[petsc-users] Installing petsc on Linux with Intel mpi
Jed Brown jed at jedbrown.org
Mon Feb 9 19:46:39 CST 2015
Wee Beng Tay <zonexo at gmail.com> writes:
> Hi,
> I'm using the latest version 5 update 1,just installed 1 wk ago.
Why are you installing such an old version now?  Satish wasn't joking
around when he said you need at least Update 2.  Earlier versions return
0 for failure making it impossible to test for features.
> Compiling of code uses mpiicc, mpiifort.  Compiling a hello mpi code
> works.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150209/e6f16c07/attachment.pgp>
