[petsc-users] Direct solvers
Thu Feb 5 17:55:02 CST 2015
On Thu, Feb 5, 2015 at 5:47 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
> Hi,
>    I am trying to use an lu decomposition method for a relatively large
> matrix (~775,000 dofs) coming from a thermoelasticity problem.
>    For the past few weeks, LU solver in 3.5.1 has been solving it just
> fine. I just upgraded to 3.5.2 from macports (running on Mac OS 10.10.2),
> and am getting the following “out of memory" error
> sab_old_mast_structural_analysis(378,0x7fff75f6e300) malloc: ***
> mach_vm_map(size=18446744066373115904) failed (error code=3)
> *** error: can't allocate region
> *** set a breakpoint in malloc_error_break to debug
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Out of memory. This could be due to allocating
> [0]PETSC ERROR: too large an object or bleeding by not properly
> [0]PETSC ERROR: destroying unneeded objects.
> [0]PETSC ERROR: Memory allocated 3649788624 Memory used by process
> 3943817216
> [0]PETSC ERROR: Try running with -malloc_dump or -malloc_log for info.
> [0]PETSC ERROR: Memory requested 18446744066373113856
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.5.2, unknown
> [0]PETSC ERROR: ./sab_old_mast_structural_analysis on a arch-macports
> named ws243-49.walker.dynamic.msstate.edu by manav Thu Feb  5 17:30:18
> 2015
> [0]PETSC ERROR: Configure options --prefix=/opt/local
> --prefix=/opt/local/lib/petsc --with-valgrind=0 --with-shared-libraries
> --with-c2html-dir=/opt/local --with-x=0
> --with-blas-lapack-lib=/System/Library/Frameworks/Accelerate.framework/Versions/Current/Accelerate
> --with-hwloc-dir=/opt/local --with-suitesparse-dir=/opt/local
> --with-superlu-dir=/opt/local --with-metis-dir=/opt/local
> --with-parmetis-dir=/opt/local --with-scalapack-dir=/opt/local
> --with-mumps-dir=/opt/local CC=/opt/local/bin/mpicc-openmpi-mp
> CXX=/opt/local/bin/mpicxx-openmpi-mp FC=/opt/local/bin/mpif90-openmpi-mp
> F77=/opt/local/bin/mpif90-openmpi-mp F90=/opt/local/bin/mpif90-openmpi-mp
> COPTFLAGS=-Os CXXOPTFLAGS=-Os FOPTFLAGS=-Os LDFLAGS="-L/opt/local/lib
> -Wl,-headerpad_max_install_names" CPPFLAGS=-I/opt/local/include CFLAGS="-Os
> -arch x86_64" CXXFLAGS=-Os FFLAGS=-Os FCFLAGS=-Os F90FLAGS=-Os
> PETSC_ARCH=arch-macports --with-mpiexec=mpiexec-openmpi-mp
> [0]PETSC ERROR: #1 PetscMallocAlign() line 46 in
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.2/src/sys/memory/mal.c
> [0]PETSC ERROR: #2 PetscTrMallocDefault() line 184 in
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.2/src/sys/memory/mtr.c
> [0]PETSC ERROR: #3 PetscFreeSpaceGet() line 13 in
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.2/src/mat/utils/freespace.c
> [0]PETSC ERROR: #4 MatLUFactorSymbolic_SeqAIJ() line 362 in
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.2/src/mat/impls/aij/seq/aijfact.c
> [0]PETSC ERROR: #5 MatLUFactorSymbolic() line 2842 in
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.2/src/mat/interface/matrix.c
> [0]PETSC ERROR: #6 PCSetUp_LU() line 127 in
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.2/src/ksp/pc/impls/factor/lu/lu.c
> [0]PETSC ERROR: #7 PCSetUp() line 902 in
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.2/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #8 KSPSetUp() line 305 in
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.2/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #9 KSPSolve() line 417 in
> [0]PETSC ERROR: #10 SNESSolve_NEWTONLS() line 232 in
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.2/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: #11 SNESSolve() line 3743 in
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.2/src/snes/interface/snes.c
> [0]PETSC ERROR: #12 solve() line 559 in
> src/solvers/petsc_nonlinear_solver.C
> A few questions:
> — has something changed between 3.5.1 and 3.5.2 that might lead to this
> behavior?
I do not see anything:
http://www.mcs.anl.gov/petsc/documentation/changes/32.html
You should upgrade to the latest release. Then we can start improving it.
> — So far I have tried the following iterative solver option: -pc_type ilu
> -pc_factor_levels 1 (and 2) with very slow convergence. Is there a better
> preconditioner recommended for this problem? This is a solid mechanics
> problem with thermal load (not a coupled thermal-structural probelm).
With the latest release, you should try -pc_type gamg.
> — I tried using MUMPS through the option -pc_factor_mat_solver_package
> mumps -mat_mumps_icntl_ 22 1 -mat_mumps_icntl_ 23 8000  to try to get it to
> use the disk I/O and limit the memory to 8GB, but that too returned with an
> out of memory error. Is this the correct format to specify the options? If
> so, is the write to disk option expected to work with MUMPS called via
> petsc?
Send the output of -ksp_view so we can see exactly what it is doing. Also I
would also try SuperLU.
    Matt
> I would greatly appreciate your inputs.
> Thanks,
> Manav
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150205/b9263f6c/attachment-0001.html>
