[petsc-users] I am wondering if there is a way to implement SPMM
Hong
hzhang at mcs.anl.gov
Thu Aug 6 10:20:42 CDT 2015
Cong:
> Hong,
> Sure.
> I want to extend the Krylov subspace by step_k dimensions by using
> monomial, which can be defined as
> K={Km(1)m Km(2), ..., Km(step_k)}
> ={Km(1), AKm(1), AKm(2), ... , AKm(step_k-1)}
> ={R, AR, A^2R, ... A^(step_k-1)R}
A subspace with dense matrices as basis?
How large step_k and your matrices will be?
Hong
> On Thu, Aug 6, 2015 at 12:23 PM, Hong <hzhang at mcs.anl.gov> wrote:
>> Cong,
>> Can you write out math equations for mpk_monomial (),
>> list input and output parameters.
>> Note:
>> 1. MatDuplicate() does not need to be followed by MatAssemblyBegin/End
>> 2. MatMatMult(A,Km(stepIdx-1),MAT_REUSE_MATRIX,..) must be called after
>> MatMatMult(A,Km(stepIdx-1),MAT_INITIAL_MATRIX,..)
>> Hong
>> On Wed, Aug 5, 2015 at 8:56 PM, Cong Li <solvercorleone at gmail.com> wrote:
>>> The entire source code files are attached.
>>> Also I copy and paste the here in this email
>>> thanks
>>> program test
>>> implicit none
>>> #include <finclude/petscsys.h>
>>> #include <finclude/petscvec.h>
>>> #include <finclude/petscmat.h>
>>> #include <finclude/petscviewer.h>
>>> PetscViewer :: view
>>> ! sparse matrix
>>> Mat :: A
>>> ! distributed dense matrix of size n x m
>>> Mat :: B, X, R, QDlt, AQDlt
>>> ! distributed dense matrix of size n x (m x k)
>>> Mat :: Q, K, AQ_p, AQ
>>> ! local dense matrix (every process keep the identical copies), (m x
>>> k) x (m x k)
>>> Mat :: AConjPara, QtAQ, QtAQ_p, Dlt
>>> PetscInt :: nDim, mDim, rhsNDim,rhsMDim,ierr, maxIter, iter,
>>> step_k,bsize
>>> PetscInt :: ownRowS,ownRowE
>>> PetscScalar, allocatable :: XInit(:,:)
>>> PetscInt :: XInitI, XInitJ
>>> PetscScalar :: v=1.0
>>> PetscBool :: flg
>>> PetscMPIInt :: size, rank
>>> character(128) :: fin, rhsfin
>>> call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
>>> call MPI_Comm_size(PETSC_COMM_WORLD,size,ierr)
>>> call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
>>> ! read binary matrix file
>>> call PetscOptionsGetString(PETSC_NULL_CHARACTER,'-f',fin,flg,ierr)
>>> call PetscOptionsGetString(PETSC_NULL_CHARACTER,'-r',rhsfin,flg,ierr)
>>> call PetscOptionsGetInt(PETSC_NULL_CHARACTER,'-i',maxIter,flg,ierr)
>>> call PetscOptionsGetInt(PETSC_NULL_CHARACTER,'-k',step_k,flg,ierr)
>>> call PetscOptionsGetInt(PETSC_NULL_CHARACTER,'-w',bsize,flg,ierr)
>>> call
>>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,fin,FILE_MODE_READ,view,ierr)
>>> call MatCreate(PETSC_COMM_WORLD,A,ierr)
>>> call MatSetType(A,MATAIJ,ierr)
>>> call MatLoad(A,view,ierr)
>>> call PetscViewerDestroy(view,ierr)
>>> ! for the time being, assume mDim == nDim is true
>>> call MatGetSize(A, nDim, mDim, ierr)
>>> if (rank == 0) then
>>> print*,'Mat Size = ', nDim, mDim
>>> end if
>>> call MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatGetOwnershipRange(A,ownRowS,ownRowE, ierr)
>>> ! create right-and-side matrix
>>> ! for the time being, choose row-wise decomposition
>>> ! for the time being, assume nDim%size = 0
>>> call MatCreateDense(PETSC_COMM_WORLD, (ownRowE - ownRowS), &
>>> bsize, nDim, bsize,PETSC_NULL_SCALAR, B, ierr)
>>> call
>>> PetscViewerBinaryOpen(PETSC_COMM_WORLD,rhsfin,FILE_MODE_READ,view, ierr)
>>> call MatLoad(B,view,ierr)
>>> call MatGetSize(B, rhsMDim, rhsNDim, ierr)
>>> if (rank == 0) then
>>> print*,'MRHS Size actually are:', rhsMDim, rhsNDim
>>> print*,'MRHS Size should be:', nDim, bsize
>>> end if
>>> call MatAssemblyBegin(B, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd(B, MAT_FINAL_ASSEMBLY, ierr)
>>> ! inintial value guses X
>>> allocate(XInit(nDim,bsize))
>>> do XInitI=1, nDim
>>> do XInitJ=1, bsize
>>> XInit(XInitI,XInitJ) = 1.0
>>> end do
>>> end do
>>> bsize, nDim, bsize,XInit, X, ierr)
>>> call MatAssemblyBegin(X, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd (X, MAT_FINAL_ASSEMBLY, ierr)
>>> ! B, X, R, QDlt, AQDlt
>>> call MatDuplicate(B, MAT_DO_NOT_COPY_VALUES, R, ierr)
>>> call MatAssemblyBegin(R, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd (R, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatDuplicate(B, MAT_DO_NOT_COPY_VALUES, QDlt, ierr)
>>> call MatAssemblyBegin(QDlt, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd (QDlt, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatDuplicate(B, MAT_DO_NOT_COPY_VALUES, AQDlt, ierr)
>>> call MatAssemblyBegin(AQDlt, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd (AQDlt, MAT_FINAL_ASSEMBLY, ierr)
>>> ! Q, K, AQ_p, AQ of size n x (m x k)
>>> (bsize*step_k), nDim,
>>> (bsize*step_k),PETSC_NULL_SCALAR, Q, ierr)
>>> call MatAssemblyBegin(Q, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd(Q, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatDuplicate(Q, MAT_DO_NOT_COPY_VALUES, K, ierr)
>>> call MatAssemblyBegin(K, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd(K, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatDuplicate(Q, MAT_DO_NOT_COPY_VALUES, AQ_p, ierr)
>>> call MatAssemblyBegin(AQ_p, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd(AQ_p, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatDuplicate(Q, MAT_DO_NOT_COPY_VALUES, AQ, ierr)
>>> call MatAssemblyBegin(AQ, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd(AQ, MAT_FINAL_ASSEMBLY, ierr)
>>> ! QtAQ, QtAQ_p, Dlt of size (m x k) x (m x k)
>>> call MatCreateSeqDense(PETSC_COMM_SELF,(bsize*step_k),(bsize*step_k),&
>>> PETSC_NULL_SCALAR, QtAQ, ierr)
>>> call MatAssemblyBegin(QtAQ, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd (QtAQ, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatDuplicate(QtAQ, MAT_DO_NOT_COPY_VALUES, QtAQ_p , ierr)
>>> call MatAssemblyBegin(QtAQ_p, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd (QtAQ_p, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatDuplicate(QtAQ, MAT_DO_NOT_COPY_VALUES, Dlt , ierr)
>>> call MatAssemblyBegin(Dlt, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd (Dlt, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatDuplicate(QtAQ, MAT_DO_NOT_COPY_VALUES, AConjPara , ierr)
>>> call MatAssemblyBegin(AConjPara, MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd (AConjPara, MAT_FINAL_ASSEMBLY, ierr)
>>> ! calculation for R
>>> ! call matrix powers kernel
>>> call mpk_monomial (K, A, R, step_k, rank,size)
>>> ! destory matrices
>>> deallocate(XInit)
>>> call MatDestroy(B, ierr)
>>> call MatDestroy(X, ierr)
>>> call MatDestroy(R, ierr)
>>> call MatDestroy(QDlt, ierr)
>>> call MatDestroy(AQDlt, ierr)
>>> call MatDestroy(Q, ierr)
>>> call MatDestroy(K, ierr)
>>> call MatDestroy(AQ_p, ierr)
>>> call MatDestroy(AQ, ierr)
>>> call MatDestroy(QtAQ, ierr)
>>> call MatDestroy(QtAQ_p, ierr)
>>> call MatDestroy(Dlt, ierr)
>>> call PetscFinalize(ierr)
>>> stop
>>> end program test
>>> subroutine mpk_monomial (K, A, R, step_k, rank, sizeMPI)
>>> implicit none
>>> Mat :: K, Km(step_k)
>>> Mat :: A, R
>>> PetscMPIInt :: sizeMPI, rank
>>> PetscInt :: nDim, bsize, step_k, local_RRow, local_RCol, genIdx
>>> PetscInt :: ierr
>>> PetscInt :: stepIdx, blockShift, localRsize
>>> PetscScalar :: KArray(1), RArray(1), PetscScalarSize
>>> PetscOffset :: KArrayOffset, RArrayOffset
>>> call MatGetSize(R, nDim, bsize, ierr)
>>> if (rank == 0) then
>>> print*,'Mat Size = ', nDim, bsize
>>> end if
>>> call MatGetArray(K,KArray,KArrayOffset,ierr)
>>> call MatGetLocalSize(R,local_RRow,local_RCol)
>>> ! print *, "local_RRow,local_RCol", local_RRow,local_RCol
>>> ! get arry from R to add values to K(1)
>>> call MatGetArray(R,RArray,RArrayOffset,ierr)
>>> call MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, &
>>> PETSC_DECIDE , nDim, bsize,KArray(KArrayOffset +
>>> 1), Km(1), ierr)
>>> ! call PetscMemmove(KArray(KArrayOffset + 1),RArray(RArrayOffset + 1) &
>>> ! ,local_RRow * local_RCol *
>>> STORAGE_SIZE(PetscScalarSize), ierr)
>>> localRsize = local_RRow * local_RCol
>>> do genIdx= 1, localRsize
>>> KArray(KArrayOffset + genIdx) = RArray(RArrayOffset + genIdx)
>>> end do
>>> call MatRestoreArray(R,RArray,RArrayOffset,ierr)
>>> call MatAssemblyBegin(Km(1), MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd (Km(1), MAT_FINAL_ASSEMBLY, ierr)
>>> do stepIdx= 2, step_k
>>> blockShift = KArrayOffset + (stepIdx-1) * (local_RRow * local_RCol)
>>> PETSC_DECIDE , nDim, bsize,KArray(blockShift+1),
>>> Km(stepIdx), ierr)
>>> call MatAssemblyBegin(Km(stepIdx), MAT_FINAL_ASSEMBLY, ierr)
>>> call MatAssemblyEnd (Km(stepIdx), MAT_FINAL_ASSEMBLY, ierr)
>>> end do
>>> call MatRestoreArray(K,KArray,KArrayOffset,ierr)
>>> ! do stepIdx= 2, step_k
>>> do stepIdx= 2,2
>>> call
>>> MatMatMult(A,Km(stepIdx-1),MAT_REUSE_MATRIX,PETSC_DEFAULT_INTEGER,Km(stepIdx),
>>> ierr)
>>> ! call
>>> MatMatMult(A,Km(stepIdx-1),MAT_INITIAL_MATRIX,PETSC_DEFAULT_INTEGER,Km(stepIdx),
>>> ierr)
>>> end do
>>> ! call MatView(K,PETSC_VIEWER_STDOUT_WORLD,ierr)
>>> end subroutine mpk_monomial
>>> Cong Li
>>> On Thu, Aug 6, 2015 at 3:30 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> Send the entire code so that we can compile it and run it ourselves
>>>> to see what is going wrong.
>>>> Barry
>>>> > On Aug 5, 2015, at 4:42 AM, Cong Li <solvercorleone at gmail.com> wrote:
>>>> > Hi
>>>> > I tried the method you suggested. However, I got the error message.
>>>> > My code and message are below.
>>>> > K is the big matrix containing column matrices.
>>>> > code:
>>>> bsize,KArray(KArrayOffset + 1), Km(1), ierr)
>>>> > end do
>>>> local_RCol)
>>>> bsize,KArray(blockShift+1), Km(stepIdx), ierr)
>>>> > end do
>>>> > call
>>>> ierr)
>>>> > end do
>>>> > And I got the error message as below:
>>>> > [0]PETSC ERROR:
>>>> > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>> probably memory access out of range
>>>> > [0]PETSC ERROR: Try option -start_in_debugger or
>>>> -on_error_attach_debugger
>>>> > [0]PETSC ERROR: or see
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC
>>>> ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to
>>>> find memory corruption errors
>>>> > [0]PETSC ERROR: configure using --with-debugging=yes, recompile,
>>>> link, and run
>>>> > [0]PETSC ERROR: to get more information on the crash.
>>>> > [0]PETSC ERROR: --------------------- Error Message
>>>> > [0]PETSC ERROR: Signal received!
>>>> > [0]PETSC ERROR:
>>>> > [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 7, Sat May 11
>>>> 22:15:24 CDT 2013
>>>> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>> > [0]PETSC ERROR: See docs/index.html for manual pages.
>>>> > [0]PETSC ERROR: --------------------[1]PETSC ERROR:
>>>> > [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>> > [0]PETSC ERROR: ./kmath.bcbcg on a arch-fuji named p01-024 by a03293
>>>> Wed Aug 5 18:24:40 2015
>>>> > [0]PETSC ERROR: Libraries linked from
>>>> /volume1/home/ra000005/a03293/kmathlibbuild/petsc-3.3-p7/arch-fujitsu-sparc64fx-opt/lib
>>>> > [0]PETSC ERROR: Configure run at Tue Jul 28 19:23:51 2015
>>>> > [0]PETSC ERROR: Configure options --known-level1-dcache-size=32768
>>>> --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0
>>>> --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8
>>>> --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8
>>>> --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8
>>>> --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=8
>>>> --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1
>>>> --known-mpi-c-double-complex=1 --with-cc=mpifccpx --CFLAGS="-mt -Xg"
>>>> --COPTFLAGS=-Kfast,openmp --with-cxx=mpiFCCpx --CXXFLAGS=-mt
>>>> --CXXOPTFLAGS=-Kfast,openmp --with-fc=mpifrtpx --FFLAGS=-Kthreadsafe
>>>> --FOPTFLAGS=-Kfast,openmp --with-blas-lapack-lib="-SCALAPACK -SSL2"
>>>> --with-x=0 --with-c++-support --with-batch=1 --with-info=1
>>>> --with-debugging=0 --known-mpi-shared-libraries=0 --with-valgrind=0
>>>> > [0]PETSC ERROR:
>>>> > [0]PETSC ERROR: User provided function() line 0 in unknown directory
>>>> unknown file
>>>> > [mpi::mpi-api::mpi-abort]
>>>> > MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>>> > with errorcode 59.
>>>> > NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>>> > You may or may not see output from other processes, depending on
>>>> > exactly when Open MPI kills them.
>>>> > [p01-024:26516]
>>>> /opt/FJSVtclang/GM-1.2.0-18/lib64/libmpi.so.0(orte_errmgr_base_error_abort+0x84)
>>>> [0xffffffff0091f684]
>>>> > [p01-024:26516]
>>>> /opt/FJSVtclang/GM-1.2.0-18/lib64/libmpi.so.0(ompi_mpi_abort+0x51c)
>>>> [0xffffffff006c389c]
>>>> > [p01-024:26516]
>>>> /opt/FJSVtclang/GM-1.2.0-18/lib64/libmpi.so.0(MPI_Abort+0x6c)
>>>> [0xffffffff006db3ac]
>>>> > [p01-024:26516]
>>>> /opt/FJSVtclang/GM-1.2.0-18/lib64/libtrtmet_c.so.1(MPI_Abort+0x2c)
>>>> [0xffffffff00281bf0]
>>>> > [p01-024:26516] ./kmath.bcbcg [0x1bf620]
>>>> > [p01-024:26516] ./kmath.bcbcg [0x1bf20c]
>>>> > [p01-024:26516] /lib64/libc.so.6(killpg+0x48) [0xffffffff02d52600]
>>>> > [p01-024:26516] [(nil)]
>>>> > [p01-024:26516] ./kmath.bcbcg [0x1a2054]
>>>> > [p01-024:26516] ./kmath.bcbcg [0x1064f8]
>>>> > [p01-024:26516] ./kmath.bcbcg(MAIN__+0x9dc) [0x105d1c]
>>>> > [p01-024:26516] ./kmath.bcbcg(main+0xec) [0x8a329c]
>>>> > [p01-024:26516] /lib64/libc.so.6(__libc_start_main+0x194)
>>>> [0xffffffff02d3b81c]
>>>> > [p01-024:26516] ./kmath.bcbcg [0x1051ec]
>>>> > [0]PETSC ERROR:
>>>> > [0]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or
>>>> the batch system) has told this process to end
>>>> link, and run
>>>> > [0]PETSC ERROR:
>>>> 22:15:24 CDT 2013
>>>> > [0]PETSC ERROR:
>>>> > [0]PETSC ERROR:
>>>> unknown file
>>>> > [ERR.] PLE 0019 plexec One of MPI processes was
>>>> aborted.(rank=0)(nid=0x020a0028)(CODE=1938,793745140674134016,15104)
>>>> > However, if I change from
>>>> > call
>>>> ierr)
>>>> > to
>>>> > call MatMatMult(A,Km(stepIdx-1),
>>>> MAT_INITIAL_MATRIX,PETSC_DEFAULT_INTEGER,Km(stepIdx), ierr)
>>>> > everything is fine.
>>>> > could you please suggest some way to solve this?
>>>> > Thanks
>>>> > Cong Li
>>>> > On Wed, Aug 5, 2015 at 10:53 AM, Cong Li <solvercorleone at gmail.com>
>>>> wrote:
>>>> > Thank you very much for your help and suggestions.
>>>> > With your help, finally I could continue my project.
>>>> > Regards
>>>> > Cong Li
>>>> > On Wed, Aug 5, 2015 at 3:09 AM, Barry Smith <bsmith at mcs.anl.gov>
>>>> wrote:
>>>> > From the manual page: Unless scall is MAT_REUSE_MATRIX C will be
>>>> created.
>>>> > Since you want to use the C that is passed in you should use
>>>> MAT_REUSE_MATRIX.
>>>> > Note that since your B and C matrices are dense the issue of
>>>> sparsity pattern of C is not relevant.
>>>> > Barry
>>>> > > On Aug 4, 2015, at 11:59 AM, Cong Li <solvercorleone at gmail.com>
>>>> wrote:
>>>> > > Thanks very much. This answer is very helpful.
>>>> > > And I have a following question.
>>>> > > If I create B1, B2, .. by the way you suggested and then use
>>>> MatMatMult to do SPMM.
>>>> > > PetscErrorCode MatMatMult(Mat A,Mat B,MatReuse scall,PetscReal
>>>> fill,Mat *C)
>>>> > > should I use MAT_REUSE_MATRIX for MatReuse part of the arguement.
>>>> > > Thanks
>>>> > > Cong Li
>>>> > > On Wed, Aug 5, 2015 at 1:27 AM, Barry Smith <bsmith at mcs.anl.gov>
>>>> wrote:
>>>> > > > On Aug 4, 2015, at 4:09 AM, Cong Li <solvercorleone at gmail.com>
>>>> wrote:
>>>> > > > I am sorry that I should have explained it more clearly.
>>>> > > > Actually I want to compute a recurrence.
>>>> > > > Like, I want to firstly compute A*X1=B1, and then calculate
>>>> A*B1=B2, A*B2=B3 and so on.
>>>> > > > Finally I want to combine all these results into a bigger matrix
>>>> C=[B1,B2 ...]
>>>> > > First create C with MatCreateDense(,&C). Then call
>>>> MatDenseGetArray(C,&array); then create B1 with
>>>> MatCreateDense(....,array,&B1); then create
>>>> > > B2 with MatCreateDense(...,array+shift,&B2) etc where shift equals
>>>> the number of __local__ rows in B1 times the number of columns in B1, then
>>>> create B3 with a larger shift etc.
>>>> > > Note that you are "sharing" the array space of C with B1, B2,
>>>> B3, ..., each Bi contains its columns of the C matrix.
>>>> > > Barry
>>>> > > > Is there any way to do this efficiently.
>>>> > > > On Tue, Aug 4, 2015 at 5:45 PM, Patrick Sanan <
>>>> patrick.sanan at gmail.com> wrote:
>>>> > > > On Tue, Aug 04, 2015 at 03:42:14PM +0900, Cong Li wrote:
>>>> > > > > Thanks for your reply.
>>>> > > > > I have an other question.
>>>> > > > > I want to do SPMM several times and combine result matrices
>>>> into one bigger
>>>> > > > > matrix.
>>>> > > > > for example
>>>> > > > > I firstly calculate AX1=B1, AX2=B2 ...
>>>> > > > > then I want to combine B1, B2.. to get a C, where C=[B1,B2...]
>>>> > > > > Could you please suggest a way of how to do this.
>>>> > > > This is just linear algebra, nothing to do with PETSc
>>>> specifically.
>>>> > > > A * [X1, X2, ... ] = [AX1, AX2, ...]
>>>> > > > > Thanks
>>>> > > > > Cong Li
>>>> > > > > On Tue, Aug 4, 2015 at 3:27 PM, Jed Brown <jed at jedbrown.org>
>>>> wrote:
>>>> > > > > > Cong Li <solvercorleone at gmail.com> writes:
>>>> > > > > > > Hello,
>>>> > > > > > > I am a PhD student using PETsc for my research.
>>>> > > > > > > I am wondering if there is a way to implement SPMM (Sparse
>>>> matrix-matrix
>>>> > > > > > > multiplication) by using PETSc.
>>>> http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatMatMult.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150806/f6814aaa/attachment-0001.html>
