[petsc-users] Increasing nodes doesn't decrease memory per node.
Jose E. Roman
jroman at dsic.upv.es
Sat Aug 29 02:55:35 CDT 2015
You are doing a spectrum slicing run (EPSSetInterval) with “size” partitions (EPSKrylovSchurSetPartitions), so every single process will be in charge of computing a subinterval. Each subcommunicator needs a redundant copy of the matrix, and in this case this copy is SeqAIJ since subcommunicators consist in just one process. You will probably need to share this memory across a set of processes and use MUMPS for the factorization. Try setting e.g. size/8 partitions.
Jose
> El 29/8/2015, a las 1:14, Barry Smith <bsmith at mcs.anl.gov> escribió:
> It is using a SeqAIJ matrix, not a parallel matrix. Increasing the number of cores won't affect the size of a sequential matrix since it must be stored entirely on one process. Perhaps you need to use parallel matrices?
> [1]PETSC ERROR: #4 MatDuplicate_SeqAIJ() line 4103 in /home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/mat/impls/aij/seq/aij.c
> [1]PETSC ERROR: #5 MatDuplicate() line 4252 in /home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/mat/interface/matrix.c
>> On Aug 28, 2015, at 4:13 PM, Hank Lamm <hanklammiv at gmail.com> wrote:
>> Hi All,
>> I am having a problem running Petsc3.6 and Slepc3.6 on Stampede. My code should be a simple eigenvalue solver, but when I attempt to solve large problems (8488x8488 matrices) I get errors:
>> --------------------- Error Message --------------------------------------------------------------
>> [1]Total space allocated 1736835920 bytes
>> [1]PETSC ERROR: Out of memory. This could be due to allocating
>> [1]PETSC ERROR: too large an object or bleeding by not properly
>> [1]PETSC ERROR: destroying unneeded objects.
>> [1]PETSC ERROR: Memory allocated 1736835920 Memory used by process 1769742336
>> [1]PETSC ERROR: [0]PETSC ERROR: Memory requested 864587796
>> [1]PETSC ERROR: [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
>> [1]PETSC ERROR: #8 STSetUp() line 305 in /work/03324/hlammiv/slepc-3.6.0/src/sys/classes/st/interface/stsolve.c
>> [1]PETSC ERROR: [0]PETSC ERROR: #1 MatDuplicateNoCreate_SeqAIJ() line 4030 in /home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/mat/impls/aij/seq/aij.c
>> [1]PETSC ERROR: #2 PetscTrMallocDefault() line 188 in /home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/sys/memory/mtr.c
>> [1]PETSC ERROR: #6 STMatMAXPY_Private() line 379 in /work/03324/hlammiv/slepc-3.6.0/src/sys/classes/st/interface/stsolve.c
>> [1]PETSC ERROR: #7 STSetUp_Sinvert() line 131 in /work/03324/hlammiv/slepc-3.6.0/src/sys/classes/st/impls/sinvert/sinvert.c
>> [1]PETSC ERROR: #9 EPSSliceGetInertia() line 295 in /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/ks-slice.c
>> [1]PETSC ERROR: #10 EPSSetUp_KrylovSchur_Slice() line 425 in /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/ks-slice.c
>> [1]PETSC ERROR: #11 EPSSetUp_KrylovSchur() line 89 in /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/krylovschur.c
>> [1]PETSC ERROR: #12 EPSSetUp() line 121 in /work/03324/hlammiv/slepc-3.6.0/src/eps/interface/epssetup.c
>> [1]PETSC ERROR: #13 EPSSliceGetEPS() line 267 in /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/ks-slice.c
>> [1]PETSC ERROR: #14 EPSSetUp_KrylovSchur_Slice() line 368 in /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/ks-slice.c
>> [1]PETSC ERROR: #15 EPSSetUp_KrylovSchur() line 89 in /work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/krylovschur.c
>> [1]PETSC ERROR: #16 EPSSetUp() line 121 in /work/03324/hlammiv/slepc-3.6.0/src/eps/interface/epssetup.c
>> [1]PETSC ERROR: #17 EPSSolve() line 88 in /work/03324/hlammiv/slepc-3.6.0/src/eps/interface/epssolve.c
>> [1]PETSC ERROR: #18 eigensolver() line 64 in /work/03324/hlammiv/TMSWIFT/src/solver.cpp
>> [1]Current space PetscMalloc()ed 1.73683e+09, max space PetscMalloced() 1.73684e+09
>> [1]Current process memory 1.76979e+09 max process memory 1.76979e+09
>> The curious thing about this error, is that it seems that if I increase the number of nodes, from 32 to 64 to 128, the amount of memory per node doesn't decrease. I have used valgrind and it doesn't seem to a memory leak.
>> The relevant code piece is:
>> void eigensolver(PetscErrorCode ierr, params *params, Mat &H, int argc, char **argv)
>> EPS eps; /* eigenproblem solver context */
>> EPSType type;
>> ST st;
>> KSP ksp;
>> PC pc;
>> PetscReal tol,error;
>> PetscReal lower,upper;
>> //PetscInt nev=dim,maxit,its;
>> PetscInt nev,maxit,its,nconv;
>> Vec xr,xi;
>> PetscScalar kr,ki;
>> PetscReal re,im;
>> PetscViewer viewer;
>> PetscInt rank;
>> PetscInt size;
>> std::string eig_file_n;
>> std::ofstream eig_file;
>> char ofile[100];
>> MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
>> MPI_Comm_size(PETSC_COMM_WORLD,&size);
>> ierr = PetscPrintf(PETSC_COMM_WORLD,"---Beginning Eigenvalue Solver---\n");CHKERRV(ierr);
>> ierr = EPSCreate(PETSC_COMM_WORLD,&eps);CHKERRV(ierr);
>> eig_file_n.append(params->ofile_n);
>> eig_file_n.append("_eval");
>> eig_file.open(eig_file_n.c_str(),std::ofstream::trunc);
>> //Set operators. In this case, it is a standard eigenvalue problem
>> ierr = EPSSetOperators(eps,H,NULL);CHKERRV(ierr);
>> ierr = EPSSetProblemType(eps,EPS_HEP);CHKERRV(ierr);
>> ierr = EPSSetType(eps,EPSKRYLOVSCHUR);CHKERRV(ierr);
>> ierr = EPSGetST(eps,&st);CHKERRV(ierr);
>> ierr = STSetType(st,STSINVERT);CHKERRV(ierr);
>> ierr = STGetKSP(st,&ksp);CHKERRV(ierr);
>> ierr = KSPSetType(ksp,KSPPREONLY);CHKERRV(ierr);
>> ierr = KSPGetPC(ksp,&pc);CHKERRV(ierr);
>> ierr = PCSetType(pc,PCCHOLESKY);CHKERRV(ierr);
>> ierr = EPSKrylovSchurSetPartitions(eps,size);CHKERRV(ierr);
>> for(PetscInt i=0;i<params->nf;i++){
>> lower=std::pow(2.0*params->m[i]-params->m[i]*params->alpha*params->alpha,2.0);
>> upper=4.0*params->m[i]*params->m[i];
>> ierr = EPSSetInterval(eps,lower,upper);
>> ierr = EPSSetWhichEigenpairs(eps,EPS_ALL);
>> //Set solver parameters at runtime
>> ierr = EPSSetFromOptions(eps);CHKERRV(ierr);
>> // ierr = EPSSetWhichEigenpairs(eps,EPS_SMALLEST_REAL);
>> ierr = MatCreateVecs(H,NULL,&xr);CHKERRV(ierr);
>> ierr = MatCreateVecs(H,NULL,&xi);CHKERRV(ierr);
>> ierr = EPSSolve(eps);CHKERRV(ierr);
>> ierr = EPSGetIterationNumber(eps,&its);CHKERRV(ierr);
>> ierr = PetscPrintf(PETSC_COMM_WORLD," Number of iterations of the method: %D\n",its);CHKERRV(ierr);
>> //Optional: Get some information from the solver and display it
>> ierr = EPSGetType(eps,&type);CHKERRV(ierr);
>> ierr = PetscPrintf(PETSC_COMM_WORLD," Solution method: %s\n\n",type);CHKERRV(ierr);
>> ierr = EPSGetDimensions(eps,&nev,NULL,NULL);CHKERRV(ierr);
>> ierr = PetscPrintf(PETSC_COMM_WORLD," Number of requested eigenvalues: %D\n",nev);CHKERRV(ierr);
>> ierr = EPSGetTolerances(eps,&tol,&maxit);CHKERRV(ierr);
>> ierr = PetscPrintf(PETSC_COMM_WORLD," Stopping condition: tol=%.4g, maxit=%D\n",tol,maxit);CHKERRV(ierr);
>> ierr = EPSGetConverged(eps,&nconv);CHKERRV(ierr);
>> ierr = PetscPrintf(PETSC_COMM_WORLD," Number of converged eigenpairs: %D\n\n",nconv);CHKERRV(ierr);
>> strcpy(ofile,params->ofile_n);
>> strcat(ofile,"_evecr");
>> ierr = PetscViewerASCIIOpen(PETSC_COMM_WORLD,ofile,&viewer);CHKERRV(ierr);
>> if (nconv>0)
>> " k ||Ax-kx||/||kx||\n"
>> " ----------------- ------------------\n");CHKERRV(ierr);
>> for (PetscInt i=0;i<nconv;i++)
>> //Get converged eigenpairs: i-th eigenvalue is stored in kr (real part) and ki (imaginary part)
>> ierr = EPSGetEigenpair(eps,i,&kr,&ki,xr,xi);CHKERRV(ierr);
>> //Compute the relative error associated to each eigenpair
>> ierr = EPSComputeError(eps,i,EPS_ERROR_RELATIVE,&error);CHKERRV(ierr);
>> #if defined(PETSC_USE_COMPLEX)
>> re = PetscRealPart(kr);
>> im = PetscImaginaryPart(kr);
>> #else
>> re = kr;
>> im = ki;
>> #endif
>> if (im!=0.0)
>> ierr = PetscPrintf(PETSC_COMM_WORLD," %9f%+9f j %12g\n",re,im,error);CHKERRV(ierr);
>> if(rank==0) eig_file << re << " " << im << " " << error << std::endl;
>> } else
>> ierr = PetscPrintf(PETSC_COMM_WORLD," %12f %12g\n",re,error);CHKERRV(ierr);
>> if(rank==0) eig_file << re << " " << 0 << " " << error << std::endl;
>> ierr = VecView(xr,viewer);CHKERRV(ierr);
>> ierr = PetscPrintf(PETSC_COMM_WORLD,"\n");CHKERRV(ierr);
>> eig_file.close();
>> ierr = EPSDestroy(&eps);CHKERRV(ierr);
>> ierr = PetscViewerDestroy(&viewer);CHKERRV(ierr);
>> ierr = VecDestroy(&xr);CHKERRV(ierr);
>> ierr = VecDestroy(&xi);CHKERRV(ierr);
>> ierr = PetscPrintf(PETSC_COMM_WORLD,"---Finishing Eigenvalue Solver---\n");CHKERRV(ierr);
>> Thanks,
>> Hank
