[petsc-users] Field Split PC for Fully-Coupled 3d stationary incompressible Navier-Stokes Solution Algorithm
    Fabian Gabel
    gabel.fabian at gmail.com
    Wed Feb  4 14:34:41 CST 2015
Thank you for pointing me into the right direction. After some first
tests on a test case with 2e6 cells (4dof) I could measure a slight
improvement (25%) with respect to wall time, using a nested
field split for the velocities:
-coupledsolve_pc_type fieldsplit
-coupledsolve_pc_fieldsplit_0_fields 0,1,2
-coupledsolve_pc_fieldsplit_1_fields 3
-coupledsolve_pc_fieldsplit_type schur
-coupledsolve_pc_fieldsplit_block_size 4
-coupledsolve_fieldsplit_0_ksp_converged_reason
-coupledsolve_fieldsplit_1_ksp_converged_reason
-coupledsolve_fieldsplit_0_ksp_type gmres
-coupledsolve_fieldsplit_0_pc_type fieldsplit
-coupledsolve_fieldsplit_0_pc_fieldsplit_block_size 3
-coupledsolve_fieldsplit_0_fieldsplit_0_pc_type ml
-coupledsolve_fieldsplit_0_fieldsplit_1_pc_type ml
-coupledsolve_fieldsplit_0_fieldsplit_2_pc_type ml
Is it normal, that I have to explicitly specify the block size for each
fieldsplit?
I attached the results (-converged_reason only for readability and another file
solely for the output of -ksp_view). I am not sure if this result could
be improved by modifying any of the solver options.
Are there any guidelines to follow that I could use to avoid taking wild
guesses?
> Petsc has some support to generate approximate pressure schur
> complements for you, but these will not be as good as the ones
> specifically constructed for you particular discretization.
I came across a tutorial (/snes/examples/tutorials/ex70.c), which shows
2 different approaches:
1- provide a Preconditioner \hat{S}p for the approximation of the true
Schur complement
2- use another Matrix (in this case its the Matrix used for constructing
the preconditioner in the former approach) as a new approximation of the
Schur complement.
Speaking in terms of the PETSc-manual p.87, looking at the factorization
of the Schur field split preconditioner, approach 1 sets \hat{S}p while
approach 2 furthermore sets \hat{S}. Is this correct?
> [2] If you assembled a different operator for your preconditioner in
> which the B_pp slot contained a pressure schur complement
> approximation, you could use the simpler and likely more robust option
> (assuming you know of a decent schur complement approximation for you
> discretisation and physical problem)
> -coupledsolve_pc_fieldsplit_type MULTIPLICATIVE
> which include you U-p coupling, or just
> -coupledsolve_pc_fieldsplit_type ADDITIVE
> which would define the following preconditioner
> inv(B) = diag( inv(B_uu,) , inv(B_vv) , inv(B_ww) , inv(B_pp) )
What do you refer to with "B_pp slot"? I don't understand this approach
completely. What would I need a Schur complement approximation for, if I
don't use a Schur complement preconditioner?
> Option 2 would be better as your operator doesn't have an u_i-u_j, i !
> = j coupling and you could use efficient AMG implementations for each
> scalar terms associated with u-u, v-v, w-w coupled terms without
> having to split again.
> Also, fieldsplit will not be aware of the fact that the Auu, Avv, Aww
> blocks are all identical - thus it cannot do anything "smart" in order
> to save memory. Accordingly, the KSP defined for each u,v,w split will
> be a unique KSP object. If your A_ii are all identical and you want to
> save memory, you could use MatNest but as Matt will always yell out,
> "MatNest is ONLY a memory optimization and should be ONLY be used once
> all solver exploration/testing is performed".
Thanks, I will keep this in mind. Does this mean that I would only have
to assemble one matrix for the velocities instead of three?
>         - A_pp is defined as the matrix resulting from the
>         discretization of the
>         pressure equation that considers only the pressure related
>         terms.
> Hmm okay, i assumed for incompressible NS the pressure equation
> that the pressure equation would be just \div(u) = 0.
Indeed, many finite element(!) formulations I found while researching use
this approach, which leads to the block A_pp being zero. I however use a
collocated finite volume formulation and, to avoid checkerboarding of the
pressure field, I deploy a pressure weighted interpolation method to
approximate the velocities surging from the discretisation of \div{u}.
This gives me an equation with the pressure as the dominant variable.
Sender: LSF System <lsfadmin at hpb0039>
Subject: Job 408293: <fieldsplit_128> in cluster <lichtenberg> Done
Job <fieldsplit_128> was submitted from host <hla0003> by user <gu08vomo> in cluster <lichtenberg>.
Job was executed on host(s) <hpb0039>, in queue <test_mpi2>, as user <gu08vomo> in cluster <lichtenberg>.
</home/gu08vomo> was used as the home directory.
</work/scratch/gu08vomo/thesis/singleblock/128_1_1> was used as the working directory.
Started at Wed Feb  4 09:41:27 2015
Results reported at Wed Feb  4 11:23:23 2015
Your job looked like:
# LSBATCH: User input
#! /bin/sh
#BSUB -J fieldsplit_128
#BSUB -o /home/gu08vomo/thesis/fieldsplit/cpld_128.out.%J
#BSUB -n 1
#BSUB -W 24:00
#BSUB -x
#BSUB -q test_mpi2
#BSUB -a openmpi
module load openmpi/intel/1.8.2
export PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr
export MYWORKDIR=/work/scratch/gu08vomo/thesis/singleblock/128_1_1/
export OUTPUTDIR=/home/gu08vomo/thesis/coupling
export PETSC_OPS="-options_file ops"
#export PETSC_OPS="-options_file ops.def"
echo "PETSC_DIR="$PETSC_DIR
echo "MYWORKDIR="$MYWORKDIR
echo "PETSC_OPS="$PETSC_OPS
cd $MYWORKDIR
mpirun -n 1 ./caffa3d.cpld.lnx ${PETSC_OPS}
Successfully completed.
Resource usage summary:
    CPU time :               6115.59 sec.
    Max Memory :             11949 MB
    Average Memory :         11588.18 MB
    Total Requested Memory : -
    Delta Memory :           -
    (Delta: the difference between total requested memory and actual max usage.)
    Max Swap :               12826 MB
    Max Processes :          6
    Max Threads :            11
The output (if any) follows:
Modules: loading gcc/4.8.3
Modules: loading intel/2015
Modules: loading openmpi/intel/1.8.2
PETSC_OPS=-options_file ops
  ENTER PROBLEM NAME (SIX CHARACTERS):
 NAME OF PROBLEM SOLVED control
 CONTROL SETTINGS
 LREAD,LWRITE,LPOST,LTEST,LOUTS,LOUTE,LTIME,LGRAD
 F F T F F F F F
  IMON, JMON, KMON, MMON, RMON,  IPR,  JPR,  KPR,  MPR,NPCOR,NIGRAD
     8     9     8     1     0     2     2     3     1     1     1
  SORMAX,     SLARGE,     ALFA
  0.1000E-07  0.1000E+31  0.9200E+00
 (URF(I),I=1,6)
  0.1000E+01  0.1000E+01  0.1000E+01  0.1000E+01  0.1000E+01  0.1000E+01
 (SOR(I),I=1,6)
  0.1000E-02  0.1000E-01  0.1000E-01  0.1000E-01  0.1000E-01  0.1000E-07
 (GDS(I),I=1,6) - BLENDING (CDS-UDS)
 LSG
    20
 START COUPLED ALGORITHM
  Linear solve converged due to CONVERGED_RTOL iterations 6
  Linear solve converged due to CONVERGED_RTOL iterations 4
  Residual norms for coupledsolve_ solve.
  0 KSP Residual norm 1.037040763958e+04
  1 KSP Residual norm 1.820301124259e+02
  2 KSP Residual norm 1.918291450815e+00
 0000001  0.1000E+01  0.0000E+00
  0 KSP Residual norm 1.023809154509e+04
  1 KSP Residual norm 3.435441118311e+01
  2 KSP Residual norm 3.845041351098e-01
 0000002  0.2240E+00  0.0000E+00
  0 KSP Residual norm 1.253367530914e+03
  1 KSP Residual norm 1.035050845597e+01
  2 KSP Residual norm 7.886700674837e-02
  Linear solve converged due to CONVERGED_RTOL iterations 7
  3 KSP Residual norm 5.051143145928e-04
 0000003  0.4427E-01  0.0000E+00
  0 KSP Residual norm 1.192891689143e+03
  1 KSP Residual norm 4.373785312405e+00
  2 KSP Residual norm 1.508617145525e-02
 0000004  0.1864E-01  0.0000E+00
  0 KSP Residual norm 1.063056228890e+03
  1 KSP Residual norm 5.221617643142e+00
  2 KSP Residual norm 1.702817267846e-02
  3 KSP Residual norm 1.094137462022e-04
 0000005  0.4104E-02  0.0000E+00
  0 KSP Residual norm 1.062202020432e+03
  1 KSP Residual norm 4.326846513717e+00
  2 KSP Residual norm 1.531682932145e-02
  3 KSP Residual norm 1.029941882864e-04
 0000006  0.1801E-02  0.0000E+00
  0 KSP Residual norm 1.061334126191e+03
  1 KSP Residual norm 4.337871426870e+00
  2 KSP Residual norm 1.534097657692e-02
  3 KSP Residual norm 1.029664077719e-04
 0000007  0.4160E-03  0.0000E+00
  0 KSP Residual norm 1.061324173792e+03
  1 KSP Residual norm 4.315857858273e+00
  2 KSP Residual norm 1.537945131376e-02
  3 KSP Residual norm 1.031173163530e-04
 0000008  0.1848E-03  0.0000E+00
  0 KSP Residual norm 1.061317257655e+03
  1 KSP Residual norm 4.314492943454e+00
  2 KSP Residual norm 1.538683173899e-02
  3 KSP Residual norm 1.031713833017e-04
  4 KSP Residual norm 3.599982126738e-07
 0000009  0.4450E-04  0.0000E+00
  0 KSP Residual norm 1.061317147625e+03
  1 KSP Residual norm 4.314373274276e+00
  2 KSP Residual norm 1.538651291802e-02
  3 KSP Residual norm 1.031589080118e-04
  4 KSP Residual norm 3.601032727860e-07
 0000010  0.1982E-04  0.0000E+00
  0 KSP Residual norm 1.061317055113e+03
  1 KSP Residual norm 4.314199309723e+00
  2 KSP Residual norm 1.538699611154e-02
  3 KSP Residual norm 1.031690161587e-04
  4 KSP Residual norm 3.601173420863e-07
 0000011  0.5015E-05  0.0000E+00
  0 KSP Residual norm 1.061317068473e+03
  1 KSP Residual norm 4.314228017250e+00
  2 KSP Residual norm 1.538741285541e-02
  3 KSP Residual norm 1.031619248943e-04
  4 KSP Residual norm 3.601008760122e-07
 0000012  0.2225E-05  0.0000E+00
  0 KSP Residual norm 1.061317075229e+03
  1 KSP Residual norm 4.314202201274e+00
  2 KSP Residual norm 1.538662628122e-02
  3 KSP Residual norm 1.031753252907e-04
  4 KSP Residual norm 3.601602035056e-07
 0000013  0.6001E-06  0.0000E+00
  0 KSP Residual norm 1.061317064817e+03
  1 KSP Residual norm 4.314207628650e+00
  2 KSP Residual norm 1.538714820949e-02
  3 KSP Residual norm 1.031624832465e-04
  4 KSP Residual norm 3.601058284873e-07
  5 KSP Residual norm 2.711147491646e-09
 0000014  0.2640E-06  0.0000E+00
  0 KSP Residual norm 1.061317065303e+03
  1 KSP Residual norm 4.314210822353e+00
  2 KSP Residual norm 1.538750779210e-02
  3 KSP Residual norm 1.031646930709e-04
  4 KSP Residual norm 3.601111939693e-07
  5 KSP Residual norm 2.710026732371e-09
 0000015  0.7712E-07  0.0000E+00
  0 KSP Residual norm 1.061317065606e+03
  1 KSP Residual norm 4.314213175941e+00
  2 KSP Residual norm 1.538753978218e-02
  3 KSP Residual norm 1.031653392986e-04
  4 KSP Residual norm 3.601142782441e-07
  5 KSP Residual norm 2.711212471088e-09
 0000016  0.3455E-07  0.0000E+00
  0 KSP Residual norm 1.061317077674e+03
  1 KSP Residual norm 4.314208812309e+00
  2 KSP Residual norm 1.538784092617e-02
  3 KSP Residual norm 1.031663931282e-04
  4 KSP Residual norm 3.601165007389e-07
  5 KSP Residual norm 2.711310183065e-09
 0000017  0.1385E-07  0.0000E+00
  0 KSP Residual norm 1.061317064500e+03
  1 KSP Residual norm 4.314212836216e+00
  2 KSP Residual norm 1.538710308210e-02
  3 KSP Residual norm 1.031672844814e-04
  4 KSP Residual norm 3.601238377940e-07
  5 KSP Residual norm 2.710467667727e-09
 0000018  0.1014E-07  0.0000E+00
  0 KSP Residual norm 1.061317068254e+03
  1 KSP Residual norm 4.314211913659e+00
  2 KSP Residual norm 1.538827062974e-02
  3 KSP Residual norm 1.031590089559e-04
  4 KSP Residual norm 3.600831497655e-07
  5 KSP Residual norm 2.709837887968e-09
 0000019  0.9232E-08  0.0000E+00
TIME FOR CALCULATION:  0.6083E+04
 L2-NORM ERROR U    VELOCITY  2.808739609933520E-005
 L2-NORM ERROR V    VELOCITY  2.786225784858970E-005
 L2-NORM ERROR W    VELOCITY  2.914198563073946E-005
 L2-NORM ERROR ABS. VELOCITY  3.154082267224834E-005
 L2-NORM ERROR      PRESSURE  1.387416651056730E-003
      *** CALCULATION FINISHED - SEE RESULTS ***
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./caffa3d.cpld.lnx on a arch-openmpi-opt-intel-hlr-ext named hpb0039 with 1 processor, by gu08vomo Wed Feb  4 11:23:23 2015
Using Petsc Release Version 3.5.3, Jan, 31, 2015
                         Max       Max/Min        Avg      Total
Time (sec):           6.113e+03      1.00000   6.113e+03
Objects:              3.286e+03      1.00000   3.286e+03
Flops:                6.812e+12      1.00000   6.812e+12  6.812e+12
Flops/sec:            1.114e+09      1.00000   1.114e+09  1.114e+09
MPI Messages:         0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Message Lengths:  0.000e+00      0.00000   0.000e+00  0.000e+00
MPI Reductions:       0.000e+00      0.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 1.0866e+02   1.8%  2.6364e+07   0.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
 1:        CPLD_SOL: 6.0048e+03  98.2%  6.8122e+12 100.0%  0.000e+00   0.0%  0.000e+00        0.0%  0.000e+00   0.0%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length (bytes)
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %F - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
ThreadCommRunKer       5 1.0 5.2452e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNorm                1 1.0 2.4110e-01 1.0 1.76e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 67  0  0  0    73
VecScale               1 1.0 6.9940e-03 1.0 8.79e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 33  0  0  0  1257
VecSet               656 1.0 6.7253e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecScatterBegin      698 1.0 2.0170e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize           1 1.0 6.9940e-03 1.0 8.79e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 33  0  0  0  1257
MatAssemblyBegin      38 1.0 1.2875e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd        38 1.0 1.9623e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatZeroEntries        19 1.0 1.4439e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
PetscBarrier          76 1.0 4.0770e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
--- Event Stage 1: CPLD_SOL
VecMDot             5308 1.0 7.4653e+01 1.0 2.25e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  3  0  0  0   1  3  0  0  0  3014
VecNorm             6107 1.0 2.0860e+01 1.0 7.51e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  1  0  0  0  3600
VecScale           17413 1.0 4.6473e+01 1.0 6.23e+10 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0  1340
VecCopy              889 1.0 4.9240e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet            135930 1.0 5.3929e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
VecAXPY              979 1.0 7.5397e+00 1.0 1.23e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  1629
VecAYPX            79905 1.0 4.7291e+01 1.0 3.94e+10 1.0 0.0e+00 0.0e+00 0.0e+00  1  1  0  0  0   1  1  0  0  0   834
VecMAXPY            6178 1.0 1.0748e+02 1.0 2.89e+11 1.0 0.0e+00 0.0e+00 0.0e+00  2  4  0  0  0   2  4  0  0  0  2689
VecScatterBegin    32322 1.0 1.7972e+02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  3  0  0  0  0   3  0  0  0  0     0
VecNormalize        6088 1.0 4.9487e+01 1.0 1.12e+11 1.0 0.0e+00 0.0e+00 0.0e+00  1  2  0  0  0   1  2  0  0  0  2266
MatMult            42821 1.0 4.6083e+03 1.0 5.58e+12 1.0 0.0e+00 0.0e+00 0.0e+00 75 82  0  0  0  77 82  0  0  0  1211
MatMultAdd         80486 1.0 2.3782e+02 1.0 3.01e+11 1.0 0.0e+00 0.0e+00 0.0e+00  4  4  0  0  0   4  4  0  0  0  1267
MatSolve           16652 1.0 1.9250e+01 1.0 1.82e+10 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   947
MatSOR            159810 1.0 3.7930e+03 1.0 4.01e+12 1.0 0.0e+00 0.0e+00 0.0e+00 62 59  0  0  0  63 59  0  0  0  1056
MatLUFactorSym        57 1.0 3.6383e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum        76 1.0 2.0026e+00 1.0 8.68e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0   434
MatILUFactorSym        1 1.0 8.4865e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatResidual        79905 1.0 4.5082e+02 1.0 7.28e+11 1.0 0.0e+00 0.0e+00 0.0e+00  7 11  0  0  0   8 11  0  0  0  1615
MatAssemblyBegin    1045 1.0 1.6451e-04 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd      1045 1.0 8.9879e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ           58 1.0 5.9843e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice     190 1.0 4.0555e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  1  0  0  0  0   1  0  0  0  0     0
MatGetOrdering        58 1.0 9.6858e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatZeroEntries        54 1.0 3.3162e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPGMRESOrthog      5218 1.0 1.5732e+02 1.0 4.47e+11 1.0 0.0e+00 0.0e+00 0.0e+00  3  7  0  0  0   3  7  0  0  0  2840
KSPSetUp             456 1.0 1.2921e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve              19 1.0 5.9995e+03 1.0 6.81e+12 1.0 0.0e+00 0.0e+00 0.0e+00 98100  0  0  0 100100  0  0  0  1134
PCSetUp              114 1.0 2.8368e+02 1.0 1.64e+10 1.0 0.0e+00 0.0e+00 0.0e+00  5  0  0  0  0   5  0  0  0  0    58
PCApply               90 1.0 5.9555e+03 1.0 6.77e+12 1.0 0.0e+00 0.0e+00 0.0e+00 97 99  0  0  0  99 99  0  0  0  1137
--- Event Stage 2: Unknown
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
              Vector    71            227   3758900776     0
      Vector Scatter     4              8         5216     0
           Index Set    12             30     17599784     0
   IS L to G Mapping     4              3     79093788     0
              Matrix     2             62   6128226616     0
       Krylov Solver     0             25        82528     0
      Preconditioner     0             25        28144     0
    Distributed Mesh     0              1         4448     0
Star Forest Bipartite Graph     0              2         1632     0
     Discrete System     0              1          800     0
              Vector  1904           1745   6580253192     0
      Vector Scatter     5              0            0     0
           Index Set   284            262       207936     0
              Matrix   924            864   6427997568     0
   Matrix Null Space    19              0            0     0
       Krylov Solver    26              1         1328     0
      Preconditioner    26              1         1016     0
              Viewer     1              0            0     0
    Distributed Mesh     1              0            0     0
Star Forest Bipartite Graph     2              0            0     0
     Discrete System     1              0            0     0
Average time to get PetscTime(): 0
#PETSc Option Table entries:
-coupledsolve_fieldsplit_1_ksp_rtol 1e-2
-coupledsolve_ksp_monitor
-log_summary
-on_error_abort
-options_left
-options_table
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure options: PETSC_ARCH=arch-openmpi-opt-intel-hlr-ext PETSC_DIR=/home/gu08vomo/soft/petsc/3.5.3 -prefix=/home/gu08vomo/soft/petsc/3.5.3/build/arch-openmpi-opt-intel-hlr-ext --with-blas-lapack-dir=/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64/ --with-mpi-dir=/shared/apps/openmpi/1.8.2_intel COPTFLAGS="-O3 -xHost" FOPTFLAGS="-O3 -xHost" CXXOPTFLAGS="-O3 -xHost" --with-debugging=0 --download-hypre --download-ml
Libraries compiled on Sun Feb  1 16:09:22 2015 on hla0003
Machine characteristics: Linux-3.0.101-0.40-default-x86_64-with-SuSE-11-x86_64
Using PETSc directory: /home/gu08vomo/soft/petsc/3.5.3
Using PETSc arch: arch-openmpi-opt-intel-hlr-ext
Using C compiler: /shared/apps/openmpi/1.8.2_intel/bin/mpicc  -fPIC -wd1572 -O3 -xHost  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /shared/apps/openmpi/1.8.2_intel/bin/mpif90  -fPIC -O3 -xHost   ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/include -I/home/gu08vomo/soft/petsc/3.5.3/include -I/home/gu08vomo/soft/petsc/3.5.3/include -I/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/include -I/shared/apps/openmpi/1.8.2_intel/include
Using C linker: /shared/apps/openmpi/1.8.2_intel/bin/mpicc
Using Fortran linker: /shared/apps/openmpi/1.8.2_intel/bin/mpif90
Using libraries: -Wl,-rpath,/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -L/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -lpetsc -Wl,-rpath,/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -L/home/gu08vomo/soft/petsc/3.5.3/arch-openmpi-opt-intel-hlr-ext/lib -lHYPRE -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -lmpi_cxx -lml -lmpi_cxx -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_sequential -lmkl_core -lpthread -lm -lX11 -lpthread -lssl -lcrypto -lmpi_usempi_ignore_tkr -lmpi_mpifh -lifport -lifcore -lm -lmpi_cxx -ldl -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -lmpi -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -limf -lsvml -lirng -lipgo -ldecimal -lcilkrts -lstdc++ -lgcc_s -lirc -lpthread -lirc_s -Wl,-rpath,/shared/apps/openmpi/1.8.2_intel/lib -L/shared/apps/openmpi/1.8.2_intel/lib -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -L/shared/apps/gcc/4.8.3/lib/gcc/x86_64-unknown-linux-gnu/4.8.3 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib64 -L/shared/apps/gcc/4.8.3/lib64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/compiler/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/ipp/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -L/shared/apps/intel/2015/composer_xe_2015.0.090/mkl/lib/intel64 -Wl,-rpath,/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -L/shared/apps/intel/2015/composer_xe_2015.0.090/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/shared/apps/gcc/4.8.3/lib -L/shared/apps/gcc/4.8.3/lib -ldl
-log_summary
-on_error_abort
-options_left
-options_table
There is one unused database option. It is:
Option left: name:-options_table (no value)
KSP Object:(coupledsolve_) 1 MPI processes
  type: gmres
    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    GMRES: happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=0.001, absolute=1e-50, divergence=10000
  left preconditioning
  has attached null space
  using PRECONDITIONED norm type for convergence test
PC Object:(coupledsolve_) 1 MPI processes
  type: fieldsplit
    FieldSplit with Schur preconditioner, blocksize = 4, factorization FULL
    Preconditioner for the Schur complement formed from A11
    Split info:
    Split number 0 Fields  0, 1, 2
    Split number 1 Fields  3
    KSP solver for A00 block
      KSP Object:      (coupledsolve_fieldsplit_0_)       1 MPI processes
        type: gmres
        tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
      PC Object:      (coupledsolve_fieldsplit_0_)       1 MPI processes
        type: fieldsplit
          FieldSplit with MULTIPLICATIVE composition: total splits = 3, blocksize = 3
          Solver info for each split is in the following KSP objects:
          KSP Object:          (coupledsolve_fieldsplit_0_fieldsplit_0_)           1 MPI processes
            type: preonly
            using NONE norm type for convergence test
          PC Object:          (coupledsolve_fieldsplit_0_fieldsplit_0_)           1 MPI processes
            type: ml
              MG: type is MULTIPLICATIVE, levels=6 cycles=v
                Cycles per PCApply=1
                Using Galerkin computed coarse grid matrices
            Coarse grid solver -- level -------------------------------
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_0_mg_coarse_)               1 MPI processes
                type: preonly
                maximum iterations=1, initial guess is zero
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_0_mg_coarse_)               1 MPI processes
                type: lu
                  LU: out-of-place factorization
                  tolerance for zero pivot 2.22045e-14
                  using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
                  matrix ordering: nd
                  factor fill ratio given 5, needed 1
                    Factored matrix follows:
                      Mat Object:                       1 MPI processes
                        type: seqaij
                        rows=1, cols=1
                        package used to perform factorization: petsc
                        total: nonzeros=1, allocated nonzeros=1
                        total number of mallocs used during MatSetValues calls =0
                          not using I-node routines
                linear system matrix = precond matrix:
                  type: seqaij
                  rows=1, cols=1
            Down solver (pre-smoother) on level 1 -------------------------------
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_0_mg_levels_1_)               1 MPI processes
                type: richardson
                  Richardson: damping factor=1
                maximum iterations=2
                using nonzero initial guess
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_0_mg_levels_1_)               1 MPI processes
                type: sor
                  SOR: type = local_symmetric, iterations = 1, local iterations = 1, omega = 1
                  type: seqaij
                  rows=4, cols=4
                  total: nonzeros=16, allocated nonzeros=16
                    using I-node routines: found 1 nodes, limit used is 5
            Up solver (post-smoother) same as down solver (pre-smoother)
            Down solver (pre-smoother) on level 2 -------------------------------
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_0_mg_levels_2_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_0_mg_levels_2_)               1 MPI processes
                type: sor
                  type: seqaij
                  rows=105, cols=105
                  total: nonzeros=3963, allocated nonzeros=3963
            Down solver (pre-smoother) on level 3 -------------------------------
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_0_mg_levels_3_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_0_mg_levels_3_)               1 MPI processes
                type: sor
                  type: seqaij
                  rows=6667, cols=6667
                  total: nonzeros=356943, allocated nonzeros=356943
            Down solver (pre-smoother) on level 4 -------------------------------
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_0_mg_levels_4_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_0_mg_levels_4_)               1 MPI processes
                type: sor
                  type: seqaij
                  rows=263552, cols=263552
                  total: nonzeros=7.74159e+06, allocated nonzeros=7.74159e+06
            Down solver (pre-smoother) on level 5 -------------------------------
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_0_mg_levels_5_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_0_mg_levels_5_)               1 MPI processes
                type: sor
                Mat Object:                (coupledsolve_fieldsplit_0_fieldsplit_0_)                 1 MPI processes
                  type: seqaij
                  rows=2197000, cols=2197000
                  total: nonzeros=1.46816e+07, allocated nonzeros=1.46816e+07
              type: seqaij
          Split number 1 Fields  1
          KSP Object:          (coupledsolve_fieldsplit_0_fieldsplit_1_)           1 MPI processes
            type: preonly
          PC Object:          (coupledsolve_fieldsplit_0_fieldsplit_1_)           1 MPI processes
            type: ml
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_1_mg_coarse_)               1 MPI processes
                type: preonly
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_1_mg_coarse_)               1 MPI processes
                type: lu
                  matrix ordering: nd
                        type: seqaij
                        rows=1, cols=1
                  type: seqaij
                  rows=1, cols=1
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_1_mg_levels_1_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_1_mg_levels_1_)               1 MPI processes
                type: sor
                  type: seqaij
                  rows=4, cols=4
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_1_mg_levels_2_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_1_mg_levels_2_)               1 MPI processes
                type: sor
                  type: seqaij
                  rows=105, cols=105
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_1_mg_levels_3_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_1_mg_levels_3_)               1 MPI processes
                type: sor
                  type: seqaij
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_1_mg_levels_4_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_1_mg_levels_4_)               1 MPI processes
                type: sor
                  type: seqaij
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_1_mg_levels_5_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_1_mg_levels_5_)               1 MPI processes
                type: sor
                Mat Object:                (coupledsolve_fieldsplit_0_fieldsplit_1_)                 1 MPI processes
                  type: seqaij
              type: seqaij
          Split number 2 Fields  2
          KSP Object:          (coupledsolve_fieldsplit_0_fieldsplit_2_)           1 MPI processes
            type: preonly
          PC Object:          (coupledsolve_fieldsplit_0_fieldsplit_2_)           1 MPI processes
            type: ml
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_2_mg_coarse_)               1 MPI processes
                type: preonly
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_2_mg_coarse_)               1 MPI processes
                type: lu
                  matrix ordering: nd
                        type: seqaij
                        rows=1, cols=1
                  type: seqaij
                  rows=1, cols=1
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_2_mg_levels_1_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_2_mg_levels_1_)               1 MPI processes
                type: sor
                  type: seqaij
                  rows=4, cols=4
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_2_mg_levels_2_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_2_mg_levels_2_)               1 MPI processes
                type: sor
                  type: seqaij
                  rows=105, cols=105
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_2_mg_levels_3_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_2_mg_levels_3_)               1 MPI processes
                type: sor
                  type: seqaij
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_2_mg_levels_4_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_2_mg_levels_4_)               1 MPI processes
                type: sor
                  type: seqaij
              KSP Object:              (coupledsolve_fieldsplit_0_fieldsplit_2_mg_levels_5_)               1 MPI processes
                type: richardson
              PC Object:              (coupledsolve_fieldsplit_0_fieldsplit_2_mg_levels_5_)               1 MPI processes
                type: sor
                Mat Object:                (coupledsolve_fieldsplit_0_fieldsplit_2_)                 1 MPI processes
                  type: seqaij
              type: seqaij
        Mat Object:        (coupledsolve_fieldsplit_0_)         1 MPI processes
          type: seqaij
          rows=6591000, cols=6591000
          total: nonzeros=4.40448e+07, allocated nonzeros=4.40448e+07
    KSP solver for S = A11 - A10 inv(A00) A01
      KSP Object:      (coupledsolve_fieldsplit_1_)       1 MPI processes
        type: gmres
        tolerances:  relative=0.01, absolute=1e-50, divergence=10000
      PC Object:      (coupledsolve_fieldsplit_1_)       1 MPI processes
        type: ilu
          ILU: out-of-place factorization
          0 levels of fill
          matrix ordering: natural
          factor fill ratio given 1, needed 1
                type: seqaij
        linear system matrix followed by preconditioner matrix:
        Mat Object:        (coupledsolve_fieldsplit_1_)         1 MPI processes
          type: schurcomplement
            Schur complement A11 - A10 inv(A00) A01
            A11
                type: seqaij
            A10
                type: seqaij
                rows=2197000, cols=6591000
                total: nonzeros=4.37453e+07, allocated nonzeros=4.37453e+07
            KSP of A00
                type: gmres
                type: fieldsplit
                    type: preonly
                    type: ml
                        type: preonly
                        type: lu
                          matrix ordering: nd
                                type: seqaij
                                rows=1, cols=1
                          type: seqaij
                          rows=1, cols=1
                        type: richardson
                        type: sor
                          type: seqaij
                          rows=4, cols=4
                        type: richardson
                        type: sor
                          type: seqaij
                          rows=105, cols=105
                        type: richardson
                        type: sor
                          type: seqaij
                        type: richardson
                        type: sor
                          type: seqaij
                        type: richardson
                        type: sor
                          type: seqaij
                      type: seqaij
                    type: preonly
                    type: ml
                        type: preonly
                        type: lu
                          matrix ordering: nd
                                type: seqaij
                                rows=1, cols=1
                          type: seqaij
                          rows=1, cols=1
                        type: richardson
                        type: sor
                          type: seqaij
                          rows=4, cols=4
                        type: richardson
                        type: sor
                          type: seqaij
                          rows=105, cols=105
                        type: richardson
                        type: sor
                          type: seqaij
                        type: richardson
                        type: sor
                          type: seqaij
                        type: richardson
                        type: sor
                          type: seqaij
                      type: seqaij
                    type: preonly
                    type: ml
                        type: preonly
                        type: lu
                          matrix ordering: nd
                                type: seqaij
                                rows=1, cols=1
                          type: seqaij
                          rows=1, cols=1
                        type: richardson
                        type: sor
                          type: seqaij
                          rows=4, cols=4
                        type: richardson
                        type: sor
                          type: seqaij
                          rows=105, cols=105
                        type: richardson
                        type: sor
                          type: seqaij
                        type: richardson
                        type: sor
                          type: seqaij
                        type: richardson
                        type: sor
                          type: seqaij
                      type: seqaij
                  type: seqaij
            A01
                type: seqaij
                rows=6591000, cols=2197000
                  using I-node routines: found 2170168 nodes, limit used is 5
          type: seqaij
    type: seqaij
    rows=8788000, cols=8788000
    total: nonzeros=1.46217e+08, allocated nonzeros=1.46217e+08
