[petsc-users] [petsc-user] intall problem when make test
Sun Aug 23 00:47:42 CDT 2015
As the message says - try running the examples manually. i.e
cd src/snes/examples/tutorials
make PETSC_DIR=/vol-th/home/taojj/luodong/sfwchombo/petsc/3.6.1 PETSC_ARCH=linux-dbg ex19 ex5f
yhrun -n 1 -t 30 -p TH_NET ./ex29
yhrun -n 1 -t 30 -p TH_NET ./ex5f
Satish
On Sat, 22 Aug 2015, 罗东 wrote:
> Dear all,
> I'm Luo Dong from Peking University in Beijing, China. I'm trying to intall the Petsc on my account on Tianhe supercomputer. But I met some problem. I have successfully make the build, but when I use make test, there is some error:
> [taojj at ln3%tianhe 3.6.1]$ make test
> Running test examples to verify correct installation
> Using PETSC_DIR=/vol-th/home/taojj/luodong/sfwchombo/petsc/3.6.1 and PETSC_ARCH=linux-dbg
> *mpiexec not found*. Please run src/snes/examples/tutorials/ex19 manually
> *******************Error detected during compile or link!*******************
> See http://www.mcs.anl.gov/petsc/documentation/faq.html
> /vol-th/home/taojj/luodong/sfwchombo/petsc/3.6.1/src/snes/examples/tutorials ex5f
> I don't know why thers is 'mpiexec not found'. I have use compilers mpicc, mpicxx, mpif90. On my account, I should use 'yhrun -n 1 -t 30 -p TH_NET' to submit a running work. I don't know if I should set some thing about this and where I should do that.
> I have attached the uname-a output below:
> [taojj at ln3%tianhe tutorials]$ uname -a
> Linux ln3 2.6.32-358.11.1.2.ky3.1.x86_64 #1 SMP Mon Jul 8 13:05:58 CST 2013 x86_64 x86_64 x86_64 GNU/Linux
> Please give me some help.
> Thanks for your help in advance.
> Best,
> Dong
