[petsc-users] Setting step acceptance criteria and/or domain validity using TS module
    Pierre Barbier de Reuille
    pierre.barbierdereuille at gmail.com
    Thu Feb 12 08:37:47 CST 2015
Hello,
so here is a patch against the MASTER branch to add time and current
solution vector to the TSAdaptCheckStage. What I did is add the same
arguments as for the TSPostStage call.
I hope I haven't made any mistake.
In addition, if the stage is rejected, PETSc only tried again, changing
nothing, and therefore failing in the exact same way. So I also added a
reduction of the time step if the stage is rejected by the user.
Note: I tested the code with the RungeKutta solver only for now.
Cheers,
Pierre
On Thu Feb 12 2015 at 03:45:13 Jed Brown <jed at jedbrown.org> wrote:
> Pierre Barbier de Reuille <pierre.barbierdereuille at gmail.com> writes:
> > Ok, I made progress. But:
> >  1 - whatever I do, I have very slightly negative values, and therefore
> all
> > my steps get rejected (values like 1e-16)
> >  2 - As I expected, SNES is only used with implicit methods. So if I use
> > explicit Runge-Kutta, then there is no solution vector stored by the SNES
> > object.
> > Reading the code for the Runge-Kutta solver, it seems that TSPostStage is
> > where I can retrieve the current state, and TSAdaptCheckStage where I can
> > reject it. But is this something I can rely on?
> TSPostStage is only called *after* the stage has been accepted (the step
> might be rejected later, e.g., based on a local error controller).
> We should pass the stage solution to TSAdaptCheckStage so you can check
> it there.  I can add this, but I'm at a conference in Singapore this
> week and have a couple more pressing things, so you'd have to wait until
> next week unless someone else can do it (or you'd like to submit a
> patch).
> We should also add TSSetSetFunctionDomainError() so you can check it
> there (my preference, actually).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150212/81d2463c/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150212/81d2463c/attachment.bin>
