[petsc-users] KSP not solving correctly
Massimiliano Leoni
leoni.massimiliano1 at gmail.com
Thu Feb 5 04:14:23 CST 2015
Hi petsc-users,
I stumbled across a curious issue while trying to setup some solver for
Navier-Stokes.
In one sentence, I tested a solver computing b = Ax with x known, then solving
the system with b to find the original x back, but it's not working.
In detail, I want to implement a matrix free method for a matrix C2 = D^T
M_L^{-1} D, where M_L^{-1} is the inverse lumped of M; here's what I do
[I'm sorry for posting code, but I suspect the error could be quite subtle...]
////// define utility struct
typedef struct _C2ctx
Mat D;
Vec Mdiag;
} C2ctx;
////// define multiplication
int C2mult(Mat A,Vec x,Vec y)
C2ctx* ctx;
MatShellGetContext(A,&ctx);
Mat D = ctx->D;
Vec Mdiag = ctx->Mdiag;
int Nu;
VecGetSize(Mdiag,&Nu);
Vec tmp;
VecCreate(PETSC_COMM_WORLD,&tmp);
VecSetType(tmp,VECSTANDARD);
VecSetSizes(tmp,PETSC_DECIDE,Nu);
MatMultTranspose(D,x,tmp);
VecPointwiseDivide(tmp,tmp,Mdiag);
MatMult(D,tmp,y);
VecDestroy(&tmp);
return 0;
Later on, I assemble D and M, and then
////// lump M into _Mdiag
Vec _Mdiag;
VecCreate(PETSC_COMM_WORLD,&_Mdiag);
VecSetType(_Mdiag,VECSTANDARD);
VecSetSizes(_Mdiag,PETSC_DECIDE,Nu);
MatGetRowSum(_M,_Mdiag);
////// set context
C2ctx ctx;
ctx.D = _D;
ctx.Mdiag = _Mdiag;
////// create _C2 [= A]
Mat _C2;
MatCreateShell(PETSC_COMM_WORLD,Np,Np,PETSC_DETERMINE,PETSC_DETERMINE,&ctx,&_C2);
MatShellSetOperation(_C2,MATOP_MULT,(void(*)(void))C2mult);
////// create _b2 [= b]
Vec _b2;
VecCreate(PETSC_COMM_WORLD,&_b2);
VecSetType(_b2,VECSTANDARD);
VecSetSizes(_b2,PETSC_DECIDE,Np);
////// create _deltaP [= x]
Vec _deltaP;
VecCreate(PETSC_COMM_WORLD,&_deltaP);
VecSetType(_deltaP,VECSTANDARD);
VecSetSizes(_deltaP,PETSC_DECIDE,Np);
////// set _deltaP = 1 and _b2 = _C2*_deltaP, then change _deltaP for check
VecSet(_deltaP,1.0);
MatMult(_C2,_deltaP,_b2);
VecSet(_deltaP,2.0);
////// setup KSP
KSP _ksp2;
KSPCreate(PETSC_COMM_WORLD,&_ksp2);
KSPSetOperators(_ksp2,_C2,_C2,DIFFERENT_NONZERO_PATTERN);
KSPSetType(_ksp2,"cg");
KSPSolve(_ksp2,_b2,_deltaP);
According to my understanding, now _deltaP should be a nice row on 1s, but
what happens is that it has some [apparently] random zeros here and there.
Additional infos:
[*] the problem comes from the cavity problem with navier-stokes. This
particular step is to solve for the pressure and the matrix _C2 is singular
[it's a laplacian] with nullspace the constants. I was told I can ignore this
and avoid setting the nullspace as long as I use a CG or GMRES solver.
[*] the number of "random zero entries" is very high with P2-P1 elements, and
is significantly lower with P1+Bubble - P1.
[*] Matrices M and D are automatically assembled by FEniCS, not by me.
Can anybody please advice on what I am doing wrong? What could be causing
this?
Thanks in advance
Massimiliano
