[petsc-users] Tensor product as matrix free method
    Dominic Meiser
    dmeiser at txcorp.com
    Mon Mar 31 12:10:49 CDT 2014
Have you considered using a matrix shell:
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateShell.html
What operations do you need to support besides sparse matrix vector
products?
On 03/31/2014 10:49 AM, Mathis Friesdorf wrote:
> Hello everybody,
> for my Ph.D. in theoretical quantum mechanics, I am currently trying
> to integrate the Schroedinger equation (a linear partial differential
> equation). In my field, we are working with so called local spin
> chains, which mathematically speaking are described by tensor products
> of small vector spaces over several systems (let's say 20). The matrix
> corresponding to the differential equation is called Hamiltonian and
> can for typical systems be written as a sum over tensor products where
> it acts as the identity on most systems. It normally has the form
> /\sum Id \otimes Id ... Id \otimes M \otimes Id \otimes .../
> where M takes different positions.I know how to explicitly construct
> the full matrix and insert it into Petsc, but for the interesting
> applications it is too large to be stored in the RAM. I would
> therefore like to implement it as a matrix free version.
> This should be possible using MatCreateMAIJ() and VecGetArray(), as
> the following very useful post points out
> http://lists.mcs.anl.gov/pipermail/petsc-users/2011-September/009992.html.
> I was wondering whether anybody already made progress with this, as I
> am still a bit lost on how to precisely proceed. These systems really
> are ubiquitous in theoretical quantum mechanics and I am sure it would
> be helpful to quite a lot of people who still shy away a bit from Petsc.
> Thanks already for your help and all the best, Mathis
Dominic Meiser
Tech-X Corporation
5621 Arapahoe Avenue
Boulder, CO 80303
USA
Telephone: 303-996-2036
Fax: 303-448-7756
www.txcorp.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140331/49783294/attachment.html>
