[petsc-users] MatMPIAIJSetPreallocation question
Barry Smith
bsmith at mcs.anl.gov
Sun Feb 15 20:31:36 CST 2015
> On Feb 15, 2015, at 8:22 PM, Gideon Simpson <gideon.simpson at gmail.com> wrote:
> I’m trying to get a handle on the different ways of constructing matrices. Currently, I have:
> MatCreate(...)
> MatSetSizes(...)
> MatSetFromOptions(...)
> MatSetUp(…)
> but I gather from reading the manual that, by not preallocating, I’m losing out in performance. If I assume that my matrix will either by SeqAIJ or MPIAIJ, depending on the number of processors available, how would I go about doing this. I see some of the example codes with:
> MatSeqAIJSetPreallocation(…)
> MatMPIAIJSetPreallocation(…)
> as successive commands. Should I interpret this as saying that PETSc will just ignore the one that is not the active one in the current instance?
Exactly*.
You can also use MatXAIJSetPreallocation() which sets the possible preallocation forms for all the matrix types without requiring you to set one each individuallly.
Barry
* We support this in many places because we hate requiring users to put a bunch of if (type == xxx) kind of code in their applications. For example KSPGMRESSetRestart() is ignored if the KSP type is not GMRES.
> -gideon
