[petsc-users] issues with sparse direct solvers
Hong
hzhang at mcs.anl.gov
Tue Aug 25 17:23:28 CDT 2015
Gideon :
> running with -mat_mumps_icntl_7 4 got it to run on problems that it
> couldn’t do before, thanks. How should I understand how this choice of
> flag is impacting whether or not it stalls?
Good to know that your code starts running :-)
I've never encountered hang with mumps. It turns that the hang occurred in
metis, which I rarely use.
Debugging what causes hang, I usually run code with a debugger, e.g. use
opiton '-start_in_debugger', when code hangs, hit control^C to see where it
hangs.
Hong
> On Aug 25, 2015, at 4:35 PM, Hong <hzhang at mcs.anl.gov> wrote:
> Gideon :
>> I ran with that flag because, while solving a SNES with MUMPS, the code
>> would just sit there as though it had died, and never seem to recover. I
>> tried using that flag just to determine where it had stalled, which was at
>> the "ordering based on METIS” bit.
> If you suspect METIS/ParMetis hangs,
> then turn to other sequential matrix orderings, e.g.,
> ' -mat_mumps_icntl_29 0 -mat_mumps_icntl_7 2', which I found the most
> robust ordering.
> Run your code with '-help |grep mumps', it will display mumps options.
> Hong
>> -gideon
>> On Aug 25, 2015, at 12:24 PM, Hong <hzhang at mcs.anl.gov> wrote:
>> Gideon:
>> -mat_mumps_icntl_4 <0>: ICNTL(4): level of printing (0 to 4) (None)
>> This is for algorithmic diagnosis, not for regular runs. Use default '0'
>> for it.
>> Hong
>> On Tue, Aug 25, 2015 at 9:06 AM, Gideon Simpson <gideon.simpson at gmail.com
>> > wrote:
>>> Regarding the MUMPS issue, I’m not sure if this is useful, but when I
>>> run with the mumps flags -mat_mumps_icntl_4 4, to see the progress, it
>>> hangs at this point:
>>> ... Structural symmetry (in percent)= 75
>>> Density: NBdense, Average, Median = 2 9 7
>>> Ordering based on METIS
>>> -gideon
>>> > On Aug 22, 2015, at 5:12 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>> >> On Aug 22, 2015, at 4:04 PM, Gideon Simpson <gideon.simpson at gmail.com>
>>> wrote:
>>> >> I’m having issues with both SuperLU dist and MUMPS, as compiled by
>>> PETsc, in the following sense:
>>> >> 1. For large enough systems, which seems to vary depending on which
>>> computer I’m on, MUMPS seems to just die and never start, when it’s used as
>>> the linear solver within a SNES. There’s no error message, it just sits
>>> there and doesn’t do anything.
>>> > You will need to use a debugger to figure out where it is "hanging";
>>> we haven't heard reports about this.
>>> >> 2. When running with SuperLU dist, I got the following error, with
>>> no further information:
>>> > The last release of SuperLU_DIST had some pretty nasty bugs, memory
>>> corruption that caused crashes etc. We think they are now fixed if you use
>>> the maint branch of the PETSc repository and --download-superlu_dist If
>>> you stick with the PETSc release and SuperLU_Dist you are using you will
>>> keep seeing these crashes
>>> > Barry
>>> >> [3]PETSC ERROR:
>>> >> [3]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>> probably memory access out of range
>>> >> [3]PETSC ERROR: Try option -start_in_debugger or
>>> -on_error_attach_debugger
>>> >> [3]PETSC ERROR: or see
>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
>>> >> [3]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>> Mac OS X to find memory corruption errors
>>> >> [3]PETSC ERROR: likely location of problem given in stack below
>>> >> [3]PETSC ERROR: --------------------- Stack Frames
>>> >> [3]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> >> [3]PETSC ERROR: INSTEAD the line number of the start of the
>>> function
>>> >> [3]PETSC ERROR: is given.
>>> >> [3]PETSC ERROR: [3] SuperLU_DIST:pdgssvx line 161
>>> /home/simpson/software/petsc-3.5.4/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c
>>> >> [3]PETSC ERROR: [3] MatSolve_SuperLU_DIST line 121
>>> >> [3]PETSC ERROR: [3] MatSolve line 3104
>>> /home/simpson/software/petsc-3.5.4/src/mat/interface/matrix.c
>>> >> [3]PETSC ERROR: [3] PCApply_LU line 194
>>> /home/simpson/software/petsc-3.5.4/src/ksp/pc/impls/factor/lu/lu.c
>>> >> [3]PETSC ERROR: [3] KSP_PCApplyBAorAB line 258
>>> /home/simpson/software/petsc-3.5.4/include/petsc-private/kspimpl.h
>>> >> [3]PETSC ERROR: --------------------- Error Message
>>> >> [3]PETSC ERROR: Signal received
>>> >> [3]PETSC ERROR: See
>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>> shooting.
>>> >> [3]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
>>> >> [3]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
>>> proteusi01 by simpson Sat Aug 22 17:01:41 2015
>>> >> [3]PETSC ERROR: Configure options
>>> --with-mpi-dir=/mnt/HA/opt/openmpi/intel/64/1.8.1-mlnx-ofed
>>> --with-blas-lib=/mnt/HA/opt/blas/gcc/64/20110419/libblas.a
>>> --with-lapack-lib=/liblapack.a --download-suitesparse=yes
>>> --download-superlu=yes --download-superlu_dist=yes --download-mumps=yes
>>> --download-metis=yes --download-parmetis=yes --download-scalapack=yes
>>> >> [3]PETSC ERROR: #1 User provided function() line 0 in unknown file
>>> >> MPI_ABORT was invoked on rank 3 in communicator MPI_COMM_WORLD
>>> >> with errorcode 59.
>>> >> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>> >> You may or may not see output from other processes, depending on
>>> >> exactly when Open MPI kills them.
>>> >> [proteusi01:14037] 1 more process has sent help message
>>> help-mpi-api.txt / mpi-abort
>>> >> [proteusi01:14037] Set MCA parameter "orte_base_help_aggregate" to 0
>>> to see all help / error messages
>>> >> [6]PETSC ERROR:
>>> >> [6]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>> the batch system) has told this process to end
>>> >> [6]PETSC ERROR: Try option -start_in_debugger or
>>> >> [6]PETSC ERROR: or see
>>> >> [6]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>> >> [6]PETSC ERROR: likely location of problem given in stack below
>>> >> [6]PETSC ERROR: --------------------- Stack Frames
>>> >> [6]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> >> [6]PETSC ERROR: INSTEAD the line number of the start of the
>>> function
>>> >> [6]PETSC ERROR: is given.
>>> >> [6]PETSC ERROR: [6] SuperLU_DIST:pdgssvx line 161
>>> >> [6]PETSC ERROR: [6] MatSolve_SuperLU_DIST line 121
>>> >> [6]PETSC ERROR: [6] MatSolve line 3104
>>> >> [6]PETSC ERROR: [6] PCApply_LU line 194
>>> >> [6]PETSC ERROR: [6] KSP_PCApplyBAorAB line 258
>>> >> [6]PETSC ERROR: --------------------- Error Message
>>> >> [6]PETSC ERROR: Signal received
>>> >> [6]PETSC ERROR: See
>>> shooting.
>>> >> [6]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
>>> >> [6]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
>>> >> [6]PETSC ERROR: Configure options
>>> >> [6]PETSC ERROR: #1 User provided function() line 0 in unknown file
>>> >> [7]PETSC ERROR:
>>> >> [7]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>> >> [7]PETSC ERROR: Try option -start_in_debugger or
>>> >> [7]PETSC ERROR: or see
>>> >> [7]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>> >> [7]PETSC ERROR: likely location of problem given in stack below
>>> >> [7]PETSC ERROR: --------------------- Stack Frames
>>> >> [7]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> >> [7]PETSC ERROR: INSTEAD the line number of the start of the
>>> function
>>> >> [7]PETSC ERROR: is given.
>>> >> [7]PETSC ERROR: [7] SuperLU_DIST:pdgssvx line 161
>>> >> [7]PETSC ERROR: [7] MatSolve_SuperLU_DIST line 121
>>> >> [7]PETSC ERROR: [7] MatSolve line 3104
>>> >> [7]PETSC ERROR: [7] PCApply_LU line 194
>>> >> [7]PETSC ERROR: [7] KSP_PCApplyBAorAB line 258
>>> >> [7]PETSC ERROR: --------------------- Error Message
>>> >> [7]PETSC ERROR: Signal received
>>> >> [7]PETSC ERROR: See
>>> shooting.
>>> >> [7]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
>>> >> [7]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
>>> >> [7]PETSC ERROR: Configure options
>>> >> [7]PETSC ERROR: #1 User provided function() line 0 in unknown file
>>> >> [0]PETSC ERROR:
>>> >> [0]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>> >> [0]PETSC ERROR: Try option -start_in_debugger or
>>> >> [0]PETSC ERROR: or see
>>> >> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>> >> [0]PETSC ERROR: likely location of problem given in stack below
>>> >> [0]PETSC ERROR: --------------------- Stack Frames
>>> >> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> >> [0]PETSC ERROR: INSTEAD the line number of the start of the
>>> function
>>> >> [0]PETSC ERROR: is given.
>>> >> [0]PETSC ERROR: [0] SuperLU_DIST:pdgssvx line 161
>>> >> [0]PETSC ERROR: [0] MatSolve_SuperLU_DIST line 121
>>> >> [0]PETSC ERROR: [0] MatSolve line 3104
>>> >> [0]PETSC ERROR: [0] PCApply_LU line 194
>>> >> [0]PETSC ERROR: [0] KSP_PCApplyBAorAB line 258
>>> >> [0]PETSC ERROR: --------------------- Error Message
>>> >> [0]PETSC ERROR: Signal received
>>> >> [0]PETSC ERROR: See
>>> shooting.
>>> >> [0]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
>>> >> [0]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
>>> >> [0]PETSC ERROR: Configure options
>>> >> [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
>>> >> [1]PETSC ERROR:
>>> >> [1]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>> >> [1]PETSC ERROR: Try option -start_in_debugger or
>>> >> [1]PETSC ERROR: or see
>>> >> [1]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>> >> [1]PETSC ERROR: likely location of problem given in stack below
>>> >> [1]PETSC ERROR: --------------------- Stack Frames
>>> >> [1]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> >> [1]PETSC ERROR: INSTEAD the line number of the start of the
>>> function
>>> >> [1]PETSC ERROR: is given.
>>> >> [1]PETSC ERROR: [1] SuperLU_DIST:pdgssvx line 161
>>> >> [1]PETSC ERROR: [1] MatSolve_SuperLU_DIST line 121
>>> >> [1]PETSC ERROR: [1] MatSolve line 3104
>>> >> [1]PETSC ERROR: [1] PCApply_LU line 194
>>> >> [1]PETSC ERROR: [1] KSP_PCApplyBAorAB line 258
>>> >> [1]PETSC ERROR: --------------------- Error Message
>>> >> [1]PETSC ERROR: Signal received
>>> >> [1]PETSC ERROR: See
>>> shooting.
>>> >> [1]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
>>> >> [1]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
>>> >> [1]PETSC ERROR: Configure options
>>> >> [1]PETSC ERROR: #1 User provided function() line 0 in unknown file
>>> >> [2]PETSC ERROR:
>>> >> [2]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>> >> [2]PETSC ERROR: Try option -start_in_debugger or
>>> >> [2]PETSC ERROR: or see
>>> >> [2]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>> >> [2]PETSC ERROR: likely location of problem given in stack below
>>> >> [2]PETSC ERROR: --------------------- Stack Frames
>>> >> [2]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> >> [2]PETSC ERROR: INSTEAD the line number of the start of the
>>> function
>>> >> [2]PETSC ERROR: is given.
>>> >> [2]PETSC ERROR: [2] SuperLU_DIST:pdgssvx line 161
>>> >> [2]PETSC ERROR: [2] MatSolve_SuperLU_DIST line 121
>>> >> [2]PETSC ERROR: [2] MatSolve line 3104
>>> >> [2]PETSC ERROR: [2] PCApply_LU line 194
>>> >> [2]PETSC ERROR: [2] KSP_PCApplyBAorAB line 258
>>> >> [2]PETSC ERROR: --------------------- Error Message
>>> >> [2]PETSC ERROR: Signal received
>>> >> [2]PETSC ERROR: See
>>> shooting.
>>> >> [2]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
>>> >> [2]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
>>> >> [2]PETSC ERROR: Configure options
>>> >> [2]PETSC ERROR: #1 User provided function() line 0 in unknown file
>>> >> [4]PETSC ERROR:
>>> >> [4]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>> >> [4]PETSC ERROR: Try option -start_in_debugger or
>>> >> [4]PETSC ERROR: or see
>>> >> [4]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>> >> [4]PETSC ERROR: likely location of problem given in stack below
>>> >> [4]PETSC ERROR: --------------------- Stack Frames
>>> >> [4]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> >> [4]PETSC ERROR: INSTEAD the line number of the start of the
>>> function
>>> >> [4]PETSC ERROR: is given.
>>> >> [4]PETSC ERROR: [4] SuperLU_DIST:pdgssvx line 161
>>> >> [4]PETSC ERROR: [4] MatSolve_SuperLU_DIST line 121
>>> >> [4]PETSC ERROR: [4] MatSolve line 3104
>>> >> [4]PETSC ERROR: [4] PCApply_LU line 194
>>> >> [4]PETSC ERROR: [4] KSP_PCApplyBAorAB line 258
>>> >> [4]PETSC ERROR: --------------------- Error Message
>>> >> [4]PETSC ERROR: Signal received
>>> >> [4]PETSC ERROR: See
>>> shooting.
>>> >> [4]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
>>> >> [4]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
>>> >> [4]PETSC ERROR: Configure options
>>> >> [4]PETSC ERROR: #1 User provided function() line 0 in unknown file
>>> >> [5]PETSC ERROR:
>>> >> [5]PETSC ERROR: Caught signal number 15 Terminate: Some process (or
>>> >> [5]PETSC ERROR: Try option -start_in_debugger or
>>> >> [5]PETSC ERROR: or see
>>> >> [5]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple
>>> >> [5]PETSC ERROR: likely location of problem given in stack below
>>> >> [5]PETSC ERROR: --------------------- Stack Frames
>>> >> [5]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>>> available,
>>> >> [5]PETSC ERROR: INSTEAD the line number of the start of the
>>> function
>>> >> [5]PETSC ERROR: is given.
>>> >> [5]PETSC ERROR: [5] SuperLU_DIST:pdgssvx line 161
>>> >> [5]PETSC ERROR: [5] MatSolve_SuperLU_DIST line 121
>>> >> [5]PETSC ERROR: [5] MatSolve line 3104
>>> >> [5]PETSC ERROR: [5] PCApply_LU line 194
>>> >> [5]PETSC ERROR: [5] KSP_PCApplyBAorAB line 258
>>> >> [5]PETSC ERROR: --------------------- Error Message
>>> >> [5]PETSC ERROR: Signal received
>>> >> [5]PETSC ERROR: See
>>> shooting.
>>> >> [5]PETSC ERROR: Petsc Release Version 3.5.4, May, 23, 2015
>>> >> [5]PETSC ERROR: ./blowup_batch2 on a arch-linux2-c-debug named
>>> >> [5]PETSC ERROR: Configure options
>>> >> [5]PETSC ERROR: #1 User provided function() line 0 in unknown file
>>> >> -gideon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150825/51d45f63/attachment-0001.html>
