[petsc-users] MUMPS causing segmentation fault
    Manav Bhatia
    bhatiamanav at gmail.com
    Fri Feb  6 22:39:31 CST 2015
   I am trying to run MUMPS with the following command line options:
 -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package mumps -mat_mumps_icntl_4 4 -info
  This works fine with ex2.c.
   My code, which runs fine with -ksp_type preonly -pc_type lu throws a segmentation fault error with the command line options listed above. The output of the code is attached.
   Is there anything that seems obviously wrong here?
Manav
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150206/5006103c/attachment-0002.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150206/5006103c/attachment-0001.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150206/5006103c/attachment-0003.html>
