[petsc-users] Petsc+Chombo example
Mani Chandra
mc0710 at gmail.com
Wed Aug 12 21:52:56 CDT 2015
Thanks for the information. I'm familiar with SNES+DMDA, just not sure it
would work with Chombo. But I'll give it a shot.
Cheers,
Mani
On Wed, Aug 12, 2015 at 5:56 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Wed, Aug 12, 2015 at 2:29 PM, Mani Chandra <mc0710 at gmail.com> wrote:
>> Hi,
>>> Chombo (me) creates an MPIAIJ matrix. So automatic Jacobian assembly
>>> should work.
>>> I have put a SNES in a Chombo code, but did not use automatic Jacobian
>>> assembly.
>> Do you have an example?
> If you want to make a SNES solver then you need an "apply" call back
> function and a way to map Chombo vectors with PETSc vectors.
> Chombo has a level solver (classes derived from PetscSolver) and an AMR
> composite matrix constructor class (classes derived from PetscCompGrid) in
> lib/src/AMRElliptic. These two class each create these maps, providing
> methods to "putChomboInPetsc", and so forth.
> lib/src/AMRElliptic/PetscSolverI.H has an apply_mfree() method that is a
> callback function that you give to PETSc to apply an operator. There are
> examples in Chombo on how to use/construct these two classes, or two
> installations of them. Each of these classes has a Poisson and a 2D
> Viscous Tensor instantiation.
> You probably want to look at PETSc SNES examples if you are not familiar
> with SNES to get an idea of what you need to provide. Then, look at the
> appropriate Chombo class as a place start. I am guessing that you will
> want to write your own solver and just use these classes to get these
> mapping methods. Wrapping a Chombo operator (apply) and solver in a SNES
> is not hard and PetscSolverI.H has examples.
> These codes only have one user each (and they are both ANAG staff
> members), so they are pretty immature codes.
> Mark
>> Thanks,
>> Mani
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150812/dcbe8be1/attachment.html>
