[petsc-users] checking jacobian
Jed Brown
jed at jedbrown.org
Tue Aug 11 12:40:40 CDT 2015
Gideon Simpson <gideon.simpson at gmail.com> writes:
> I’m a bit confused by the following options:
> Run with -snes_check_jacobian_view [viewer][:filename][:format] to show difference of hand-coded and finite difference Jacobian.
> What flags do I pass it to get some output to diagnose my Jacobian error?
Nothing to display ASCII to the screen. You might use
"binary:thematrix" if you want to read it in with Python or MATLAB, for
example.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150811/b43a91d9/attachment.pgp>
