[petsc-users] Multiple in-flight communications with PetscSFs
Lawrence Mitchell
lawrence.mitchell at imperial.ac.uk
Sat Feb 7 05:13:06 CST 2015
On 6 Feb 2015, at 18:09, Jed Brown <jed at jedbrown.org> wrote:
> Lawrence Mitchell <lawrence.mitchell at imperial.ac.uk> writes:
>> Or is this not something that is supposed to work at all and I'm just lucky.
> It's supposed to work, but I think not tested. Can you test the above
> (have the conditional check the key instead of changing "match"; there
> is no implicit conversion from bool to PetscBool) and submit as a patch?
Thanks, patch (plus simple test) here https://bitbucket.org/petsc/petsc/pull-request/255/sf-fix-multiple-in-flight-comm-rounds-for/diff
Before this change the communication completion into A get's B's data and vice versa. This doesn't occur for -sf_type window.
While I'm here, is there any reason that DMs don't call setfromoptions on their SFs: it looks like one can't select an an sf type except programmatically.
Maybe the following:
diff --git a/src/dm/interface/dm.c b/src/dm/interface/dm.c
index 324b101..9e9b130 100644
--- a/src/dm/interface/dm.c
+++ b/src/dm/interface/dm.c
@@ -49,6 +49,8 @@ PetscErrorCode DMCreate(MPI_Comm comm,DM *dm)
v->coloringtype = IS_COLORING_GLOBAL;
ierr = PetscSFCreate(comm, &v->sf);CHKERRQ(ierr);
ierr = PetscSFCreate(comm, &v->defaultSF);CHKERRQ(ierr);
+ ierr = PetscSFSetFromOptions(v->sf); CHKERRQ(ierr);
+ ierr = PetscSFSetFromOptions(v->defaultSF); CHKERRQ(ierr);
v->defaultSection = NULL;
v->defaultGlobalSection = NULL;
v->defaultConstraintSection = NULL;
Cheers,
Lawrence
Desc: Message signed with OpenPGP using GPGMail
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150207/6e01b337/attachment.pgp>
