[petsc-users] Problems running ex12.c
Mon Mar 31 19:08:24 CDT 2014
On Mon, Mar 31, 2014 at 6:37 PM, Miguel Angel Salazar de Troya <
salazardetroya at gmail.com> wrote:
> Thanks for your response. Now I am trying to modify this example to
> include Dirichlet and Neumann conditions at the same time.
> I can see that inside of DMPlexCreateSquareBoundary there is an option
> ("-dm_plex_separate_marker") to just mark the top boundary with 1. I
> understand that only this side would have Dirichlet conditions that are
> described by the function bcFuncs in user.fem (the exact function in this
> example). However, when we run the Neumann condition, we fix all the
> boundary as Neumann condition with the function DMPlexAddBoundary, is this
> right?
Right about the shortcoming, but wrong about the source.
DMPlexAddBoundary() takes an argument that is the marker value for the
given label, so you can select boundaries.
However, DMPlexComputeResidualFEM() currently hardcodes the boundary name
("boundary")
and the marker value (1). I wrote this when we had no boundary
representation in PETSc. Now that we have DMAddBoundary(), we can
loop over the Neumann boundaries. I have put this on my todo list. If you
are motivated, you can do it first and I will help.
     Matt
> Could there be a way to just fix a certain boundary with the Neumann
> condition in this example? Would it be easier with an external library as
> Exodus II?
> On Sun, Mar 30, 2014 at 7:51 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Sun, Mar 30, 2014 at 7:07 PM, Miguel Angel Salazar de Troya <
>>> Thanks for your response. Your help is really useful to me.
>>> The difference between the analytic and the field options are that for
>>> the field options the function is projected onto the function space defined
>>> for feAux right? What is the advantage of doing this?
>> If it is not purely a function of the coordinates, or you do not know
>> that function, there is no option left.
>>> Also, for this field case I see that the function always has to be a
>>> vector. What if we wanted to implement a heterogeneous material in linear
>>> elasticity? Would we implement the constitutive tensor as a vector? It
>>> would not be very difficult I think, I just want to make sure it would be
>>> this way.
>> Its not a vector, which indicates a particular behavior under coordinate
>> transformations, but an array
>> which can hold any data you want.
>>    Matt
>>> Thanks in advance
>>> Miguel
>>> On Sun, Mar 30, 2014 at 2:01 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Sun, Mar 30, 2014 at 1:57 PM, Miguel Angel Salazar de Troya <
>>>>> Hello everybody
>>>>> I had a question about this example. In the petsc-dev next version,
>>>>> why don't we create a PetscSection in the function SetupSection, but we do
>>>>> it in the function SetupMaterialSection and in the function SetupSection of
>>>>> the petsc-current version.
>>>> 1) I wanted to try and make things more automatic for the user
>>>> 2) I needed a way to automatically layout data for coarser/finer grids
>>>> in unstructured MG
>>>> Thus, now when you set for PetscFE into the DM using DMSetField(), it
>>>> will automatically create
>>>> the section on the first call to DMGetDefaultSection().
>>>> I do not have a similar provision now for materials, so you create your
>>>> own section. I think this is
>>>> alright until we have some idea of a nicer interface.
>>>>   Thanks,
>>>>      Matt
>>>>> petsc-dev:
>>>>> #undef __FUNCT__
>>>>> #define __FUNCT__ "SetupSection"
>>>>> PetscErrorCode SetupSection(DM dm, AppCtx *user)
>>>>>   DM             cdm = dm;
>>>>>   const PetscInt id  = 1;
>>>>>   PetscErrorCode ierr;
>>>>>   PetscFunctionBeginUser;
>>>>>   ierr = PetscObjectSetName((PetscObject) user->fe[0],
>>>>> "potential");CHKERRQ(ierr);
>>>>>   while (cdm) {
>>>>>     ierr = DMSetNumFields(cdm, 1);CHKERRQ(ierr);
>>>>>     ierr = DMSetField(cdm, 0, (PetscObject) user->fe[0]);CHKERRQ(ierr);
>>>>>     ierr = DMPlexAddBoundary(cdm, user->bcType == DIRICHLET,
>>>>> user->bcType == NEUMANN ? "boundary" : "marker", 0, user->exactFuncs[0], 1,
>>>>> &id, user);CHKERRQ(ierr);
>>>>>     ierr = DMPlexGetCoarseDM(cdm, &cdm);CHKERRQ(ierr);
>>>>>   PetscFunctionReturn(0);
>>>>> It seems that it adds the number of fields directly to the DM, and
>>>>> takes the number of components that were specified in SetupElementCommon,
>>>>> but what about the number of degrees of freedom? Why we added it for the
>>>>> MaterialSection but not for the regular Section.
>>>>> Thanks in advance
>>>>> Miguel
>>>>> On Sat, Mar 15, 2014 at 4:16 PM, Miguel Angel Salazar de Troya <
>>>>>> Thanks a lot.
>>>>>> On Sat, Mar 15, 2014 at 3:36 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> On Sat, Mar 15, 2014 at 3:31 PM, Miguel Angel Salazar de Troya <
>>>>>>>> Hello everybody
>>>>>>>> I keep trying to understand this example. I don't have any problems
>>>>>>>> with this example when I run it like this:
>>>>>>>> [salaza11 at maya PETSC]$ ./ex12 -bc_type dirichlet -interpolate
>>>>>>>> -petscspace_order 1 -variable_coefficient nonlinear -dim 2 -run_type full
>>>>>>>> -show_solution
>>>>>>>> Number of SNES iterations = 5
>>>>>>>> L_2 Error: 0.107289
>>>>>>>> Solution
>>>>>>>> Vec Object: 1 MPI processes
>>>>>>>>   type: seq
>>>>>>>> 0.484618
>>>>>>>> However, when I change the boundary conditions to Neumann, I get
>>>>>>>> this error.
>>>>>>>> [salaza11 at maya PETSC]$ ./ex12 -bc_type neumann -interpolate 1
>>>>>>>> -petscspace_order 2 -variable_coefficient nonlinear -dim 2 -run_type full
>>>>>>>> -show_solution
>>>>>>> Here you set the order of the element used in bulk, but not on the
>>>>>>> boundary where you condition is, so it defaults to 0. In
>>>>>>> order to become more familiar, take a look at the tests that I run
>>>>>>> here:
>>>>>>> https://bitbucket.org/petsc/petsc/src/64715f0f033346c10c77b73cf58216d111db8789/config/builder.py?at=master#cl-216
>>>>>>>      Matt
>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>>> [0]PETSC ERROR: Petsc has generated inconsistent data
>>>>>>>> [0]PETSC ERROR: Number of dual basis vectors 0 not equal to
>>>>>>>> dimension 1
>>>>>>>> [0]PETSC ERROR: See http://
>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>>>>> shooting.
>>>>>>>> [0]PETSC ERROR: Petsc Development GIT revision:
>>>>>>>> v3.4.3-4776-gb18359b  GIT Date: 2014-03-04 10:53:30 -0600
>>>>>>>> [0]PETSC ERROR: ./ex12 on a linux-gnu-c-debug named maya by
>>>>>>>> salaza11 Sat Mar 15 14:28:05 2014
>>>>>>>>  [0]PETSC ERROR: Configure options --download-mpich
>>>>>>>> --download-scientificpython --download-triangle --download-ctetgen
>>>>>>>> --download-chaco --with-c2html=0
>>>>>>>> [0]PETSC ERROR: #1 PetscDualSpaceSetUp_Lagrange() line 1763 in
>>>>>>>> /home/salaza11/petsc/src/dm/dt/interface/dtfe.c
>>>>>>>> [0]PETSC ERROR: #2 PetscDualSpaceSetUp() line 1277 in
>>>>>>>> [0]PETSC ERROR: #3 SetupElementCommon() line 474 in
>>>>>>>> /home/salaza11/workspace/PETSC/ex12.c
>>>>>>>> [0]PETSC ERROR: #4 SetupBdElement() line 559 in
>>>>>>>> [0]PETSC ERROR: #5 main() line 755 in
>>>>>>>> [0]PETSC ERROR: ----------------End of Error Message -------send
>>>>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 77) - process 0
>>>>>>>> [unset]: aborting job:
>>>>>>>> I honestly do not know much about using dual spaces in a finite
>>>>>>>> element context. I have been trying to find some material that could help
>>>>>>>> me without much success. I tried to modify the dual space order with the
>>>>>>>> option -petscdualspace_order but I kept getting errors. In particular, I
>>>>>>>> got this when I set it to 1.
>>>>>>>> -show_solution -petscdualspace_order 1
>>>>>>>> [0]PETSC ERROR: PetscTrFreeDefault() called from
>>>>>>>> PetscFESetUp_Basic() line 2492 in
>>>>>>>> [0]PETSC ERROR: Block [id=0(32)] at address 0x1cc32f0 is corrupted
>>>>>>>> (probably write past end of array)
>>>>>>>> [0]PETSC ERROR: Block allocated in PetscFESetUp_Basic() line 2483
>>>>>>>> in /home/salaza11/petsc/src/dm/dt/interface/dtfe.c
>>>>>>>> [0]PETSC ERROR: Memory corruption:
>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
>>>>>>>> [0]PETSC ERROR: Corrupted memory
>>>>>>>> shooting.
>>>>>>>> salaza11 Sat Mar 15 14:37:34 2014
>>>>>>>> [0]PETSC ERROR: #1 PetscTrFreeDefault() line 289 in
>>>>>>>> /home/salaza11/petsc/src/sys/memory/mtr.c
>>>>>>>> [0]PETSC ERROR: #2 PetscFESetUp_Basic() line 2492 in
>>>>>>>> [0]PETSC ERROR: #3 PetscFESetUp() line 2126 in
>>>>>>>> [0]PETSC ERROR: #4 SetupElementCommon() line 482 in
>>>>>>>> [0]PETSC ERROR: #5 SetupElement() line 506 in
>>>>>>>> [0]PETSC ERROR: #6 main() line 754 in
>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>>>>>>>> Then again, I do not know much what I am doing given my ignorance
>>>>>>>> with respect to the dual spaces in FE. I apologize for that. My questions
>>>>>>>> are:
>>>>>>>> - Where could I find more resources in order to understand the
>>>>>>>> PETSc implementation of dual spaces for FE?
>>>>>>>> - Why does it run with Dirichlet but not with Neumann?
>>>>>>>> Thanks in advance.
>>>>>>>> Miguel.
>>>>>>>> On Tue, Mar 4, 2014 at 11:28 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>> > wrote:
>>>>>>>>> On Tue, Mar 4, 2014 at 12:01 PM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Tue, Mar 4, 2014 at 11:51 AM, Miguel Angel Salazar de Troya <
>>>>>>>>>>> I can run it now, thanks. Although if I run it with valgrind
>>>>>>>>>>> 3.5.0 (should I update to the last version?) I get some memory leaks
>>>>>>>>>>> related with the function DMPlexCreateBoxMesh.
>>>>>>>>>> I will check it out.
>>>>>>>>> This is now fixed.
>>>>>>>>>   Thanks for finding it
>>>>>>>>>       Matt
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>> [salaza11 at maya tutorials]$ valgrind --leak-check=full ./ex12
>>>>>>>>>>> -run_type test -refinement_limit 0.0    -bc_type dirichlet -interpolate 0
>>>>>>>>>>> -petscspace_order 1 -show_initial -dm_plex_print_fem 1
>>>>>>>>>>> ==9625== Memcheck, a memory error detector
>>>>>>>>>>> ==9625== Copyright (C) 2002-2009, and GNU GPL'd, by Julian
>>>>>>>>>>> Seward et al.
>>>>>>>>>>> ==9625== Using Valgrind-3.5.0 and LibVEX; rerun with -h for
>>>>>>>>>>> copyright info
>>>>>>>>>>> ==9625== Command: ./ex12 -run_type test -refinement_limit 0.0
>>>>>>>>>>> -bc_type dirichlet -interpolate 0 -petscspace_order 1 -show_initial
>>>>>>>>>>> ==9625==
>>>>>>>>>>> Local function:
>>>>>>>>>>>   type: seq
>>>>>>>>>>> 0
>>>>>>>>>>> 0.25
>>>>>>>>>>> 1
>>>>>>>>>>> 0.25
>>>>>>>>>>> 0.5
>>>>>>>>>>> 1.25
>>>>>>>>>>> 1
>>>>>>>>>>> 1.25
>>>>>>>>>>> 2
>>>>>>>>>>> Initial guess
>>>>>>>>>>>   type: seq
>>>>>>>>>>> 0.5
>>>>>>>>>>> L_2 Error: 0.111111
>>>>>>>>>>> Residual:
>>>>>>>>>>>   type: seq
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>>  0
>>>>>>>>>>> Initial Residual
>>>>>>>>>>>   type: seq
>>>>>>>>>>> 0
>>>>>>>>>>> L_2 Residual: 0
>>>>>>>>>>> Jacobian:
>>>>>>>>>>> Mat Object: 1 MPI processes
>>>>>>>>>>>   type: seqaij
>>>>>>>>>>> row 0: (0, 4)
>>>>>>>>>>> Residual:
>>>>>>>>>>>   type: seq
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> -2
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> 0
>>>>>>>>>>> Au - b = Au + F(0)
>>>>>>>>>>>   type: seq
>>>>>>>>>>> 0
>>>>>>>>>>> Linear L_2 Residual: 0
>>>>>>>>>>> ==9625==
>>>>>>>>>>> ==9625== HEAP SUMMARY:
>>>>>>>>>>> ==9625==     in use at exit: 288 bytes in 3 blocks
>>>>>>>>>>> ==9625==   total heap usage: 2,484 allocs, 2,481 frees,
>>>>>>>>>>> 1,009,287 bytes allocated
>>>>>>>>>>> ==9625==
>>>>>>>>>>> ==9625== 48 bytes in 1 blocks are definitely lost in loss record
>>>>>>>>>>> 1 of 3
>>>>>>>>>>> ==9625==    at 0x4A05E46: malloc (vg_replace_malloc.c:195)
>>>>>>>>>>> ==9625==    by 0x5D8D4E1: writepoly (triangle.c:12012)
>>>>>>>>>>> ==9625==    by 0x5D8FAAC: triangulate (triangle.c:13167)
>>>>>>>>>>> ==9625==    by 0x56B0884: DMPlexGenerate_Triangle (plex.c:3749)
>>>>>>>>>>> ==9625==    by 0x56B5EE4: DMPlexGenerate (plex.c:4503)
>>>>>>>>>>> ==9625==    by 0x567F414: DMPlexCreateBoxMesh (plexcreate.c:668)
>>>>>>>>>>> ==9625==    by 0x4051FA: CreateMesh (ex12.c:341)
>>>>>>>>>>> ==9625==    by 0x408D3D: main (ex12.c:651)
>>>>>>>>>>> ==9625==
>>>>>>>>>>> ==9625== 96 bytes in 1 blocks are definitely lost in loss record
>>>>>>>>>>> 2 of 3
>>>>>>>>>>> ==9625==    by 0x5D8D485: writepoly (triangle.c:12004)
>>>>>>>>>>> ==9625==
>>>>>>>>>>> ==9625== 144 bytes in 1 blocks are definitely lost in loss
>>>>>>>>>>> record 3 of 3
>>>>>>>>>>> ==9625==    by 0x5D8CD20: writenodes (triangle.c:11718)
>>>>>>>>>>> ==9625==    by 0x5D8F9DE: triangulate (triangle.c:13132)
>>>>>>>>>>> ==9625==
>>>>>>>>>>> ==9625== LEAK SUMMARY:
>>>>>>>>>>> ==9625==    definitely lost: 288 bytes in 3 blocks
>>>>>>>>>>> ==9625==    indirectly lost: 0 bytes in 0 blocks
>>>>>>>>>>> ==9625==      possibly lost: 0 bytes in 0 blocks
>>>>>>>>>>> ==9625==    still reachable: 0 bytes in 0 blocks
>>>>>>>>>>> ==9625==         suppressed: 0 bytes in 0 blocks
>>>>>>>>>>> ==9625==
>>>>>>>>>>> ==9625== For counts of detected and suppressed errors, rerun
>>>>>>>>>>> with: -v
>>>>>>>>>>> ==9625== ERROR SUMMARY: 3 errors from 3 contexts (suppressed: 6
>>>>>>>>>>> from 6)
>>>>>>>>>>> On Mon, Mar 3, 2014 at 7:05 PM, Matthew Knepley <
>>>>>>>>>>>> On Mon, Mar 3, 2014 at 4:59 PM, Miguel Angel Salazar de Troya <
>>>>>>>>>>>>> You are welcome, thanks for your help.
>>>>>>>>>>>> Okay, I have rebuilt completely clean, and ex12 runs for me.
>>>>>>>>>>>> Can you try again after pulling?
>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>  On Mon, Mar 3, 2014 at 4:13 PM, Matthew Knepley <
>>>>>>>>>>>>>> On Mon, Mar 3, 2014 at 1:44 PM, Miguel Angel Salazar de Troya
>>>>>>>>>>>>>> <salazardetroya at gmail.com> wrote:
>>>>>>>>>>>>>>> Thanks. This is what I get.
>>>>>>>>>>>>>> Okay, this was broken by a new push to master/next in the
>>>>>>>>>>>>>> last few days. I have pushed a fix,
>>>>>>>>>>>>>> however next is currently broken due to a failure to check in
>>>>>>>>>>>>>> a file. This should be fixed shortly,
>>>>>>>>>>>>>> and then ex12 will work. I will mail you when its ready.
>>>>>>>>>>>>>>   Thanks for finding this,
>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>> (gdb) cont
>>>>>>>>>>>>>>> Continuing.
>>>>>>>>>>>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>>>>>>>>>>>> 0x00007fd6811bea7b in DMPlexComputeJacobianFEM
>>>>>>>>>>>>>>> (dm=0x159a180, X=0x168b5b0,
>>>>>>>>>>>>>>>     Jac=0x7fffae6e8a88, JacP=0x7fffae6e8a88,
>>>>>>>>>>>>>>> str=0x7fffae6e7970,
>>>>>>>>>>>>>>>     user=0x7fd6811be509)
>>>>>>>>>>>>>>>     at /home/salaza11/petsc/src/dm/impls/plex/plexfem.c:882
>>>>>>>>>>>>>>> 882         ierr = PetscFEGetDimension(fe[f],
>>>>>>>>>>>>>>> &Nb);CHKERRQ(ierr);
>>>>>>>>>>>>>>> (gdb) where
>>>>>>>>>>>>>>> #0  0x00007fd6811bea7b in DMPlexComputeJacobianFEM
>>>>>>>>>>>>>>> str=0x7fffae6e7970,
>>>>>>>>>>>>>>> #1  0x00007fd6814a5bf6 in SNESComputeJacobian_DMLocal
>>>>>>>>>>>>>>> (snes=0x14e9450,
>>>>>>>>>>>>>>>     X=0x1622ad0, A=0x7fffae6e8a88, B=0x7fffae6e8a88,
>>>>>>>>>>>>>>> ctx=0x1652300)
>>>>>>>>>>>>>>>     at /home/salaza11/petsc/src/snes/utils/dmlocalsnes.c:102
>>>>>>>>>>>>>>> #2  0x00007fd6814cc609 in SNESComputeJacobian
>>>>>>>>>>>>>>> (snes=0x14e9450, X=0x1622ad0,
>>>>>>>>>>>>>>>     A=0x7fffae6e8a88, B=0x7fffae6e8a88)
>>>>>>>>>>>>>>>     at /home/salaza11/petsc/src/snes/interface/snes.c:2245
>>>>>>>>>>>>>>> #3  0x000000000040af72 in main (argc=15, argv=0x7fffae6e8bc8)
>>>>>>>>>>>>>>>     at
>>>>>>>>>>>>>>> /home/salaza11/petsc/src/snes/examples/tutorials/ex12.c:784
>>>>>>>>>>>>>>> On Mon, Mar 3, 2014 at 1:40 PM, Matthew Knepley <
>>>>>>>>>>>>>>>> On Mon, Mar 3, 2014 at 1:39 PM, Miguel Angel Salazar de
>>>>>>>>>>>>>>>> Troya <salazardetroya at gmail.com> wrote:
>>>>>>>>>>>>>>>>> This is what I get at gdb when I type 'where'.
>>>>>>>>>>>>>>>> You have to type 'cont', and then when it fails you type
>>>>>>>>>>>>>>>> 'where'.
>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>> #0  0x000000310e0aa860 in __nanosleep_nocancel () from
>>>>>>>>>>>>>>>>> /lib64/libc.so.6
>>>>>>>>>>>>>>>>> #1  0x000000310e0aa70f in sleep () from /lib64/libc.so.6
>>>>>>>>>>>>>>>>> #2  0x00007fd83a00a8be in PetscSleep (s=10)
>>>>>>>>>>>>>>>>>     at /home/salaza11/petsc/src/sys/utils/psleep.c:52
>>>>>>>>>>>>>>>>> #3  0x00007fd83a06f331 in PetscAttachDebugger ()
>>>>>>>>>>>>>>>>>     at /home/salaza11/petsc/src/sys/error/adebug.c:397
>>>>>>>>>>>>>>>>> #4  0x00007fd83a0af1d2 in PetscOptionsCheckInitial_Private
>>>>>>>>>>>>>>>>>     at /home/salaza11/petsc/src/sys/objects/init.c:444
>>>>>>>>>>>>>>>>> #5  0x00007fd83a0b6448 in PetscInitialize
>>>>>>>>>>>>>>>>> (argc=0x7fff5cd8df2c,
>>>>>>>>>>>>>>>>>     args=0x7fff5cd8df20, file=0x0,
>>>>>>>>>>>>>>>>>     help=0x60ce40 "Poisson Problem in 2d and 3d with
>>>>>>>>>>>>>>>>> simplicial finite elements.\nWe solve the Poisson problem in a
>>>>>>>>>>>>>>>>> rectangular\ndomain, using a parallel unstructured mesh (DMPLEX) to
>>>>>>>>>>>>>>>>> discretize it.\n\n\n")
>>>>>>>>>>>>>>>>>     at /home/salaza11/petsc/src/sys/objects/pinit.c:876
>>>>>>>>>>>>>>>>> #6  0x0000000000408f2c in main (argc=15,
>>>>>>>>>>>>>>>>> argv=0x7fff5cd8f1f8)
>>>>>>>>>>>>>>>>>     at
>>>>>>>>>>>>>>>>> /home/salaza11/petsc/src/snes/examples/tutorials/ex12.c:663
>>>>>>>>>>>>>>>>> The rest of the gdb output is attached. I am a bit
>>>>>>>>>>>>>>>>> ignorant with gdb, I apologize for that.
>>>>>>>>>>>>>>>>> On Mon, Mar 3, 2014 at 12:48 PM, Matthew Knepley <
>>>>>>>>>>>>>>>>>> On Mon, Mar 3, 2014 at 12:39 PM, Miguel Angel Salazar de
>>>>>>>>>>>>>>>>>>> Thanks for your response. Sorry I did not have the
>>>>>>>>>>>>>>>>>>> "next" version, but the "master" version. I still have an error though. I
>>>>>>>>>>>>>>>>>>> followed the steps given here (
>>>>>>>>>>>>>>>>>>> https://bitbucket.org/petsc/petsc/wiki/Home) to obtain
>>>>>>>>>>>>>>>>>>> the next version, I configured petsc as above and ran ex12 as above as
>>>>>>>>>>>>>>>>>>> well, getting this error:
>>>>>>>>>>>>>>>>>>> [salaza11 at maya tutorials]$ ./ex12 -run_type test
>>>>>>>>>>>>>>>>>>> Local function:
>>>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0.25
>>>>>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>>>>>> 0.25
>>>>>>>>>>>>>>>>>>> 0.5
>>>>>>>>>>>>>>>>>>> 1.25
>>>>>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>>>>>> 1.25
>>>>>>>>>>>>>>>>>>> 2
>>>>>>>>>>>>>>>>>>> Initial guess
>>>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>>>> 0.5
>>>>>>>>>>>>>>>>>>> L_2 Error: 0.111111
>>>>>>>>>>>>>>>>>>> Residual:
>>>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> Initial Residual
>>>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> L_2 Residual: 0
>>>>>>>>>>>>>>>>>> Okay, now run with -start_in_debugger, and give me a
>>>>>>>>>>>>>>>>>> stack trace using 'where'.
>>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>>>>>  [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV:
>>>>>>>>>>>>>>>>>>> Segmentation Violation, probably memory access out of range
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>>>>>>>>>> -on_error_attach_debugger
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: or see
>>>>>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
>>>>>>>>>>>>>>>>>>> http://valgrind.org on GNU/linux and Apple Mac OS X to
>>>>>>>>>>>>>>>>>>> find memory corruption errors
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: likely location of problem given in
>>>>>>>>>>>>>>>>>>> stack below
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the
>>>>>>>>>>>>>>>>>>> stack are not available,
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:       INSTEAD the line number of the
>>>>>>>>>>>>>>>>>>> start of the function
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:       is given.
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] DMPlexComputeJacobianFEM line 871
>>>>>>>>>>>>>>>>>>>  [0]PETSC ERROR: [0] SNESComputeJacobian_DMLocal line
>>>>>>>>>>>>>>>>>>> 94 /home/salaza11/petsc/src/snes/utils/dmlocalsnes.c
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNES user Jacobian function line
>>>>>>>>>>>>>>>>>>> 2244 /home/salaza11/petsc/src/snes/interface/snes.c
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeJacobian line 2203
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Signal received
>>>>>>>>>>>>>>>>>>> trouble shooting.
>>>>>>>>>>>>>>>>>>> v3.4.3-4705-gfb6b3bc  GIT Date: 2014-03-03 08:23:43 -0600
>>>>>>>>>>>>>>>>>>> by salaza11 Mon Mar  3 11:49:15 2014
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: #1 User provided function() line 0 in
>>>>>>>>>>>>>>>>>>>  unknown file
>>>>>>>>>>>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) -
>>>>>>>>>>>>>>>>>>> process 0
>>>>>>>>>>>>>>>>>>> process 0
>>>>>>>>>>>>>>>>>>> On Sun, Mar 2, 2014 at 7:11 PM, Matthew Knepley <
>>>>>>>>>>>>>>>>>>>> On Sun, Mar 2, 2014 at 6:54 PM, Miguel Angel Salazar de
>>>>>>>>>>>>>>>>>>>>> Hi everybody
>>>>>>>>>>>>>>>>>>>>> I am trying to run example ex12.c without much
>>>>>>>>>>>>>>>>>>>>> success. I specifically run it with the command options:
>>>>>>>>>>>>>>>>>>>> We need to start narrowing down differences, because it
>>>>>>>>>>>>>>>>>>>> runs for me and our nightly tests. So, first can
>>>>>>>>>>>>>>>>>>>> you confirm that you are using the latest 'next' branch?
>>>>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>>>>>>> And I get this output
>>>>>>>>>>>>>>>>>>>>> Local function:
>>>>>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>>>>>>>> 2
>>>>>>>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>>>>>>>> 2
>>>>>>>>>>>>>>>>>>>>> 2
>>>>>>>>>>>>>>>>>>>>> 3
>>>>>>>>>>>>>>>>>>>>> Initial guess
>>>>>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>>>>>> L_2 Error: 0.625
>>>>>>>>>>>>>>>>>>>>> Residual:
>>>>>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>>>> Initial Residual
>>>>>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>>>>>> L_2 Residual: 0
>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>> to find memory corruption errors
>>>>>>>>>>>>>>>>>>>>> stack below
>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] DMPlexComputeJacobianFEM line 867
>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Signal received!
>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>> v3.4.3-3453-g0a94005  GIT Date: 2014-03-02 13:12:04 -0600
>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent
>>>>>>>>>>>>>>>>>>>>> updates.
>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about
>>>>>>>>>>>>>>>>>>>>> trouble shooting.
>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>> maya by salaza11 Sun Mar  2 17:00:09 2014
>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>>>>>>>>>>>>>> /home/salaza11/petsc/linux-gnu-c-debug/lib
>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure run at Sun Mar  2 16:46:51
>>>>>>>>>>>>>>>>>>>>> 2014
>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: User provided function() line 0 in
>>>>>>>>>>>>>>>>>>>>>  unknown file
>>>>>>>>>>>>>>>>>>>>> process 0
>>>>>>>>>>>>>>>>>>>>> process 0
>>>>>>>>>>>>>>>>>>>>> Probably my problems could be on my configuration. I
>>>>>>>>>>>>>>>>>>>>> attach the configure.log. I ran ./configure like this
>>>>>>>>>>>>>>>>>>>>> ./configure --download-mpich
>>>>>>>>>>>>>>>>>>>>> Thanks a lot in advance.
>>>>>>>>>>>>>>>>>>>>> On Tue, Jan 28, 2014 at 10:37 AM, Matthew Knepley <
>>>>>>>>>>>>>>>>>>>>>> On Tue, Jan 28, 2014 at 10:31 AM, Yaakoub El Khamra <
>>>>>>>>>>>>>>>>>>>>>> yelkhamra at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>>>> If
>>>>>>>>>>>>>>>>>>>>>>>  ./ex12 -run_type test -dim 3 -refinement_limit
>>>>>>>>>>>>>>>>>>>>>>> 0.0125 -variable_coefficient field    -interpolate 1 -petscspace_order 2
>>>>>>>>>>>>>>>>>>>>>>> is for serial, any chance we can get the options to
>>>>>>>>>>>>>>>>>>>>>>> run in parallel?
>>>>>>>>>>>>>>>>>>>>>> Just use mpiexec -n <procs>
>>>>>>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>>>>>> Regards
>>>>>>>>>>>>>>>>>>>>>>> Yaakoub El Khamra
>>>>>>>>>>>>>>>>>>>>>>> On Fri, Jan 17, 2014 at 11:29 AM, Matthew Knepley <
>>>>>>>>>>>>>>>>>>>>>>>> On Fri, Jan 17, 2014 at 11:06 AM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>>> Alexander <MAJones2 at mdanderson.org> wrote:
>>>>>>>>>>>>>>>>>>>>>>>>> *From:* Matthew Knepley [knepley at gmail.com]
>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Friday, January 17, 2014 11:04 AM
>>>>>>>>>>>>>>>>>>>>>>>>> *To:* Jones,Martin Alexander
>>>>>>>>>>>>>>>>>>>>>>>>> *Cc:* petsc-users at mcs.anl.gov
>>>>>>>>>>>>>>>>>>>>>>>>> *Subject:* Re: [petsc-users] Problems running
>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>    On Fri, Jan 17, 2014 at 11:00 AM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>>>>>  These examples all seem to run excepting the
>>>>>>>>>>>>>>>>>>>>>>>>>> following command,
>>>>>>>>>>>>>>>>>>>>>>>>>> I get the following ouput:
>>>>>>>>>>>>>>>>>>>>>>>>>> Local function:
>>>>>>>>>>>>>>>>>>>>>>>>>> ./ex12: symbol lookup error:
>>>>>>>>>>>>>>>>>>>>>>>>>> /opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so: undefined
>>>>>>>>>>>>>>>>>>>>>>>>>> symbol: omp_get_num_procs
>>>>>>>>>>>>>>>>>>>>>>>>>  This is a build problem, but it should affect
>>>>>>>>>>>>>>>>>>>>>>>>> all the runs. Is this reproducible? Can you send configure.log? MKL is the
>>>>>>>>>>>>>>>>>>>>>>>>> worst. If this
>>>>>>>>>>>>>>>>>>>>>>>>> persists, I would just switch to
>>>>>>>>>>>>>>>>>>>>>>>>> --download-f-blas-lapack.
>>>>>>>>>>>>>>>>>>>>>>>> Thanks. I have some advice on options
>>>>>>>>>>>>>>>>>>>>>>>>   --with-precision=single # I would not use this
>>>>>>>>>>>>>>>>>>>>>>>> unless you are doing something special, like CUDA
>>>>>>>>>>>>>>>>>>>>>>>>   --with-clanguage=C++  # I would recommend
>>>>>>>>>>>>>>>>>>>>>>>> switching to C, the build is much faster
>>>>>>>>>>>>>>>>>>>>>>>>   --with-mpi-dir=/usr --with-mpi4py=0
>>>>>>>>>>>>>>>>>>>>>>>>   --with-shared-libraries --CFLAGS=-O0
>>>>>>>>>>>>>>>>>>>>>>>> --CXXFLAGS=-O0 --with-fc=0
>>>>>>>>>>>>>>>>>>>>>>>>   --with-etags=1                # This is
>>>>>>>>>>>>>>>>>>>>>>>> unnecessary
>>>>>>>>>>>>>>>>>>>>>>>> --with-blas-lapack-lib="[/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_rt.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_core.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libiomp5.so]"
>>>>>>>>>>>>>>>>>>>>>>>> # Here is the problem, see below
>>>>>>>>>>>>>>>>>>>>>>>>   --download-metis
>>>>>>>>>>>>>>>>>>>>>>>>   --download-fiat=yes --download-generator
>>>>>>>>>>>>>>>>>>>>>>>> --download-scientificpython # Get rid of these, they are obsolete
>>>>>>>>>>>>>>>>>>>>>>>> Your MKL needs another library for the OpenMP
>>>>>>>>>>>>>>>>>>>>>>>> symbols. I would recommend switching to --download-f2cblaslapack,
>>>>>>>>>>>>>>>>>>>>>>>> or you can try and find that library.
>>>>>>>>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>>>>>>>>>>>    Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 6:35 PM
>>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 5:43 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>>>>>>  Hi, This is the next error message after
>>>>>>>>>>>>>>>>>>>>>>>>>>> configuring and building with the triangle package when trying to run ex12
>>>>>>>>>>>>>>>>>>>>>>>>>>  This is my fault for bad defaults. I will fix.
>>>>>>>>>>>>>>>>>>>>>>>>>> Try running
>>>>>>>>>>>>>>>>>>>>>>>>>>  for a representative run. Then you could try 3D
>>>>>>>>>>>>>>>>>>>>>>>>>>  or a full run
>>>>>>>>>>>>>>>>>>>>>>>>>>    ex12 -refinement_limit 0.01 -bc_type
>>>>>>>>>>>>>>>>>>>>>>>>>> dirichlet -interpolate -petscspace_order 1
>>>>>>>>>>>>>>>>>>>>>>>>>> dirichlet -interpolate -petscspace_order 2
>>>>>>>>>>>>>>>>>>>>>>>>>>  Let me know if those work.
>>>>>>>>>>>>>>>>>>>>>>>>>>    Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>>>>>>>>>>>>>   ./ex12
>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Caught signal number 8 FPE:
>>>>>>>>>>>>>>>>>>>>>>>>>>> Floating Point Exception,probably divide by zero
>>>>>>>>>>>>>>>>>>>>>>>>>>> OS X to find memory corruption errors
>>>>>>>>>>>>>>>>>>>>>>>>>>> in stack below
>>>>>>>>>>>>>>>>>>>>>>>>>>> Frames ------------------------------------
>>>>>>>>>>>>>>>>>>>>>>>>>>> the stack are not available,
>>>>>>>>>>>>>>>>>>>>>>>>>>> the start of the function
>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] DMPlexComputeResidualFEM
>>>>>>>>>>>>>>>>>>>>>>>>>>> line 531 /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexfem.c
>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeFunction_DMLocal
>>>>>>>>>>>>>>>>>>>>>>>>>>> line 63 /home/mjonesa/PETSc/petsc/src/snes/utils/dmlocalsnes.c
>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNES user function line 2088
>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/interface/snes.c
>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeFunction line
>>>>>>>>>>>>>>>>>>>>>>>>>>> 2076 /home/mjonesa/PETSc/petsc/src/snes/interface/snes.c
>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESSolve_NEWTONLS line 144
>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/impls/ls/ls.c
>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESSolve line 3765
>>>>>>>>>>>>>>>>>>>>>>>>>>> Message ------------------------------------
>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>>>> v3.4.3-2317-gcd0e7f7  GIT Date: 2014-01-15 20:33:42 -0600
>>>>>>>>>>>>>>>>>>>>>>>>>>> recent updates.
>>>>>>>>>>>>>>>>>>>>>>>>>>> about trouble shooting.
>>>>>>>>>>>>>>>>>>>>>>>>>>> pages.
>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>>>> arch-linux2-cxx-debug named maeda by mjonesa Thu Jan 16 17:41:23 2014
>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/local/lib
>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure run at Thu Jan 16
>>>>>>>>>>>>>>>>>>>>>>>>>>> 17:38:33 2014
>>>>>>>>>>>>>>>>>>>>>>>>>>> --prefix=/home/mjonesa/local
>>>>>>>>>>>>>>>>>>>>>>>>>>> --with-c2html=0 --with-clanguage=c++ PETSC_ARCH=arch-linux2-cxx-debug
>>>>>>>>>>>>>>>>>>>>>>>>>>> --download-triangle
>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>>>> in  unknown file
>>>>>>>>>>>>>>>>>>>>>>>>>>> - process 0
>>>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 4:37 PM
>>>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 4:33 PM,
>>>>>>>>>>>>>>>>>>>>>>>>>>> Jones,Martin Alexander <MAJones2 at mdanderson.org>wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Hi, I have downloaded and built the dev
>>>>>>>>>>>>>>>>>>>>>>>>>>>> version you suggested. I think I need the triangle package to run this
>>>>>>>>>>>>>>>>>>>>>>>>>>>> particular case. Is there any thing else that appears wrong in what I have
>>>>>>>>>>>>>>>>>>>>>>>>>>>> done from the error messages below:
>>>>>>>>>>>>>>>>>>>>>>>>>>>  Great! Its running. You can reconfigure like
>>>>>>>>>>>>>>>>>>>>>>>>>>> this:
>>>>>>>>>>>>>>>>>>>>>>>>>>> $PETSC_DIR/$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py --download-triangle
>>>>>>>>>>>>>>>>>>>>>>>>>>>  and then rebuild
>>>>>>>>>>>>>>>>>>>>>>>>>>>     make
>>>>>>>>>>>>>>>>>>>>>>>>>>>  and then rerun. You can load meshes, but its
>>>>>>>>>>>>>>>>>>>>>>>>>>> much easier to have triangle create them.
>>>>>>>>>>>>>>>>>>>>>>>>>>>    Thanks for being patient,
>>>>>>>>>>>>>>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: No support for this operation
>>>>>>>>>>>>>>>>>>>>>>>>>>>> for this object type!
>>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Mesh generation needs external
>>>>>>>>>>>>>>>>>>>>>>>>>>>> package support.
>>>>>>>>>>>>>>>>>>>>>>>>>>>> Please reconfigure with --download-triangle.!
>>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>>>>> recent updates.
>>>>>>>>>>>>>>>>>>>>>>>>>>>> pages.
>>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>>>>> arch-linux2-cxx-debug named maeda by mjonesa Thu Jan 16 16:28:20 2014
>>>>>>>>>>>>>>>>>>>>>>>>>>>> 16:25:53 2014
>>>>>>>>>>>>>>>>>>>>>>>>>>>> --prefix=/home/mjonesa/local --with-clanguage=c++ --with-c2html=0
>>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: DMPlexGenerate() line 4332 in
>>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plex.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: DMPlexCreateBoxMesh() line 600
>>>>>>>>>>>>>>>>>>>>>>>>>>>> in /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexcreate.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: CreateMesh() line 295 in
>>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/examples/tutorials/ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: main() line 659 in
>>>>>>>>>>>>>>>>>>>>>>>>>>>> 56) - process 0
>>>>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 4:06 PM
>>>>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 4:05 PM,
>>>>>>>>>>>>>>>>>>>>>>>>>>>> > wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Hi. I changed the ENV variable to the
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> correct entry. when I type make ex12 I get this:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> mjonesa at maeda:~/PETSc/petsc-3.4.3/src/snes/examples/tutorials$
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> make ex12
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> g++ -o ex12.o -c -Wall -Wwrite-strings
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -g   -fPIC
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/arch-linux2-cxx-debug/include
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include/mpiuni
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> -D__INSDIR__=src/snes/examples/tutorials/ ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c:14:18: fatal error: ex12.h: No such
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> file or directory
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> compilation terminated.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> make: *** [ex12.o] Error 1
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Any help of yours is very much appreciated.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Yes, this relates to my 3). This is not going
>>>>>>>>>>>>>>>>>>>>>>>>>>>> to work for you with the release. Please see the link I sent.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 3:58 PM
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 3:55 PM,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Thanks!
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  You built with
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 3:31 PM
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> running ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 3:11 PM,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Now I went to the directory where ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> sits and just did a 'make ex12.c' with the following error if this helps?  :
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> make ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/variables:108:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscvariables: No
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> such file or directory
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/rules:962:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules: No
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> make: *** No rule to make target
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> `/home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules'.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Stop.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  1) You would type 'make ex12'
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  2) Either you PETSC_DIR (
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3) or
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> PETSC_ARCH (linux-gnu-cxx-debug) environment
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> variables
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>     do not match what you built. Please send
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> configure.log and make.log
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  3) Since it was only recently added, if you
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> want to use the FEM functionality, you must use the development version:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/developers/index.html
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>    Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>        Matt
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> *From:* Matthew Knepley [mailto:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 2:48 PM
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> running ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jan 16, 2014 at 2:35 PM,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Hello To Whom it Concerns,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> I am trying to run the tutorial ex12.c by
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> running 'bin/pythonscripts/PetscGenerateFEMQuadrature.py
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> dim order dim 1 laplacian dim order dim 1 boundary
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> src/snes/examples/tutorials/ex12.h'
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> but getting the following error:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> bin/pythonscripts/PetscGenerateFEMQuadrature.py dim order dim 1 laplacian
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> dim order dim 1 boundary src/snes/examples/tutorials/ex12.h
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> "bin/pythonscripts/PetscGenerateFEMQuadrature.py", line 15, in <module>
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>     from FIAT.reference_element import
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> default_simplex
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ImportError: No module named
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> I have removed the requirement of generating
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> the header file (its now all handled in C). I thought
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> I changed the documentation everywhere
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> (including the latest tutorial slides). Can you try running
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> with 'master' (or 'next'), and point me
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> toward the old docs?
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> before they begin their experiments is infinitely more interesting than any
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> results to which their experiments lead.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before
>>>>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>> *Miguel Angel Salazar de Troya*
>>>>>>>>>>>>>>>>>>>>> Graduate Research Assistant
>>>>>>>>>>>>>>>>>>>>> Department of Mechanical Science and Engineering
>>>>>>>>>>>>>>>>>>>>> University of Illinois at Urbana-Champaign
>>>>>>>>>>>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>>>>>>>>>>>> salaza11 at illinois.edu
>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> (217) 550-2360
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>> (217) 550-2360
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> (217) 550-2360
>>>>> (217) 550-2360
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> (217) 550-2360
>> experiments lead.
>> -- Norbert Wiener
> (217) 550-2360
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140331/467abc24/attachment-0001.html>
