[petsc-users] pcfieldsplit for a composite dm with multiple subfields
Fri Aug 28 05:20:02 CDT 2015
On Thu, Aug 27, 2015 at 10:23 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Aug 27, 2015, at 10:15 PM, Gideon Simpson <gideon.simpson at gmail.com>
> wrote:
> > That’s correct, I am not using the SNESGetDM.  I suppose I could.  Keep
> in mind that I’m trying to solve, simultaneously, for the scalar parameters
> and the vector field.  I guess what I am unclear about is how DMRefine is
> to know that the unknown associated with the scalar parameters can never be
> coarsened out, but must be retained at all iterations.
>     Nothing ever gets coarsened in grid sequencing, it only gets refined.
>     The reason it knows not to "refine" the scalars is because the scalars
> are created with DMRedundant and the DMRedundant object knows that
> refinement means "leave as is, since there is no grid" while the DMDA knows
> it is a grid and knows how to refine itself. So when it "interpolates" the
> DMRedundant variables it just copies them (or multiples them by the matrix
> 1 which is just a copy).
I think you might be misunderstanding the "scalars" part. He is solving a
nonlinear eigenproblem (which he did not write down) for some variables.
Then he
uses those variable in the coupled diffusion equations he did write down.
He has wrapped the whole problem in a SNES with 2 parts: the nonlinear
eigenproblem
and the diffusion equations. He uses DMComposite to deal with all the
unknowns.
I think Nonlinear Block Gauss-Siedel on the different problems would be a
useful starting point, but we do not have that.
     Matt
> > Here is my form function.  I can send more code if needed.
>   Just change the user->packer that you use to be the DM obtained with
> SNESGetDM()
> > /* Form the system of equations for computing a blowup solution*/
> > PetscErrorCode form_function(SNES snes, Vec U, Vec F, void *ctx){
> >  blowup_ctx *user = (blowup_ctx *) ctx;
> >  PetscInt i;
> >  PetscScalar dx, dx2, xmax,x;
> >  PetscScalar u, v, f,g, ux, vx, uxx, vxx, fx,gx, fxx, gxx;
> >  DMDALocalInfo info;
> >  Vec p_vec, Q_vec, Fp_vec, FQ_vec;
> >  PetscScalar *p_array, *Fp_array;
> >  Q *Qvals, *FQvals;
> >  PetscScalar Q2sig, W2sig;
> >  PetscScalar a,a2, b, u0, sigma;
> >  dx = user->dx; dx2 = dx *dx;
> >  xmax = user->xmax;
> >  sigma = user->sigma;
> >  /* PetscPrintf(PETSC_COMM_SELF, " dx = %g, sigma = %g\n", dx, sigma);
> >  /* Extract raw arrays */
> >  DMCompositeGetLocalVectors(user->packer, &p_vec, &Q_vec);
> >  DMCompositeGetLocalVectors(user->packer, &Fp_vec, &FQ_vec);
> >  DMCompositeScatter(user->packer, U, p_vec, Q_vec);
> >  /* VecView(Q_vec,    PETSC_VIEWER_STDOUT_SELF); */
> >  VecGetArray(p_vec,&p_array);
> >  VecGetArray(Fp_vec,&Fp_array);
> >  DMDAVecGetArray(user->Q_dm, Q_vec, &Qvals);
> >  DMDAVecGetArray(user->Q_dm, FQ_vec, &FQvals);
> >  DMDAGetLocalInfo(user->Q_dm, &info);
> >  a = p_array[0]; a2 = a*a;
> >  b = p_array[1];
> >  u0 = p_array[2];
> >  /* Set boundary conditions at the origin*/
> >  if(info.xs ==0){
> >    set_origin_bcs(u0, Qvals);
> >  /* Set boundray conditions in the far field */
> >  if(info.xs+ info.xm == info.mx){
> >    set_farfield_bcs(xmax,sigma, a,  b,  dx, Qvals,info.mx);
> >  /* Solve auxiliary equations */
> >  if(info.xs ==0){
> >    uxx = (2 * Qvals[0].u-2 * u0)/dx2;
> >    vxx = (Qvals[0].v + Qvals[0].g)/dx2;
> >    vx = (Qvals[0].v - Qvals[0].g)/(2*dx);
> >    Fp_array[0] = Qvals[0].u - Qvals[0].f;
> >    Fp_array[1] = -vxx - (1/a) * (.5/sigma) * u0;
> >    Fp_array[2] = -uxx + (1/a2) * u0
> >      + (1/a) * (-b * vx + PetscPowScalar(u0 * u0, sigma) * vx);
> >  /* Solve equations in the bulk */
> >  for(i=info.xs; i < info.xs + info.xm;i++){
> >    u = Qvals[i].u;
> >    v = Qvals[i].v;
> >    f = Qvals[i].f;
> >    g = Qvals[i].g;
> >    x = (i+1) * dx;
> >    Q2sig = PetscPowScalar(u*u + v*v,sigma);
> >    W2sig= PetscPowScalar(f*f + g*g, sigma);
> >    ux = (Qvals[i+1].u-Qvals[i-1].u)/(2*dx);
> >    vx = (Qvals[i+1].v-Qvals[i-1].v)/(2*dx);
> >    fx = (Qvals[i+1].f-Qvals[i-1].f)/(2*dx);
> >    gx = (Qvals[i+1].g-Qvals[i-1].g)/(2*dx);
> >    uxx = (Qvals[i+1].u+Qvals[i-1].u - 2 *u)/(dx2);
> >    vxx = (Qvals[i+1].v+Qvals[i-1].v- 2 *v)/(dx2);
> >    fxx = (Qvals[i+1].f+Qvals[i-1].f -2*f)/(dx2);
> >    gxx = (Qvals[i+1].g+Qvals[i-1].g -2*g)/(dx2);
> >    FQvals[i].u = -uxx +1/a2 * u
> >      + 1/a *(.5/sigma* v +x * vx- b* vx +Q2sig* vx);
> >    FQvals[i].v = -vxx +1/a2 * v
> >      - 1/a *(.5/sigma * u +x * ux- b* ux +Q2sig* ux);
> >    FQvals[i].f = -fxx +1/a2 * f
> >      + 1/a *(.5/sigma * g +x * gx+ b* gx -W2sig* gx);
> >    FQvals[i].g =-gxx +1/a2 * g
> >      - 1/a *(.5/sigma * f +x * fx+ b* fx -W2sig* fx);
> >  /* Restore raw arrays */
> >  VecRestoreArray(p_vec, &p_array);
> >  VecRestoreArray(Fp_vec, &Fp_array);
> >  DMDAVecRestoreArray(user->Q_dm, Q_vec, &Qvals);
> >  DMDAVecRestoreArray(user->Q_dm, FQ_vec, &FQvals);
> >  DMCompositeGather(user->packer,F,INSERT_VALUES, Fp_vec, FQ_vec);
> >  DMCompositeRestoreLocalVectors(user->packer, &p_vec, &Q_vec);
> >  DMCompositeRestoreLocalVectors(user->packer, &Fp_vec, &FQ_vec);
> >  return 0;
> > Here is the form function:
> > -gideon
> >> On Aug 27, 2015, at 11:09 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >> Can you send the code, that will be the easiest way to find the problem.
> >>  My guess is that you have hardwired in your function/Jacobian
> computation the use of the original DM for computations instead of using
> the current DM (with refinement there will be a new DM on the second level
> different than your original DM). So what you need to do in writing your
> FormFunction and FormJacobian is to call SNESGetDM() to get the current DM
> and then use DMComputeGet... to access the individual DMDA and DMRedundent
> for the parts. I notice you have this user.Q_dm I bet inside your form
> functions you use this DM? You have to remove this logic.
> >> Barry
> >>> On Aug 27, 2015, at 9:42 PM, Gideon Simpson <gideon.simpson at gmail.com>
> wrote:
> >>> I have it set up as:
> >>>   DMCompositeCreate(PETSC_COMM_WORLD, &user.packer);
> >>>   DMRedundantCreate(PETSC_COMM_WORLD, 0, 3, &user.p_dm);
> >>>   DMCompositeAddDM(user.packer,user.p_dm);
> >>>   DMDACreate1d(PETSC_COMM_WORLD,DM_BOUNDARY_GHOSTED,
> >>>              nx, 4, 1, NULL, &user.Q_dm);
> >>>   DMCompositeAddDM(user.packer,user.Q_dm);
> >>>   DMCreateGlobalVector(user.packer,&U);
> >>> where the user.packer structure has
> >>> DM packer;
> >>> DM p_dm, Q_dm;
> >>> Q_dm holds the field variables and p_dm holds the scalar values (the
> nonlinear eigenvalues).
> >>> Here are some of the errors that are generated:
> >>> [0]PETSC ERROR: --------------------- Error Message
> >>> [0]PETSC ERROR: Argument out of range
> >>> [0]PETSC ERROR: New nonzero at (0,3) caused a malloc
> >>> Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to
> turn off this check
> >>> [0]PETSC ERROR: See
> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> >>> [0]PETSC ERROR: Petsc Release Version 3.5.3, unknown
> >>> [0]PETSC ERROR: ./blowup_batch2 on a arch-macports named gs_air by
> gideon Thu Aug 27 22:40:54 2015
> >>> [0]PETSC ERROR: Configure options --prefix=/opt/local
> --prefix=/opt/local/lib/petsc --with-valgrind=0 --with-shared-libraries
> --with-debugging=0 --with-c2html-dir=/opt/local --with-x=0
> --with-blas-lapack-lib=/System/Library/Frameworks/Accelerate.framework/Versions/Current/Accelerate
> --with-hwloc-dir=/opt/local --with-suitesparse-dir=/opt/local
> --with-superlu-dir=/opt/local --with-metis-dir=/opt/local
> --with-parmetis-dir=/opt/local --with-scalapack-dir=/opt/local
> --with-mumps-dir=/opt/local --with-superlu_dist-dir=/opt/local
> CC=/opt/local/bin/mpicc-mpich-mp CXX=/opt/local/bin/mpicxx-mpich-mp
> FC=/opt/local/bin/mpif90-mpich-mp F77=/opt/local/bin/mpif90-mpich-mp
> F90=/opt/local/bin/mpif90-mpich-mp COPTFLAGS=-Os CXXOPTFLAGS=-Os
> FOPTFLAGS=-Os LDFLAGS="-L/opt/local/lib -Wl,-headerpad_max_install_names"
> CPPFLAGS=-I/opt/local/include CFLAGS="-Os -arch x86_64" CXXFLAGS=-Os
> FFLAGS=-Os FCFLAGS=-Os F90FLAGS=-Os PETSC_ARCH=arch-macports
> --with-mpiexec=mpiexec-mpich-mp
> >>> [0]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 530 in
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.3/src/mat/impls/aij/mpi/mpiaij.c
> >>> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
> >>> [1]PETSC ERROR: Argument out of range
> >>> [1]PETSC ERROR: Inserting a new nonzero (40003, 0) into matrix
> >>> [1]PETSC ERROR: See
> >>> [1]PETSC ERROR: Petsc Release Version 3.5.3, unknown
> >>> [1]PETSC ERROR: ./blowup_batch2 on a arch-macports named gs_air by
> >>> [1]PETSC ERROR: Configure options --prefix=/opt/local
> >>> [1]PETSC ERROR: #1 MatSetValues_MPIAIJ() line 561 in
> >>> [1]PETSC ERROR: #2 MatSetValues() line 1135 in
> /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_petsc/petsc/work/v3.5.3/src/mat/interface/matrix.c
> >>> -gideon
> >>>> On Aug 27, 2015, at 10:37 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >>>> We need the full error message.
> >>>> But are you using a DMDA for the scalars?  You should not be, you
> should be using a DMRedundant for the scalars.
> >>>> Barry
> >>>> Though you should not get this error even if you are using a DMDA
> there.
> >>>>> On Aug 27, 2015, at 9:32 PM, Gideon Simpson <
> gideon.simpson at gmail.com> wrote:
> >>>>> I’m getting the following errors:
> >>>>> Could this have to do with me using the DMComposite with one da
> holding the scalar parameters and the other holding the field variables?
> >>>>> -gideon
> >>>>>> On Aug 27, 2015, at 10:15 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> >>>>>> On Thu, Aug 27, 2015 at 9:11 PM, Gideon Simpson <
> >>>>>> HI Barry,
> >>>>>> Nope, I’m not doing any grid sequencing. Clearly that makes a lot
> of sense, to solve on a spatially coarse mesh for the field variables,
> interpolate onto the finer mesh, and then solve again.  I’m not entirely
> clear on the practical implementation
> >>>>>> SNES should do this automatically using -snes_grid_sequence <k>.
> If this does not work, complain. Loudly.
> >>>>>> Matt
> >>>>>> -gideon
> >>>>>>> On Aug 27, 2015, at 10:02 PM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> >>>>>>> Gideon,
> >>>>>>> Are you using grid sequencing? Simply solve on a coarse grid,
> interpolate u1 and u2 to a once refined version of the grid and use that
> plus the mu lam as initial guess for the next level. Repeat to as fine a
> grid as you want. You can use DMRefine() and DMGetInterpolation() to get
> the interpolation needed to interpolate from the coarse to finer mesh.
> >>>>>>> Then and only then you can use multigrid (with or without
> fieldsplit) to solve the linear problems for finer meshes. Once you have
> the grid sequencing working we can help you with this.
> >>>>>>> Barry
> >>>>>>>> On Aug 27, 2015, at 7:00 PM, Gideon Simpson <
> >>>>>>>> I’m working on a problem which, morally, can be posed as a system
> of coupled semi linear elliptic PDEs together with unknown nonlinear
> eigenvalue parameters, loosely, of the form
> >>>>>>>> -\Delta u_1 + f(u_1, u_2) = lam * u1 - mu * du2/dx
> >>>>>>>> -\Delta u_2 + g(u_1, u_2) = lam * u2 + mu * du1/dx
> >>>>>>>> Currently, I have it set up with a DMComposite with two sub da’s,
> one for the parameters (lam, mu), and one for the vector field (u_1, u_2)
> on the mesh.  I have had success in solving this as a fully coupled system
> with SNES + sparse direct solvers (MUMPS, SuperLU).
> >>>>>>>> Lately, I am finding that, when the mesh resolution gets fine
> enough (i.e.  10^6-10^8 lattice points), my SNES gets stuck with the
> function norm = O(10^{-4}),  eventually returning reason -6 (failed line
> search).
> >>>>>>>> Perhaps there is another way around the above problem, but one
> thing I was thinking of trying would be to get away from direct solvers,
> and I was hoping to use field split for this.  However, it’s a bit beyond
> what I’ve seen examples for because it has 2 types of variables: scalar
> parameters which appear globally in the system and vector valued field
> variables.  Any suggestions on how to get started?
> >>>>>>>> -gideon
> >>>>>> What most experimenters take for granted before they begin their
> experiments lead.
> >>>>>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150828/2a0a8e43/attachment-0001.html>
