[petsc-users] Full blas-lapack on Windows
    Jed Brown
    jed at jedbrown.org
    Wed Feb 11 00:35:49 CST 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
>   The reason it (superlu_dist) doesn't build is that it uses C99 compiler features while Microsoft C compiler only supports C89. The line of code
>       int nlsupers = nsupers/Pc;
> is not valid c89 since it declares a new variable after other code.
Or upgrade to MSVC 2013 (MS C Version 18 or later), which supports a few C99 features.
https://msdn.microsoft.com/en-us/library/hh409293.aspx
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150210/4df9a528/attachment.pgp>
