[petsc-users] Problem with linking PETSc
TAY wee-beng
zonexo at gmail.com
Thu Aug 27 01:05:59 CDT 2015
I used to compile and link using PETSc 3.6.0 + MPICH2 on VS2008.
Due to some MPICH2 issues, I am trying to use Intel MPI (newest
version). Building and testing of PETSc 3.6.1 with Intel MPI all went
smoothly.
However, I now have problem linking the files on VS2008 to create the
final exe. The error is:
/*1>Compiling manifest to resources...*//*
*//*1>Microsoft (R) Windows (R) Resource Compiler Version 6.0.5724.0*//*
*//*1>Copyright (C) Microsoft Corporation. All rights reserved.*//*
*//*1>Linking...*//*
*//*1>global.obj : error LNK2019: unresolved external symbol
MATCREATEAIJ referenced in function GLOBAL_DATA_mp_ALLO_VAR*//*
MATSETFROMOPTIONS referenced in function GLOBAL_DATA_mp_ALLO_VAR*//*
*//*1>PETSc_solvers.obj : error LNK2019: unresolved external symbol
VECGETARRAY referenced in function PETSC_SOLVERS_mp_P_MATRIX_SOLV_PETSC*//*
VECRESTOREARRAY referenced in function
DMLOCALTOLOCALBEGIN referenced in function
PETSC_SOLVERS_mp_DM_UPDATE_ARRAY*//*
DMLOCALTOLOCALEND referenced in function
*//*1>ibm3d_high_Re.obj : error LNK2019: unresolved external symbol
PETSCINITIALIZE referenced in function MAIN__*//*
*//*1>C:\Obj_tmp\ibm3d_IIB_mpi_old\Debug\ibm3d_IIB_mpi.exe : fatal error
LNK1120: 74 unresolved externals*//*
*//*1>*//*
*//*1>Build log written to
"file://C:\Obj_tmp\ibm3d_IIB_mpi_old\Debug\BuildLog.htm"*//*
*//*1>ibm3d_IIB_mpi_old - 165 error(s), 0 warning(s)*//*
*//*========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========*/
I did not do much changes since the prev PETSc worked. I only changed
the directory $(PETSC_DIR) and $(IMPI) to the new directory in win7
environment variables. I wonder what's wrong.
Thank you
Yours sincerely,
TAY wee-beng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150827/b9e85892/attachment-0001.html>
