[petsc-users] GMRES -> PCMG -> PCASM pre- post- smoother
Aulisa, Eugenio
eugenio.aulisa at ttu.edu
Wed Aug 19 21:26:25 CDT 2015
I am solving an iteration of
where I build my particular ASM domain decomposition.
In setting the PCMG I would like at each level
to use the same pre- and post-smoother
and for this reason I am using
PCMGGetSmoother ( pcMG, level , &subksp );
to extract and set at each level the ksp object.
In setting PCASM then I use
KSPGetPC ( subksp, &subpc );
PCSetType ( subpc, PCASM );
and then set my own decomposition
PCASMSetLocalSubdomains(subpc,_is_loc_idx.size(),&_is_ovl[0],&_is_loc[0]);
Now everything compiles, and runs with no memory leakage,
but I do not get the expected convergence.
When I checked the output of -ksp_view, I saw something that puzzled me:
at each level >0, while in the MG pre-smoother the ASM domain decomposition
is the one that I set, for example with 4 processes I get
Down solver (pre-smoother) on level 2 -------------------------------
KSP Object: (level-2) 4 MPI processes
type: gmres
GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
GMRES: happy breakdown tolerance 1e-30
maximum iterations=1
using preconditioner applied to right hand side for initial guess
tolerances: relative=1e-12, absolute=1e-20, divergence=1e+50
left preconditioning
using nonzero initial guess
using NONE norm type for convergence test
PC Object: (level-2) 4 MPI processes
type: asm
Additive Schwarz: total subdomain blocks = 198, amount of overlap = 0
Additive Schwarz: restriction/interpolation type - RESTRICT
[0] number of local blocks = 52
[1] number of local blocks = 48
[2] number of local blocks = 48
[3] number of local blocks = 50
Local solve info for each block is in the following KSP and PC objects:
in the post-smoother I have the default ASM decomposition with overlapping 1:
Up solver (post-smoother) on level 2 -------------------------------
type: gmres
maximum iterations=2
type: asm
Additive Schwarz: total subdomain blocks = 4, amount of overlap = 1
Local solve is same for all blocks, in the following KSP and PC objects:
KSP Object: (level-2sub_) 1 MPI processes
type: preonly
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
So it seams that by using
I was capable to set both the pre- and post- smoothers to be PCASM
but everything I did after that applied only to the
pre-smoother, while the post-smoother got the default PCASM options.
I know that I can use
PCMGGetSmootherDown and PCMGGetSmootherUp, but that would
probably double the memory allocation and the computational time in the ASM.
Is there any way I can just use PCMGGetSmoother
and use the same PCASM in the pre- and post- smoother?
I hope I was clear enough.
Thanks a lot for your help,
Eugenio
