[petsc-users] SLEPc choosing inner product
Jose E. Roman jroman at dsic.upv.es
Thu Feb 5 12:54:24 CST 2015
El 05/02/2015, a las 19:45, Andrew Spott escribió:
> If I have some inner matrix upon which I want the eigensolver context to check orthogonality and norm, how do I set that?
> Is it:
>     BV bv;
>     EPSGetBV( e, &bv );
>     BVSetMatrix( bv, InnerProductMatrix, PETSC_FALSE );
> This doesn’t appear to be changing the norm that is being used.  Is the norm used for the eigensolver context when normalizing the eigenvectors always just the 2norm?
> -Andrew
In normal usage, the user should not mess with the BV object.
If you set the EPS problem type to GHEP then the solver (at least the default one) will use B-innerproducts so that eigenvectors with satisfy the B-orthogonality condition. Also, in this case EPS should provide eigenvectors with unit B-norm.
So InnerProductMatrix should be the B matrix of your problem Ax=\lambda Bx. Is this what you need to do?
If you want to check orthogonality a posteriori, call SlepcCheckOrthogonality with the B matrix.
Jose
