[petsc-users] superlu_dist output
    Satish Balay
    balay at mcs.anl.gov
    Mon Aug 17 15:37:49 CDT 2015
from superlu_dist README
      o -DPRNTlevel=[0,1,2,...]
      printing level to show solver's execution details. (default is 0)
      o -DDEBUGlevel=[0,1,2,...]
        diagnostic printing level for debugging purpose. (default is 0)
Presumably macports version of superlu_dist is built with these flags enabled.
cc:ing Sean to check if its an issue with macports superlu_dist package.
If you need to get rid of this output - you can build petsc from sources [with --download_superlu_dist]
Satish
On Mon, 17 Aug 2015, Gideon Simpson wrote:
> This is the macports version.  For me, this appears when running a problem with a linear solver with the flags
> -pc_factor_mat_solver_package superlu_dist -pc_type lu
> Nothing else is required.  The answer it gives is correct, I’d just like to suppress the output.
> -gideon
> > On Aug 17, 2015, at 4:14 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > How can we reproduce this? Is this using debian pkg install of petsc,
> > superlu_dist? [which versions?]
> > balay at es^/scratch/balay/petsc/src/ksp/ksp/examples/tutorials(maint=) $ $PETSC_DIR/bin/petscmpiexec -n 2 ./ex2 -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package superlu_dist
> > Norm of error 1.87427e-15 iterations 1
> > You can try installing our latest version using
> > --download-superlu_dist and see if you still have this issue.
> > Satish
> > Satish
> >> Is there a way to suppress this kind of output when running with superlu_dist?
> >> .. equilibrated? *equed = B
> >> .. LDPERM job 5	 time: 0.00
> >> .. anorm 3.541231e+01
> >> .. Use METIS ordering on A'+A
> >> .. symbfact(): relax   10, maxsuper   60, fill    4
> >> 	No of supers 73
> >> 	Size of G(L) 991
> >> 	Size of G(U) 722
> >> 	int 4, short 2, float 4, double 8
> >> 	SYMBfact (MB):	L\U 0.02	total 0.03	expansions 0
> >> .. # L blocks 228	# U blocks 211
> >> MPI tag upper bound = 536870911
> >> === using DAG ===
> >> * init: 1.779720e-04 seconds
> >> .. thresh = s_eps 0.000000e+00 * anorm 3.541231e+01 = 0.000000e+00
> >> .. Buffer size: Lsub 30	Lval 200	Usub 35	Uval 120	LDA 20
> >> 	NUMfact (MB) all PEs:	L\U	0.10	all	0.12
> >> 	All space (MB):		total	0.32	Avg	0.32	Max	0.32
> >> 	Number of tiny pivots:          0
> >> .. DiagScale = 3
> >> .. DiagScale = 3
> >> .. DiagScale = 3
> >> .. anorm 3.378641e+01
> >> -gideon
