[petsc-users] Get CPU time from events
Matthew Knepley
knepley at gmail.com
Mon Aug 3 11:36:32 CDT 2015
2015-08-03 10:50 GMT-05:00 Theler German Guillermo <gtheler at cites-gss.com>:
> Hi Matt
> I get empty PetscEventPerfInfo structures after calling
> PetscLogEventGetPerfInfo(), i.e. both integers and floats are zero, as
If you do not pass -log_summary, you have to call PetscLogBegin() after
PetscInitialize() to
get it to start logging.
Matt
> if the structure was just calloc'ed and never filled. However, I managed
> to get the overall stage CPU time (which is ok for me) by doing
> PetscLogGetStageLog(&stageLog);
> and then accessing stageLog->stageInfo[stage].perfInfo.time
> I attach a modified src/ksp/ksp/examples/tutorials/ex1.c that tries to
> illustrate my point.
> jeremy
> On Fri, 2015-07-31 at 09:00 -0500, Matthew Knepley wrote:
> > 2015-07-31 8:43 GMT-05:00 Theler German Guillermo
> > Is there a way to obtain as a PetscScalar the CPU time
> > associated to an
> > event or stage?
> > Something like PetscGetFlops() in an event or stage-based
> > basis?
> > Here is a test where I do that:
> https://bitbucket.org/petsc/petsc/src/77c2d1544b79e11f3573a3360b35a7573ef4d1bf/src/dm/impls/plex/examples/tests/ex9.c?at=master#ex9.c-237
> ________________________________
> Imprima este mensaje sólo si es absolutamente necesario.
> Para imprimir, en lo posible utilice el papel de ambos lados.
> El Grupo Sancor Seguros se compromete con el cuidado del medioambiente.
> ************AVISO DE CONFIDENCIALIDAD************
> El Grupo Sancor Seguros comunica que:
> Este mensaje y todos los archivos adjuntos a el son para uso exclusivo del
> destinatario y pueden contener información confidencial o propietaria, cuya
> divulgación es sancionada por ley. Si usted recibió este mensaje
> erróneamente, por favor notifíquenos respondiendo al remitente, borre el
> mensaje original y destruya las copias (impresas o grabadas en cualquier
> medio magnético) que pueda haber realizado del mismo. Todas las opiniones
> contenidas en este mail son propias del autor del mensaje. La publicación,
> uso, copia o impresión total o parcial de este mensaje o documentos
> adjuntos queda prohibida.
> Disposición DNDP 10-2008. El titular de los datos personales tiene la
> facultad de ejercer el derecho de acceso a los mismos en forma gratuita a
> intervalos no inferiores a seis meses, salvo que acredite un interés
> legítimo al efecto conforme lo establecido en el artículo 14, inciso 3 de
> la Ley 25.326. La DIRECCIÓN NACIONAL DE PROTECCIÓN DE DATOS PERSONALES,
> Organo de Control de la Ley 25.326, tiene la atribución de atender las
> denuncias y reclamos que se interpongan con relación al incumplimiento de
> las normas sobre la protección de datos personales.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20150803/c7c0c095/attachment.html>
