[petsc-users] I am wondering if there is a way to implement SPMM
Cong Li
solvercorleone at gmail.com
Wed Aug 5 11:50:59 CDT 2015
Hong,
A is a sparse matrix.
In the first loop, I don't use Km(stepIdx) here. However, I want to let Km(stepIdx) matrix be associated with the some of columns of K here. In the second loop, I want to update Km(stepIdx) by using A*Km(stepIdx-1) so that the corresponding columns of K can be updated simultaneously .
If I use MAT_INITIAL_MATRIX, I guess I have to copy the values of updated Km(stepIdx) back to the corresponding columns of K after SPMM call. But this copy phrase costs bandwidth, I think.
Do you have any idea by which I can do SPMM as well as remove the copy phrase.
Thanks
Cong Li
iPhoneから送信
2015/08/06 0:28、Hong <hzhang at mcs.anl.gov> のメッセージ:
> Cong,
> For the first loop:
> do stepIdx= 2, step_k
> blockShift = KArrayOffset + (stepIdx-1) * (local_RRow * local_RCol)
> call MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, &
> PETSC_DECIDE , nDim, bsize,KArray(blockShift+1), Km(stepIdx), ierr)
> end do
> Do you use Km(stepIdx) here?
> If not, replace MatCreateDense() with
> MatMatMult(A,Km(stepIdx-1),.MAT_INITIAL_MATRIX,..).
> Is matrix A dense or sparse?
> Hong
>> On Wed, Aug 5, 2015 at 9:43 AM, Cong Li <solvercorleone at gmail.com> wrote:
>> Hong,
>> Thanks for your answer.
>> However, in my problem, I have a pre-allocated matrix K, and its columns are associated with Km(1), .. Km(step_k) respectively. What I want to do is to update Km(2) by using the result of A*Km(1), and then to update Km(3) by using the product of A and updated Km(2) and so on.
>> So, I think I need to use MAT_REUSE_MATRIX from the beginning, since even when it is the first time I call
>> MatMatMult(A,Km(stepIdx-1), MAT_REUSE_MATRIX,PETSC_DEFAULT_INTEGER,Km(stepIdx), ierr)',
>> Km(stepIdx) have actually already been allocated (in K).
>> Do you think it is possible that I can do this, and could you please suggest some possible ways.
>> Thanks
>> Cong Li
>>> On Wed, Aug 5, 2015 at 11:23 PM, Hong <hzhang at mcs.anl.gov> wrote:
>>> Cong:
>>> You cannot use "MAT_REUSE_MATRIX" on arbitrary matrix product.
>>> The correct process is
>>> call MatMatMult(A,Km(stepIdx-1), MAT_INITIAL_MATRIX,PETSC_DEFAULT_INTEGER,C, ierr)
>>> call MatMatMult(A,Km(stepIdx-1), MAT_REUSE_MATRIX,PETSC_DEFAULT_INTEGER,C, ierr)
>>> i.e., C has data structure of A*Km(stepIdx-1) and is created in the first call. C can be reused in the 2nd call when A or Km(stepIdx-1) changed values, but not the structures.
>>> In your case, Km(stepIdx) = A*Km(stepIdx-1). You should do
>>> 'call MatMatMult(A,Km(stepIdx-1), MAT_INITIAL_MATRIX,PETSC_DEFAULT_INTEGER,Km(stepIdx), ierr)'
>>> directly.
>>> Hong
>>>> On Wed, Aug 5, 2015 at 4:42 AM, Cong Li <solvercorleone at gmail.com> wrote:
>>>> Hi
>>>> I tried the method you suggested. However, I got the error message.
>>>> My code and message are below.
>>>> K is the big matrix containing column matrices.
>>>> code:
>>>> call MatGetArray(K,KArray,KArrayOffset,ierr)
>>>> call MatGetLocalSize(R,local_RRow,local_RCol)
>>>> call MatGetArray(R,RArray,RArrayOffset,ierr)
>>>> PETSC_DECIDE , nDim, bsize,KArray(KArrayOffset + 1), Km(1), ierr)
>>>> localRsize = local_RRow * local_RCol
>>>> do genIdx= 1, localRsize
>>>> KArray(KArrayOffset + genIdx) = RArray(RArrayOffset + genIdx)
>>>> end do
>>>> call MatRestoreArray(R,RArray,RArrayOffset,ierr)
>>>> call MatAssemblyBegin(Km(1), MAT_FINAL_ASSEMBLY, ierr)
>>>> call MatAssemblyEnd (Km(1), MAT_FINAL_ASSEMBLY, ierr)
>>>> call MatAssemblyBegin(Km(stepIdx), MAT_FINAL_ASSEMBLY, ierr)
>>>> call MatAssemblyEnd (Km(stepIdx), MAT_FINAL_ASSEMBLY, ierr)
>>>> end do
>>>> call MatRestoreArray(K,KArray,KArrayOffset,ierr)
>>>> call MatMatMult(A,Km(stepIdx-1),MAT_REUSE_MATRIX,PETSC_DEFAULT_INTEGER,Km(stepIdx), ierr)
>>>> end do
>>>> And I got the error message as below:
>>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
>>>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>>>> [0]PETSC ERROR: to get more information on the crash.
>>>> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
>>>> [0]PETSC ERROR: Signal received!
>>>> [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 7, Sat May 11 22:15:24 CDT 2013
>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>> [0]PETSC ERROR: --------------------[1]PETSC ERROR: ------------------------------------------------------------------------
>>>> [1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>>> [0]PETSC ERROR: ./kmath.bcbcg on a arch-fuji named p01-024 by a03293 Wed Aug 5 18:24:40 2015
>>>> [0]PETSC ERROR: Libraries linked from /volume1/home/ra000005/a03293/kmathlibbuild/petsc-3.3-p7/arch-fujitsu-sparc64fx-opt/lib
>>>> [0]PETSC ERROR: Configure run at Tue Jul 28 19:23:51 2015
>>>> [0]PETSC ERROR: Configure options --known-level1-dcache-size=32768 --known-level1-dcache-linesize=32 --known-level1-dcache-assoc=0 --known-memcmp-ok=1 --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2 --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8 --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8 --known-bits-per-byte=8 --known-sizeof-MPI_Comm=8 --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-c-double-complex=1 --with-cc=mpifccpx --CFLAGS="-mt -Xg" --COPTFLAGS=-Kfast,openmp --with-cxx=mpiFCCpx --CXXFLAGS=-mt --CXXOPTFLAGS=-Kfast,openmp --with-fc=mpifrtpx --FFLAGS=-Kthreadsafe --FOPTFLAGS=-Kfast,openmp --with-blas-lapack-lib="-SCALAPACK -SSL2" --with-x=0 --with-c++-support --with-batch=1 --with-info=1 --with-debugging=0 --known-mpi-shared-libraries=0 --with-valgrind=0
>>>> [0]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
>>>> [mpi::mpi-api::mpi-abort]
>>>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>>> with errorcode 59.
>>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>>> You may or may not see output from other processes, depending on
>>>> exactly when Open MPI kills them.
>>>> [p01-024:26516] /opt/FJSVtclang/GM-1.2.0-18/lib64/libmpi.so.0(orte_errmgr_base_error_abort+0x84) [0xffffffff0091f684]
>>>> [p01-024:26516] /opt/FJSVtclang/GM-1.2.0-18/lib64/libmpi.so.0(ompi_mpi_abort+0x51c) [0xffffffff006c389c]
>>>> [p01-024:26516] /opt/FJSVtclang/GM-1.2.0-18/lib64/libmpi.so.0(MPI_Abort+0x6c) [0xffffffff006db3ac]
>>>> [p01-024:26516] /opt/FJSVtclang/GM-1.2.0-18/lib64/libtrtmet_c.so.1(MPI_Abort+0x2c) [0xffffffff00281bf0]
>>>> [p01-024:26516] ./kmath.bcbcg [0x1bf620]
>>>> [p01-024:26516] ./kmath.bcbcg [0x1bf20c]
>>>> [p01-024:26516] /lib64/libc.so.6(killpg+0x48) [0xffffffff02d52600]
>>>> [p01-024:26516] [(nil)]
>>>> [p01-024:26516] ./kmath.bcbcg [0x1a2054]
>>>> [p01-024:26516] ./kmath.bcbcg [0x1064f8]
>>>> [p01-024:26516] ./kmath.bcbcg(MAIN__+0x9dc) [0x105d1c]
>>>> [p01-024:26516] ./kmath.bcbcg(main+0xec) [0x8a329c]
>>>> [p01-024:26516] /lib64/libc.so.6(__libc_start_main+0x194) [0xffffffff02d3b81c]
>>>> [p01-024:26516] ./kmath.bcbcg [0x1051ec]
>>>> [0]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
>>>> [ERR.] PLE 0019 plexec One of MPI processes was aborted.(rank=0)(nid=0x020a0028)(CODE=1938,793745140674134016,15104)
>>>> However, if I change from
>>>> to
>>>> everything is fine.
>>>> could you please suggest some way to solve this?
>>>> Thanks
>>>> Cong Li
>>>>> On Wed, Aug 5, 2015 at 10:53 AM, Cong Li <solvercorleone at gmail.com> wrote:
>>>>> Thank you very much for your help and suggestions.
>>>>> With your help, finally I could continue my project.
>>>>> Regards
>>>>> Cong Li
>>>>>> On Wed, Aug 5, 2015 at 3:09 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>> From the manual page: Unless scall is MAT_REUSE_MATRIX C will be created.
>>>>>> Since you want to use the C that is passed in you should use MAT_REUSE_MATRIX.
>>>>>> Note that since your B and C matrices are dense the issue of sparsity pattern of C is not relevant.
>>>>>> Barry
>>>>>> > On Aug 4, 2015, at 11:59 AM, Cong Li <solvercorleone at gmail.com> wrote:
>>>>>> > Thanks very much. This answer is very helpful.
>>>>>> > And I have a following question.
>>>>>> > If I create B1, B2, .. by the way you suggested and then use MatMatMult to do SPMM.
>>>>>> > PetscErrorCode MatMatMult(Mat A,Mat B,MatReuse scall,PetscReal fill,Mat *C)
>>>>>> > should I use MAT_REUSE_MATRIX for MatReuse part of the arguement.
>>>>>> > Thanks
>>>>>> > Cong Li
>>>>>> > On Wed, Aug 5, 2015 at 1:27 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>> > > On Aug 4, 2015, at 4:09 AM, Cong Li <solvercorleone at gmail.com> wrote:
>>>>>> > > I am sorry that I should have explained it more clearly.
>>>>>> > > Actually I want to compute a recurrence.
>>>>>> > > Like, I want to firstly compute A*X1=B1, and then calculate A*B1=B2, A*B2=B3 and so on.
>>>>>> > > Finally I want to combine all these results into a bigger matrix C=[B1,B2 ...]
>>>>>> > First create C with MatCreateDense(,&C). Then call MatDenseGetArray(C,&array); then create B1 with MatCreateDense(....,array,&B1); then create
>>>>>> > B2 with MatCreateDense(...,array+shift,&B2) etc where shift equals the number of __local__ rows in B1 times the number of columns in B1, then create B3 with a larger shift etc.
>>>>>> > Note that you are "sharing" the array space of C with B1, B2, B3, ..., each Bi contains its columns of the C matrix.
>>>>>> > Barry
>>>>>> > > Is there any way to do this efficiently.
>>>>>> > > On Tue, Aug 4, 2015 at 5:45 PM, Patrick Sanan <patrick.sanan at gmail.com> wrote:
>>>>>> > > On Tue, Aug 04, 2015 at 03:42:14PM +0900, Cong Li wrote:
>>>>>> > > > Thanks for your reply.
>>>>>> > > > I have an other question.
>>>>>> > > > I want to do SPMM several times and combine result matrices into one bigger
>>>>>> > > > matrix.
>>>>>> > > > for example
>>>>>> > > > I firstly calculate AX1=B1, AX2=B2 ...
>>>>>> > > > then I want to combine B1, B2.. to get a C, where C=[B1,B2...]
>>>>>> > > > Could you please suggest a way of how to do this.
>>>>>> > > This is just linear algebra, nothing to do with PETSc specifically.
>>>>>> > > A * [X1, X2, ... ] = [AX1, AX2, ...]
>>>>>> > > > Thanks
>>>>>> > > > Cong Li
>>>>>> > > > On Tue, Aug 4, 2015 at 3:27 PM, Jed Brown <jed at jedbrown.org> wrote:
>>>>>> > > > > Cong Li <solvercorleone at gmail.com> writes:
>>>>>> > > > > > Hello,
>>>>>> > > > > > I am a PhD student using PETsc for my research.
>>>>>> > > > > > I am wondering if there is a way to implement SPMM (Sparse matrix-matrix
>>>>>> > > > > > multiplication) by using PETSc.
>>>>>> > > > > http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatMatMult.html
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150806/188eeae5/attachment-0001.html>
