[petsc-users] Field Split PC for Fully-Coupled 3d stationary incompressible Navier-Stokes Solution Algorithm
    Matthew Knepley
    knepley at gmail.com
    Thu Feb  5 18:53:58 CST 2015
On Thu, Feb 5, 2015 at 6:15 PM, Fabian Gabel <gabel.fabian at gmail.com> wrote:
> On Do, 2015-02-05 at 16:45 -0600, Matthew Knepley wrote:
> > On Thu, Feb 5, 2015 at 4:15 PM, Fabian Gabel <gabel.fabian at gmail.com>
> > wrote:
> >         Thank you for your feedback.
> >         >         -coupledsolve_pc_type fieldsplit
> >         >         -coupledsolve_pc_fieldsplit_0_fields 0,1,2
> >         >         -coupledsolve_pc_fieldsplit_1_fields 3
> >         >         -coupledsolve_pc_fieldsplit_type schur
> >         >         -coupledsolve_pc_fieldsplit_block_size 4
> >         >         -coupledsolve_fieldsplit_0_ksp_converged_reason
> >         >         -coupledsolve_fieldsplit_1_ksp_converged_reason
> >         >         -coupledsolve_fieldsplit_0_ksp_type gmres
> >         >         -coupledsolve_fieldsplit_0_pc_type fieldsplit
> >         >         -coupledsolve_fieldsplit_0_pc_fieldsplit_block_size
> >         3
> >         >         -coupledsolve_fieldsplit_0_fieldsplit_0_pc_type ml
> >         >         -coupledsolve_fieldsplit_0_fieldsplit_1_pc_type ml
> >         >         -coupledsolve_fieldsplit_0_fieldsplit_2_pc_type ml
> >         >         Is it normal, that I have to explicitly specify the
> >         block size
> >         >         for each
> >         >         fieldsplit?
> >         > No. You should be able to just specify
> >         > -coupledsolve_fieldsplit_ksp_converged
> >         > -coupledsolve_fieldsplit_0_fieldsplit_pc_type ml
> >         > and same options will be applied to all splits (0,1,2).
> >         > Does this functionality not work?
> >         It does work indeed, but what I actually was referring to, was
> >         the use
> >         of
> >         -coupledsolve_fieldsplit_0_pc_fieldsplit_block_size 3
> >         Without them, I get the error message
> >         [0]PETSC ERROR: PCFieldSplitSetDefaults() line 468
> >         in /work/build/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
> >         Unhandled
> >         case, must have at least two fields, not 1
> >         I thought PETSc would already know, what I want to do, since I
> >         initialized the fieldsplit with
> >         CALL PCFieldSplitSetIS(PRECON,PETSC_NULL_CHARACTER,ISU,IERR)
> >         etc.
> >         >         Are there any guidelines to follow that I could use
> >         to avoid
> >         >         taking wild
> >         >         guesses?
> >         > Sure. There are lots of papers published on how to construct
> >         robust
> >         > block preconditioners for saddle point problems arising from
> >         Navier
> >         > Stokes.
> >         > I would start by looking at this book:
> >         >   Finite Elements and Fast Iterative Solvers
> >         >   Howard Elman, David Silvester and Andy Wathen
> >         >   Oxford University Press
> >         >   See chapters 6 and 8.
> >         As a matter of fact I spent the last days digging through
> >         papers on the
> >         regard of preconditioners or approximate Schur complements and
> >         the names
> >         Elman and Silvester have come up quite often.
> >         The problem I experience is, that, except for one publication,
> >         all the
> >         other ones I checked deal with finite element formulations.
> >         Only
> >         Klaij, C. and Vuik, C. SIMPLE-type preconditioners for
> >         cell-centered,
> >         colocated finite volume discretization of incompressible
> >         Reynolds-averaged Navier–Stokes equations
> >         presented an approach for finite volume methods. Furthermore,
> >         a lot of
> >         literature is found on saddle point problems, since the linear
> >         system
> >         from stable finite element formulations comes with a 0 block
> >         as pressure
> >         matrix. I'm not sure how I can benefit from the work that has
> >         already
> >         been done for finite element methods, since I neither use
> >         finite
> >         elements nor I am trying to solve a saddle point problem (?).
> > I believe the operator estimates for FV are very similar to first
> > order FEM,
> Ok, so you would suggest to just discretize the operators differently
> (FVM instead of FEM discretization)?
I thought you were using FV.
> > and
> > I believe that you do have a saddle-point system in that there are
> > both positive
> > and negative eigenvalues.
> A first test on a small system in Matlab shows, that my system matrix is
> positive semi-definite but I am not sure how this result could be
> derived in general form from the discretization approach I used.
You can always make it definite by adding a large enough A_pp. I thought
the penalization would be small.
     Matt
> >   Thanks,
> >      Matt
> >         >         > Petsc has some support to generate approximate
> >         pressure
> >         >         schur
> >         >         > complements for you, but these will not be as good
> >         as the
> >         >         ones
> >         >         > specifically constructed for you particular
> >         discretization.
> >         >         I came across a tutorial
> >         (/snes/examples/tutorials/ex70.c),
> >         >         which shows
> >         >         2 different approaches:
> >         >         1- provide a Preconditioner \hat{S}p for the
> >         approximation of
> >         >         the true
> >         >         Schur complement
> >         >         2- use another Matrix (in this case its the Matrix
> >         used for
> >         >         constructing
> >         >         the preconditioner in the former approach) as a new
> >         >         approximation of the
> >         >         Schur complement.
> >         >         Speaking in terms of the PETSc-manual p.87, looking
> >         at the
> >         >         factorization
> >         >         of the Schur field split preconditioner, approach 1
> >         sets
> >         >         \hat{S}p while
> >         >         approach 2 furthermore sets \hat{S}. Is this
> >         correct?
> >         > No this is not correct.
> >         > \hat{S} is always constructed by PETSc as
> >         >   \hat{S} = A11 - A10 KSP(A00) A01
> >         But then what happens in this line from the
> >         tutorial /snes/examples/tutorials/ex70.c
> >         ierr = KSPSetOperators(subksp[1], s->myS,
> >         s->myS);CHKERRQ(ierr);
> >         It think the approximate Schur complement a (Matrix of type
> >         Schur) gets
> >         replaced by an explicitely formed Matrix (myS, of type
> >         MPIAIJ).
> >         > You have two choices in how to define the preconditioned,
> >         \hat{S_p}:
> >         > [1] Assemble you own matrix (as is done in ex70)
> >         > [2] Let PETSc build one. PETSc does this according to
> >         >   \hat{S_p} = A11 - A10 inv(diag(A00)) A01
> >         Regards,
> >         Fabian
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150205/11868215/attachment.html>
