[petsc-users] GPU speedup in Poisson solvers
Karl Rupp rupp at iue.tuwien.ac.at
Mon Sep 22 23:37:10 CDT 2014
Hi Dominic,
I've got some time available at the end of this week for a merge to
next. Is there anything other than PR #178 needed? It currently shows
some conflicts, so is there any chance to rebase it on ~Thursday?
Best regards,
Karli
On 09/22/2014 09:38 PM, Dominic Meiser wrote:
> On 09/22/2014 12:57 PM, Chung Shen wrote:
>> Dear PETSc Users,
>> I am new to PETSc and trying to determine if GPU speedup is possible
>> with the 3D Poisson solvers. I configured 2 copies of 'petsc-master'
>> on a standalone machine, one with CUDA toolkit 5.0 and one without
>> (both without MPI):
>> Machine: HP Z820 Workstation, Redhat Enterprise Linux 5.0
>> CPU: (x2) 8-core Xeon E5-2650 2.0GHz, 128GB Memory
>> GPU: (x2) Tesla K20c (706MHz, 5.12GB Memory, Cuda Compatibility: 3.5,
>> Driver: 313.09)
>> I used 'src/ksp/ksp/examples/tests/ex32.c' as a test and was getting
>> about 20% speedup with GPU. Is this reasonable or did I miss something?
>> Attached is a comparison chart with two sample logs. The y-axis is the
>> elapsed time in seconds and the x-axis corresponds to the size of the
>> problem. In particular, I wonder if the numbers of calls to
>> 'VecCUSPCopyTo' and 'VecCUSPCopyFrom' shown in the GPU log are excessive?
>> Thanks in advance for your reply.
>> Best Regards,
>> Chung Shen
> A few comments:
> - To get reliable timing you should configure PETSc without debugging
> (i.e. --with-debugging=no)
> - The ILU preconditioning in your GPU benchmark is done on the CPU. The
> host-device data transfers are killing performance. Can you try to run
> with the additional option --pc_factor_mat_solver_packe cusparse? This
> will perform the preconditioning on the GPU.
> - If you're interested in running benchmarks in parallel you will need a
> few patches that are not yet in petsc/master. I can put together a
> branch that has the needed fixes.
> Cheers,
> Dominic
