[petsc-users] Increasing nodes doesn't decrease memory per node.
Hank Lamm
hanklammiv at gmail.com
Fri Aug 28 16:13:56 CDT 2015
Hi All,
I am having a problem running Petsc3.6 and Slepc3.6 on Stampede. My code
should be a simple eigenvalue solver, but when I attempt to solve large
problems (8488x8488 matrices) I get errors:
--------------------- Error Message
[1]Total space allocated 1736835920 bytes
[1]PETSC ERROR: Out of memory. This could be due to allocating
[1]PETSC ERROR: too large an object or bleeding by not properly
[1]PETSC ERROR: destroying unneeded objects.
[1]PETSC ERROR: Memory allocated 1736835920 Memory used by process
1769742336
[1]PETSC ERROR: [0]PETSC ERROR: Memory requested 864587796
[1]PETSC ERROR: [0]PETSC ERROR: See
http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[1]PETSC ERROR: #8 STSetUp() line 305 in
/work/03324/hlammiv/slepc-3.6.0/src/sys/classes/st/interface/stsolve.c
[1]PETSC ERROR: [0]PETSC ERROR: #1 MatDuplicateNoCreate_SeqAIJ() line 4030
in /home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/mat/impls/aij/seq/aij.c
[1]PETSC ERROR: #2 PetscTrMallocDefault() line 188 in
/home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/sys/memory/mtr.c
[1]PETSC ERROR: #4 MatDuplicate_SeqAIJ() line 4103 in
[1]PETSC ERROR: #5 MatDuplicate() line 4252 in
/home1/apps/intel15/mvapich2_2_1/petsc/3.6/src/mat/interface/matrix.c
[1]PETSC ERROR: #6 STMatMAXPY_Private() line 379 in
[1]PETSC ERROR: #7 STSetUp_Sinvert() line 131 in
/work/03324/hlammiv/slepc-3.6.0/src/sys/classes/st/impls/sinvert/sinvert.c
[1]PETSC ERROR: #9 EPSSliceGetInertia() line 295 in
/work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/ks-slice.c
[1]PETSC ERROR: #10 EPSSetUp_KrylovSchur_Slice() line 425 in
[1]PETSC ERROR: #11 EPSSetUp_KrylovSchur() line 89 in
/work/03324/hlammiv/slepc-3.6.0/src/eps/impls/krylov/krylovschur/krylovschur.c
[1]PETSC ERROR: #12 EPSSetUp() line 121 in
/work/03324/hlammiv/slepc-3.6.0/src/eps/interface/epssetup.c
[1]PETSC ERROR: #13 EPSSliceGetEPS() line 267 in
[1]PETSC ERROR: #14 EPSSetUp_KrylovSchur_Slice() line 368 in
[1]PETSC ERROR: #15 EPSSetUp_KrylovSchur() line 89 in
[1]PETSC ERROR: #16 EPSSetUp() line 121 in
[1]PETSC ERROR: #17 EPSSolve() line 88 in
/work/03324/hlammiv/slepc-3.6.0/src/eps/interface/epssolve.c
[1]PETSC ERROR: #18 eigensolver() line 64 in
/work/03324/hlammiv/TMSWIFT/src/solver.cpp
[1]Current space PetscMalloc()ed 1.73683e+09, max space PetscMalloced()
1.73684e+09
[1]Current process memory 1.76979e+09 max process memory 1.76979e+09
The curious thing about this error, is that it seems that if I increase the
number of nodes, from 32 to 64 to 128, the amount of memory per node
doesn't decrease. I have used valgrind and it doesn't seem to a memory
leak.
The relevant code piece is:
void eigensolver(PetscErrorCode ierr, params *params, Mat &H, int argc,
char **argv)
EPS eps; /* eigenproblem solver context */
EPSType type;
ST st;
KSP ksp;
PC pc;
PetscReal tol,error;
PetscReal lower,upper;
//PetscInt nev=dim,maxit,its;
PetscInt nev,maxit,its,nconv;
Vec xr,xi;
PetscScalar kr,ki;
PetscReal re,im;
PetscViewer viewer;
PetscInt rank;
PetscInt size;
std::string eig_file_n;
std::ofstream eig_file;
char ofile[100];
MPI_Comm_rank(PETSC_COMM_WORLD,&rank);
MPI_Comm_size(PETSC_COMM_WORLD,&size);
ierr = PetscPrintf(PETSC_COMM_WORLD,"---Beginning Eigenvalue
Solver---\n");CHKERRV(ierr);
ierr = EPSCreate(PETSC_COMM_WORLD,&eps);CHKERRV(ierr);
eig_file_n.append(params->ofile_n);
eig_file_n.append("_eval");
eig_file.open(eig_file_n.c_str(),std::ofstream::trunc);
//Set operators. In this case, it is a standard eigenvalue problem
ierr = EPSSetOperators(eps,H,NULL);CHKERRV(ierr);
ierr = EPSSetProblemType(eps,EPS_HEP);CHKERRV(ierr);
ierr = EPSSetType(eps,EPSKRYLOVSCHUR);CHKERRV(ierr);
ierr = EPSGetST(eps,&st);CHKERRV(ierr);
ierr = STSetType(st,STSINVERT);CHKERRV(ierr);
ierr = STGetKSP(st,&ksp);CHKERRV(ierr);
ierr = KSPSetType(ksp,KSPPREONLY);CHKERRV(ierr);
ierr = KSPGetPC(ksp,&pc);CHKERRV(ierr);
ierr = PCSetType(pc,PCCHOLESKY);CHKERRV(ierr);
ierr = EPSKrylovSchurSetPartitions(eps,size);CHKERRV(ierr);
for(PetscInt i=0;i<params->nf;i++){
lower=std::pow(2.0*params->m[i]-params->m[i]*params->alpha*params->alpha,2.0);
upper=4.0*params->m[i]*params->m[i];
ierr = EPSSetInterval(eps,lower,upper);
ierr = EPSSetWhichEigenpairs(eps,EPS_ALL);
//Set solver parameters at runtime
ierr = EPSSetFromOptions(eps);CHKERRV(ierr);
// ierr = EPSSetWhichEigenpairs(eps,EPS_SMALLEST_REAL);
ierr = MatCreateVecs(H,NULL,&xr);CHKERRV(ierr);
ierr = MatCreateVecs(H,NULL,&xi);CHKERRV(ierr);
ierr = EPSSolve(eps);CHKERRV(ierr);
ierr = EPSGetIterationNumber(eps,&its);CHKERRV(ierr);
ierr = PetscPrintf(PETSC_COMM_WORLD," Number of iterations of the
method: %D\n",its);CHKERRV(ierr);
//Optional: Get some information from the solver and display it
ierr = EPSGetType(eps,&type);CHKERRV(ierr);
ierr = PetscPrintf(PETSC_COMM_WORLD," Solution method:
%s\n\n",type);CHKERRV(ierr);
ierr = EPSGetDimensions(eps,&nev,NULL,NULL);CHKERRV(ierr);
ierr = PetscPrintf(PETSC_COMM_WORLD," Number of requested
eigenvalues: %D\n",nev);CHKERRV(ierr);
ierr = EPSGetTolerances(eps,&tol,&maxit);CHKERRV(ierr);
ierr = PetscPrintf(PETSC_COMM_WORLD," Stopping condition: tol=%.4g,
maxit=%D\n",tol,maxit);CHKERRV(ierr);
ierr = EPSGetConverged(eps,&nconv);CHKERRV(ierr);
ierr = PetscPrintf(PETSC_COMM_WORLD," Number of converged eigenpairs:
%D\n\n",nconv);CHKERRV(ierr);
strcpy(ofile,params->ofile_n);
strcat(ofile,"_evecr");
ierr =
PetscViewerASCIIOpen(PETSC_COMM_WORLD,ofile,&viewer);CHKERRV(ierr);
if (nconv>0)
" k ||Ax-kx||/||kx||\n"
" ----------------- ------------------\n");CHKERRV(ierr);
for (PetscInt i=0;i<nconv;i++)
//Get converged eigenpairs: i-th eigenvalue is stored in kr
(real part) and ki (imaginary part)
ierr = EPSGetEigenpair(eps,i,&kr,&ki,xr,xi);CHKERRV(ierr);
//Compute the relative error associated to each eigenpair
ierr =
EPSComputeError(eps,i,EPS_ERROR_RELATIVE,&error);CHKERRV(ierr);
#if defined(PETSC_USE_COMPLEX)
re = PetscRealPart(kr);
im = PetscImaginaryPart(kr);
#else
re = kr;
im = ki;
#endif
if (im!=0.0)
ierr = PetscPrintf(PETSC_COMM_WORLD," %9f%+9f j
%12g\n",re,im,error);CHKERRV(ierr);
if(rank==0) eig_file << re << " " << im << " " << error <<
std::endl;
} else
ierr = PetscPrintf(PETSC_COMM_WORLD," %12f
%12g\n",re,error);CHKERRV(ierr);
if(rank==0) eig_file << re << " " << 0 << " " << error <<
std::endl;
ierr = VecView(xr,viewer);CHKERRV(ierr);
ierr = PetscPrintf(PETSC_COMM_WORLD,"\n");CHKERRV(ierr);
eig_file.close();
ierr = EPSDestroy(&eps);CHKERRV(ierr);
ierr = PetscViewerDestroy(&viewer);CHKERRV(ierr);
ierr = VecDestroy(&xr);CHKERRV(ierr);
ierr = VecDestroy(&xi);CHKERRV(ierr);
ierr = PetscPrintf(PETSC_COMM_WORLD,"---Finishing Eigenvalue
Hank
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150828/21052ec5/attachment.html>
