[petsc-users] VTK output
    Jed Brown
    jed at jedbrown.org
    Wed Feb  4 08:08:15 CST 2015
Sanjay Kharche <Sanjay.Kharche at manchester.ac.uk> writes:
> Dear All
> I am working through the various library dependencies to permit me to
> use the Petsc VTK output functions. Based on errors I saw (pasted
> below), I think I need a working VTK installation on my fedora 15
> before the PetscVTK functions will work - is this correct?
No.
> My preference is basic binary VTK in 2D and 3D, but ASCII will be good
> for manually checking also.
The ASCII VTK format has been deprecated by VTK since almost the
beginning of time.  Use an XML format (*.vts or *.vtr for DMDA).
DMPlex supports *.vtk for historical reasons, though only in serial.  If
you use DMPlex, you should write *.vtu.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150204/f1488575/attachment.pgp>
