[petsc-users] Installing petsc on Linux with Intel mpi
    Satish Balay
    balay at mcs.anl.gov
    Mon Feb  9 17:42:58 CST 2015
Which version of IMPI do you have?
Make sure you have the following (or newer?) - as it has the required fixes.
https://software.intel.com/en-us/articles/intel-mpi-library-50-update-2-readme
Satish
On Mon, 9 Feb 2015, Wee Beng Tay wrote:
> Hi,
> I'm trying to install petsc on Linux with Intel mpi 5 and compiler. What should be the configure
> Command line to use? Anyone has experience?
> I tried the usual options but they all can't work.
> Thanks
> Sent using CloudMagic
