[petsc-users] MatMPIAIJSetPreallocation question
Gideon Simpson gideon.simpson at gmail.com
Mon Feb 16 09:29:40 CST 2015
Got it.  I had a coding error.
-gideon
> On Feb 15, 2015, at 10:34 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Feb 15, 2015, at 9:17 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>> Got it, one follow up question:
>> When calling MatMPIAIJSetPreallocation, is there a reason why the number of nonzero entries in the off-diagonal sub matrix cannot be zero?
> It could be zero; that means there is not coupling between processes however so essentially each process has its own independent problem; thus normally it is most definitely not zero.
>  Barry
>> -gideon
>>> On Feb 15, 2015, at 9:31 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> On Feb 15, 2015, at 8:22 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
>>>> I’m trying to get a handle on the different ways of constructing matrices.  Currently, I have:
>>>> MatCreate(...)
>>>> MatSetSizes(...)
>>>> MatSetFromOptions(...)
>>>> MatSetUp(…)
>>>> but I gather from reading the manual that, by not preallocating, I’m losing out in performance.  If I assume that my matrix will either by SeqAIJ or MPIAIJ, depending on the number of processors available, how would I go about doing this.  I see some of the example codes with:
>>>> MatSeqAIJSetPreallocation(…)
>>>> MatMPIAIJSetPreallocation(…)
>>>> as successive commands.  Should I interpret this as saying that PETSc will just ignore the one that is not the active one in the current instance?
>>> Exactly*.
>>> You can also use MatXAIJSetPreallocation() which sets the possible preallocation forms for all the matrix types without requiring you to set one each individuallly.
>>> Barry
>>> * We support this in many places because we hate requiring users to put a bunch of if (type == xxx) kind of code in their applications. For example KSPGMRESSetRestart() is ignored if the KSP type is not GMRES.
>>>> -gideon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150216/899e47f2/attachment.html>
