[petsc-users] Transpose of rectangular dense parallel matrix
Ghosh, Swarnava
sghosh2012 at gatech.edu
Tue Feb 3 23:07:29 CST 2015
I am trying to calculate the transpose of a dense rectangular matrix (pSddft->YOrb, size=Npts x Nstates) and then MatMatMult
I am creating the dense matrix first of size (Nstates x Npts) and then doing an inplace transpose.
Both the dense rectangular matrices have the same parallel communicator PetscObjectComm((PetscObject)pSddft->da).
The following steps are the steps
PetscInt rowloc,colloc;
MatGetLocalSize(pSddft->YOrb,&rowloc,&colloc);
MatCreate(PetscObjectComm((PetscObject)pSddft->da),&pSddft->YOrbTranspose);
MatSetSizes(pSddft->YOrbTranspose,colloc,rowloc,PETSC_DETERMINE,PETSC_DETERMINE);
MatSetType(pSddft->YOrbTranspose,MATDENSE);
MatSetFromOptions(pSddft->YOrbTranspose);
MatSetUp(pSddft->YOrbTranspose);
MatTranspose(pSddft->YOrb,MAT_INITIAL_MATRIX,&pSddft->YOrbTranspose);
MatMatMultNumeric(pSddft->YOrbTranspose,HpsiMat,HsubDense);
The matrix HpsiMat has the same parallel communicator as pSddft->YOrb
The code works fine on 1 core but I am getting segmentation fault in the MatMatMultNumeric step for more than 1 cores.
So I think the problem is due to the way I am setting up the communicator of transpose matrix.
Could you please tell me if there is a general way of creating a transpose of a rectangular dense parallel matrix and use it for matrix matrix multiplication?
Swarnava Ghosh
PhD Candidate,
Structural Engineering, Mechanics and Materials
School of Civil and Environmental Engineering
Georgia Institute of Technology
Atlanta, GA 30332
