[petsc-users] SIGSEGV in Superlu_dist
Anthony Haas aph at email.arizona.edu
Tue Aug 11 13:08:22 CDT 2015
Hi Hong,
Sorry for my late reply and thanks for the fix. Does that mean that I
will be able to run that matrix on 10 procs in the future (petsc 3.6.2?)?
Thanks
Anthony
On 08/11/2015 09:58 AM, Hong wrote:
> Anthony,
> I pushed a fix
> https://bitbucket.org/petsc/petsc/commits/ceeba3afeff0c18262ed13ef92e2508ca68b0ecf
> Once it passes our nightly tests, I'll merge it to petsc-maint, then
> petsc-dev.
> Thanks for reporting it!
> Hong
> On Mon, Aug 10, 2015 at 4:27 PM, Barry Smith <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>> wrote:
>       Anthony,
>        This crash is in PETSc code before it calls the SuperLU_DIST
>     numeric factorization; likely we have a mistake such as assuming a
>     process has at least one row of the matrix and need to fix it.
>        Barry
>     > 0x00007fe6ba609297 in MatLUFactorNumeric_SuperLU_DIST (F=0x1922b50,
>     >    A=0x14a6a70, info=0x19099f8)
>     >    at
>     /home/anthony/LIB/petsc-3.6.1/src/mat/impls/aij/mpi/superlu_dist/superlu_dist.c:368
>     > 368           colA_start = rstart + ajj[0]; /* the smallest
>     global col index of A */
>     > On Aug 10, 2015, at 3:50 PM, Anthony Haas <aph at email.arizona.edu
>     <mailto:aph at email.arizona.edu>> wrote:
>     > Hi Sherry,
>     > I recently submitted a matrix for which I noticed that
>     Superlu_dist was hanging when running on 4 processors with
>     parallel symbolic factorization. I have been using the latest
>     version of Superlu_dist and the code is not hanging anymore.
>     However, I noticed that when running the same matrix (I have
>     attached the matrix), the code crashes with the following SIGSEGV
>     when running on 10 procs (with or without parallel symbolic
>     factorization). It is probably overkill to run such a 'small'
>     matrix on 10 procs but I thought that it might still be useful to
>     report the problem?? See below for the error obtained when running
>     with gdb and also a code snippet to reproduce the error.
>     > Thanks,
>     > Anthony
>     > 1) ERROR in GDB
>     > Program received signal SIGSEGV, Segmentation fault.
>     >    at
>     > (gdb)
>     > 2) PORTION OF CODE TO REPRODUCE ERROR
>     >    Subroutine HowBigLUCanBe(rank)
>     >      IMPLICIT NONE
>     >      integer(i4b),intent(in) :: rank
>     >      integer(i4b)            :: i,ct
>     >      real(dp)                :: begin,endd
>     >      complex(dpc)            :: sigma
>     >      PetscErrorCode ierr
>     >      if (rank==0) call cpu_time(begin)
>     >      if (rank==0) then
>     >         write(*,*)
>     >         write(*,*)'Testing How Big LU Can Be...'
>     >         write(*,*)'============================'
>     >         write(*,*)
>     >      endif
>     >      !sigma = (1.0d0,0.0d0)
>     >      !call MatAXPY(A,-sigma,B,DIFFERENT_NONZERO_PATTERN,ierr) !
>     on exit A = A-sigma*B
>     >      !call MatView(A,PETSC_VIEWER_STDOUT_WORLD,ierr)
>     > !.....Write Matrix to ASCII and Binary Format
>     >      !call
>     PetscViewerASCIIOpen(PETSC_COMM_WORLD,"Amat.m",viewer,ierr)
>     >      !call MatView(DXX,viewer,ierr)
>     >      !call PetscViewerDestroy(viewer,ierr)
>     >      !call
>     PetscViewerBinaryOpen(PETSC_COMM_WORLD,"Amat_binary.m",FILE_MODE_WRITE,viewer,ierr)
>     >      !call MatView(A,viewer,ierr)
>     > !...Load a Matrix in Binary Format
>     >      call
>     PetscViewerBinaryOpen(PETSC_COMM_WORLD,"Amat_binary.m",FILE_MODE_READ,viewer,ierr)
>     >      call MatCreate(PETSC_COMM_WORLD,DLOAD,ierr)
>     >      call MatSetType(DLOAD,MATAIJ,ierr)
>     >      call MatLoad(DLOAD,viewer,ierr)
>     >      !call MatView(DLOAD,PETSC_VIEWER_STDOUT_WORLD,ierr)
>     > !.....Create Linear Solver Context
>     >      call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
>     > !.....Set operators. Here the matrix that defines the linear
>     system also serves as the preconditioning matrix.
>     >      !call
>     KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr) !aha
>     commented and replaced by next line
>     >      !call KSPSetOperators(ksp,A,A,ierr) ! remember: here A =
>     A-sigma*B
>     >      call KSPSetOperators(ksp,DLOAD,DLOAD,ierr) ! remember: here
>     A = A-sigma*B
>     > !.....Set Relative and Absolute Tolerances and Uses Default for
>     Divergence Tol
>     >      tol = 1.e-10
>     >      call
>     KSPSetTolerances(ksp,tol,tol,PETSC_DEFAULT_REAL,PETSC_DEFAULT_INTEGER,ierr)
>     > !.....Set the Direct (LU) Solver
>     >      call KSPSetType(ksp,KSPPREONLY,ierr)
>     >      call KSPGetPC(ksp,pc,ierr)
>     >      call PCSetType(pc,PCLU,ierr)
>     >      call
>     PCFactorSetMatSolverPackage(pc,MATSOLVERSUPERLU_DIST,ierr) !
>     MATSOLVERSUPERLU_DIST MATSOLVERMUMPS
>     > !.....Create Right-Hand-Side Vector
>     >      !call MatCreateVecs(A,frhs,PETSC_NULL_OBJECT,ierr)
>     >      !call MatCreateVecs(A,sol,PETSC_NULL_OBJECT,ierr)
>     >      call MatCreateVecs(DLOAD,frhs,PETSC_NULL_OBJECT,ierr)
>     >      call MatCreateVecs(DLOAD,sol,PETSC_NULL_OBJECT,ierr)
>     >      call
>     MatGetOwnershipRange(DLOAD,IstartA,IendA,ierr)!;CHKERRQ(ierr)
>     >      allocate(xwork1(IendA-IstartA))
>     >      allocate(loc(IendA-IstartA))
>     >      ct=0
>     >      do i=IstartA,IendA-1
>     >         ct=ct+1
>     >         loc(ct)=i
>     >         xwork1(ct)=(1.0d0,0.0d0)
>     >      enddo
>     >      call
>     VecSetValues(frhs,IendA-IstartA,loc,xwork1,INSERT_VALUES,ierr)
>     >      call VecZeroEntries(sol,ierr)
>     >      deallocate(xwork1,loc)
>     > !.....Assemble Vectors
>     >      call VecAssemblyBegin(frhs,ierr)
>     >      call VecAssemblyEnd(frhs,ierr)
>     > !.....Solve the Linear System
>     >      call KSPSolve(ksp,frhs,sol,ierr)
>     >      !call VecView(sol,PETSC_VIEWER_STDOUT_WORLD,ierr)
>     >      if (rank==0) then
>     >         call cpu_time(endd)
>     >         write(*,*)
>     >         print '("Total time for HowBigLUCanBe = ",f21.3,"
>     seconds.")',endd-begin
>     >      endif
>     >      call SlepcFinalize(ierr)
>     >      STOP
>     >    end Subroutine HowBigLUCanBe
>     > <Amat_binary.m.info <http://Amat_binary.m.info>>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150811/76555f38/attachment-0001.html>
