[petsc-users] checking jacobian
Gideon Simpson
gideon.simpson at gmail.com
Tue Aug 11 13:09:12 CDT 2015
I don’t see it listed in -help, but I do get
./blowup -xmax 50 -nx 1000 -snes_check_jacobian
Testing hand-coded Jacobian, if the ratio is O(1.e-8), the hand-coded Jacobian is probably correct.
Run with -snes_check_jacobian_view [viewer][:filename][:format] to show difference of hand-coded and finite difference Jacobian.
63386.1 = ||J - Jfd||//J|| 63386.1 = ||J - Jfd||
-gideon
> On Aug 11, 2015, at 2:07 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Aug 11, 2015 at 1:04 PM, Gideon Simpson <gideon.simpson at gmail.com <mailto:gideon.simpson at gmail.com>> wrote:
> Macports installation of 3.5.3.
> Use -help to find the option name. Maybe its -snes_test.
> Thanks,
> Matt
> -gideon
>> On Aug 11, 2015, at 2:03 PM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>> On Tue, Aug 11, 2015 at 12:51 PM, Gideon Simpson <gideon.simpson at gmail.com <mailto:gideon.simpson at gmail.com>> wrote:
>> #End of PETSc Option Table entries
>> There is one unused database option. It is:
>> Option left: name:-snes_check_jacobian_view (no value)
>> This is the option for the newest release. What are you using?
>> Matt
>> -gideon
>>> On Aug 11, 2015, at 1:50 PM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>> On Tue, Aug 11, 2015 at 12:49 PM, Gideon Simpson <gideon.simpson at gmail.com <mailto:gideon.simpson at gmail.com>> wrote:
>>> Maybe it’s a quirk of the macports installation of petsc, but nothing seems to be getting generated.
>>> Run with -options_left. Is it reading the option?
>>> Matt
>>> -gideon
>>>> On Aug 11, 2015, at 1:40 PM, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
>>>> Gideon Simpson <gideon.simpson at gmail.com <mailto:gideon.simpson at gmail.com>> writes:
>>>>> I’m a bit confused by the following options:
>>>>> What flags do I pass it to get some output to diagnose my Jacobian error?
>>>> Nothing to display ASCII to the screen. You might use
>>>> "binary:thematrix" if you want to read it in with Python or MATLAB, for
>>>> example.
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>> -- Norbert Wiener
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150811/49bf6800/attachment.html>
