[petsc-users] DMCreateGlobalVector and DMGetGlobalVector
bichinhoverde
bichinhoverde at spwinternet.com.br
Wed Feb 4 03:35:19 CST 2015
Got it. Thank you.
On Wed, Feb 4, 2015 at 7:25 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
> On Wednesday, 4 February 2015, bichinhoverde <
> bichinhoverde at spwinternet.com.br> wrote:
>> Ok, but from a PETSc user perspective, what is the difference between
>> create and get?
>> When should I use get and when should I use create?
> It's a memory saving optimization.
> It's a cache of vectors you can use. It's clever as it lets you reuse data
> rather always create/destroying objects.
>> Can I call create several times to create several vectors? Is it the same
>> as creating one and then duplicating?
>> Yes to both
>> Can I call get several times to get several vectors? Is it the same as
>> getting one and then duplicating?
> Functionally, both approaches are equivalent. However duplicating always
> allocated new memory thus the total memory footprint will increase.
>> If I replace all gets with creates, or all creates with gets in my code,
>> what will change?
> If you change all creates to gets, probably the most notable difference
> would be the memory usage. Plus whatever extra time is required for
> creating which isn't incurred when you re use vectors.
> Note that the DMGetVec will NOT initialize the entries to zero (unlike the
> Create variants). The user is responsible for that task.
>> On Wed, Feb 4, 2015 at 5:16 AM, Jed Brown <jed at jedbrown.org> wrote:
>>> bichinhoverde <bichinhoverde at spwinternet.com.br> writes:
>>> > Hi. I have some questions.
>>> > What is the difference between DMCreateGlobalVector and
>>> DMGetGlobalVector
>>> > (and the local counterparts)?
>>> Create creates a vector that the caller owns. Get merely gets access to
>>> a vector from a managed pool (creating it if necessary), to be returned
>>> via DMRestoreGlobalVector().
>>> > What happens when one calls SNESSolve with NULL for the solution
>>> vector, as
>>> > in src/snes/examples/tutorials/ex7.c:158? SNESSolve(snes,NULL,NULL);
>>> A vector is created automatically. You can get access to it with
>>> SNESGetSolution.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150204/181f3a79/attachment.html>
