[petsc-users] SGI compiler (mpt-2.11) and fortran interface
Matteo Parsani
parsani.matteo at gmail.com
Wed Feb 11 13:16:55 CST 2015
Hello,
I am already using VecGetArrayF90().
I am waiting now for the IT help because the issue is only with the SGI
compiler on our cluster. Once everything is set up I will try to run the
fortran examples in PETSc and then I will let you know if the example work.
On Wed, Feb 11, 2015 at 2:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Feb 11, 2015, at 11:32 AM, Matteo Parsani <parsani.matteo at gmail.com>
> wrote:
> > Dear Petsc Users and Developers,
> > Recently, I have compiled my fortran code using the SGI compiler
> (mpt-2.11). Previously I was using openmpi 1.7.3 and everything worked fine.
> Almost for sure your code is now being compiled to check for out of
> bounds in array access. You need to turn that off if you use VecGetArray()
> you need to check the documentation for your compiler to find the flag to
> turn it off.
> Or you can switch to using VecGetArrayF90() which will also simplify
> your code slightly and is the post-f77 way of accessing arrays from PETSc
> vectors.
> Barry
> > Now, with when I run the code compiled with SGI I get the following
> error:
> > At line 1921 of file mpi_module.F90
> > Fortran runtime error: Array reference out of bounds for array 'xx_v',
> upper bound of dimension 1 exceeded (349921 > 1)
> > Precisely the line that gives troubles is the following
> > x_ghost(i_dir,i_loc) = xx_v(n_tot+3*(i_loc-1) + i_dir)
> > The variables xx_v is a fortran pointer which I get using
> > call VecGetArrayF90(x_local, xx_v, i_er)
> > where i_err is defined as
> > PetscErrorCode i_err
> > Do you have any idea what I am doing wrong?
> > Thank you!
> > Matteo
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150211/4fdd98fb/attachment.html>
