.1665E-06  0.0000E+00
 0000468  0.2969E-04  0.1111E-04  0.2969E-04  0.1649E-06  0.0000E+00
 0000469  0.2942E-04  0.1100E-04  0.2942E-04  0.1633E-06  0.0000E+00
 0000470  0.2914E-04  0.1089E-04  0.2914E-04  0.1617E-06  0.0000E+00
 0000471  0.2887E-04  0.1079E-04  0.2887E-04  0.1602E-06  0.0000E+00
 0000472  0.2860E-04  0.1068E-04  0.2860E-04  0.1586E-06  0.0000E+00
 0000473  0.2833E-04  0.1058E-04  0.2833E-04  0.1571E-06  0.0000E+00
 0000474  0.2806E-04  0.1047E-04  0.2807E-04  0.1556E-06  0.0000E+00
 0000475  0.2780E-04  0.1037E-04  0.2780E-04  0.1541E-06  0.0000E+00
 0000476  0.2754E-04  0.1027E-04  0.2754E-04  0.1526E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 220
 0000477  0.2728E-04  0.1017E-04  0.2729E-04  0.1511E-06  0.0000E+00
 0000478  0.2703E-04  0.1007E-04  0.2703E-04  0.1496E-06  0.0000E+00
 0000479  0.2677E-04  0.9975E-05  0.2678E-04  0.1482E-06  0.0000E+00
 0000480  0.2652E-04  0.9878E-05  0.2653E-04  0.1467E-06  0.0000E+00
 0000481  0.2628E-04  0.9782E-05  0.2628E-04  0.1453E-06  0.0000E+00
 0000482  0.2603E-04  0.9687E-05  0.2604E-04  0.1439E-06  0.0000E+00
 0000483  0.2579E-04  0.9593E-05  0.2579E-04  0.1425E-06  0.0000E+00
 0000484  0.2555E-04  0.9500E-05  0.2555E-04  0.1412E-06  0.0000E+00
 0000485  0.2531E-04  0.9407E-05  0.2532E-04  0.1398E-06  0.0000E+00
 0000486  0.2507E-04  0.9316E-05  0.2508E-04  0.1384E-06  0.0000E+00
 0000487  0.2484E-04  0.9225E-05  0.2485E-04  0.1371E-06  0.0000E+00
 0000488  0.2461E-04  0.9135E-05  0.2462E-04  0.1358E-06  0.0000E+00
 0000489  0.2438E-04  0.9047E-05  0.2439E-04  0.1345E-06  0.0000E+00
 0000490  0.2415E-04  0.8959E-05  0.2416E-04  0.1332E-06  0.0000E+00
 0000491  0.2393E-04  0.8872E-05  0.2394E-04  0.1319E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 221
 0000492  0.2371E-04  0.8785E-05  0.2372E-04  0.1306E-06  0.0000E+00
 0000493  0.2349E-04  0.8700E-05  0.2350E-04  0.1294E-06  0.0000E+00
 0000494  0.2327E-04  0.8615E-05  0.2328E-04  0.1281E-06  0.0000E+00
 0000495  0.2305E-04  0.8531E-05  0.2306E-04  0.1269E-06  0.0000E+00
 0000496  0.2284E-04  0.8448E-05  0.2285E-04  0.1257E-06  0.0000E+00
 0000497  0.2263E-04  0.8366E-05  0.2264E-04  0.1245E-06  0.0000E+00
 0000498  0.2242E-04  0.8285E-05  0.2243E-04  0.1233E-06  0.0000E+00
 0000499  0.2221E-04  0.8204E-05  0.2222E-04  0.1221E-06  0.0000E+00
 0000500  0.2200E-04  0.8124E-05  0.2201E-04  0.1209E-06  0.0000E+00
 0000501  0.2180E-04  0.8045E-05  0.2181E-04  0.1197E-06  0.0000E+00
 0000502  0.2160E-04  0.7967E-05  0.2161E-04  0.1186E-06  0.0000E+00
 0000503  0.2140E-04  0.7890E-05  0.2141E-04  0.1174E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 222
 0000504  0.2120E-04  0.7813E-05  0.2121E-04  0.1163E-06  0.0000E+00
 0000505  0.2100E-04  0.7737E-05  0.2102E-04  0.1152E-06  0.0000E+00
 0000506  0.2081E-04  0.7662E-05  0.2082E-04  0.1141E-06  0.0000E+00
 0000507  0.2062E-04  0.7587E-05  0.2063E-04  0.1130E-06  0.0000E+00
 0000508  0.2043E-04  0.7513E-05  0.2044E-04  0.1119E-06  0.0000E+00
 0000509  0.2024E-04  0.7440E-05  0.2025E-04  0.1108E-06  0.0000E+00
 0000510  0.2005E-04  0.7368E-05  0.2007E-04  0.1098E-06  0.0000E+00
 0000511  0.1987E-04  0.7296E-05  0.1988E-04  0.1087E-06  0.0000E+00
 0000512  0.1968E-04  0.7225E-05  0.1970E-04  0.1077E-06  0.0000E+00
 0000513  0.1950E-04  0.7155E-05  0.1952E-04  0.1066E-06  0.0000E+00
 0000514  0.1932E-04  0.7085E-05  0.1934E-04  0.1056E-06  0.0000E+00
 0000515  0.1915E-04  0.7016E-05  0.1916E-04  0.1046E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 223
 0000516  0.1897E-04  0.6948E-05  0.1898E-04  0.1036E-06  0.0000E+00
 0000517  0.1879E-04  0.6880E-05  0.1881E-04  0.1026E-06  0.0000E+00
 0000518  0.1862E-04  0.6813E-05  0.1864E-04  0.1016E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 224
 0000519  0.1845E-04  0.6747E-05  0.1847E-04  0.1007E-06  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 228
 0000520  0.1828E-04  0.6681E-05  0.1830E-04  0.9970E-07  0.0000E+00
 0000521  0.1811E-04  0.6616E-05  0.1813E-04  0.9875E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 229
 0000522  0.1795E-04  0.6552E-05  0.1796E-04  0.9780E-07  0.0000E+00
 0000523  0.1778E-04  0.6488E-05  0.1780E-04  0.9687E-07  0.0000E+00
 0000524  0.1762E-04  0.6425E-05  0.1764E-04  0.9594E-07  0.0000E+00
 0000525  0.1746E-04  0.6362E-05  0.1748E-04  0.9503E-07  0.0000E+00
 0000526  0.1730E-04  0.6300E-05  0.1732E-04  0.9412E-07  0.0000E+00
 0000527  0.1714E-04  0.6239E-05  0.1716E-04  0.9322E-07  0.0000E+00
 0000528  0.1698E-04  0.6178E-05  0.1700E-04  0.9233E-07  0.0000E+00
 0000529  0.1683E-04  0.6118E-05  0.1685E-04  0.9145E-07  0.0000E+00
 0000530  0.1668E-04  0.6058E-05  0.1669E-04  0.9058E-07  0.0000E+00
 0000531  0.1652E-04  0.5999E-05  0.1654E-04  0.8971E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 230
 0000532  0.1637E-04  0.5941E-05  0.1639E-04  0.8886E-07  0.0000E+00
 0000533  0.1622E-04  0.5883E-05  0.1624E-04  0.8801E-07  0.0000E+00
 0000534  0.1608E-04  0.5826E-05  0.1610E-04  0.8717E-07  0.0000E+00
 0000535  0.1593E-04  0.5769E-05  0.1595E-04  0.8634E-07  0.0000E+00
 0000536  0.1579E-04  0.5713E-05  0.1580E-04  0.8552E-07  0.0000E+00
 0000537  0.1564E-04  0.5657E-05  0.1566E-04  0.8471E-07  0.0000E+00
 0000538  0.1550E-04  0.5602E-05  0.1552E-04  0.8390E-07  0.0000E+00
 0000539  0.1536E-04  0.5547E-05  0.1538E-04  0.8310E-07  0.0000E+00
 0000540  0.1522E-04  0.5493E-05  0.1524E-04  0.8231E-07  0.0000E+00
 0000541  0.1508E-04  0.5440E-05  0.1510E-04  0.8153E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 238
 0000542  0.1494E-04  0.5387E-05  0.1496E-04  0.8075E-07  0.0000E+00
 0000543  0.1481E-04  0.5334E-05  0.1483E-04  0.7999E-07  0.0000E+00
 0000544  0.1467E-04  0.5282E-05  0.1469E-04  0.7923E-07  0.0000E+00
 0000545  0.1454E-04  0.5231E-05  0.1456E-04  0.7847E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 239
 0000546  0.1441E-04  0.5180E-05  0.1443E-04  0.7773E-07  0.0000E+00
 0000547  0.1428E-04  0.5129E-05  0.1430E-04  0.7699E-07  0.0000E+00
 0000548  0.1415E-04  0.5079E-05  0.1417E-04  0.7626E-07  0.0000E+00
 0000549  0.1402E-04  0.5030E-05  0.1404E-04  0.7554E-07  0.0000E+00
 0000550  0.1390E-04  0.4981E-05  0.1392E-04  0.7482E-07  0.0000E+00
 0000551  0.1377E-04  0.4932E-05  0.1379E-04  0.7411E-07  0.0000E+00
 0000552  0.1365E-04  0.4884E-05  0.1367E-04  0.7341E-07  0.0000E+00
 0000553  0.1352E-04  0.4837E-05  0.1355E-04  0.7272E-07  0.0000E+00
 0000554  0.1340E-04  0.4790E-05  0.1342E-04  0.7203E-07  0.0000E+00
 0000555  0.1328E-04  0.4743E-05  0.1330E-04  0.7135E-07  0.0000E+00
 0000556  0.1316E-04  0.4697E-05  0.1318E-04  0.7067E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 240
 0000557  0.1304E-04  0.4651E-05  0.1307E-04  0.7000E-07  0.0000E+00
 0000558  0.1293E-04  0.4606E-05  0.1295E-04  0.6934E-07  0.0000E+00
 0000559  0.1281E-04  0.4561E-05  0.1283E-04  0.6868E-07  0.0000E+00
 0000560  0.1270E-04  0.4516E-05  0.1272E-04  0.6804E-07  0.0000E+00
 0000561  0.1258E-04  0.4472E-05  0.1260E-04  0.6739E-07  0.0000E+00
 0000562  0.1247E-04  0.4429E-05  0.1249E-04  0.6676E-07  0.0000E+00
 0000563  0.1236E-04  0.4385E-05  0.1238E-04  0.6613E-07  0.0000E+00
 0000564  0.1225E-04  0.4343E-05  0.1227E-04  0.6550E-07  0.0000E+00
 0000565  0.1214E-04  0.4300E-05  0.1216E-04  0.6488E-07  0.0000E+00
 0000566  0.1203E-04  0.4258E-05  0.1205E-04  0.6427E-07  0.0000E+00
 0000567  0.1192E-04  0.4217E-05  0.1194E-04  0.6367E-07  0.0000E+00
 0000568  0.1182E-04  0.4176E-05  0.1184E-04  0.6307E-07  0.0000E+00
 0000569  0.1171E-04  0.4135E-05  0.1173E-04  0.6247E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 241
 0000570  0.1161E-04  0.4095E-05  0.1163E-04  0.6188E-07  0.0000E+00
 0000571  0.1150E-04  0.4055E-05  0.1153E-04  0.6130E-07  0.0000E+00
 0000572  0.1140E-04  0.4015E-05  0.1142E-04  0.6072E-07  0.0000E+00
 0000573  0.1130E-04  0.3976E-05  0.1132E-04  0.6015E-07  0.0000E+00
 0000574  0.1120E-04  0.3937E-05  0.1122E-04  0.5959E-07  0.0000E+00
 0000575  0.1110E-04  0.3899E-05  0.1112E-04  0.5903E-07  0.0000E+00
 0000576  0.1100E-04  0.3861E-05  0.1102E-04  0.5847E-07  0.0000E+00
 0000577  0.1090E-04  0.3823E-05  0.1093E-04  0.5792E-07  0.0000E+00
 0000578  0.1081E-04  0.3786E-05  0.1083E-04  0.5738E-07  0.0000E+00
 0000579  0.1071E-04  0.3749E-05  0.1073E-04  0.5684E-07  0.0000E+00
 0000580  0.1062E-04  0.3712E-05  0.1064E-04  0.5631E-07  0.0000E+00
 0000581  0.1052E-04  0.3676E-05  0.1055E-04  0.5578E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 242
 0000582  0.1043E-04  0.3640E-05  0.1045E-04  0.5526E-07  0.0000E+00
 0000583  0.1034E-04  0.3605E-05  0.1036E-04  0.5474E-07  0.0000E+00
 0000584  0.1025E-04  0.3570E-05  0.1027E-04  0.5423E-07  0.0000E+00
 0000585  0.1016E-04  0.3535E-05  0.1018E-04  0.5372E-07  0.0000E+00
 0000586  0.1007E-04  0.3500E-05  0.1009E-04  0.5322E-07  0.0000E+00
 0000587  0.9978E-05  0.3466E-05  0.1000E-04  0.5272E-07  0.0000E+00
 0000588  0.9891E-05  0.3432E-05  0.9913E-05  0.5222E-07  0.0000E+00
 0000589  0.9804E-05  0.3399E-05  0.9826E-05  0.5174E-07  0.0000E+00
 0000590  0.9718E-05  0.3366E-05  0.9740E-05  0.5125E-07  0.0000E+00
 0000591  0.9632E-05  0.3333E-05  0.9655E-05  0.5077E-07  0.0000E+00
 0000592  0.9548E-05  0.3300E-05  0.9570E-05  0.5030E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 243
 0000593  0.9464E-05  0.3268E-05  0.9487E-05  0.4983E-07  0.0000E+00
 0000594  0.9381E-05  0.3236E-05  0.9404E-05  0.4936E-07  0.0000E+00
 0000595  0.9299E-05  0.3205E-05  0.9322E-05  0.4890E-07  0.0000E+00
 0000596  0.9218E-05  0.3173E-05  0.9241E-05  0.4845E-07  0.0000E+00
 0000597  0.9137E-05  0.3142E-05  0.9160E-05  0.4800E-07  0.0000E+00
 0000598  0.9058E-05  0.3112E-05  0.9080E-05  0.4755E-07  0.0000E+00
 0000599  0.8979E-05  0.3081E-05  0.9001E-05  0.4711E-07  0.0000E+00
 0000600  0.8900E-05  0.3051E-05  0.8923E-05  0.4667E-07  0.0000E+00
 0000601  0.8823E-05  0.3021E-05  0.8846E-05  0.4623E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 244
 0000602  0.8746E-05  0.2992E-05  0.8769E-05  0.4580E-07  0.0000E+00
 0000603  0.8670E-05  0.2963E-05  0.8693E-05  0.4538E-07  0.0000E+00
 0000604  0.8595E-05  0.2934E-05  0.8617E-05  0.4496E-07  0.0000E+00
 0000605  0.8520E-05  0.2905E-05  0.8543E-05  0.4454E-07  0.0000E+00
 0000606  0.8446E-05  0.2877E-05  0.8469E-05  0.4413E-07  0.0000E+00
 0000607  0.8373E-05  0.2849E-05  0.8396E-05  0.4372E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 245
 0000608  0.8301E-05  0.2821E-05  0.8323E-05  0.4331E-07  0.0000E+00
 0000609  0.8229E-05  0.2793E-05  0.8251E-05  0.4291E-07  0.0000E+00
 0000610  0.8158E-05  0.2766E-05  0.8180E-05  0.4251E-07  0.0000E+00
 0000611  0.8087E-05  0.2739E-05  0.8110E-05  0.4212E-07  0.0000E+00
 0000612  0.8017E-05  0.2712E-05  0.8040E-05  0.4173E-07  0.0000E+00
 0000613  0.7948E-05  0.2686E-05  0.7971E-05  0.4134E-07  0.0000E+00
 0000614  0.7880E-05  0.2660E-05  0.7902E-05  0.4096E-07  0.0000E+00
 0000615  0.7812E-05  0.2634E-05  0.7834E-05  0.4058E-07  0.0000E+00
 0000616  0.7745E-05  0.2608E-05  0.7767E-05  0.4020E-07  0.0000E+00
 0000617  0.7678E-05  0.2583E-05  0.7701E-05  0.3983E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 246
 0000618  0.7612E-05  0.2557E-05  0.7635E-05  0.3947E-07  0.0000E+00
 0000619  0.7547E-05  0.2532E-05  0.7569E-05  0.3910E-07  0.0000E+00
 0000620  0.7482E-05  0.2508E-05  0.7505E-05  0.3874E-07  0.0000E+00
 0000621  0.7418E-05  0.2483E-05  0.7440E-05  0.3838E-07  0.0000E+00
 0000622  0.7355E-05  0.2459E-05  0.7377E-05  0.3803E-07  0.0000E+00
 0000623  0.7292E-05  0.2435E-05  0.7314E-05  0.3768E-07  0.0000E+00
 0000624  0.7229E-05  0.2411E-05  0.7252E-05  0.3733E-07  0.0000E+00
 0000625  0.7168E-05  0.2388E-05  0.7190E-05  0.3699E-07  0.0000E+00
 0000626  0.7107E-05  0.2364E-05  0.7129E-05  0.3665E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 247
 0000627  0.7046E-05  0.2341E-05  0.7068E-05  0.3631E-07  0.0000E+00
 0000628  0.6986E-05  0.2318E-05  0.7008E-05  0.3598E-07  0.0000E+00
 0000629  0.6927E-05  0.2296E-05  0.6949E-05  0.3565E-07  0.0000E+00
 0000630  0.6868E-05  0.2273E-05  0.6890E-05  0.3532E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 248
 0000631  0.6810E-05  0.2251E-05  0.6831E-05  0.3500E-07  0.0000E+00
 0000632  0.6752E-05  0.2229E-05  0.6774E-05  0.3468E-07  0.0000E+00
 0000633  0.6695E-05  0.2207E-05  0.6716E-05  0.3436E-07  0.0000E+00
 0000634  0.6638E-05  0.2186E-05  0.6660E-05  0.3404E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 249
 0000635  0.6582E-05  0.2164E-05  0.6603E-05  0.3373E-07  0.0000E+00
 0000636  0.6526E-05  0.2143E-05  0.6548E-05  0.3342E-07  0.0000E+00
 0000637  0.6471E-05  0.2122E-05  0.6493E-05  0.3312E-07  0.0000E+00
 0000638  0.6416E-05  0.2102E-05  0.6438E-05  0.3281E-07  0.0000E+00
 0000639  0.6362E-05  0.2081E-05  0.6384E-05  0.3251E-07  0.0000E+00
 0000640  0.6309E-05  0.2061E-05  0.6330E-05  0.3222E-07  0.0000E+00
 0000641  0.6256E-05  0.2041E-05  0.6277E-05  0.3192E-07  0.0000E+00
 0000642  0.6203E-05  0.2021E-05  0.6225E-05  0.3163E-07  0.0000E+00
 0000643  0.6151E-05  0.2001E-05  0.6172E-05  0.3134E-07  0.0000E+00
 0000644  0.6099E-05  0.1981E-05  0.6121E-05  0.3106E-07  0.0000E+00
 0000645  0.6048E-05  0.1962E-05  0.6070E-05  0.3077E-07  0.0000E+00
 0000646  0.5998E-05  0.1943E-05  0.6019E-05  0.3049E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 250
 0000647  0.5948E-05  0.1924E-05  0.5969E-05  0.3022E-07  0.0000E+00
 0000648  0.5898E-05  0.1905E-05  0.5919E-05  0.2994E-07  0.0000E+00
 0000649  0.5849E-05  0.1886E-05  0.5870E-05  0.2967E-07  0.0000E+00
 0000650  0.5800E-05  0.1868E-05  0.5821E-05  0.2940E-07  0.0000E+00
 0000651  0.5752E-05  0.1850E-05  0.5772E-05  0.2913E-07  0.0000E+00
 0000652  0.5704E-05  0.1832E-05  0.5724E-05  0.2887E-07  0.0000E+00
 0000653  0.5656E-05  0.1814E-05  0.5677E-05  0.2861E-07  0.0000E+00
 0000654  0.5609E-05  0.1796E-05  0.5630E-05  0.2835E-07  0.0000E+00
 0000655  0.5563E-05  0.1778E-05  0.5583E-05  0.2809E-07  0.0000E+00
 0000656  0.5517E-05  0.1761E-05  0.5537E-05  0.2784E-07  0.0000E+00
 0000657  0.5471E-05  0.1744E-05  0.5491E-05  0.2758E-07  0.0000E+00
 0000658  0.5426E-05  0.1727E-05  0.5446E-05  0.2734E-07  0.0000E+00
 0000659  0.5381E-05  0.1710E-05  0.5401E-05  0.2709E-07  0.0000E+00
 0000660  0.5336E-05  0.1693E-05  0.5357E-05  0.2684E-07  0.0000E+00
 0000661  0.5292E-05  0.1677E-05  0.5312E-05  0.2660E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 251
 0000662  0.5249E-05  0.1660E-05  0.5269E-05  0.2636E-07  0.0000E+00
 0000663  0.5205E-05  0.1644E-05  0.5226E-05  0.2612E-07  0.0000E+00
 0000664  0.5163E-05  0.1628E-05  0.5183E-05  0.2589E-07  0.0000E+00
 0000665  0.5120E-05  0.1612E-05  0.5140E-05  0.2566E-07  0.0000E+00
 0000666  0.5078E-05  0.1596E-05  0.5098E-05  0.2542E-07  0.0000E+00
 0000667  0.5036E-05  0.1581E-05  0.5056E-05  0.2520E-07  0.0000E+00
 0000668  0.4995E-05  0.1565E-05  0.5015E-05  0.2497E-07  0.0000E+00
 0000669  0.4954E-05  0.1550E-05  0.4974E-05  0.2475E-07  0.0000E+00
 0000670  0.4914E-05  0.1535E-05  0.4933E-05  0.2452E-07  0.0000E+00
 0000671  0.4874E-05  0.1520E-05  0.4893E-05  0.2430E-07  0.0000E+00
 0000672  0.4834E-05  0.1505E-05  0.4853E-05  0.2409E-07  0.0000E+00
 0000673  0.4795E-05  0.1490E-05  0.4814E-05  0.2387E-07  0.0000E+00
 0000674  0.4756E-05  0.1476E-05  0.4775E-05  0.2366E-07  0.0000E+00
 0000675  0.4717E-05  0.1461E-05  0.4736E-05  0.2344E-07  0.0000E+00
 0000676  0.4679E-05  0.1447E-05  0.4698E-05  0.2323E-07  0.0000E+00
 0000677  0.4641E-05  0.1433E-05  0.4660E-05  0.2303E-07  0.0000E+00
 0000678  0.4603E-05  0.1419E-05  0.4622E-05  0.2282E-07  0.0000E+00
 0000679  0.4566E-05  0.1405E-05  0.4585E-05  0.2262E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 252
 0000680  0.4529E-05  0.1391E-05  0.4548E-05  0.2242E-07  0.0000E+00
 0000681  0.4492E-05  0.1378E-05  0.4511E-05  0.2222E-07  0.0000E+00
 0000682  0.4456E-05  0.1364E-05  0.4475E-05  0.2202E-07  0.0000E+00
 0000683  0.4420E-05  0.1351E-05  0.4439E-05  0.2182E-07  0.0000E+00
 0000684  0.4384E-05  0.1338E-05  0.4403E-05  0.2163E-07  0.0000E+00
 0000685  0.4349E-05  0.1325E-05  0.4368E-05  0.2144E-07  0.0000E+00
 0000686  0.4314E-05  0.1312E-05  0.4332E-05  0.2125E-07  0.0000E+00
 0000687  0.4279E-05  0.1299E-05  0.4298E-05  0.2106E-07  0.0000E+00
 0000688  0.4245E-05  0.1286E-05  0.4263E-05  0.2087E-07  0.0000E+00
 0000689  0.4211E-05  0.1273E-05  0.4229E-05  0.2068E-07  0.0000E+00
 0000690  0.4177E-05  0.1261E-05  0.4195E-05  0.2050E-07  0.0000E+00
 0000691  0.4144E-05  0.1249E-05  0.4162E-05  0.2032E-07  0.0000E+00
 0000692  0.4111E-05  0.1236E-05  0.4129E-05  0.2014E-07  0.0000E+00
 0000693  0.4078E-05  0.1224E-05  0.4096E-05  0.1996E-07  0.0000E+00
 0000694  0.4045E-05  0.1212E-05  0.4063E-05  0.1979E-07  0.0000E+00
 0000695  0.4013E-05  0.1201E-05  0.4031E-05  0.1961E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 253
 0000696  0.3981E-05  0.1189E-05  0.3999E-05  0.1944E-07  0.0000E+00
 0000697  0.3950E-05  0.1177E-05  0.3967E-05  0.1927E-07  0.0000E+00
 0000698  0.3918E-05  0.1166E-05  0.3936E-05  0.1910E-07  0.0000E+00
 0000699  0.3887E-05  0.1154E-05  0.3905E-05  0.1893E-07  0.0000E+00
 0000700  0.3857E-05  0.1143E-05  0.3874E-05  0.1876E-07  0.0000E+00
 0000701  0.3826E-05  0.1132E-05  0.3843E-05  0.1860E-07  0.0000E+00
 0000702  0.3796E-05  0.1121E-05  0.3813E-05  0.1843E-07  0.0000E+00
 0000703  0.3766E-05  0.1110E-05  0.3783E-05  0.1827E-07  0.0000E+00
 0000704  0.3736E-05  0.1099E-05  0.3753E-05  0.1811E-07  0.0000E+00
 0000705  0.3707E-05  0.1088E-05  0.3724E-05  0.1795E-07  0.0000E+00
 0000706  0.3678E-05  0.1078E-05  0.3695E-05  0.1780E-07  0.0000E+00
 0000707  0.3649E-05  0.1067E-05  0.3666E-05  0.1764E-07  0.0000E+00
 0000708  0.3620E-05  0.1057E-05  0.3637E-05  0.1749E-07  0.0000E+00
 0000709  0.3592E-05  0.1046E-05  0.3608E-05  0.1733E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 254
 0000710  0.3564E-05  0.1036E-05  0.3580E-05  0.1718E-07  0.0000E+00
 0000711  0.3536E-05  0.1026E-05  0.3552E-05  0.1703E-07  0.0000E+00
 0000712  0.3508E-05  0.1016E-05  0.3525E-05  0.1688E-07  0.0000E+00
 0000713  0.3481E-05  0.1006E-05  0.3497E-05  0.1674E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 255
 0000714  0.3454E-05  0.9961E-06  0.3470E-05  0.1659E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 256
 0000715  0.3427E-05  0.9863E-06  0.3443E-05  0.1645E-07  0.0000E+00
 0000716  0.3400E-05  0.9767E-06  0.3416E-05  0.1630E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 271
 0000717  0.3374E-05  0.9671E-06  0.3390E-05  0.1616E-07  0.0000E+00
 0000718  0.3347E-05  0.9577E-06  0.3363E-05  0.1602E-07  0.0000E+00
 0000719  0.3321E-05  0.9483E-06  0.3337E-05  0.1588E-07  0.0000E+00
 0000720  0.3296E-05  0.9390E-06  0.3312E-05  0.1575E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 272
 0000721  0.3270E-05  0.9298E-06  0.3286E-05  0.1561E-07  0.0000E+00
 0000722  0.3245E-05  0.9208E-06  0.3261E-05  0.1547E-07  0.0000E+00
 0000723  0.3220E-05  0.9117E-06  0.3236E-05  0.1534E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 273
 0000724  0.3195E-05  0.9028E-06  0.3211E-05  0.1521E-07  0.0000E+00
 0000725  0.3170E-05  0.8940E-06  0.3186E-05  0.1508E-07  0.0000E+00
 0000726  0.3146E-05  0.8853E-06  0.3161E-05  0.1495E-07  0.0000E+00
 0000727  0.3122E-05  0.8766E-06  0.3137E-05  0.1482E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 274
 0000728  0.3098E-05  0.8680E-06  0.3113E-05  0.1469E-07  0.0000E+00
 0000729  0.3074E-05  0.8595E-06  0.3089E-05  0.1456E-07  0.0000E+00
 0000730  0.3051E-05  0.8511E-06  0.3066E-05  0.1444E-07  0.0000E+00
 0000731  0.3027E-05  0.8428E-06  0.3042E-05  0.1432E-07  0.0000E+00
 0000732  0.3004E-05  0.8345E-06  0.3019E-05  0.1419E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 275
 0000733  0.2981E-05  0.8264E-06  0.2996E-05  0.1407E-07  0.0000E+00
 0000734  0.2959E-05  0.8183E-06  0.2973E-05  0.1395E-07  0.0000E+00
 0000735  0.2936E-05  0.8103E-06  0.2951E-05  0.1383E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 276
 0000736  0.2914E-05  0.8024E-06  0.2928E-05  0.1371E-07  0.0000E+00
 0000737  0.2892E-05  0.7945E-06  0.2906E-05  0.1360E-07  0.0000E+00
 0000738  0.2870E-05  0.7867E-06  0.2884E-05  0.1348E-07  0.0000E+00
 0000739  0.2848E-05  0.7790E-06  0.2862E-05  0.1337E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 277
 0000740  0.2826E-05  0.7714E-06  0.2841E-05  0.1325E-07  0.0000E+00
 0000741  0.2805E-05  0.7639E-06  0.2819E-05  0.1314E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 278
 0000742  0.2784E-05  0.7564E-06  0.2798E-05  0.1303E-07  0.0000E+00
 0000743  0.2763E-05  0.7490E-06  0.2777E-05  0.1292E-07  0.0000E+00
 0000744  0.2742E-05  0.7417E-06  0.2756E-05  0.1281E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 279
 0000745  0.2721E-05  0.7344E-06  0.2735E-05  0.1270E-07  0.0000E+00
 0000746  0.2701E-05  0.7272E-06  0.2715E-05  0.1259E-07  0.0000E+00
 0000747  0.2681E-05  0.7201E-06  0.2694E-05  0.1248E-07  0.0000E+00
 0000748  0.2661E-05  0.7131E-06  0.2674E-05  0.1238E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 280
 0000749  0.2641E-05  0.7061E-06  0.2654E-05  0.1227E-07  0.0000E+00
 0000750  0.2621E-05  0.6992E-06  0.2634E-05  0.1217E-07  0.0000E+00
 0000751  0.2601E-05  0.6923E-06  0.2615E-05  0.1207E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 281
 0000752  0.2582E-05  0.6856E-06  0.2595E-05  0.1197E-07  0.0000E+00
 0000753  0.2563E-05  0.6789E-06  0.2576E-05  0.1186E-07  0.0000E+00
 0000754  0.2544E-05  0.6722E-06  0.2557E-05  0.1177E-07  0.0000E+00
 0000755  0.2525E-05  0.6656E-06  0.2538E-05  0.1167E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 282
 0000756  0.2506E-05  0.6591E-06  0.2519E-05  0.1157E-07  0.0000E+00
 0000757  0.2487E-05  0.6527E-06  0.2500E-05  0.1147E-07  0.0000E+00
 0000758  0.2469E-05  0.6463E-06  0.2482E-05  0.1138E-07  0.0000E+00
 0000759  0.2451E-05  0.6400E-06  0.2463E-05  0.1128E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 290
 0000760  0.2432E-05  0.6337E-06  0.2445E-05  0.1119E-07  0.0000E+00
 0000761  0.2414E-05  0.6275E-06  0.2427E-05  0.1109E-07  0.0000E+00
 0000762  0.2397E-05  0.6214E-06  0.2409E-05  0.1100E-07  0.0000E+00
 0000763  0.2379E-05  0.6153E-06  0.2392E-05  0.1091E-07  0.0000E+00
 0000764  0.2361E-05  0.6093E-06  0.2374E-05  0.1082E-07  0.0000E+00
 0000765  0.2344E-05  0.6033E-06  0.2356E-05  0.1073E-07  0.0000E+00
 0000766  0.2327E-05  0.5974E-06  0.2339E-05  0.1064E-07  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 291
 0000767  0.2310E-05  0.5916E-06  0.2322E-05  0.1055E-07  0.0000E+00
 0000768  0.2293E-05  0.5858E-06  0.2305E-05  0.1046E-07  0.0000E+00
 0000769  0.2276E-05  0.5800E-06  0.2288E-05  0.1037E-07  0.0000E+00
 0000770  0.2259E-05  0.5744E-06  0.2271E-05  0.1029E-07  0.0000E+00
 0000771  0.2243E-05  0.5687E-06  0.2255E-05  0.1020E-07  0.0000E+00
 0000772  0.2227E-05  0.5632E-06  0.2238E-05  0.1012E-07  0.0000E+00
 0000773  0.2210E-05  0.5577E-06  0.2222E-05  0.1004E-07  0.0000E+00
 0000774  0.2194E-05  0.5522E-06  0.2206E-05  0.9953E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 292
 0000775  0.2178E-05  0.5468E-06  0.2190E-05  0.9871E-08  0.0000E+00
 0000776  0.2163E-05  0.5414E-06  0.2174E-05  0.9789E-08  0.0000E+00
 0000777  0.2147E-05  0.5361E-06  0.2158E-05  0.9709E-08  0.0000E+00
 0000778  0.2131E-05  0.5309E-06  0.2143E-05  0.9629E-08  0.0000E+00
 0000779  0.2116E-05  0.5257E-06  0.2127E-05  0.9550E-08  0.0000E+00
 0000780  0.2101E-05  0.5206E-06  0.2112E-05  0.9472E-08  0.0000E+00
 0000781  0.2085E-05  0.5155E-06  0.2097E-05  0.9394E-08  0.0000E+00
 0000782  0.2070E-05  0.5104E-06  0.2082E-05  0.9317E-08  0.0000E+00
 0000783  0.2055E-05  0.5054E-06  0.2067E-05  0.9241E-08  0.0000E+00
 0000784  0.2041E-05  0.5005E-06  0.2052E-05  0.9165E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 293
 0000785  0.2026E-05  0.4956E-06  0.2037E-05  0.9091E-08  0.0000E+00
 0000786  0.2012E-05  0.4907E-06  0.2022E-05  0.9016E-08  0.0000E+00
 0000787  0.1997E-05  0.4859E-06  0.2008E-05  0.8943E-08  0.0000E+00
 0000788  0.1983E-05  0.4812E-06  0.1993E-05  0.8870E-08  0.0000E+00
 0000789  0.1969E-05  0.4765E-06  0.1979E-05  0.8798E-08  0.0000E+00
 0000790  0.1955E-05  0.4718E-06  0.1965E-05  0.8727E-08  0.0000E+00
 0000791  0.1941E-05  0.4672E-06  0.1951E-05  0.8656E-08  0.0000E+00
 0000792  0.1927E-05  0.4626E-06  0.1937E-05  0.8586E-08  0.0000E+00
 0000793  0.1913E-05  0.4581E-06  0.1923E-05  0.8516E-08  0.0000E+00
 0000794  0.1899E-05  0.4536E-06  0.1910E-05  0.8447E-08  0.0000E+00
 0000795  0.1886E-05  0.4492E-06  0.1896E-05  0.8379E-08  0.0000E+00
 0000796  0.1873E-05  0.4448E-06  0.1883E-05  0.8312E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 294
 0000797  0.1859E-05  0.4404E-06  0.1869E-05  0.8245E-08  0.0000E+00
 0000798  0.1846E-05  0.4361E-06  0.1856E-05  0.8178E-08  0.0000E+00
 0000799  0.1833E-05  0.4318E-06  0.1843E-05  0.8112E-08  0.0000E+00
 0000800  0.1820E-05  0.4276E-06  0.1830E-05  0.8047E-08  0.0000E+00
 0000801  0.1807E-05  0.4234E-06  0.1817E-05  0.7983E-08  0.0000E+00
 0000802  0.1794E-05  0.4193E-06  0.1804E-05  0.7918E-08  0.0000E+00
 0000803  0.1782E-05  0.4152E-06  0.1792E-05  0.7855E-08  0.0000E+00
 0000804  0.1769E-05  0.4111E-06  0.1779E-05  0.7792E-08  0.0000E+00
 0000805  0.1757E-05  0.4071E-06  0.1766E-05  0.7730E-08  0.0000E+00
 0000806  0.1745E-05  0.4031E-06  0.1754E-05  0.7668E-08  0.0000E+00
 0000807  0.1732E-05  0.3992E-06  0.1742E-05  0.7607E-08  0.0000E+00
 0000808  0.1720E-05  0.3952E-06  0.1730E-05  0.7546E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 295
 0000809  0.1708E-05  0.3914E-06  0.1717E-05  0.7486E-08  0.0000E+00
 0000810  0.1696E-05  0.3876E-06  0.1705E-05  0.7427E-08  0.0000E+00
 0000811  0.1684E-05  0.3838E-06  0.1694E-05  0.7368E-08  0.0000E+00
 0000812  0.1673E-05  0.3800E-06  0.1682E-05  0.7309E-08  0.0000E+00
 0000813  0.1661E-05  0.3763E-06  0.1670E-05  0.7251E-08  0.0000E+00
 0000814  0.1649E-05  0.3726E-06  0.1658E-05  0.7194E-08  0.0000E+00
 0000815  0.1638E-05  0.3690E-06  0.1647E-05  0.7137E-08  0.0000E+00
 0000816  0.1627E-05  0.3653E-06  0.1635E-05  0.7081E-08  0.0000E+00
 0000817  0.1615E-05  0.3618E-06  0.1624E-05  0.7025E-08  0.0000E+00
 0000818  0.1604E-05  0.3582E-06  0.1613E-05  0.6969E-08  0.0000E+00
 0000819  0.1593E-05  0.3547E-06  0.1602E-05  0.6915E-08  0.0000E+00
 0000820  0.1582E-05  0.3512E-06  0.1591E-05  0.6860E-08  0.0000E+00
 0000821  0.1571E-05  0.3478E-06  0.1580E-05  0.6806E-08  0.0000E+00
 0000822  0.1560E-05  0.3444E-06  0.1569E-05  0.6753E-08  0.0000E+00
 0000823  0.1549E-05  0.3410E-06  0.1558E-05  0.6700E-08  0.0000E+00
 0000824  0.1539E-05  0.3377E-06  0.1547E-05  0.6647E-08  0.0000E+00
 0000825  0.1528E-05  0.3344E-06  0.1537E-05  0.6595E-08  0.0000E+00
 0000826  0.1518E-05  0.3311E-06  0.1526E-05  0.6544E-08  0.0000E+00
 0000827  0.1507E-05  0.3279E-06  0.1516E-05  0.6493E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 296
 0000828  0.1497E-05  0.3247E-06  0.1505E-05  0.6442E-08  0.0000E+00
 0000829  0.1487E-05  0.3215E-06  0.1495E-05  0.6392E-08  0.0000E+00
 0000830  0.1477E-05  0.3183E-06  0.1485E-05  0.6342E-08  0.0000E+00
 0000831  0.1466E-05  0.3152E-06  0.1474E-05  0.6293E-08  0.0000E+00
 0000832  0.1456E-05  0.3121E-06  0.1464E-05  0.6244E-08  0.0000E+00
 0000833  0.1447E-05  0.3091E-06  0.1454E-05  0.6196E-08  0.0000E+00
 0000834  0.1437E-05  0.3061E-06  0.1445E-05  0.6148E-08  0.0000E+00
 0000835  0.1427E-05  0.3031E-06  0.1435E-05  0.6100E-08  0.0000E+00
 0000836  0.1417E-05  0.3001E-06  0.1425E-05  0.6053E-08  0.0000E+00
 0000837  0.1408E-05  0.2972E-06  0.1415E-05  0.6006E-08  0.0000E+00
 0000838  0.1398E-05  0.2943E-06  0.1406E-05  0.5960E-08  0.0000E+00
 0000839  0.1389E-05  0.2914E-06  0.1396E-05  0.5914E-08  0.0000E+00
 0000840  0.1379E-05  0.2885E-06  0.1387E-05  0.5869E-08  0.0000E+00
 0000841  0.1370E-05  0.2857E-06  0.1377E-05  0.5824E-08  0.0000E+00
 0000842  0.1361E-05  0.2829E-06  0.1368E-05  0.5779E-08  0.0000E+00
 0000843  0.1351E-05  0.2801E-06  0.1359E-05  0.5735E-08  0.0000E+00
 0000844  0.1342E-05  0.2774E-06  0.1350E-05  0.5691E-08  0.0000E+00
 0000845  0.1333E-05  0.2747E-06  0.1340E-05  0.5647E-08  0.0000E+00
 0000846  0.1324E-05  0.2720E-06  0.1331E-05  0.5604E-08  0.0000E+00
 0000847  0.1315E-05  0.2693E-06  0.1323E-05  0.5561E-08  0.0000E+00
 0000848  0.1307E-05  0.2667E-06  0.1314E-05  0.5519E-08  0.0000E+00
 0000849  0.1298E-05  0.2641E-06  0.1305E-05  0.5477E-08  0.0000E+00
 0000850  0.1289E-05  0.2615E-06  0.1296E-05  0.5435E-08  0.0000E+00
 0000851  0.1280E-05  0.2589E-06  0.1287E-05  0.5394E-08  0.0000E+00
 0000852  0.1272E-05  0.2564E-06  0.1279E-05  0.5353E-08  0.0000E+00
 0000853  0.1263E-05  0.2539E-06  0.1270E-05  0.5312E-08  0.0000E+00
 0000854  0.1255E-05  0.2514E-06  0.1262E-05  0.5272E-08  0.0000E+00
 0000855  0.1247E-05  0.2489E-06  0.1253E-05  0.5232E-08  0.0000E+00
 0000856  0.1238E-05  0.2465E-06  0.1245E-05  0.5193E-08  0.0000E+00
 0000857  0.1230E-05  0.2441E-06  0.1237E-05  0.5154E-08  0.0000E+00
 0000858  0.1222E-05  0.2417E-06  0.1228E-05  0.5115E-08  0.0000E+00
 0000859  0.1214E-05  0.2393E-06  0.1220E-05  0.5076E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 297
 0000860  0.1206E-05  0.2370E-06  0.1212E-05  0.5038E-08  0.0000E+00
 0000861  0.1198E-05  0.2347E-06  0.1204E-05  0.5000E-08  0.0000E+00
 0000862  0.1190E-05  0.2324E-06  0.1196E-05  0.4963E-08  0.0000E+00
 0000863  0.1182E-05  0.2301E-06  0.1188E-05  0.4925E-08  0.0000E+00
 0000864  0.1174E-05  0.2279E-06  0.1180E-05  0.4889E-08  0.0000E+00
 0000865  0.1166E-05  0.2256E-06  0.1173E-05  0.4852E-08  0.0000E+00
 0000866  0.1159E-05  0.2234E-06  0.1165E-05  0.4816E-08  0.0000E+00
 0000867  0.1151E-05  0.2212E-06  0.1157E-05  0.4780E-08  0.0000E+00
 0000868  0.1143E-05  0.2191E-06  0.1149E-05  0.4744E-08  0.0000E+00
 0000869  0.1136E-05  0.2169E-06  0.1142E-05  0.4709E-08  0.0000E+00
 0000870  0.1128E-05  0.2148E-06  0.1134E-05  0.4674E-08  0.0000E+00
 0000871  0.1121E-05  0.2127E-06  0.1127E-05  0.4639E-08  0.0000E+00
 0000872  0.1114E-05  0.2106E-06  0.1120E-05  0.4605E-08  0.0000E+00
 0000873  0.1106E-05  0.2086E-06  0.1112E-05  0.4571E-08  0.0000E+00
 0000874  0.1099E-05  0.2065E-06  0.1105E-05  0.4537E-08  0.0000E+00
 0000875  0.1092E-05  0.2045E-06  0.1098E-05  0.4503E-08  0.0000E+00
 0000876  0.1085E-05  0.2025E-06  0.1090E-05  0.4470E-08  0.0000E+00
 0000877  0.1078E-05  0.2005E-06  0.1083E-05  0.4437E-08  0.0000E+00
 0000878  0.1071E-05  0.1986E-06  0.1076E-05  0.4404E-08  0.0000E+00
 0000879  0.1064E-05  0.1966E-06  0.1069E-05  0.4372E-08  0.0000E+00
 0000880  0.1057E-05  0.1947E-06  0.1062E-05  0.4340E-08  0.0000E+00
 0000881  0.1050E-05  0.1928E-06  0.1055E-05  0.4308E-08  0.0000E+00
 0000882  0.1043E-05  0.1909E-06  0.1048E-05  0.4276E-08  0.0000E+00
 0000883  0.1036E-05  0.1890E-06  0.1042E-05  0.4245E-08  0.0000E+00
 0000884  0.1029E-05  0.1872E-06  0.1035E-05  0.4214E-08  0.0000E+00
 0000885  0.1023E-05  0.1853E-06  0.1028E-05  0.4183E-08  0.0000E+00
 0000886  0.1016E-05  0.1835E-06  0.1021E-05  0.4153E-08  0.0000E+00
 0000887  0.1010E-05  0.1817E-06  0.1015E-05  0.4122E-08  0.0000E+00
 0000888  0.1003E-05  0.1800E-06  0.1008E-05  0.4092E-08  0.0000E+00
 0000889  0.9966E-06  0.1782E-06  0.1002E-05  0.4063E-08  0.0000E+00
 0000890  0.9901E-06  0.1765E-06  0.9953E-06  0.4033E-08  0.0000E+00
 0000891  0.9837E-06  0.1747E-06  0.9888E-06  0.4004E-08  0.0000E+00
 0000892  0.9774E-06  0.1730E-06  0.9824E-06  0.3975E-08  0.0000E+00
 0000893  0.9711E-06  0.1713E-06  0.9761E-06  0.3946E-08  0.0000E+00
 0000894  0.9648E-06  0.1697E-06  0.9698E-06  0.3917E-08  0.0000E+00
 0000895  0.9586E-06  0.1680E-06  0.9636E-06  0.3889E-08  0.0000E+00
 0000896  0.9525E-06  0.1663E-06  0.9574E-06  0.3861E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 298
 0000897  0.9464E-06  0.1647E-06  0.9512E-06  0.3833E-08  0.0000E+00
 0000898  0.9403E-06  0.1631E-06  0.9451E-06  0.3806E-08  0.0000E+00
 0000899  0.9343E-06  0.1615E-06  0.9390E-06  0.3778E-08  0.0000E+00
 0000900  0.9283E-06  0.1599E-06  0.9330E-06  0.3751E-08  0.0000E+00
 0000901  0.9223E-06  0.1584E-06  0.9270E-06  0.3724E-08  0.0000E+00
 0000902  0.9164E-06  0.1568E-06  0.9211E-06  0.3697E-08  0.0000E+00
 0000903  0.9106E-06  0.1553E-06  0.9152E-06  0.3671E-08  0.0000E+00
 0000904  0.9048E-06  0.1538E-06  0.9094E-06  0.3645E-08  0.0000E+00
 0000905  0.8990E-06  0.1523E-06  0.9035E-06  0.3619E-08  0.0000E+00
 0000906  0.8932E-06  0.1508E-06  0.8978E-06  0.3593E-08  0.0000E+00
 0000907  0.8876E-06  0.1493E-06  0.8920E-06  0.3567E-08  0.0000E+00
 0000908  0.8819E-06  0.1478E-06  0.8864E-06  0.3542E-08  0.0000E+00
 0000909  0.8763E-06  0.1464E-06  0.8807E-06  0.3517E-08  0.0000E+00
 0000910  0.8707E-06  0.1450E-06  0.8751E-06  0.3492E-08  0.0000E+00
 0000911  0.8652E-06  0.1435E-06  0.8695E-06  0.3467E-08  0.0000E+00
 0000912  0.8597E-06  0.1421E-06  0.8640E-06  0.3442E-08  0.0000E+00
 0000913  0.8543E-06  0.1407E-06  0.8585E-06  0.3418E-08  0.0000E+00
 0000914  0.8488E-06  0.1394E-06  0.8531E-06  0.3394E-08  0.0000E+00
 0000915  0.8435E-06  0.1380E-06  0.8477E-06  0.3370E-08  0.0000E+00
 0000916  0.8381E-06  0.1367E-06  0.8423E-06  0.3346E-08  0.0000E+00
 0000917  0.8328E-06  0.1353E-06  0.8370E-06  0.3322E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 299
 0000918  0.8276E-06  0.1340E-06  0.8317E-06  0.3299E-08  0.0000E+00
 0000919  0.8223E-06  0.1327E-06  0.8264E-06  0.3276E-08  0.0000E+00
 0000920  0.8172E-06  0.1314E-06  0.8212E-06  0.3253E-08  0.0000E+00
 0000921  0.8120E-06  0.1301E-06  0.8160E-06  0.3230E-08  0.0000E+00
 0000922  0.8069E-06  0.1288E-06  0.8109E-06  0.3207E-08  0.0000E+00
 0000923  0.8018E-06  0.1276E-06  0.8058E-06  0.3185E-08  0.0000E+00
 0000924  0.7968E-06  0.1263E-06  0.8007E-06  0.3162E-08  0.0000E+00
 0000925  0.7918E-06  0.1251E-06  0.7956E-06  0.3140E-08  0.0000E+00
 0000926  0.7868E-06  0.1239E-06  0.7906E-06  0.3118E-08  0.0000E+00
 0000927  0.7819E-06  0.1227E-06  0.7857E-06  0.3097E-08  0.0000E+00
 0000928  0.7769E-06  0.1215E-06  0.7807E-06  0.3075E-08  0.0000E+00
 0000929  0.7721E-06  0.1203E-06  0.7758E-06  0.3054E-08  0.0000E+00
 0000930  0.7672E-06  0.1191E-06  0.7710E-06  0.3032E-08  0.0000E+00
 0000931  0.7624E-06  0.1179E-06  0.7661E-06  0.3011E-08  0.0000E+00
 0000932  0.7577E-06  0.1168E-06  0.7613E-06  0.2991E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 306
 0000933  0.7529E-06  0.1156E-06  0.7566E-06  0.2970E-08  0.0000E+00
 0000934  0.7482E-06  0.1145E-06  0.7518E-06  0.2949E-08  0.0000E+00
 0000935  0.7436E-06  0.1134E-06  0.7471E-06  0.2929E-08  0.0000E+00
 0000936  0.7389E-06  0.1123E-06  0.7425E-06  0.2909E-08  0.0000E+00
 0000937  0.7343E-06  0.1112E-06  0.7378E-06  0.2889E-08  0.0000E+00
 0000938  0.7297E-06  0.1101E-06  0.7332E-06  0.2869E-08  0.0000E+00
 0000939  0.7252E-06  0.1090E-06  0.7287E-06  0.2849E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 307
 0000940  0.7207E-06  0.1079E-06  0.7241E-06  0.2829E-08  0.0000E+00
 0000941  0.7162E-06  0.1069E-06  0.7196E-06  0.2810E-08  0.0000E+00
 0000942  0.7118E-06  0.1058E-06  0.7151E-06  0.2791E-08  0.0000E+00
 0000943  0.7073E-06  0.1048E-06  0.7107E-06  0.2771E-08  0.0000E+00
 0000944  0.7030E-06  0.1038E-06  0.7063E-06  0.2752E-08  0.0000E+00
 0000945  0.6986E-06  0.1028E-06  0.7019E-06  0.2734E-08  0.0000E+00
 0000946  0.6943E-06  0.1018E-06  0.6975E-06  0.2715E-08  0.0000E+00
 0000947  0.6900E-06  0.1008E-06  0.6932E-06  0.2696E-08  0.0000E+00
 0000948  0.6857E-06  0.9979E-07  0.6889E-06  0.2678E-08  0.0000E+00
 0000949  0.6815E-06  0.9881E-07  0.6846E-06  0.2660E-08  0.0000E+00
 0000950  0.6772E-06  0.9785E-07  0.6804E-06  0.2642E-08  0.0000E+00
 0000951  0.6731E-06  0.9689E-07  0.6762E-06  0.2624E-08  0.0000E+00
 0000952  0.6689E-06  0.9594E-07  0.6720E-06  0.2606E-08  0.0000E+00
 0000953  0.6648E-06  0.9501E-07  0.6679E-06  0.2588E-08  0.0000E+00
 0000954  0.6607E-06  0.9408E-07  0.6637E-06  0.2571E-08  0.0000E+00
 0000955  0.6566E-06  0.9316E-07  0.6596E-06  0.2553E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 308
 0000956  0.6526E-06  0.9225E-07  0.6556E-06  0.2536E-08  0.0000E+00
 0000957  0.6486E-06  0.9135E-07  0.6515E-06  0.2519E-08  0.0000E+00
 0000958  0.6446E-06  0.9045E-07  0.6475E-06  0.2502E-08  0.0000E+00
 0000959  0.6406E-06  0.8957E-07  0.6435E-06  0.2485E-08  0.0000E+00
 0000960  0.6367E-06  0.8870E-07  0.6396E-06  0.2468E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 309
 0000961  0.6328E-06  0.8783E-07  0.6356E-06  0.2451E-08  0.0000E+00
 0000962  0.6289E-06  0.8697E-07  0.6317E-06  0.2435E-08  0.0000E+00
 0000963  0.6250E-06  0.8612E-07  0.6278E-06  0.2419E-08  0.0000E+00
 0000964  0.6212E-06  0.8528E-07  0.6240E-06  0.2402E-08  0.0000E+00
 0000965  0.6174E-06  0.8445E-07  0.6202E-06  0.2386E-08  0.0000E+00
 0000966  0.6136E-06  0.8362E-07  0.6164E-06  0.2370E-08  0.0000E+00
 0000967  0.6099E-06  0.8280E-07  0.6126E-06  0.2354E-08  0.0000E+00
 0000968  0.6061E-06  0.8200E-07  0.6088E-06  0.2339E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 315
 0000969  0.6024E-06  0.8119E-07  0.6051E-06  0.2323E-08  0.0000E+00
 0000970  0.5987E-06  0.8040E-07  0.6014E-06  0.2308E-08  0.0000E+00
 0000971  0.5951E-06  0.7962E-07  0.5977E-06  0.2292E-08  0.0000E+00
 0000972  0.5915E-06  0.7884E-07  0.5941E-06  0.2277E-08  0.0000E+00
 0000973  0.5879E-06  0.7807E-07  0.5904E-06  0.2262E-08  0.0000E+00
 0000974  0.5843E-06  0.7731E-07  0.5868E-06  0.2247E-08  0.0000E+00
 0000975  0.5807E-06  0.7655E-07  0.5833E-06  0.2232E-08  0.0000E+00
 0000976  0.5772E-06  0.7580E-07  0.5797E-06  0.2217E-08  0.0000E+00
 0000977  0.5737E-06  0.7506E-07  0.5762E-06  0.2202E-08  0.0000E+00
 0000978  0.5702E-06  0.7433E-07  0.5727E-06  0.2188E-08  0.0000E+00
 0000979  0.5667E-06  0.7360E-07  0.5692E-06  0.2173E-08  0.0000E+00
 0000980  0.5633E-06  0.7289E-07  0.5657E-06  0.2159E-08  0.0000E+00
 0000981  0.5599E-06  0.7217E-07  0.5623E-06  0.2145E-08  0.0000E+00
 0000982  0.5565E-06  0.7147E-07  0.5589E-06  0.2130E-08  0.0000E+00
 0000983  0.5531E-06  0.7077E-07  0.5555E-06  0.2116E-08  0.0000E+00
 0000984  0.5497E-06  0.7008E-07  0.5521E-06  0.2102E-08  0.0000E+00
 0000985  0.5464E-06  0.6940E-07  0.5487E-06  0.2089E-08  0.0000E+00
 0000986  0.5431E-06  0.6872E-07  0.5454E-06  0.2075E-08  0.0000E+00
 0000987  0.5398E-06  0.6805E-07  0.5421E-06  0.2061E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 316
 0000988  0.5365E-06  0.6738E-07  0.5388E-06  0.2048E-08  0.0000E+00
 0000989  0.5333E-06  0.6673E-07  0.5355E-06  0.2034E-08  0.0000E+00
 0000990  0.5301E-06  0.6607E-07  0.5323E-06  0.2021E-08  0.0000E+00
 0000991  0.5269E-06  0.6543E-07  0.5291E-06  0.2008E-08  0.0000E+00
 0000992  0.5237E-06  0.6479E-07  0.5259E-06  0.1995E-08  0.0000E+00
 0000993  0.5205E-06  0.6416E-07  0.5227E-06  0.1982E-08  0.0000E+00
 0000994  0.5174E-06  0.6353E-07  0.5195E-06  0.1969E-08  0.0000E+00
 0000995  0.5143E-06  0.6291E-07  0.5164E-06  0.1956E-08  0.0000E+00
 0000996  0.5112E-06  0.6230E-07  0.5133E-06  0.1943E-08  0.0000E+00
 0000997  0.5081E-06  0.6169E-07  0.5102E-06  0.1930E-08  0.0000E+00
 0000998  0.5050E-06  0.6109E-07  0.5071E-06  0.1918E-08  0.0000E+00
 0000999  0.5020E-06  0.6049E-07  0.5041E-06  0.1905E-08  0.0000E+00
 0001000  0.4990E-06  0.5990E-07  0.5010E-06  0.1893E-08  0.0000E+00
 0001001  0.4960E-06  0.5932E-07  0.4980E-06  0.1881E-08  0.0000E+00
 0001002  0.4930E-06  0.5874E-07  0.4950E-06  0.1868E-08  0.0000E+00
 0001003  0.4900E-06  0.5817E-07  0.4920E-06  0.1856E-08  0.0000E+00
 0001004  0.4871E-06  0.5760E-07  0.4891E-06  0.1844E-08  0.0000E+00
 0001005  0.4842E-06  0.5704E-07  0.4861E-06  0.1832E-08  0.0000E+00
 0001006  0.4813E-06  0.5648E-07  0.4832E-06  0.1821E-08  0.0000E+00
 0001007  0.4784E-06  0.5593E-07  0.4803E-06  0.1809E-08  0.0000E+00
 0001008  0.4755E-06  0.5538E-07  0.4774E-06  0.1797E-08  0.0000E+00
 0001009  0.4727E-06  0.5484E-07  0.4746E-06  0.1786E-08  0.0000E+00
 0001010  0.4698E-06  0.5431E-07  0.4717E-06  0.1774E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 317
 0001011  0.4670E-06  0.5378E-07  0.4689E-06  0.1763E-08  0.0000E+00
 0001012  0.4642E-06  0.5325E-07  0.4661E-06  0.1751E-08  0.0000E+00
 0001013  0.4614E-06  0.5273E-07  0.4633E-06  0.1740E-08  0.0000E+00
 0001014  0.4587E-06  0.5222E-07  0.4605E-06  0.1729E-08  0.0000E+00
 0001015  0.4559E-06  0.5171E-07  0.4577E-06  0.1718E-08  0.0000E+00
 0001016  0.4532E-06  0.5121E-07  0.4550E-06  0.1707E-08  0.0000E+00
 0001017  0.4505E-06  0.5071E-07  0.4523E-06  0.1696E-08  0.0000E+00
 0001018  0.4478E-06  0.5021E-07  0.4496E-06  0.1685E-08  0.0000E+00
 0001019  0.4452E-06  0.4972E-07  0.4469E-06  0.1674E-08  0.0000E+00
 0001020  0.4425E-06  0.4924E-07  0.4442E-06  0.1664E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 318
 0001021  0.4399E-06  0.4876E-07  0.4416E-06  0.1653E-08  0.0000E+00
 0001022  0.4372E-06  0.4828E-07  0.4389E-06  0.1642E-08  0.0000E+00
 0001023  0.4346E-06  0.4781E-07  0.4363E-06  0.1632E-08  0.0000E+00
 0001024  0.4321E-06  0.4735E-07  0.4337E-06  0.1622E-08  0.0000E+00
 0001025  0.4295E-06  0.4689E-07  0.4311E-06  0.1611E-08  0.0000E+00
 0001026  0.4269E-06  0.4643E-07  0.4286E-06  0.1601E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 319
 0001027  0.4244E-06  0.4598E-07  0.4260E-06  0.1591E-08  0.0000E+00
 0001028  0.4219E-06  0.4553E-07  0.4235E-06  0.1581E-08  0.0000E+00
 0001029  0.4194E-06  0.4508E-07  0.4210E-06  0.1571E-08  0.0000E+00
 0001030  0.4169E-06  0.4465E-07  0.4184E-06  0.1561E-08  0.0000E+00
 0001031  0.4144E-06  0.4421E-07  0.4160E-06  0.1551E-08  0.0000E+00
 0001032  0.4119E-06  0.4378E-07  0.4135E-06  0.1541E-08  0.0000E+00
 0001033  0.4095E-06  0.4335E-07  0.4110E-06  0.1531E-08  0.0000E+00
 0001034  0.4071E-06  0.4293E-07  0.4086E-06  0.1522E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 320
 0001035  0.4047E-06  0.4251E-07  0.4062E-06  0.1512E-08  0.0000E+00
 0001036  0.4023E-06  0.4210E-07  0.4037E-06  0.1502E-08  0.0000E+00
 0001037  0.3999E-06  0.4169E-07  0.4013E-06  0.1493E-08  0.0000E+00
 0001038  0.3975E-06  0.4128E-07  0.3990E-06  0.1484E-08  0.0000E+00
 0001039  0.3951E-06  0.4088E-07  0.3966E-06  0.1474E-08  0.0000E+00
 0001040  0.3928E-06  0.4048E-07  0.3942E-06  0.1465E-08  0.0000E+00
 0001041  0.3905E-06  0.4009E-07  0.3919E-06  0.1456E-08  0.0000E+00
 0001042  0.3882E-06  0.3970E-07  0.3896E-06  0.1447E-08  0.0000E+00
 0001043  0.3859E-06  0.3931E-07  0.3873E-06  0.1437E-08  0.0000E+00
 0001044  0.3836E-06  0.3893E-07  0.3850E-06  0.1428E-08  0.0000E+00
 0001045  0.3813E-06  0.3855E-07  0.3827E-06  0.1420E-08  0.0000E+00
 0001046  0.3791E-06  0.3817E-07  0.3804E-06  0.1411E-08  0.0000E+00
 0001047  0.3768E-06  0.3780E-07  0.3782E-06  0.1402E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 321
 0001048  0.3746E-06  0.3744E-07  0.3760E-06  0.1393E-08  0.0000E+00
 0001049  0.3724E-06  0.3707E-07  0.3737E-06  0.1384E-08  0.0000E+00
 0001050  0.3702E-06  0.3671E-07  0.3715E-06  0.1376E-08  0.0000E+00
 0001051  0.3680E-06  0.3635E-07  0.3693E-06  0.1367E-08  0.0000E+00
 0001052  0.3659E-06  0.3600E-07  0.3672E-06  0.1359E-08  0.0000E+00
 0001053  0.3637E-06  0.3565E-07  0.3650E-06  0.1350E-08  0.0000E+00
 0001054  0.3616E-06  0.3530E-07  0.3628E-06  0.1342E-08  0.0000E+00
 0001055  0.3594E-06  0.3496E-07  0.3607E-06  0.1333E-08  0.0000E+00
 0001056  0.3573E-06  0.3462E-07  0.3586E-06  0.1325E-08  0.0000E+00
 0001057  0.3552E-06  0.3428E-07  0.3565E-06  0.1317E-08  0.0000E+00
 0001058  0.3531E-06  0.3395E-07  0.3544E-06  0.1309E-08  0.0000E+00
 0001059  0.3511E-06  0.3362E-07  0.3523E-06  0.1300E-08  0.0000E+00
 0001060  0.3490E-06  0.3329E-07  0.3502E-06  0.1292E-08  0.0000E+00
 0001061  0.3469E-06  0.3297E-07  0.3481E-06  0.1284E-08  0.0000E+00
 0001062  0.3449E-06  0.3265E-07  0.3461E-06  0.1276E-08  0.0000E+00
 0001063  0.3429E-06  0.3233E-07  0.3440E-06  0.1268E-08  0.0000E+00
 0001064  0.3409E-06  0.3202E-07  0.3420E-06  0.1261E-08  0.0000E+00
 0001065  0.3389E-06  0.3170E-07  0.3400E-06  0.1253E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 322
 0001066  0.3369E-06  0.3140E-07  0.3380E-06  0.1245E-08  0.0000E+00
 0001067  0.3349E-06  0.3109E-07  0.3360E-06  0.1237E-08  0.0000E+00
 0001068  0.3329E-06  0.3079E-07  0.3340E-06  0.1230E-08  0.0000E+00
 0001069  0.3310E-06  0.3049E-07  0.3321E-06  0.1222E-08  0.0000E+00
 0001070  0.3290E-06  0.3019E-07  0.3301E-06  0.1215E-08  0.0000E+00
 0001071  0.3271E-06  0.2990E-07  0.3282E-06  0.1207E-08  0.0000E+00
 0001072  0.3252E-06  0.2961E-07  0.3263E-06  0.1200E-08  0.0000E+00
 0001073  0.3233E-06  0.2932E-07  0.3244E-06  0.1192E-08  0.0000E+00
 0001074  0.3214E-06  0.2904E-07  0.3225E-06  0.1185E-08  0.0000E+00
 0001075  0.3195E-06  0.2876E-07  0.3206E-06  0.1178E-08  0.0000E+00
 0001076  0.3176E-06  0.2848E-07  0.3187E-06  0.1170E-08  0.0000E+00
 0001077  0.3158E-06  0.2820E-07  0.3168E-06  0.1163E-08  0.0000E+00
 0001078  0.3139E-06  0.2793E-07  0.3150E-06  0.1156E-08  0.0000E+00
 0001079  0.3121E-06  0.2765E-07  0.3131E-06  0.1149E-08  0.0000E+00
 0001080  0.3103E-06  0.2739E-07  0.3113E-06  0.1142E-08  0.0000E+00
 0001081  0.3085E-06  0.2712E-07  0.3095E-06  0.1135E-08  0.0000E+00
 0001082  0.3067E-06  0.2686E-07  0.3076E-06  0.1128E-08  0.0000E+00
 0001083  0.3049E-06  0.2660E-07  0.3058E-06  0.1121E-08  0.0000E+00
 0001084  0.3031E-06  0.2634E-07  0.3041E-06  0.1114E-08  0.0000E+00
 0001085  0.3013E-06  0.2608E-07  0.3023E-06  0.1107E-08  0.0000E+00
 0001086  0.2996E-06  0.2583E-07  0.3005E-06  0.1101E-08  0.0000E+00
 0001087  0.2978E-06  0.2558E-07  0.2988E-06  0.1094E-08  0.0000E+00
 0001088  0.2961E-06  0.2533E-07  0.2970E-06  0.1087E-08  0.0000E+00
 0001089  0.2944E-06  0.2508E-07  0.2953E-06  0.1081E-08  0.0000E+00
 0001090  0.2926E-06  0.2484E-07  0.2936E-06  0.1074E-08  0.0000E+00
 0001091  0.2909E-06  0.2460E-07  0.2918E-06  0.1067E-08  0.0000E+00
 0001092  0.2892E-06  0.2436E-07  0.2901E-06  0.1061E-08  0.0000E+00
 0001093  0.2875E-06  0.2413E-07  0.2884E-06  0.1055E-08  0.0000E+00
 0001094  0.2859E-06  0.2389E-07  0.2868E-06  0.1048E-08  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 323
 0001095  0.2842E-06  0.2366E-07  0.2851E-06  0.1042E-08  0.0000E+00
 0001096  0.2826E-06  0.2343E-07  0.2834E-06  0.1035E-08  0.0000E+00
 0001097  0.2809E-06  0.2320E-07  0.2818E-06  0.1029E-08  0.0000E+00
 0001098  0.2793E-06  0.2298E-07  0.2801E-06  0.1023E-08  0.0000E+00
 0001099  0.2776E-06  0.2276E-07  0.2785E-06  0.1017E-08  0.0000E+00
 0001100  0.2760E-06  0.2254E-07  0.2769E-06  0.1010E-08  0.0000E+00
 0001101  0.2744E-06  0.2232E-07  0.2753E-06  0.1004E-08  0.0000E+00
 0001102  0.2728E-06  0.2210E-07  0.2737E-06  0.9983E-09  0.0000E+00
 0001103  0.2712E-06  0.2189E-07  0.2721E-06  0.9922E-09  0.0000E+00
 0001104  0.2697E-06  0.2167E-07  0.2705E-06  0.9862E-09  0.0000E+00
 0001105  0.2681E-06  0.2146E-07  0.2689E-06  0.9802E-09  0.0000E+00
 0001106  0.2665E-06  0.2126E-07  0.2673E-06  0.9743E-09  0.0000E+00
 0001107  0.2650E-06  0.2105E-07  0.2658E-06  0.9684E-09  0.0000E+00
 0001108  0.2635E-06  0.2085E-07  0.2642E-06  0.9626E-09  0.0000E+00
 0001109  0.2619E-06  0.2065E-07  0.2627E-06  0.9568E-09  0.0000E+00
 0001110  0.2604E-06  0.2045E-07  0.2612E-06  0.9510E-09  0.0000E+00
 0001111  0.2589E-06  0.2025E-07  0.2597E-06  0.9452E-09  0.0000E+00
 0001112  0.2574E-06  0.2005E-07  0.2581E-06  0.9395E-09  0.0000E+00
 0001113  0.2559E-06  0.1986E-07  0.2566E-06  0.9339E-09  0.0000E+00
 0001114  0.2544E-06  0.1967E-07  0.2552E-06  0.9283E-09  0.0000E+00
 0001115  0.2529E-06  0.1948E-07  0.2537E-06  0.9227E-09  0.0000E+00
 0001116  0.2515E-06  0.1929E-07  0.2522E-06  0.9171E-09  0.0000E+00
 0001117  0.2500E-06  0.1910E-07  0.2507E-06  0.9116E-09  0.0000E+00
 0001118  0.2486E-06  0.1892E-07  0.2493E-06  0.9061E-09  0.0000E+00
 0001119  0.2471E-06  0.1873E-07  0.2478E-06  0.9007E-09  0.0000E+00
 0001120  0.2457E-06  0.1855E-07  0.2464E-06  0.8952E-09  0.0000E+00
 0001121  0.2443E-06  0.1837E-07  0.2450E-06  0.8899E-09  0.0000E+00
 0001122  0.2429E-06  0.1819E-07  0.2435E-06  0.8845E-09  0.0000E+00
 0001123  0.2415E-06  0.1802E-07  0.2421E-06  0.8792E-09  0.0000E+00
 0001124  0.2401E-06  0.1784E-07  0.2407E-06  0.8739E-09  0.0000E+00
 0001125  0.2387E-06  0.1767E-07  0.2393E-06  0.8687E-09  0.0000E+00
 0001126  0.2373E-06  0.1750E-07  0.2379E-06  0.8635E-09  0.0000E+00
 0001127  0.2359E-06  0.1733E-07  0.2366E-06  0.8583E-09  0.0000E+00
 0001128  0.2346E-06  0.1716E-07  0.2352E-06  0.8532E-09  0.0000E+00
 0001129  0.2332E-06  0.1700E-07  0.2338E-06  0.8481E-09  0.0000E+00
 0001130  0.2318E-06  0.1683E-07  0.2325E-06  0.8430E-09  0.0000E+00
 0001131  0.2305E-06  0.1667E-07  0.2311E-06  0.8380E-09  0.0000E+00
 0001132  0.2292E-06  0.1651E-07  0.2298E-06  0.8330E-09  0.0000E+00
 0001133  0.2278E-06  0.1635E-07  0.2285E-06  0.8280E-09  0.0000E+00
 0001134  0.2265E-06  0.1619E-07  0.2271E-06  0.8230E-09  0.0000E+00
 0001135  0.2252E-06  0.1604E-07  0.2258E-06  0.8181E-09  0.0000E+00
 0001136  0.2239E-06  0.1588E-07  0.2245E-06  0.8132E-09  0.0000E+00
 0001137  0.2226E-06  0.1573E-07  0.2232E-06  0.8084E-09  0.0000E+00
 0001138  0.2213E-06  0.1558E-07  0.2219E-06  0.8036E-09  0.0000E+00
 0001139  0.2201E-06  0.1543E-07  0.2206E-06  0.7988E-09  0.0000E+00
 0001140  0.2188E-06  0.1528E-07  0.2194E-06  0.7940E-09  0.0000E+00
 0001141  0.2175E-06  0.1513E-07  0.2181E-06  0.7893E-09  0.0000E+00
 0001142  0.2163E-06  0.1499E-07  0.2168E-06  0.7846E-09  0.0000E+00
 0001143  0.2150E-06  0.1484E-07  0.2156E-06  0.7799E-09  0.0000E+00
 0001144  0.2138E-06  0.1470E-07  0.2143E-06  0.7753E-09  0.0000E+00
 0001145  0.2126E-06  0.1456E-07  0.2131E-06  0.7707E-09  0.0000E+00
 0001146  0.2113E-06  0.1442E-07  0.2119E-06  0.7661E-09  0.0000E+00
 0001147  0.2101E-06  0.1428E-07  0.2107E-06  0.7615E-09  0.0000E+00
 0001148  0.2089E-06  0.1414E-07  0.2094E-06  0.7570E-09  0.0000E+00
 0001149  0.2077E-06  0.1400E-07  0.2082E-06  0.7525E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 324
 0001150  0.2065E-06  0.1387E-07  0.2070E-06  0.7481E-09  0.0000E+00
 0001151  0.2053E-06  0.1374E-07  0.2058E-06  0.7436E-09  0.0000E+00
 0001152  0.2041E-06  0.1360E-07  0.2046E-06  0.7392E-09  0.0000E+00
 0001153  0.2030E-06  0.1347E-07  0.2035E-06  0.7348E-09  0.0000E+00
 0001154  0.2018E-06  0.1334E-07  0.2023E-06  0.7305E-09  0.0000E+00
 0001155  0.2006E-06  0.1321E-07  0.2011E-06  0.7261E-09  0.0000E+00
 0001156  0.1995E-06  0.1309E-07  0.2000E-06  0.7218E-09  0.0000E+00
 0001157  0.1983E-06  0.1296E-07  0.1988E-06  0.7176E-09  0.0000E+00
 0001158  0.1972E-06  0.1284E-07  0.1977E-06  0.7133E-09  0.0000E+00
 0001159  0.1960E-06  0.1271E-07  0.1965E-06  0.7091E-09  0.0000E+00
 0001160  0.1949E-06  0.1259E-07  0.1954E-06  0.7049E-09  0.0000E+00
 0001161  0.1938E-06  0.1247E-07  0.1943E-06  0.7007E-09  0.0000E+00
 0001162  0.1927E-06  0.1235E-07  0.1931E-06  0.6966E-09  0.0000E+00
 0001163  0.1916E-06  0.1223E-07  0.1920E-06  0.6925E-09  0.0000E+00
 0001164  0.1905E-06  0.1211E-07  0.1909E-06  0.6884E-09  0.0000E+00
 0001165  0.1894E-06  0.1200E-07  0.1898E-06  0.6843E-09  0.0000E+00
 0001166  0.1883E-06  0.1188E-07  0.1887E-06  0.6803E-09  0.0000E+00
 0001167  0.1872E-06  0.1177E-07  0.1877E-06  0.6763E-09  0.0000E+00
 0001168  0.1861E-06  0.1166E-07  0.1866E-06  0.6723E-09  0.0000E+00
 0001169  0.1851E-06  0.1154E-07  0.1855E-06  0.6683E-09  0.0000E+00
 0001170  0.1840E-06  0.1143E-07  0.1844E-06  0.6644E-09  0.0000E+00
 0001171  0.1829E-06  0.1132E-07  0.1834E-06  0.6605E-09  0.0000E+00
 0001172  0.1819E-06  0.1121E-07  0.1823E-06  0.6566E-09  0.0000E+00
 0001173  0.1808E-06  0.1111E-07  0.1813E-06  0.6527E-09  0.0000E+00
 0001174  0.1798E-06  0.1100E-07  0.1802E-06  0.6489E-09  0.0000E+00
 0001175  0.1788E-06  0.1089E-07  0.1792E-06  0.6450E-09  0.0000E+00
 0001176  0.1777E-06  0.1079E-07  0.1782E-06  0.6412E-09  0.0000E+00
 0001177  0.1767E-06  0.1069E-07  0.1771E-06  0.6375E-09  0.0000E+00
 0001178  0.1757E-06  0.1058E-07  0.1761E-06  0.6337E-09  0.0000E+00
 0001179  0.1747E-06  0.1048E-07  0.1751E-06  0.6300E-09  0.0000E+00
 0001180  0.1737E-06  0.1038E-07  0.1741E-06  0.6263E-09  0.0000E+00
 0001181  0.1727E-06  0.1028E-07  0.1731E-06  0.6226E-09  0.0000E+00
 0001182  0.1717E-06  0.1018E-07  0.1721E-06  0.6190E-09  0.0000E+00
 0001183  0.1707E-06  0.1009E-07  0.1711E-06  0.6153E-09  0.0000E+00
 0001184  0.1697E-06  0.9991E-08  0.1701E-06  0.6117E-09  0.0000E+00
 0001185  0.1688E-06  0.9895E-08  0.1692E-06  0.6081E-09  0.0000E+00
 0001186  0.1678E-06  0.9801E-08  0.1682E-06  0.6046E-09  0.0000E+00
 0001187  0.1668E-06  0.9707E-08  0.1672E-06  0.6010E-09  0.0000E+00
 0001188  0.1659E-06  0.9614E-08  0.1663E-06  0.5975E-09  0.0000E+00
 0001189  0.1649E-06  0.9522E-08  0.1653E-06  0.5940E-09  0.0000E+00
 0001190  0.1640E-06  0.9431E-08  0.1644E-06  0.5905E-09  0.0000E+00
 0001191  0.1630E-06  0.9341E-08  0.1634E-06  0.5870E-09  0.0000E+00
 0001192  0.1621E-06  0.9252E-08  0.1625E-06  0.5836E-09  0.0000E+00
 0001193  0.1612E-06  0.9163E-08  0.1615E-06  0.5802E-09  0.0000E+00
 0001194  0.1603E-06  0.9076E-08  0.1606E-06  0.5768E-09  0.0000E+00
 0001195  0.1593E-06  0.8989E-08  0.1597E-06  0.5734E-09  0.0000E+00
 0001196  0.1584E-06  0.8903E-08  0.1588E-06  0.5701E-09  0.0000E+00
 0001197  0.1575E-06  0.8818E-08  0.1579E-06  0.5667E-09  0.0000E+00
 0001198  0.1566E-06  0.8734E-08  0.1570E-06  0.5634E-09  0.0000E+00
 0001199  0.1557E-06  0.8651E-08  0.1561E-06  0.5601E-09  0.0000E+00
 0001200  0.1548E-06  0.8568E-08  0.1552E-06  0.5568E-09  0.0000E+00
 0001201  0.1539E-06  0.8487E-08  0.1543E-06  0.5536E-09  0.0000E+00
 0001202  0.1531E-06  0.8406E-08  0.1534E-06  0.5504E-09  0.0000E+00
 0001203  0.1522E-06  0.8326E-08  0.1525E-06  0.5471E-09  0.0000E+00
 0001204  0.1513E-06  0.8246E-08  0.1516E-06  0.5439E-09  0.0000E+00
 0001205  0.1505E-06  0.8168E-08  0.1508E-06  0.5408E-09  0.0000E+00
 0001206  0.1496E-06  0.8090E-08  0.1499E-06  0.5376E-09  0.0000E+00
 0001207  0.1487E-06  0.8013E-08  0.1490E-06  0.5345E-09  0.0000E+00
 0001208  0.1479E-06  0.7937E-08  0.1482E-06  0.5314E-09  0.0000E+00
 0001209  0.1470E-06  0.7861E-08  0.1473E-06  0.5283E-09  0.0000E+00
 0001210  0.1462E-06  0.7786E-08  0.1465E-06  0.5252E-09  0.0000E+00
 0001211  0.1454E-06  0.7712E-08  0.1457E-06  0.5221E-09  0.0000E+00
 0001212  0.1445E-06  0.7639E-08  0.1448E-06  0.5191E-09  0.0000E+00
 0001213  0.1437E-06  0.7566E-08  0.1440E-06  0.5161E-09  0.0000E+00
 0001214  0.1429E-06  0.7494E-08  0.1432E-06  0.5131E-09  0.0000E+00
 0001215  0.1421E-06  0.7423E-08  0.1424E-06  0.5101E-09  0.0000E+00
 0001216  0.1413E-06  0.7353E-08  0.1415E-06  0.5071E-09  0.0000E+00
 0001217  0.1404E-06  0.7283E-08  0.1407E-06  0.5041E-09  0.0000E+00
 0001218  0.1396E-06  0.7214E-08  0.1399E-06  0.5012E-09  0.0000E+00
 0001219  0.1388E-06  0.7145E-08  0.1391E-06  0.4983E-09  0.0000E+00
 0001220  0.1381E-06  0.7077E-08  0.1383E-06  0.4954E-09  0.0000E+00
 0001221  0.1373E-06  0.7010E-08  0.1375E-06  0.4925E-09  0.0000E+00
 0001222  0.1365E-06  0.6944E-08  0.1367E-06  0.4897E-09  0.0000E+00
 0001223  0.1357E-06  0.6878E-08  0.1360E-06  0.4868E-09  0.0000E+00
 0001224  0.1349E-06  0.6813E-08  0.1352E-06  0.4840E-09  0.0000E+00
 0001225  0.1342E-06  0.6748E-08  0.1344E-06  0.4812E-09  0.0000E+00
 0001226  0.1334E-06  0.6684E-08  0.1336E-06  0.4784E-09  0.0000E+00
 0001227  0.1326E-06  0.6621E-08  0.1329E-06  0.4756E-09  0.0000E+00
 0001228  0.1319E-06  0.6558E-08  0.1321E-06  0.4728E-09  0.0000E+00
 0001229  0.1311E-06  0.6496E-08  0.1314E-06  0.4701E-09  0.0000E+00
 0001230  0.1304E-06  0.6434E-08  0.1306E-06  0.4674E-09  0.0000E+00
 0001231  0.1296E-06  0.6374E-08  0.1299E-06  0.4646E-09  0.0000E+00
 0001232  0.1289E-06  0.6313E-08  0.1291E-06  0.4619E-09  0.0000E+00
 0001233  0.1281E-06  0.6254E-08  0.1284E-06  0.4593E-09  0.0000E+00
 0001234  0.1274E-06  0.6194E-08  0.1277E-06  0.4566E-09  0.0000E+00
 0001235  0.1267E-06  0.6136E-08  0.1269E-06  0.4540E-09  0.0000E+00
 0001236  0.1260E-06  0.6078E-08  0.1262E-06  0.4513E-09  0.0000E+00
 0001237  0.1252E-06  0.6021E-08  0.1255E-06  0.4487E-09  0.0000E+00
 0001238  0.1245E-06  0.5964E-08  0.1248E-06  0.4461E-09  0.0000E+00
 0001239  0.1238E-06  0.5907E-08  0.1240E-06  0.4435E-09  0.0000E+00
 0001240  0.1231E-06  0.5852E-08  0.1233E-06  0.4410E-09  0.0000E+00
 0001241  0.1224E-06  0.5796E-08  0.1226E-06  0.4384E-09  0.0000E+00
 0001242  0.1217E-06  0.5742E-08  0.1219E-06  0.4359E-09  0.0000E+00
 0001243  0.1210E-06  0.5688E-08  0.1212E-06  0.4333E-09  0.0000E+00
 0001244  0.1203E-06  0.5634E-08  0.1205E-06  0.4308E-09  0.0000E+00
 0001245  0.1196E-06  0.5581E-08  0.1199E-06  0.4283E-09  0.0000E+00
 0001246  0.1190E-06  0.5528E-08  0.1192E-06  0.4259E-09  0.0000E+00
 0001247  0.1183E-06  0.5476E-08  0.1185E-06  0.4234E-09  0.0000E+00
 0001248  0.1176E-06  0.5425E-08  0.1178E-06  0.4209E-09  0.0000E+00
 0001249  0.1169E-06  0.5374E-08  0.1171E-06  0.4185E-09  0.0000E+00
 0001250  0.1163E-06  0.5323E-08  0.1165E-06  0.4161E-09  0.0000E+00
 0001251  0.1156E-06  0.5273E-08  0.1158E-06  0.4137E-09  0.0000E+00
 0001252  0.1149E-06  0.5224E-08  0.1151E-06  0.4113E-09  0.0000E+00
 0001253  0.1143E-06  0.5174E-08  0.1145E-06  0.4089E-09  0.0000E+00
 0001254  0.1136E-06  0.5126E-08  0.1138E-06  0.4066E-09  0.0000E+00
 0001255  0.1130E-06  0.5078E-08  0.1132E-06  0.4042E-09  0.0000E+00
 0001256  0.1123E-06  0.5030E-08  0.1125E-06  0.4019E-09  0.0000E+00
 0001257  0.1117E-06  0.4983E-08  0.1119E-06  0.3996E-09  0.0000E+00
 0001258  0.1111E-06  0.4936E-08  0.1113E-06  0.3972E-09  0.0000E+00
 0001259  0.1104E-06  0.4890E-08  0.1106E-06  0.3950E-09  0.0000E+00
 0001260  0.1098E-06  0.4844E-08  0.1100E-06  0.3927E-09  0.0000E+00
 0001261  0.1092E-06  0.4799E-08  0.1094E-06  0.3904E-09  0.0000E+00
 0001262  0.1086E-06  0.4754E-08  0.1087E-06  0.3882E-09  0.0000E+00
 0001263  0.1079E-06  0.4709E-08  0.1081E-06  0.3859E-09  0.0000E+00
 0001264  0.1073E-06  0.4665E-08  0.1075E-06  0.3837E-09  0.0000E+00
 0001265  0.1067E-06  0.4621E-08  0.1069E-06  0.3815E-09  0.0000E+00
 0001266  0.1061E-06  0.4578E-08  0.1063E-06  0.3793E-09  0.0000E+00
 0001267  0.1055E-06  0.4535E-08  0.1057E-06  0.3771E-09  0.0000E+00
 0001268  0.1049E-06  0.4493E-08  0.1051E-06  0.3749E-09  0.0000E+00
 0001269  0.1043E-06  0.4451E-08  0.1045E-06  0.3728E-09  0.0000E+00
 0001270  0.1037E-06  0.4409E-08  0.1039E-06  0.3706E-09  0.0000E+00
 0001271  0.1031E-06  0.4368E-08  0.1033E-06  0.3685E-09  0.0000E+00
 0001272  0.1025E-06  0.4327E-08  0.1027E-06  0.3663E-09  0.0000E+00
 0001273  0.1019E-06  0.4287E-08  0.1021E-06  0.3642E-09  0.0000E+00
 0001274  0.1014E-06  0.4247E-08  0.1015E-06  0.3621E-09  0.0000E+00
 0001275  0.1008E-06  0.4207E-08  0.1010E-06  0.3601E-09  0.0000E+00
 0001276  0.1002E-06  0.4168E-08  0.1004E-06  0.3580E-09  0.0000E+00
 0001277  0.9965E-07  0.4129E-08  0.9981E-07  0.3559E-09  0.0000E+00
 0001278  0.9908E-07  0.4091E-08  0.9924E-07  0.3539E-09  0.0000E+00
 0001279  0.9852E-07  0.4053E-08  0.9867E-07  0.3518E-09  0.0000E+00
 0001280  0.9796E-07  0.4015E-08  0.9811E-07  0.3498E-09  0.0000E+00
 0001281  0.9740E-07  0.3978E-08  0.9755E-07  0.3478E-09  0.0000E+00
 0001282  0.9684E-07  0.3941E-08  0.9700E-07  0.3458E-09  0.0000E+00
 0001283  0.9629E-07  0.3904E-08  0.9644E-07  0.3438E-09  0.0000E+00
 0001284  0.9575E-07  0.3868E-08  0.9589E-07  0.3418E-09  0.0000E+00
 0001285  0.9520E-07  0.3832E-08  0.9535E-07  0.3399E-09  0.0000E+00
 0001286  0.9466E-07  0.3797E-08  0.9480E-07  0.3379E-09  0.0000E+00
 0001287  0.9412E-07  0.3761E-08  0.9426E-07  0.3360E-09  0.0000E+00
 0001288  0.9358E-07  0.3726E-08  0.9373E-07  0.3340E-09  0.0000E+00
 0001289  0.9305E-07  0.3692E-08  0.9319E-07  0.3321E-09  0.0000E+00
 0001290  0.9252E-07  0.3658E-08  0.9266E-07  0.3302E-09  0.0000E+00
 0001291  0.9200E-07  0.3624E-08  0.9214E-07  0.3283E-09  0.0000E+00
 0001292  0.9147E-07  0.3590E-08  0.9161E-07  0.3264E-09  0.0000E+00
 0001293  0.9095E-07  0.3557E-08  0.9109E-07  0.3245E-09  0.0000E+00
 0001294  0.9044E-07  0.3524E-08  0.9057E-07  0.3227E-09  0.0000E+00
 0001295  0.8992E-07  0.3492E-08  0.9005E-07  0.3208E-09  0.0000E+00
 0001296  0.8941E-07  0.3459E-08  0.8954E-07  0.3190E-09  0.0000E+00
 0001297  0.8890E-07  0.3427E-08  0.8903E-07  0.3172E-09  0.0000E+00
 0001298  0.8840E-07  0.3396E-08  0.8853E-07  0.3153E-09  0.0000E+00
 0001299  0.8789E-07  0.3364E-08  0.8802E-07  0.3135E-09  0.0000E+00
 0001300  0.8739E-07  0.3333E-08  0.8752E-07  0.3117E-09  0.0000E+00
 0001301  0.8690E-07  0.3303E-08  0.8702E-07  0.3099E-09  0.0000E+00
 0001302  0.8640E-07  0.3272E-08  0.8653E-07  0.3082E-09  0.0000E+00
 0001303  0.8591E-07  0.3242E-08  0.8604E-07  0.3064E-09  0.0000E+00
 0001304  0.8542E-07  0.3212E-08  0.8555E-07  0.3046E-09  0.0000E+00
 0001305  0.8494E-07  0.3183E-08  0.8506E-07  0.3029E-09  0.0000E+00
 0001306  0.8445E-07  0.3153E-08  0.8457E-07  0.3011E-09  0.0000E+00
 0001307  0.8397E-07  0.3124E-08  0.8409E-07  0.2994E-09  0.0000E+00
 0001308  0.8350E-07  0.3096E-08  0.8362E-07  0.2977E-09  0.0000E+00
 0001309  0.8302E-07  0.3067E-08  0.8314E-07  0.2960E-09  0.0000E+00
 0001310  0.8255E-07  0.3039E-08  0.8267E-07  0.2943E-09  0.0000E+00
 0001311  0.8208E-07  0.3011E-08  0.8220E-07  0.2926E-09  0.0000E+00
 0001312  0.8162E-07  0.2984E-08  0.8173E-07  0.2909E-09  0.0000E+00
 0001313  0.8115E-07  0.2956E-08  0.8126E-07  0.2893E-09  0.0000E+00
 0001314  0.8069E-07  0.2929E-08  0.8080E-07  0.2876E-09  0.0000E+00
 0001315  0.8023E-07  0.2902E-08  0.8034E-07  0.2860E-09  0.0000E+00
 0001316  0.7978E-07  0.2876E-08  0.7989E-07  0.2843E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 314
 0001317  0.7932E-07  0.2850E-08  0.7943E-07  0.2827E-09  0.0000E+00
 0001318  0.7887E-07  0.2823E-08  0.7898E-07  0.2811E-09  0.0000E+00
 0001319  0.7842E-07  0.2798E-08  0.7853E-07  0.2795E-09  0.0000E+00
 0001320  0.7798E-07  0.2772E-08  0.7808E-07  0.2779E-09  0.0000E+00
 0001321  0.7754E-07  0.2747E-08  0.7764E-07  0.2763E-09  0.0000E+00
 0001322  0.7710E-07  0.2722E-08  0.7720E-07  0.2747E-09  0.0000E+00
 0001323  0.7666E-07  0.2697E-08  0.7676E-07  0.2731E-09  0.0000E+00
 0001324  0.7622E-07  0.2672E-08  0.7632E-07  0.2716E-09  0.0000E+00
 0001325  0.7579E-07  0.2648E-08  0.7589E-07  0.2700E-09  0.0000E+00
 0001326  0.7536E-07  0.2624E-08  0.7546E-07  0.2685E-09  0.0000E+00
 0001327  0.7493E-07  0.2600E-08  0.7503E-07  0.2669E-09  0.0000E+00
 0001328  0.7450E-07  0.2576E-08  0.7460E-07  0.2654E-09  0.0000E+00
 0001329  0.7408E-07  0.2553E-08  0.7418E-07  0.2639E-09  0.0000E+00
 0001330  0.7366E-07  0.2530E-08  0.7376E-07  0.2624E-09  0.0000E+00
 0001331  0.7324E-07  0.2507E-08  0.7334E-07  0.2609E-09  0.0000E+00
 0001332  0.7283E-07  0.2484E-08  0.7292E-07  0.2594E-09  0.0000E+00
 0001333  0.7241E-07  0.2462E-08  0.7251E-07  0.2579E-09  0.0000E+00
 0001334  0.7200E-07  0.2439E-08  0.7209E-07  0.2564E-09  0.0000E+00
 0001335  0.7159E-07  0.2417E-08  0.7168E-07  0.2549E-09  0.0000E+00
 0001336  0.7119E-07  0.2395E-08  0.7128E-07  0.2535E-09  0.0000E+00
 0001337  0.7078E-07  0.2374E-08  0.7087E-07  0.2520E-09  0.0000E+00
 0001338  0.7038E-07  0.2352E-08  0.7047E-07  0.2506E-09  0.0000E+00
 0001339  0.6998E-07  0.2331E-08  0.7007E-07  0.2492E-09  0.0000E+00
 0001340  0.6958E-07  0.2310E-08  0.6967E-07  0.2477E-09  0.0000E+00
 0001341  0.6919E-07  0.2289E-08  0.6927E-07  0.2463E-09  0.0000E+00
 0001342  0.6880E-07  0.2268E-08  0.6888E-07  0.2449E-09  0.0000E+00
 0001343  0.6841E-07  0.2248E-08  0.6849E-07  0.2435E-09  0.0000E+00
 0001344  0.6802E-07  0.2228E-08  0.6810E-07  0.2421E-09  0.0000E+00
 0001345  0.6763E-07  0.2208E-08  0.6771E-07  0.2407E-09  0.0000E+00
 0001346  0.6725E-07  0.2188E-08  0.6733E-07  0.2394E-09  0.0000E+00
 0001347  0.6687E-07  0.2168E-08  0.6695E-07  0.2380E-09  0.0000E+00
 0001348  0.6649E-07  0.2149E-08  0.6657E-07  0.2366E-09  0.0000E+00
 0001349  0.6611E-07  0.2129E-08  0.6619E-07  0.2353E-09  0.0000E+00
 0001350  0.6573E-07  0.2110E-08  0.6581E-07  0.2339E-09  0.0000E+00
 0001351  0.6536E-07  0.2091E-08  0.6544E-07  0.2326E-09  0.0000E+00
 0001352  0.6499E-07  0.2073E-08  0.6507E-07  0.2313E-09  0.0000E+00
 0001353  0.6462E-07  0.2054E-08  0.6470E-07  0.2300E-09  0.0000E+00
 0001354  0.6425E-07  0.2036E-08  0.6433E-07  0.2286E-09  0.0000E+00
 0001355  0.6389E-07  0.2017E-08  0.6396E-07  0.2273E-09  0.0000E+00
 0001356  0.6353E-07  0.1999E-08  0.6360E-07  0.2260E-09  0.0000E+00
 0001357  0.6317E-07  0.1981E-08  0.6324E-07  0.2247E-09  0.0000E+00
 0001358  0.6281E-07  0.1964E-08  0.6288E-07  0.2235E-09  0.0000E+00
 0001359  0.6245E-07  0.1946E-08  0.6252E-07  0.2222E-09  0.0000E+00
 0001360  0.6210E-07  0.1929E-08  0.6217E-07  0.2209E-09  0.0000E+00
 0001361  0.6174E-07  0.1912E-08  0.6182E-07  0.2197E-09  0.0000E+00
 0001362  0.6139E-07  0.1895E-08  0.6146E-07  0.2184E-09  0.0000E+00
 0001363  0.6105E-07  0.1878E-08  0.6112E-07  0.2172E-09  0.0000E+00
 0001364  0.6070E-07  0.1861E-08  0.6077E-07  0.2159E-09  0.0000E+00
 0001365  0.6036E-07  0.1845E-08  0.6042E-07  0.2147E-09  0.0000E+00
 0001366  0.6001E-07  0.1828E-08  0.6008E-07  0.2135E-09  0.0000E+00
 0001367  0.5967E-07  0.1812E-08  0.5974E-07  0.2122E-09  0.0000E+00
 0001368  0.5933E-07  0.1796E-08  0.5940E-07  0.2110E-09  0.0000E+00
 0001369  0.5900E-07  0.1780E-08  0.5906E-07  0.2098E-09  0.0000E+00
 0001370  0.5866E-07  0.1764E-08  0.5873E-07  0.2086E-09  0.0000E+00
 0001371  0.5833E-07  0.1749E-08  0.5839E-07  0.2074E-09  0.0000E+00
 0001372  0.5800E-07  0.1733E-08  0.5806E-07  0.2063E-09  0.0000E+00
 0001373  0.5767E-07  0.1718E-08  0.5773E-07  0.2051E-09  0.0000E+00
 0001374  0.5734E-07  0.1703E-08  0.5741E-07  0.2039E-09  0.0000E+00
 0001375  0.5702E-07  0.1688E-08  0.5708E-07  0.2028E-09  0.0000E+00
 0001376  0.5669E-07  0.1673E-08  0.5676E-07  0.2016E-09  0.0000E+00
 0001377  0.5637E-07  0.1658E-08  0.5643E-07  0.2004E-09  0.0000E+00
 0001378  0.5605E-07  0.1643E-08  0.5611E-07  0.1993E-09  0.0000E+00
 0001379  0.5574E-07  0.1629E-08  0.5580E-07  0.1982E-09  0.0000E+00
 0001380  0.5542E-07  0.1615E-08  0.5548E-07  0.1970E-09  0.0000E+00
 0001381  0.5511E-07  0.1600E-08  0.5516E-07  0.1959E-09  0.0000E+00
 0001382  0.5479E-07  0.1586E-08  0.5485E-07  0.1948E-09  0.0000E+00
 0001383  0.5448E-07  0.1572E-08  0.5454E-07  0.1937E-09  0.0000E+00
 0001384  0.5417E-07  0.1559E-08  0.5423E-07  0.1926E-09  0.0000E+00
 0001385  0.5387E-07  0.1545E-08  0.5392E-07  0.1915E-09  0.0000E+00
 0001386  0.5356E-07  0.1532E-08  0.5362E-07  0.1904E-09  0.0000E+00
 0001387  0.5326E-07  0.1518E-08  0.5331E-07  0.1893E-09  0.0000E+00
 0001388  0.5295E-07  0.1505E-08  0.5301E-07  0.1882E-09  0.0000E+00
 0001389  0.5265E-07  0.1492E-08  0.5271E-07  0.1872E-09  0.0000E+00
 0001390  0.5236E-07  0.1479E-08  0.5241E-07  0.1861E-09  0.0000E+00
 0001391  0.5206E-07  0.1466E-08  0.5211E-07  0.1850E-09  0.0000E+00
 0001392  0.5176E-07  0.1453E-08  0.5182E-07  0.1840E-09  0.0000E+00
 0001393  0.5147E-07  0.1440E-08  0.5152E-07  0.1829E-09  0.0000E+00
 0001394  0.5118E-07  0.1428E-08  0.5123E-07  0.1819E-09  0.0000E+00
 0001395  0.5089E-07  0.1415E-08  0.5094E-07  0.1809E-09  0.0000E+00
 0001396  0.5060E-07  0.1403E-08  0.5065E-07  0.1798E-09  0.0000E+00
 0001397  0.5031E-07  0.1391E-08  0.5036E-07  0.1788E-09  0.0000E+00
 0001398  0.5003E-07  0.1379E-08  0.5008E-07  0.1778E-09  0.0000E+00
 0001399  0.4974E-07  0.1367E-08  0.4979E-07  0.1768E-09  0.0000E+00
 0001400  0.4946E-07  0.1355E-08  0.4951E-07  0.1758E-09  0.0000E+00
 0001401  0.4918E-07  0.1343E-08  0.4923E-07  0.1748E-09  0.0000E+00
 0001402  0.4890E-07  0.1332E-08  0.4895E-07  0.1738E-09  0.0000E+00
 0001403  0.4863E-07  0.1320E-08  0.4867E-07  0.1728E-09  0.0000E+00
 0001404  0.4835E-07  0.1309E-08  0.4840E-07  0.1718E-09  0.0000E+00
 0001405  0.4808E-07  0.1298E-08  0.4812E-07  0.1708E-09  0.0000E+00
 0001406  0.4780E-07  0.1286E-08  0.4785E-07  0.1699E-09  0.0000E+00
 0001407  0.4753E-07  0.1275E-08  0.4758E-07  0.1689E-09  0.0000E+00
 0001408  0.4726E-07  0.1264E-08  0.4731E-07  0.1679E-09  0.0000E+00
 0001409  0.4700E-07  0.1254E-08  0.4704E-07  0.1670E-09  0.0000E+00
 0001410  0.4673E-07  0.1243E-08  0.4677E-07  0.1660E-09  0.0000E+00
 0001411  0.4646E-07  0.1232E-08  0.4651E-07  0.1651E-09  0.0000E+00
 0001412  0.4620E-07  0.1222E-08  0.4624E-07  0.1641E-09  0.0000E+00
 0001413  0.4594E-07  0.1211E-08  0.4598E-07  0.1632E-09  0.0000E+00
 0001414  0.4568E-07  0.1201E-08  0.4572E-07  0.1623E-09  0.0000E+00
 0001415  0.4542E-07  0.1190E-08  0.4546E-07  0.1613E-09  0.0000E+00
 0001416  0.4516E-07  0.1180E-08  0.4520E-07  0.1604E-09  0.0000E+00
 0001417  0.4491E-07  0.1170E-08  0.4495E-07  0.1595E-09  0.0000E+00
 0001418  0.4465E-07  0.1160E-08  0.4469E-07  0.1586E-09  0.0000E+00
 0001419  0.4440E-07  0.1150E-08  0.4444E-07  0.1577E-09  0.0000E+00
 0001420  0.4415E-07  0.1141E-08  0.4419E-07  0.1568E-09  0.0000E+00
 0001421  0.4390E-07  0.1131E-08  0.4394E-07  0.1559E-09  0.0000E+00
 0001422  0.4365E-07  0.1121E-08  0.4369E-07  0.1550E-09  0.0000E+00
 0001423  0.4340E-07  0.1112E-08  0.4344E-07  0.1542E-09  0.0000E+00
 0001424  0.4316E-07  0.1102E-08  0.4319E-07  0.1533E-09  0.0000E+00
 0001425  0.4291E-07  0.1093E-08  0.4295E-07  0.1524E-09  0.0000E+00
 0001426  0.4267E-07  0.1084E-08  0.4271E-07  0.1515E-09  0.0000E+00
 0001427  0.4243E-07  0.1075E-08  0.4246E-07  0.1507E-09  0.0000E+00
 0001428  0.4219E-07  0.1065E-08  0.4222E-07  0.1498E-09  0.0000E+00
 0001429  0.4195E-07  0.1056E-08  0.4198E-07  0.1490E-09  0.0000E+00
 0001430  0.4171E-07  0.1048E-08  0.4175E-07  0.1481E-09  0.0000E+00
 0001431  0.4147E-07  0.1039E-08  0.4151E-07  0.1473E-09  0.0000E+00
 0001432  0.4124E-07  0.1030E-08  0.4127E-07  0.1464E-09  0.0000E+00
 0001433  0.4100E-07  0.1021E-08  0.4104E-07  0.1456E-09  0.0000E+00
 0001434  0.4077E-07  0.1013E-08  0.4081E-07  0.1448E-09  0.0000E+00
 0001435  0.4054E-07  0.1004E-08  0.4058E-07  0.1440E-09  0.0000E+00
 0001436  0.4031E-07  0.9958E-09  0.4035E-07  0.1431E-09  0.0000E+00
 0001437  0.4008E-07  0.9875E-09  0.4012E-07  0.1423E-09  0.0000E+00
 0001438  0.3986E-07  0.9792E-09  0.3989E-07  0.1415E-09  0.0000E+00
 0001439  0.3963E-07  0.9710E-09  0.3966E-07  0.1407E-09  0.0000E+00
 0001440  0.3941E-07  0.9629E-09  0.3944E-07  0.1399E-09  0.0000E+00
 0001441  0.3918E-07  0.9549E-09  0.3921E-07  0.1391E-09  0.0000E+00
 0001442  0.3896E-07  0.9469E-09  0.3899E-07  0.1383E-09  0.0000E+00
 0001443  0.3874E-07  0.9390E-09  0.3877E-07  0.1375E-09  0.0000E+00
 0001444  0.3852E-07  0.9312E-09  0.3855E-07  0.1368E-09  0.0000E+00
 0001445  0.3830E-07  0.9235E-09  0.3833E-07  0.1360E-09  0.0000E+00
 0001446  0.3808E-07  0.9158E-09  0.3812E-07  0.1352E-09  0.0000E+00
 0001447  0.3787E-07  0.9082E-09  0.3790E-07  0.1344E-09  0.0000E+00
 0001448  0.3765E-07  0.9007E-09  0.3769E-07  0.1337E-09  0.0000E+00
 0001449  0.3744E-07  0.8932E-09  0.3747E-07  0.1329E-09  0.0000E+00
 0001450  0.3723E-07  0.8858E-09  0.3726E-07  0.1322E-09  0.0000E+00
 0001451  0.3702E-07  0.8785E-09  0.3705E-07  0.1314E-09  0.0000E+00
 0001452  0.3681E-07  0.8712E-09  0.3684E-07  0.1307E-09  0.0000E+00
 0001453  0.3660E-07  0.8640E-09  0.3663E-07  0.1299E-09  0.0000E+00
 0001454  0.3639E-07  0.8569E-09  0.3642E-07  0.1292E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 327
 0001455  0.3619E-07  0.8499E-09  0.3622E-07  0.1285E-09  0.0000E+00
 0001456  0.3598E-07  0.8429E-09  0.3601E-07  0.1277E-09  0.0000E+00
 0001457  0.3578E-07  0.8360E-09  0.3581E-07  0.1270E-09  0.0000E+00
 0001458  0.3558E-07  0.8291E-09  0.3560E-07  0.1263E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 328
 0001459  0.3537E-07  0.8223E-09  0.3540E-07  0.1256E-09  0.0000E+00
 0001460  0.3517E-07  0.8156E-09  0.3520E-07  0.1248E-09  0.0000E+00
 0001461  0.3497E-07  0.8089E-09  0.3500E-07  0.1241E-09  0.0000E+00
 0001462  0.3478E-07  0.8023E-09  0.3480E-07  0.1234E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 329
 0001463  0.3458E-07  0.7957E-09  0.3461E-07  0.1227E-09  0.0000E+00
 0001464  0.3438E-07  0.7892E-09  0.3441E-07  0.1220E-09  0.0000E+00
 0001465  0.3419E-07  0.7828E-09  0.3421E-07  0.1213E-09  0.0000E+00
 0001466  0.3400E-07  0.7764E-09  0.3402E-07  0.1207E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 331
 0001467  0.3380E-07  0.7701E-09  0.3383E-07  0.1200E-09  0.0000E+00
 0001468  0.3361E-07  0.7638E-09  0.3364E-07  0.1193E-09  0.0000E+00
 0001469  0.3342E-07  0.7576E-09  0.3345E-07  0.1186E-09  0.0000E+00
 0001470  0.3323E-07  0.7515E-09  0.3326E-07  0.1179E-09  0.0000E+00
 0001471  0.3304E-07  0.7454E-09  0.3307E-07  0.1173E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 332
 0001472  0.3286E-07  0.7394E-09  0.3288E-07  0.1166E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 333
 0001473  0.3267E-07  0.7334E-09  0.3269E-07  0.1159E-09  0.0000E+00
 0001474  0.3249E-07  0.7275E-09  0.3251E-07  0.1153E-09  0.0000E+00
 0001475  0.3230E-07  0.7216E-09  0.3232E-07  0.1146E-09  0.0000E+00
 0001476  0.3212E-07  0.7158E-09  0.3214E-07  0.1140E-09  0.0000E+00
 0001477  0.3194E-07  0.7100E-09  0.3196E-07  0.1133E-09  0.0000E+00
 0001478  0.3176E-07  0.7043E-09  0.3178E-07  0.1127E-09  0.0000E+00
 0001479  0.3158E-07  0.6987E-09  0.3160E-07  0.1120E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 337
 0001480  0.3140E-07  0.6931E-09  0.3142E-07  0.1114E-09  0.0000E+00
 0001481  0.3122E-07  0.6875E-09  0.3124E-07  0.1108E-09  0.0000E+00
 0001482  0.3104E-07  0.6820E-09  0.3106E-07  0.1102E-09  0.0000E+00
 0001483  0.3087E-07  0.6766E-09  0.3089E-07  0.1095E-09  0.0000E+00
 0001484  0.3069E-07  0.6711E-09  0.3071E-07  0.1089E-09  0.0000E+00
 0001485  0.3052E-07  0.6658E-09  0.3054E-07  0.1083E-09  0.0000E+00
 0001486  0.3035E-07  0.6605E-09  0.3037E-07  0.1077E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 336
 0001487  0.3017E-07  0.6552E-09  0.3019E-07  0.1071E-09  0.0000E+00
 0001488  0.3000E-07  0.6500E-09  0.3002E-07  0.1065E-09  0.0000E+00
 0001489  0.2983E-07  0.6448E-09  0.2985E-07  0.1058E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 335
 0001490  0.2966E-07  0.6397E-09  0.2968E-07  0.1052E-09  0.0000E+00
 0001491  0.2950E-07  0.6347E-09  0.2952E-07  0.1047E-09  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 338
 0001492  0.2933E-07  0.6296E-09  0.2935E-07  0.1041E-09  0.0000E+00
 0001493  0.2916E-07  0.6246E-09  0.2918E-07  0.1035E-09  0.0000E+00
 0001494  0.2900E-07  0.6197E-09  0.2902E-07  0.1029E-09  0.0000E+00
 0001495  0.2883E-07  0.6148E-09  0.2885E-07  0.1023E-09  0.0000E+00
 0001496  0.2867E-07  0.6100E-09  0.2869E-07  0.1017E-09  0.0000E+00
 0001497  0.2851E-07  0.6052E-09  0.2853E-07  0.1011E-09  0.0000E+00
 0001498  0.2835E-07  0.6004E-09  0.2837E-07  0.1006E-09  0.0000E+00
 0001499  0.2819E-07  0.5957E-09  0.2821E-07  0.9999E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 339
 0001500  0.2803E-07  0.5910E-09  0.2805E-07  0.9943E-10  0.0000E+00
 0001501  0.2787E-07  0.5864E-09  0.2789E-07  0.9886E-10  0.0000E+00
 0001502  0.2771E-07  0.5818E-09  0.2773E-07  0.9830E-10  0.0000E+00
 0001503  0.2755E-07  0.5772E-09  0.2757E-07  0.9775E-10  0.0000E+00
 0001504  0.2740E-07  0.5727E-09  0.2742E-07  0.9719E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 340
 0001505  0.2724E-07  0.5683E-09  0.2726E-07  0.9664E-10  0.0000E+00
 0001506  0.2709E-07  0.5638E-09  0.2711E-07  0.9609E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 334
 0001507  0.2693E-07  0.5594E-09  0.2695E-07  0.9555E-10  0.0000E+00
 0001508  0.2678E-07  0.5551E-09  0.2680E-07  0.9500E-10  0.0000E+00
 0001509  0.2663E-07  0.5508E-09  0.2665E-07  0.9447E-10  0.0000E+00
 0001510  0.2648E-07  0.5465E-09  0.2650E-07  0.9393E-10  0.0000E+00
 0001511  0.2633E-07  0.5423E-09  0.2635E-07  0.9340E-10  0.0000E+00
 0001512  0.2618E-07  0.5381E-09  0.2620E-07  0.9287E-10  0.0000E+00
 0001513  0.2603E-07  0.5339E-09  0.2605E-07  0.9234E-10  0.0000E+00
 0001514  0.2589E-07  0.5298E-09  0.2590E-07  0.9182E-10  0.0000E+00
 0001515  0.2574E-07  0.5257E-09  0.2575E-07  0.9130E-10  0.0000E+00
 0001516  0.2559E-07  0.5216E-09  0.2561E-07  0.9078E-10  0.0000E+00
 0001517  0.2545E-07  0.5176E-09  0.2546E-07  0.9026E-10  0.0000E+00
 0001518  0.2530E-07  0.5136E-09  0.2532E-07  0.8975E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 320
 0001519  0.2516E-07  0.5097E-09  0.2518E-07  0.8924E-10  0.0000E+00
 0001520  0.2502E-07  0.5058E-09  0.2503E-07  0.8874E-10  0.0000E+00
 0001521  0.2488E-07  0.5019E-09  0.2489E-07  0.8823E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 341
 0001522  0.2474E-07  0.4980E-09  0.2475E-07  0.8773E-10  0.0000E+00
 0001523  0.2460E-07  0.4942E-09  0.2461E-07  0.8724E-10  0.0000E+00
 0001524  0.2446E-07  0.4905E-09  0.2447E-07  0.8674E-10  0.0000E+00
 0001525  0.2432E-07  0.4867E-09  0.2433E-07  0.8625E-10  0.0000E+00
 0001526  0.2418E-07  0.4830E-09  0.2420E-07  0.8576E-10  0.0000E+00
 0001527  0.2404E-07  0.4793E-09  0.2406E-07  0.8528E-10  0.0000E+00
 0001528  0.2391E-07  0.4757E-09  0.2392E-07  0.8479E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 342
 0001529  0.2377E-07  0.4721E-09  0.2379E-07  0.8431E-10  0.0000E+00
 0001530  0.2364E-07  0.4685E-09  0.2365E-07  0.8383E-10  0.0000E+00
 0001531  0.2350E-07  0.4649E-09  0.2352E-07  0.8336E-10  0.0000E+00
 0001532  0.2337E-07  0.4614E-09  0.2338E-07  0.8289E-10  0.0000E+00
 0001533  0.2324E-07  0.4579E-09  0.2325E-07  0.8242E-10  0.0000E+00
 0001534  0.2311E-07  0.4545E-09  0.2312E-07  0.8195E-10  0.0000E+00
 0001535  0.2298E-07  0.4510E-09  0.2299E-07  0.8148E-10  0.0000E+00
 0001536  0.2285E-07  0.4476E-09  0.2286E-07  0.8102E-10  0.0000E+00
 0001537  0.2272E-07  0.4443E-09  0.2273E-07  0.8056E-10  0.0000E+00
 0001538  0.2259E-07  0.4409E-09  0.2260E-07  0.8011E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 343
 0001539  0.2246E-07  0.4376E-09  0.2247E-07  0.7965E-10  0.0000E+00
 0001540  0.2233E-07  0.4343E-09  0.2235E-07  0.7920E-10  0.0000E+00
 0001541  0.2221E-07  0.4311E-09  0.2222E-07  0.7875E-10  0.0000E+00
 0001542  0.2208E-07  0.4279E-09  0.2209E-07  0.7831E-10  0.0000E+00
 0001543  0.2196E-07  0.4247E-09  0.2197E-07  0.7786E-10  0.0000E+00
 0001544  0.2183E-07  0.4215E-09  0.2184E-07  0.7742E-10  0.0000E+00
 0001545  0.2171E-07  0.4183E-09  0.2172E-07  0.7698E-10  0.0000E+00
 0001546  0.2159E-07  0.4152E-09  0.2160E-07  0.7655E-10  0.0000E+00
 0001547  0.2146E-07  0.4121E-09  0.2148E-07  0.7611E-10  0.0000E+00
 0001548  0.2134E-07  0.4091E-09  0.2135E-07  0.7568E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 344
 0001549  0.2122E-07  0.4060E-09  0.2123E-07  0.7525E-10  0.0000E+00
 0001550  0.2110E-07  0.4030E-09  0.2111E-07  0.7482E-10  0.0000E+00
 0001551  0.2098E-07  0.4000E-09  0.2099E-07  0.7440E-10  0.0000E+00
 0001552  0.2086E-07  0.3971E-09  0.2087E-07  0.7398E-10  0.0000E+00
 0001553  0.2075E-07  0.3941E-09  0.2076E-07  0.7356E-10  0.0000E+00
 0001554  0.2063E-07  0.3912E-09  0.2064E-07  0.7314E-10  0.0000E+00
 0001555  0.2051E-07  0.3884E-09  0.2052E-07  0.7273E-10  0.0000E+00
 0001556  0.2039E-07  0.3855E-09  0.2041E-07  0.7232E-10  0.0000E+00
 0001557  0.2028E-07  0.3827E-09  0.2029E-07  0.7191E-10  0.0000E+00
 0001558  0.2016E-07  0.3798E-09  0.2018E-07  0.7150E-10  0.0000E+00
 0001559  0.2005E-07  0.3771E-09  0.2006E-07  0.7109E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 333
 0001560  0.1994E-07  0.3743E-09  0.1995E-07  0.7069E-10  0.0000E+00
 0001561  0.1982E-07  0.3716E-09  0.1983E-07  0.7029E-10  0.0000E+00
 0001562  0.1971E-07  0.3688E-09  0.1972E-07  0.6989E-10  0.0000E+00
 0001563  0.1960E-07  0.3661E-09  0.1961E-07  0.6950E-10  0.0000E+00
 0001564  0.1949E-07  0.3635E-09  0.1950E-07  0.6910E-10  0.0000E+00
 0001565  0.1938E-07  0.3608E-09  0.1939E-07  0.6871E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 334
 0001566  0.1927E-07  0.3582E-09  0.1928E-07  0.6832E-10  0.0000E+00
 0001567  0.1916E-07  0.3556E-09  0.1917E-07  0.6793E-10  0.0000E+00
 0001568  0.1905E-07  0.3530E-09  0.1906E-07  0.6755E-10  0.0000E+00
 0001569  0.1894E-07  0.3504E-09  0.1895E-07  0.6717E-10  0.0000E+00
 0001570  0.1884E-07  0.3479E-09  0.1885E-07  0.6679E-10  0.0000E+00
 0001571  0.1873E-07  0.3454E-09  0.1874E-07  0.6641E-10  0.0000E+00
 0001572  0.1862E-07  0.3429E-09  0.1863E-07  0.6603E-10  0.0000E+00
 0001573  0.1852E-07  0.3404E-09  0.1853E-07  0.6566E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 611
 0001574  0.1841E-07  0.3380E-09  0.1842E-07  0.6529E-10  0.0000E+00
 0001575  0.1831E-07  0.3355E-09  0.1832E-07  0.6492E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 332
 0001576  0.1821E-07  0.3331E-09  0.1822E-07  0.6455E-10  0.0000E+00
 0001577  0.1810E-07  0.3307E-09  0.1811E-07  0.6418E-10  0.0000E+00
 0001578  0.1800E-07  0.3283E-09  0.1801E-07  0.6382E-10  0.0000E+00
 0001579  0.1790E-07  0.3260E-09  0.1791E-07  0.6346E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 345
 0001580  0.1780E-07  0.3237E-09  0.1781E-07  0.6310E-10  0.0000E+00
 0001581  0.1770E-07  0.3213E-09  0.1771E-07  0.6274E-10  0.0000E+00
 0001582  0.1760E-07  0.3190E-09  0.1761E-07  0.6239E-10  0.0000E+00
 0001583  0.1750E-07  0.3168E-09  0.1751E-07  0.6203E-10  0.0000E+00
 0001584  0.1740E-07  0.3145E-09  0.1741E-07  0.6168E-10  0.0000E+00
 0001585  0.1730E-07  0.3123E-09  0.1731E-07  0.6133E-10  0.0000E+00
 0001586  0.1720E-07  0.3100E-09  0.1721E-07  0.6098E-10  0.0000E+00
 0001587  0.1710E-07  0.3078E-09  0.1711E-07  0.6064E-10  0.0000E+00
 0001588  0.1701E-07  0.3056E-09  0.1702E-07  0.6030E-10  0.0000E+00
 0001589  0.1691E-07  0.3035E-09  0.1692E-07  0.5995E-10  0.0000E+00
 0001590  0.1682E-07  0.3013E-09  0.1682E-07  0.5961E-10  0.0000E+00
 0001591  0.1672E-07  0.2992E-09  0.1673E-07  0.5928E-10  0.0000E+00
 0001592  0.1663E-07  0.2971E-09  0.1663E-07  0.5894E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 346
 0001593  0.1653E-07  0.2950E-09  0.1654E-07  0.5861E-10  0.0000E+00
 0001594  0.1644E-07  0.2929E-09  0.1645E-07  0.5827E-10  0.0000E+00
 0001595  0.1635E-07  0.2908E-09  0.1635E-07  0.5794E-10  0.0000E+00
 0001596  0.1625E-07  0.2888E-09  0.1626E-07  0.5762E-10  0.0000E+00
 0001597  0.1616E-07  0.2868E-09  0.1617E-07  0.5729E-10  0.0000E+00
 0001598  0.1607E-07  0.2847E-09  0.1608E-07  0.5697E-10  0.0000E+00
 0001599  0.1598E-07  0.2828E-09  0.1599E-07  0.5664E-10  0.0000E+00
 0001600  0.1589E-07  0.2808E-09  0.1590E-07  0.5632E-10  0.0000E+00
 0001601  0.1580E-07  0.2788E-09  0.1581E-07  0.5600E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 350
 0001602  0.1571E-07  0.2769E-09  0.1572E-07  0.5569E-10  0.0000E+00
 0001603  0.1562E-07  0.2749E-09  0.1563E-07  0.5537E-10  0.0000E+00
 0001604  0.1553E-07  0.2730E-09  0.1554E-07  0.5506E-10  0.0000E+00
 0001605  0.1544E-07  0.2711E-09  0.1545E-07  0.5475E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_ITS iterations 10000
 0001606  0.1536E-07  0.2692E-09  0.1536E-07  0.5444E-10  0.0000E+00
 0001607  0.1527E-07  0.2673E-09  0.1528E-07  0.5413E-10  0.0000E+00
 0001608  0.1518E-07  0.2655E-09  0.1519E-07  0.5382E-10  0.0000E+00
 0001609  0.1510E-07  0.2636E-09  0.1510E-07  0.5352E-10  0.0000E+00
 0001610  0.1501E-07  0.2618E-09  0.1502E-07  0.5321E-10  0.0000E+00
 0001611  0.1493E-07  0.2600E-09  0.1493E-07  0.5291E-10  0.0000E+00
 0001612  0.1484E-07  0.2582E-09  0.1485E-07  0.5261E-10  0.0000E+00
 0001613  0.1476E-07  0.2564E-09  0.1476E-07  0.5231E-10  0.0000E+00
 0001614  0.1468E-07  0.2546E-09  0.1468E-07  0.5202E-10  0.0000E+00
 0001615  0.1459E-07  0.2529E-09  0.1460E-07  0.5172E-10  0.0000E+00
 0001616  0.1451E-07  0.2512E-09  0.1452E-07  0.5143E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 337
 0001617  0.1443E-07  0.2494E-09  0.1443E-07  0.5114E-10  0.0000E+00
 0001618  0.1435E-07  0.2477E-09  0.1435E-07  0.5085E-10  0.0000E+00
 0001619  0.1426E-07  0.2460E-09  0.1427E-07  0.5056E-10  0.0000E+00
 0001620  0.1418E-07  0.2443E-09  0.1419E-07  0.5028E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 348
 0001621  0.1410E-07  0.2426E-09  0.1411E-07  0.4999E-10  0.0000E+00
 0001622  0.1402E-07  0.2410E-09  0.1403E-07  0.4971E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 371
 0001623  0.1394E-07  0.2393E-09  0.1395E-07  0.4943E-10  0.0000E+00
 0001624  0.1387E-07  0.2377E-09  0.1387E-07  0.4915E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 331
 0001625  0.1379E-07  0.2361E-09  0.1379E-07  0.4887E-10  0.0000E+00
 0001626  0.1371E-07  0.2345E-09  0.1371E-07  0.4859E-10  0.0000E+00
 0001627  0.1363E-07  0.2329E-09  0.1364E-07  0.4832E-10  0.0000E+00
 0001628  0.1355E-07  0.2313E-09  0.1356E-07  0.4804E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 420
 0001629  0.1348E-07  0.2297E-09  0.1348E-07  0.4777E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 709
 0001630  0.1340E-07  0.2282E-09  0.1341E-07  0.4750E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 375
 0001631  0.1333E-07  0.2266E-09  0.1333E-07  0.4723E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 330
 0001632  0.1325E-07  0.2251E-09  0.1326E-07  0.4696E-10  0.0000E+00
 0001633  0.1318E-07  0.2236E-09  0.1318E-07  0.4670E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 394
 0001634  0.1310E-07  0.2220E-09  0.1311E-07  0.4643E-10  0.0000E+00
 0001635  0.1303E-07  0.2205E-09  0.1303E-07  0.4617E-10  0.0000E+00
 0001636  0.1295E-07  0.2191E-09  0.1296E-07  0.4591E-10  0.0000E+00
 0001637  0.1288E-07  0.2176E-09  0.1288E-07  0.4565E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 975
 0001638  0.1281E-07  0.2161E-09  0.1281E-07  0.4539E-10  0.0000E+00
 0001639  0.1273E-07  0.2147E-09  0.1274E-07  0.4513E-10  0.0000E+00
 0001640  0.1266E-07  0.2132E-09  0.1267E-07  0.4488E-10  0.0000E+00
 0001641  0.1259E-07  0.2118E-09  0.1260E-07  0.4462E-10  0.0000E+00
 0001642  0.1252E-07  0.2104E-09  0.1252E-07  0.4437E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 559
 0001643  0.1245E-07  0.2090E-09  0.1245E-07  0.4412E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 395
 0001644  0.1238E-07  0.2076E-09  0.1238E-07  0.4387E-10  0.0000E+00
 0001645  0.1231E-07  0.2062E-09  0.1231E-07  0.4362E-10  0.0000E+00
 0001646  0.1224E-07  0.2048E-09  0.1224E-07  0.4338E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 347
 0001647  0.1217E-07  0.2034E-09  0.1217E-07  0.4313E-10  0.0000E+00
 0001648  0.1210E-07  0.2021E-09  0.1210E-07  0.4289E-10  0.0000E+00
 0001649  0.1203E-07  0.2007E-09  0.1204E-07  0.4264E-10  0.0000E+00
 0001650  0.1196E-07  0.1994E-09  0.1197E-07  0.4240E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 355
 0001651  0.1190E-07  0.1981E-09  0.1190E-07  0.4216E-10  0.0000E+00
 0001652  0.1183E-07  0.1968E-09  0.1183E-07  0.4192E-10  0.0000E+00
 0001653  0.1176E-07  0.1954E-09  0.1177E-07  0.4169E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 421
 0001654  0.1170E-07  0.1941E-09  0.1170E-07  0.4145E-10  0.0000E+00
 0001655  0.1163E-07  0.1929E-09  0.1163E-07  0.4121E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 556
 0001656  0.1156E-07  0.1916E-09  0.1157E-07  0.4098E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 349
 0001657  0.1150E-07  0.1903E-09  0.1150E-07  0.4075E-10  0.0000E+00
 0001658  0.1143E-07  0.1891E-09  0.1144E-07  0.4052E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 370
 0001659  0.1137E-07  0.1878E-09  0.1137E-07  0.4029E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 398
 0001660  0.1130E-07  0.1866E-09  0.1131E-07  0.4006E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 531
 0001661  0.1124E-07  0.1853E-09  0.1124E-07  0.3983E-10  0.0000E+00
 0001662  0.1118E-07  0.1841E-09  0.1118E-07  0.3961E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 351
 0001663  0.1111E-07  0.1829E-09  0.1112E-07  0.3938E-10  0.0000E+00
 0001664  0.1105E-07  0.1817E-09  0.1105E-07  0.3916E-10  0.0000E+00
 0001665  0.1099E-07  0.1805E-09  0.1099E-07  0.3894E-10  0.0000E+00
 0001666  0.1093E-07  0.1793E-09  0.1093E-07  0.3872E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 382
 0001667  0.1086E-07  0.1782E-09  0.1087E-07  0.3850E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 336
 0001668  0.1080E-07  0.1770E-09  0.1081E-07  0.3828E-10  0.0000E+00
 0001669  0.1074E-07  0.1758E-09  0.1074E-07  0.3807E-10  0.0000E+00
 0001670  0.1068E-07  0.1747E-09  0.1068E-07  0.3785E-10  0.0000E+00
 0001671  0.1062E-07  0.1736E-09  0.1062E-07  0.3764E-10  0.0000E+00
 0001672  0.1056E-07  0.1724E-09  0.1056E-07  0.3742E-10  0.0000E+00
 0001673  0.1050E-07  0.1713E-09  0.1050E-07  0.3721E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 328
 0001674  0.1044E-07  0.1702E-09  0.1044E-07  0.3700E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 367
 0001675  0.1038E-07  0.1691E-09  0.1039E-07  0.3679E-10  0.0000E+00
 0001676  0.1032E-07  0.1680E-09  0.1033E-07  0.3658E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 539
 0001677  0.1026E-07  0.1669E-09  0.1027E-07  0.3638E-10  0.0000E+00
 0001678  0.1021E-07  0.1658E-09  0.1021E-07  0.3617E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 343
 0001679  0.1015E-07  0.1647E-09  0.1015E-07  0.3597E-10  0.0000E+00
 0001680  0.1009E-07  0.1637E-09  0.1009E-07  0.3576E-10  0.0000E+00
Linear solve did not converge due to DIVERGED_INDEFINITE_PC iterations 487
 0001681  0.1003E-07  0.1626E-09  0.1004E-07  0.3556E-10  0.0000E+00
Linear solve converged due to CONVERGED_RTOL iterations 376
 0001682  0.9978E-08  0.1616E-09  0.9981E-08  0.3536E-10  0.0000E+00
TIME FOR CALCULATION:  0.3764E+05
 L2-NORM ERROR U    VELOCITY  1.073682047939190E-005
 L2-NORM ERROR V    VELOCITY  1.133485976464090E-005
 L2-NORM ERROR W    VELOCITY  1.095441215075716E-005
 L2-NORM ERROR ABS. VELOCITY  1.412181697151783E-005
 L2-NORM ERROR      PRESSURE  1.307959793303857E-003
      *** CALCULATION FINISHED - SEE RESULTS ***
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./caffa3d.MB.lnx on a arch-openmpi-opt-intel-hlr-ext named hpb0093 with 1 processor, by gu08vomo Wed Feb 11 10:36:22 2015
Using Petsc Release Version 3.5.3, Jan, 31, 2015
                         Max       Max/Min        Avg      Total
Time (sec):           3.767e+04      1.00000   3.767e+04
Objects:              2.365e+04      1.00000   2.365e+04
Flops:                4.492e+13      1.00000   4.492e+13  4.492e+13
Flops/sec:            1.192e+09      1.00000   1.192e+09  1.192e+09
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 4.5374e+03  12.0%  6.5910e+06   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 1:        MOMENTUM: 1.6045e+03   4.3%  1.5283e+12   3.4%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 2:        PRESCORR: 3.1529e+04  83.7%  4.3392e+13  96.6%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
ThreadCommRunKer    8411 1.0 5.5954e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNorm                1 1.0 2.2788e-01 1.0 4.39e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 67  0  0  0    19
VecScale               1 1.0 1.8089e-03 1.0 2.20e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 33  0  0  0  1215
VecSet             67286 1.0 6.2042e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecScatterBegin    75701 1.0 2.0827e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize           1 1.0 1.8089e-03 1.0 2.20e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 33  0  0  0  1215
MatAssemblyBegin    3364 1.0 9.1219e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd      3364 1.0 6.2114e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
--- Event Stage 1: MOMENTUM
VecDot             10092 1.0 1.8554e+01 1.0 4.43e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  3  0  0  0  2390
VecDotNorm2         5046 1.0 1.2589e+01 1.0 4.43e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  3  0  0  0  3522
VecNorm            20184 1.0 2.3761e+01 1.0 8.87e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  6  0  0  0  3733
VecCopy            15138 1.0 3.2298e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
VecSet             10092 1.0 9.2871e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecAXPY            10092 1.0 2.5340e+01 1.0 4.43e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  3  0  0  0  1750
VecAXPBYCZ         10092 1.0 3.6799e+01 1.0 8.87e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  6  0  0  0  2410
VecWAXPY           10092 1.0 3.6827e+01 1.0 4.43e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  3  0  0  0  1204
MatMult            20184 1.0 3.5849e+02 1.0 5.48e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0  22 36  0  0  0  1530
MatSolve           20184 1.0 5.7618e+02 1.0 5.48e+11 1.0 0.0e+00 0.0e+00 0.0e+00  2  1  0  0  0  36 36  0  0  0   952
MatLUFactorNum      1682 1.0 1.7723e+02 1.0 7.69e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0  11  5  0  0  0   434
MatILUFactorSym     1682 1.0 1.4229e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   9  0  0  0  0     0
MatGetRowIJ         1682 1.0 3.4428e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering      1682 1.0 1.5008e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
KSPSetUp            5046 1.0 3.8792e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve            5046 1.0 1.3773e+03 1.0 1.35e+12 1.0 0.0e+00 0.0e+00 0.0e+00  4  3  0  0  0  86 88  0  0  0   978
PCSetUp             1682 1.0 3.3669e+02 1.0 7.69e+10 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0  21  5  0  0  0   228
PCApply            20184 1.0 5.7620e+02 1.0 5.48e+11 1.0 0.0e+00 0.0e+00 0.0e+00  2  1  0  0  0  36 36  0  0  0   952
--- Event Stage 2: PRESCORR
VecMDot           484380 1.0 1.0689e+03 1.0 2.13e+12 1.0 0.0e+00 0.0e+00 0.0e+00  3  5  0  0  0   3  5  0  0  0  1991
VecTDot           965431 1.0 1.9167e+03 1.0 4.24e+12 1.0 0.0e+00 0.0e+00 0.0e+00  5  9  0  0  0   6 10  0  0  0  2213
VecNorm           486062 1.0 6.4723e+02 1.0 2.14e+12 1.0 0.0e+00 0.0e+00 0.0e+00  2  5  0  0  0   2  5  0  0  0  3300
VecCopy             5046 1.0 1.0416e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet              1682 1.0 1.5487e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY           967078 1.0 2.5711e+03 1.0 4.25e+12 1.0 0.0e+00 0.0e+00 0.0e+00  7  9  0  0  0   8 10  0  0  0  1653
VecAYPX           481016 1.0 1.2653e+03 1.0 2.11e+12 1.0 0.0e+00 0.0e+00 0.0e+00  3  5  0  0  0   4  5  0  0  0  1670
VecMAXPY          484380 1.0 1.2692e+03 1.0 2.13e+12 1.0 0.0e+00 0.0e+00 0.0e+00  3  5  0  0  0   4  5  0  0  0  1677
MatMult           484380 1.0 8.6068e+03 1.0 1.32e+13 1.0 0.0e+00 0.0e+00 0.0e+00 23 29  0  0  0  27 30  0  0  0  1529
MatSolve          484380 1.0 1.3831e+04 1.0 1.32e+13 1.0 0.0e+00 0.0e+00 0.0e+00 37 29  0  0  0  44 30  0  0  0   951
MatLUFactorNum      1682 1.0 1.7705e+02 1.0 7.69e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0   434
MatILUFactorSym     1682 1.0 1.4204e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ         1682 1.0 3.3236e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering      1682 1.0 1.4995e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatView                2 1.0 1.4806e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSetUp            1682 1.0 1.9146e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve            1682 1.0 3.1490e+04 1.0 4.33e+13 1.0 0.0e+00 0.0e+00 0.0e+00 84 96  0  0  0 100100  0  0  0  1376
PCSetUp             1682 1.0 3.3613e+02 1.0 7.69e+10 1.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0   229
PCApply           484380 1.0 1.3832e+04 1.0 1.32e+13 1.0 0.0e+00 0.0e+00 0.0e+00 37 29  0  0  0  44 30  0  0  0   951
--- Event Stage 3: Unknown
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector    67             78    791040816     0
      Vector Scatter     2              2         1304     0
           Index Set     4             10     35159920     0
   IS L to G Mapping     2              2     17577192     0
              Matrix     1              3    634001996     0
   Matrix Null Space     0              1          620     0
       Krylov Solver     0              2         2408     0
      Preconditioner     0              2         2032     0
              Vector 10108          10092  88704078048     0
           Index Set  5046           5043  29549250056     0
              Matrix  1682           1681  355252454000     0
   Matrix Null Space     1              0            0     0
       Krylov Solver     2              0            0     0
      Preconditioner     2              0            0     0
              Vector     6              0            0     0
              Viewer     1              0            0     0
Average time to get PetscTime(): 0
#PETSc Option Table entries:
-log_summary
-options_left
-pressure_ksp_converged_reason
-ressure_pc_type icc
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: PETSC_ARCH=arch-openmpi-opt-intel-hlr-ext PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3 -prefix=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr-ext --with-blas-lapack-dir=/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64/ --with-mpi-dir=/shared/apps/openmpi/1.8.2_intel COPTFLAGS="-O3 -xHost" FOPTFLAGS="-O3 -xHost" CXXOPTFLAGS="-O3 -xHost" --with-debugging=0 --download-hypre --download-ml
Libraries compiled on Sun Feb  1 16:09:22 2015 on hla0003
Machine characteristics: Linux-3.0.101-0.40-default-x86_64-with-SuSE-11-x86_64
Using PETSc directory: /home/gu08vomo/soft/petsc/3.5.3
Using PETSc arch: arch-openmpi-opt-intel-hlr-ext
Using C compiler: /shared/apps/openmpi/1.8.2_intel/bin/mpicc  -fPIC -wd1572 -O3 -xHost  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /shared/apps/openmpi/1.8.2_intel/bin/mpif90  -fPIC -O3 -xHost   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/include -I/home/gu08vomo/soft/petsc/3.5.3/include -I/home/gu08vomo/soft/petsc/3.5.3/include -I/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/include -I/shared/apps/openmpi/1.8.2_intel/include
Using C linker: /shared/apps/openmpi/1.8.2_intel/bin/mpicc
Using Fortran linker: /shared/apps/openmpi/1.8.2_intel/bin/mpif90
Using libraries: -Wl,-rpath,/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -L/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -lpetsc -Wl,-rpath,/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -L/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -lHYPRE -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -lmpi_cxx -lml -lmpi_cxx -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -lX11 -lpthread -lssl -lcrypto -lmpi_usempi_ignore_tkr -lmpi_mpifh -lifport -lifcore -lm -lmpi_cxx -ldl -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -lmpi -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -limf -lsvml -lirng -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc_s -lirc -lpthread -lirc_s -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -ldl
-log_summary
-options_left
There is one unused database option. It is:
Option left: name:-ressure_pc_type value: icc
