[petsc-users] Hang while attempting to run EPSSolve()
Barry Smith
bsmith at mcs.anl.gov
Fri Feb 13 15:21:49 CST 2015
Andrew,
This is a bug in the 1.8.2 OpenMPI implementation they recently introduced. Can you link against an earlier OpenMPI implementation on the machine? Or do they have MPICH installed you could use?
Barry
> On Feb 13, 2015, at 3:17 PM, Andrew Spott <andrew at spott.us> wrote:
> Local tests on OS X can’t reproduce, but production tests on our local supercomputer always hang while waiting for a lock.
> The back trace:
> #0 0x00002ba2980df054 in __lll_lock_wait () from /lib64/libpthread.so.0
> #1 0x00002ba2980da388 in _L_lock_854 () from /lib64/libpthread.so.0
> #2 0x00002ba2980da257 in pthread_mutex_lock () from /lib64/libpthread.so.0
> #3 0x00002ba29a1d9e2c in ompi_attr_get_c () from /curc/tools/x_86_64/rh6/openmpi/1.8.2/gcc/4.9.1/lib/libmpi.so.1
> #4 0x00002ba29a207f8e in PMPI_Attr_get () from /curc/tools/x_86_64/rh6/openmpi/1.8.2/gcc/4.9.1/lib/libmpi.so.1
> #5 0x00002ba294aa111e in Petsc_DelComm_Outer () at /home/ansp6066/local/src/petsc-3.5.3/src/sys/objects/pinit.c:409
> #6 0x00002ba29a1dae02 in ompi_attr_delete_all () from /curc/tools/x_86_64/rh6/openmpi/1.8.2/gcc/4.9.1/lib/libmpi.so.1
> #7 0x00002ba29a1dcb6c in ompi_comm_free () from /curc/tools/x_86_64/rh6/openmpi/1.8.2/gcc/4.9.1/lib/libmpi.so.1
> #8 0x00002ba29a20c713 in PMPI_Comm_free () from /curc/tools/x_86_64/rh6/openmpi/1.8.2/gcc/4.9.1/lib/libmpi.so.1
> #9 0x00002ba294aba7cf in PetscSubcommCreate_contiguous(_n_PetscSubcomm*) () from /home/ansp6066/local/petsc-3.5.3-debug/lib/libpetsc.so.3.5
> #10 0x00002ba294ab89d5 in PetscSubcommSetType () from /home/ansp6066/local/petsc-3.5.3-debug/lib/libpetsc.so.3.5
> #11 0x00002ba2958ce437 in PCSetUp_Redundant(_p_PC*) () from /home/ansp6066/local/petsc-3.5.3-debug/lib/libpetsc.so.3.5
> #12 0x00002ba2957a243d in PCSetUp () at /home/ansp6066/local/src/petsc-3.5.3/src/ksp/pc/interface/precon.c:902
> #13 0x00002ba2958dea31 in KSPSetUp () at /home/ansp6066/local/src/petsc-3.5.3/src/ksp/ksp/interface/itfunc.c:306
> #14 0x00002ba29a7f8e70 in STSetUp_Sinvert(_p_ST*) () at /home/ansp6066/local/src/slepc-3.5.3/src/sys/classes/st/impls/sinvert/sinvert.c:145
> #15 0x00002ba29a7e92cf in STSetUp () at /home/ansp6066/local/src/slepc-3.5.3/src/sys/classes/st/interface/stsolve.c:301
> #16 0x00002ba29a845ea6 in EPSSetUp () at /home/ansp6066/local/src/slepc-3.5.3/src/eps/interface/epssetup.c:207
> #17 0x00002ba29a849f91 in EPSSolve () at /home/ansp6066/local/src/slepc-3.5.3/src/eps/interface/epssolve.c:88
> #18 0x0000000000410de5 in petsc::EigenvalueSolver::solve() () at /home/ansp6066/code/petsc_cpp_wrapper/src/petsc_cpp/EigenvalueSolver.cpp:40
> #19 0x00000000004065c7 in main () at /home/ansp6066/code/new_work_project/src/main.cpp:165
> This happens for MPI or single process runs. Does anyone have any hints on how I can debug this? I honestly have no idea.
> -Andrew
