[petsc-users] SIGSEGV in Superlu_dist
Anthony Haas
aph at email.arizona.edu
Wed Aug 12 14:01:32 CDT 2015
Hi Hong,
I have attached a schematic of my matrices. I solve a generalized EVP in
shift-and-invert mode. As you will see, I have indeed a zero diagonal
block in the matrices A and B (blocks 4,4). I guess I could just add the
zero entries to the diagonal elements of A? Is that strictly necessary
when using a direct (LU) solver? Can you please give me a short
explanation of why empty diagonal blocks can be problematic?
Is the patch still available at:
https://bitbucket.org/petsc/petsc/commits/ceeba3afeff0c18262ed13ef92e2508ca68b0ecf
Thanks again,
Anthony
On 08/12/2015 08:58 AM, Hong wrote:
> Anthony,
> I just patched petsc-maint branch.
> Your matrix Amat_binary.m has empty diagonal blocks. Most petsc
> solvers require matrix diagonal entries to be allocated as 'non-zero',
> i.e., insert zero values to these zero entries. I would suggest you
> add zeros to Amat_binary.m during its buildup. This would enable
> petsc solvers, as well as other packages.
> Again, thanks for bug reporting.
> Hong
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150812/ef9e6881/attachment-0001.pdf>
