[petsc-users] Domain Decomposition Method for Parallel FEM Code
    Hanglin Ye
    hanglinye at gmail.com
    Wed Feb 11 14:07:01 CST 2015
Thank you again for the reply. I am trying to run ex62. But there is an
error :  "Mesh generation needs external package support. Please
reconfigure with --download-triangle." I then configure again with
--download triangle, and it is download and installed. But this error keeps
showing up. Could you please let me know if I am missing anything?
Thank you.
On Wed, Feb 11, 2015 at 1:05 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Feb 11, 2015 at 12:01 PM, Hanglin Ye <hanglinye at gmail.com> wrote:
>> Thank you very much for the reply.
>> I am not very sure if structured/unstructured mesh means differently in
>> PETSc, but my mesh are simply hexahedral mesh, which I assume is
>> structured. Is there any difference when dealing with structured and
>> unstructured mesh?
>> And another question is: Can I say that I only need to provide the whole
>> domain, and PETSc can take care of the decomposition, so that I do not need
>> to use software such as Metis to partition the mesh in advance?
> Now your mesh sounds unstructured. SNES ex62 is an example of a finite
> element code using DMPlex
> which can have tetrahedral or hexahedral cells, and solves Stokes equation.
> PETSc can handle partitioning and distribution for you.
>   Thanks,
>     Matt
>> Thank you.
>> On Feb 11, 2015, at 12:01, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Feb 11, 2015 at 10:52 AM, Hanglin Ye <hanglinye at gmail.com> wrote:
>>> Dear all,
>>> I am new to PETSc and I want to use it to parallel my current serial FEM
>>> code. I want to use Domain Decomposition Method so that the whole FEM
>>> domain is partitioned into sub-domains and computations are performed in
>>> sub-domains then assemble together. Is there a way to use PETSc to realize
>>> that ?
>>> I've been searching through tutorials but none seems to be clear about
>>> this aspect. I mainly wish to know what solver of PETSc do I need.
>> Do you have a structured or unstructured mesh? In either case, you will
>> use a DM to encapsulate your mesh, which will give you
>> DMLocalToGlobal() and DMGlobalToLocal() to map between Vecs which are
>> appropriate for the solver (global) and those with
>> ghost regions which are appropriate for assembly (local). You can see an
>> example in SNES ex5, ex12, and ex19.
>>  Thanks,
>>    Matt
>>> Thank you very much.
>>> Hanglin Ye
>>> Ph.D.Student MANE, RPI
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
Hanglin Ye
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150211/429a495e/attachment.html>
