[petsc-users] SuperLU convergence problem (More test)
Danyang Su dsu at eos.ubc.ca
Tue Dec 8 20:37:20 CST 2015
Hi Hong,
Sorry to bother you again. The modified code works much better than
before using both superlu or mumps. However, it still encounters
failure. The case is similar with the previous one, ill-conditioned
matrices.
The code crashed after a long time simulation if I use superlu_dist, but
will not fail if use superlu. I restart the simulation before the time
it crashes and can reproduce the following error
  timestep:      22 time: 1.750E+04 years   delt: 2.500E+00 years iter:
1 max.sia: 5.053E-03 tol.sia: 1.000E-01
  Newton Iteration Convergence Summary:
  Newton       maximum      maximum     solver
  iteration    updatePa  updateTemp    residual    iterations maxvolpa
maxvoltemp   nexvolpa   nexvoltemp
      1       0.1531E+08 0.1755E+04   0.6920E-05        1 5585
4402        5814        5814
*** Error in `../program_test': malloc(): memory corruption:
0x0000000003a70d50 ***
Program received signal SIGABRT: Process abort signal.
Backtrace for this error:
The solver failed at timestep 22, Newton iteration 2. I exported the
matrices at timestep 1 (matrix 1) and timestep 22 (matrix 140 and 141).
Matrix 141 is where it failed.  The three matrices here are not
ill-conditioned form the estimated value.
I did the same using the new modified ex52f code and found pretty
different results for matrix 141. The norm by superlu is much acceptable
than superlu_dist. In this test, memory corruption was not detected. The
codes and example data can be download from the link below.
https://www.dropbox.com/s/i1ls0bg0vt7gu0v/petsc-superlu-test2.tar.gz?dl=0
****************More test on matrix_and_rhs_bin2*******************
mpiexec.hydra -n 1 ./ex52f -f0 ./matrix_and_rhs_bin2/a_flow_check_1.bin
-rhs ./matrix_and_rhs_bin2/b_flow_check_1.bin -loop_matrices flow_check
-loop_folder ./matrix_and_rhs_bin2 -matrix_index_start 140
-matrix_index_end 141  -pc_type lu -pc_factor_mat_solver_package superlu
-ksp_monitor_true_residual -mat_superlu_conditionnumber
  -->loac matrix a
  -->load rhs b
  size l,m,n,mm       90000       90000       90000       90000
   Recip. condition number = 6.000846e-16
   0 KSP preconditioned resid norm 1.146871454377e+08 true resid norm
4.711091037809e+03 ||r(i)||/||b|| 1.000000000000e+00
   1 KSP preconditioned resid norm 2.071118508260e-06 true resid norm
3.363767171515e-08 ||r(i)||/||b|| 7.140102249181e-12
Norm of error  3.3638E-08 iterations     1
  -->Test for matrix          140
   Recip. condition number = 2.256434e-27
   0 KSP preconditioned resid norm 2.084372893355e+14 true resid norm
   1 KSP preconditioned resid norm 4.689629276419e+00 true resid norm
1.037236635337e-01 ||r(i)||/||b|| 2.201690918330e-05
Norm of error  1.0372E-01 iterations     1
  -->Test for matrix          141
   Recip. condition number = 1.256452e-18
   0 KSP preconditioned resid norm 1.055488964519e+08 true resid norm
   1 KSP preconditioned resid norm 2.998827511681e-04 true resid norm
4.805214542776e-04 ||r(i)||/||b|| 1.019979130994e-07
Norm of error  4.8052E-04 iterations     1
  --> End of test, bye
superlu_dist
  -->loac matrix a
  -->load rhs b
Norm of error  3.6752E-08 iterations     1
Norm of error  1.6335E-01 iterations     1
Norm of error  3.4345E+01 iterations     1
Danyang
On 15-12-07 12:01 PM, Hong wrote:
> Danyang:
> Add 'call MatSetFromOptions(A,ierr)' to your code.
> Attached below is ex52f.F modified from your ex52f.F to be compatible
> with petsc-dev.
> Hong
>     Hello Hong,
>     Thanks for the quick reply and the option "-mat_superlu_dist_fact
>     SamePattern" works like a charm, if I use this option from the
>     command line.
>     How can I add this option as the default. I tried using
>     PetscOptionsInsertString("-mat_superlu_dist_fact
>     SamePattern",ierr) in my code but this does not work.
>     Thanks,
>     Danyang
>     On 15-12-07 10:42 AM, Hong wrote:
>>     Danyang :
>>     Adding '-mat_superlu_dist_fact SamePattern' fixed the problem.
>>     Below is how I figured it out.
>>     1. Reading ex52f.F, I see '-superlu_default' =
>>     '-pc_factor_mat_solver_package superlu_dist', the later enables
>>     runtime options for other packages. I use superlu_dist-4.2 and
>>     superlu-4.1 for the tests below.
>>     2. Use the Matrix 168 to setup KSP solver and factorization, all
>>     packages, petsc, superlu_dist and mumps give same correct results:
>>     ./ex52f -f0 matrix_and_rhs_bin/a_flow_check_168.bin -rhs
>>     matrix_and_rhs_bin/b_flow_check_168.bin -loop_matrices flow_check
>>     -loop_folder matrix_and_rhs_bin -pc_type lu
>>     -pc_factor_mat_solver_package petsc
>>      -->loac matrix a
>>      -->load rhs b
>>     Norm of error  7.7308E-11 iterations     1
>>      -->Test for matrix          168
>>      -->Test for matrix          172
>>     Norm of error  3.8461E-11 iterations     1
>>     Norm of error  9.4073E-11 iterations     1
>>     Norm of error  3.8187E-11 iterations     1
>>     3. Use superlu, I get
>>     Norm of error  1.0191E-06 iterations     1
>>     Norm of error  9.7858E-07 iterations     1
>>     Replacing default DiagPivotThresh: 1. to 0.0, I get same
>>     solutions as other packages:
>>     -mat_superlu_diagpivotthresh 0.0
>>     Norm of error  8.3614E-11 iterations     1
>>     Norm of error  3.7098E-11 iterations     1
>>     4.
>>     using '-mat_view ascii::ascii_info', I found that
>>     a_flow_check_1.bin and a_flow_check_168.bin seem have same structure:
>>      -->loac matrix a
>>     Mat Object: 1 MPI processes
>>       type: seqaij
>>       rows=90000, cols=90000
>>       total: nonzeros=895600, allocated nonzeros=895600
>>       total number of mallocs used during MatSetValues calls =0
>>         using I-node routines: found 45000 nodes, limit used is 5
>>     5.
>>     Using a_flow_check_1.bin, I am able to reproduce the error you
>>     reported: all packages give correct results except superlu_dist:
>>     ./ex52f -f0 matrix_and_rhs_bin/a_flow_check_1.bin -rhs
>>     Norm of error  2.5970E-12 iterations     1
>>     Norm of error  1.3936E-01 iterations    34
>>      -->Test for matrix          169
>>     I guess the error might come from reuse of matrix factor.
>>     Replacing default
>>     -mat_superlu_dist_fact <SamePattern_SameRowPerm> with
>>     -mat_superlu_dist_fact SamePattern, I get
>>     -pc_factor_mat_solver_package superlu_dist -mat_superlu_dist_fact
>>     SamePattern
>>     Norm of error  6.4303E-11 iterations     1
>>      -->Test for matrix          170
>>     Norm of error  7.4327E-11 iterations     1
>>      -->Test for matrix          171
>>     Norm of error  5.4162E-11 iterations     1
>>     Norm of error  3.4440E-11 iterations     1
>>     Sherry may tell you why SamePattern_SameRowPerm cause the
>>     difference here.
>>     Best on the above experiments, I would set following as default
>>     '-mat_superlu_diagpivotthresh 0.0' in petsc/superlu interface.
>>     '-mat_superlu_dist_fact SamePattern' in petsc/superlu_dist interface.
>>     Hong
>>         Hi Hong,
>>         I did more test today and finally found that the solution
>>         accuracy depends on the initial (first) matrix quality. I
>>         modified the ex52f.F to do the test. There are 6 matrices and
>>         right-hand-side vectors. All these matrices and rhs are from
>>         my reactive transport simulation. Results will be quite
>>         different depending on which one you use to do factorization.
>>         Results will also be different if you run with different
>>         options. My code is similar to the First or the Second test
>>         below. When the matrix is well conditioned, it works fine.
>>         But if the initial matrix is well conditioned, it likely to
>>         crash when the matrix become ill-conditioned. Since most of
>>         my case are well conditioned so I didn't detect the problem
>>         before. This case is a special one.
>>         How can I avoid this problem? Shall I redo factorization? Can
>>         PETSc automatically detect this prolbem or is there any
>>         option available to do this?
>>         All the data and test code (modified ex52f) can be found via
>>         the dropbox link below.
>>         _
>>         __https://www.dropbox.com/s/4al1a60creogd8m/petsc-superlu-test.tar.gz?dl=0_
>>         Summary of my test is shown below.
>>         First, use the Matrix 1 to setup KSP solver and
>>         factorization, then solve 168 to 172
>>         /home/dsu/work/petsc-superlu-test/matrix_and_rhs_bin/a_flow_check_1.bin
>>         -rhs
>>         /home/dsu/work/petsc-superlu-test/matrix_and_rhs_bin/b_flow_check_1.bin
>>         -loop_matrices flow_check -loop_folder
>>         /home/dsu/work/petsc-superlu-test/matrix_and_rhs_bin -pc_type
>>         lu -pc_factor_mat_solver_package superlu_dist
>>         Norm of error  3.8815E-11 iterations 1
>>         Norm of error  4.2307E-01 iterations 32
>>         Norm of error  3.0528E-01 iterations 32
>>         Norm of error  3.1177E-01 iterations 32
>>         Norm of error  3.2793E-01 iterations 32
>>         Norm of error  3.1251E-01 iterations 31
>>         Second, use the Matrix 1 to setup KSP solver and
>>         factorization using the implemented SuperLU relative codes. I
>>         thought this will generate the same results as the First
>>         test, but it actually not.
>>         -rhs
>>         -superlu_default
>>         Norm of error  2.2632E-12 iterations 1
>>         Norm of error  1.0817E+04 iterations 1
>>         Norm of error  1.0786E+04 iterations 1
>>         Norm of error  1.0792E+04 iterations 1
>>         Third, use the Matrix 168 to setup KSP solver and
>>         /home/dsu/work/petsc-superlu-test/matrix_and_rhs_bin/a_flow_check_168.bin
>>         -rhs
>>         /home/dsu/work/petsc-superlu-test/matrix_and_rhs_bin/b_flow_check_168.bin
>>         Norm of error  9.5528E-10 iterations 1
>>         Norm of error  9.4945E-10 iterations 1
>>         Norm of error  6.4279E-10 iterations 1
>>         Norm of error  7.4633E-10 iterations 1
>>         Norm of error  7.4863E-10 iterations 1
>>         Norm of error  8.9701E-10 iterations 1
>>         Fourth, use the Matrix 168 to setup KSP solver and
>>         thought this will generate the same results as the Third
>>         -rhs
>>         -superlu_default
>>         Norm of error  3.7017E-11 iterations 1
>>         Norm of error  3.6420E-11 iterations 1
>>         Norm of error  3.7184E-11 iterations 1
>>         Norm of error  3.6847E-11 iterations 1
>>         Norm of error  3.7883E-11 iterations 1
>>         Norm of error  3.8805E-11 iterations 1
>>         Thanks very much,
>>         Danyang
>>         On 15-12-03 01:59 PM, Hong wrote:
>>>         Danyang :
>>>         Further testing a_flow_check_168.bin,
>>>         ./ex10 -f0
>>>         /Users/Hong/Downloads/matrix_and_rhs_bin/a_flow_check_168.bin -rhs
>>>         /Users/Hong/Downloads/matrix_and_rhs_bin/x_flow_check_168.bin -pc_type
>>>         Recip. condition number = 1.610480e-12
>>>           0 KSP preconditioned resid norm 6.873340313547e+09 true
>>>         resid norm 7.295020990196e+03 ||r(i)||/||b|| 1.000000000000e+00
>>>           1 KSP preconditioned resid norm 2.051833296449e-02 true
>>>         resid norm 2.976859070118e-02 ||r(i)||/||b|| 4.080672384793e-06
>>>         Number of iterations =   1
>>>         Residual norm 0.0297686
>>>         condition number of this matrix = 1/1.610480e-12 = 1.e+12,
>>>         i.e., this matrix is ill-conditioned.
>>>         Hong
>>>             Hi Hong,
>>>             The binary format of matrix, rhs and solution can be
>>>             downloaded via the link below.
>>>             https://www.dropbox.com/s/cl3gfi0s0kjlktf/matrix_and_rhs_bin.tar.gz?dl=0
>>>             Thanks,
>>>             Danyang
>>>             On 15-12-03 10:50 AM, Hong wrote:
>>>>             Danyang:
>>>>                 To my surprising, solutions from SuperLU at
>>>>                 timestep 29 seems not correct for the first 4
>>>>                 Newton iterations, but the solutions from iteration
>>>>                 solver and MUMPS are correct.
>>>>                 Please find all the matrices, rhs and solutions at
>>>>                 timestep 29 via the link below. The data is a bit
>>>>                 large so that I just share it through Dropbox. A
>>>>                 piece of matlab code to read these data and then
>>>>                 computer the norm has also been attached.
>>>>                 _https://www.dropbox.com/s/rr8ueysgflmxs7h/results-check.tar.gz?dl=0_
>>>>             Can you send us matrix in petsc binary format?
>>>>             e.g., call MatView(M,
>>>>             PETSC_VIEWER_BINARY_(PETSC_COMM_WORLD))
>>>>             or '-ksp_view_mat binary'
>>>>             Hong
>>>>                 Below is a summary of the norm from the three
>>>>                 solvers at timestep 29, newton iteration 1 to 5.
>>>>                 Timestep 29
>>>>                 Norm of residual seq 1.661321e-09, superlu
>>>>                 1.657103e+04, mumps 3.731225e-11
>>>>                 Norm of residual seq 1.753079e-09, superlu
>>>>                 6.675467e+02, mumps 1.509919e-13
>>>>                 Norm of residual seq 4.914971e-10, superlu
>>>>                 1.236362e-01, mumps 2.139303e-17
>>>>                 Norm of residual seq 3.532769e-10, superlu
>>>>                 1.304670e-04, mumps 5.387000e-20
>>>>                 Norm of residual seq 3.885629e-10, superlu
>>>>                 2.754876e-07, mumps 4.108675e-21
>>>>                 Would anybody please check if SuperLU can solve
>>>>                 these matrices? Another possibility is that
>>>>                 something is wrong in my own code. But so far, I
>>>>                 cannot find any problem in my code since the same
>>>>                 code works fine if I using iterative solver or
>>>>                 direct solver MUMPS. But for other cases I have
>>>>                 tested, all these solvers work fine.
>>>>                 Please let me know if I did not write down the
>>>>                 problem clearly.
>>>>                 Thanks,
>>>>                 Danyang
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20151208/cb7d19ba/attachment-0001.html>
