[petsc-users] SGI compiler (mpt-2.11) and fortran interface
    Matteo Parsani
    parsani.matteo at gmail.com
    Wed Feb 11 15:53:36 CST 2015
I have included petscvec.h90 (the code was indeed working with openmpi)
I can run all the examples you suggested.
Thanks for your help!
On Wed, Feb 11, 2015 at 2:31 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> I suspect its one of the following:
> - missing including petscvec.h90 [i.e missing prototype for
> VecGetArrayF90().
> - perhaps building PETSc with fortran-compiler-a -but attempt to use with
> fortran-compiler-b.
> - unknown fortran compile that does crazy things with f90 pointers..
> It would be best to reproduce the problem with a PETSc example -
> perhaps one from the list below
> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Vec/VecGetArrayF90.html
> BTW: looks like SGI mpt refers to MPI from SGI? - but then - you can
> use either intel or gnu compilers with it.
> http://www.nas.nasa.gov/hecc/support/kb/SGI-MPT_89.html
> [and VecGetArrayF90 should work with both these compiler sets..]
> Satish
> On Wed, 11 Feb 2015, Barry Smith wrote:
> >   Oh, yes, sorry I should have read more clearly.  Then I am not sure
> what the issue could be.
> >   Barry
> > > On Feb 11, 2015, at 1:16 PM, Matteo Parsani <parsani.matteo at gmail.com>
> wrote:
> > > Hello,
> > > I am already using VecGetArrayF90().
> > > I am waiting now for the IT help because the issue is only with the
> SGI compiler on our cluster. Once everything is set up I will try to run
> the fortran examples in PETSc and then I will let you know if the example
> work.
> > > On Wed, Feb 11, 2015 at 2:12 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> > > > On Feb 11, 2015, at 11:32 AM, Matteo Parsani <
> parsani.matteo at gmail.com> wrote:
> > > > Dear Petsc Users and Developers,
> > > > Recently, I have compiled my fortran code using the SGI compiler
> (mpt-2.11). Previously I was using openmpi 1.7.3 and everything worked fine.
> > >   Almost for sure your code is now being compiled to check for out of
> bounds  in array access. You need to turn that off if you use VecGetArray()
> you need to check the documentation for your compiler to find the flag to
> turn it off.
> > >   Or you can switch to using VecGetArrayF90() which will also simplify
> your code slightly and is the post-f77 way of accessing arrays from PETSc
> vectors.
> > >   Barry
> > > > Now, with when I run the code compiled with SGI I get the following
> error:
> > > > At line 1921 of file mpi_module.F90
> > > > Fortran runtime error: Array reference out of bounds for array
> 'xx_v', upper bound of dimension 1 exceeded (349921 > 1)
> > > > Precisely the line that gives troubles is the following
> > > > x_ghost(i_dir,i_loc) = xx_v(n_tot+3*(i_loc-1) + i_dir)
> > > > The variables xx_v is a fortran pointer which I get using
> > > > call VecGetArrayF90(x_local, xx_v, i_er)
> > > > where i_err is defined as
> > > > PetscErrorCode i_err
> > > > Do you have any idea what I am doing wrong?
> > > > Thank you!
> > > > Matteo
> > > Matteo
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150211/8608814f/attachment.html>
