[petsc-users] Problems running ex12.c
    Matthew Knepley
    knepley at gmail.com
    Sun Mar 30 19:51:40 CDT 2014
On Sun, Mar 30, 2014 at 7:07 PM, Miguel Angel Salazar de Troya <
salazardetroya at gmail.com> wrote:
> Thanks for your response. Your help is really useful to me.
> The difference between the analytic and the field options are that for the
> field options the function is projected onto the function space defined for
> feAux right? What is the advantage of doing this?
If it is not purely a function of the coordinates, or you do not know that
function, there is no option left.
> Also, for this field case I see that the function always has to be a
> vector. What if we wanted to implement a heterogeneous material in linear
> elasticity? Would we implement the constitutive tensor as a vector? It
> would not be very difficult I think, I just want to make sure it would be
> this way.
Its not a vector, which indicates a particular behavior under coordinate
transformations, but an array
which can hold any data you want.
   Matt
> Thanks in advance
> Miguel
> On Sun, Mar 30, 2014 at 2:01 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Sun, Mar 30, 2014 at 1:57 PM, Miguel Angel Salazar de Troya <
>>> Hello everybody
>>> I had a question about this example. In the petsc-dev next version, why
>>> don't we create a PetscSection in the function SetupSection, but we do it
>>> in the function SetupMaterialSection and in the function SetupSection of
>>> the petsc-current version.
>> 1) I wanted to try and make things more automatic for the user
>> 2) I needed a way to automatically layout data for coarser/finer grids in
>> unstructured MG
>> Thus, now when you set for PetscFE into the DM using DMSetField(), it
>> will automatically create
>> the section on the first call to DMGetDefaultSection().
>> I do not have a similar provision now for materials, so you create your
>> own section. I think this is
>> alright until we have some idea of a nicer interface.
>>   Thanks,
>>      Matt
>>> petsc-dev:
>>> #undef __FUNCT__
>>> #define __FUNCT__ "SetupSection"
>>> PetscErrorCode SetupSection(DM dm, AppCtx *user)
>>>   DM             cdm = dm;
>>>   const PetscInt id  = 1;
>>>   PetscErrorCode ierr;
>>>   PetscFunctionBeginUser;
>>>   ierr = PetscObjectSetName((PetscObject) user->fe[0],
>>> "potential");CHKERRQ(ierr);
>>>   while (cdm) {
>>>     ierr = DMSetNumFields(cdm, 1);CHKERRQ(ierr);
>>>     ierr = DMSetField(cdm, 0, (PetscObject) user->fe[0]);CHKERRQ(ierr);
>>>     ierr = DMPlexAddBoundary(cdm, user->bcType == DIRICHLET,
>>> user->bcType == NEUMANN ? "boundary" : "marker", 0, user->exactFuncs[0], 1,
>>> &id, user);CHKERRQ(ierr);
>>>     ierr = DMPlexGetCoarseDM(cdm, &cdm);CHKERRQ(ierr);
>>>   PetscFunctionReturn(0);
>>> It seems that it adds the number of fields directly to the DM, and takes
>>> the number of components that were specified in SetupElementCommon, but
>>> what about the number of degrees of freedom? Why we added it for the
>>> MaterialSection but not for the regular Section.
>>> Thanks in advance
>>> Miguel
>>> On Sat, Mar 15, 2014 at 4:16 PM, Miguel Angel Salazar de Troya <
>>>> Thanks a lot.
>>>> On Sat, Mar 15, 2014 at 3:36 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Sat, Mar 15, 2014 at 3:31 PM, Miguel Angel Salazar de Troya <
>>>>>> Hello everybody
>>>>>> I keep trying to understand this example. I don't have any problems
>>>>>> with this example when I run it like this:
>>>>>> [salaza11 at maya PETSC]$ ./ex12 -bc_type dirichlet -interpolate
>>>>>> -petscspace_order 1 -variable_coefficient nonlinear -dim 2 -run_type full
>>>>>> -show_solution
>>>>>> Number of SNES iterations = 5
>>>>>> L_2 Error: 0.107289
>>>>>> Solution
>>>>>> Vec Object: 1 MPI processes
>>>>>>   type: seq
>>>>>> 0.484618
>>>>>> However, when I change the boundary conditions to Neumann, I get this
>>>>>> error.
>>>>>> [salaza11 at maya PETSC]$ ./ex12 -bc_type neumann -interpolate 1
>>>>>> -petscspace_order 2 -variable_coefficient nonlinear -dim 2 -run_type full
>>>>>> -show_solution
>>>>> Here you set the order of the element used in bulk, but not on the
>>>>> boundary where you condition is, so it defaults to 0. In
>>>>> order to become more familiar, take a look at the tests that I run
>>>>> here:
>>>>> https://bitbucket.org/petsc/petsc/src/64715f0f033346c10c77b73cf58216d111db8789/config/builder.py?at=master#cl-216
>>>>>      Matt
>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>> [0]PETSC ERROR: Petsc has generated inconsistent data
>>>>>> [0]PETSC ERROR: Number of dual basis vectors 0 not equal to dimension
>>>>>> 1
>>>>>> [0]PETSC ERROR: See http://
>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>>>> shooting.
>>>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.4.3-4776-gb18359b
>>>>>>  GIT Date: 2014-03-04 10:53:30 -0600
>>>>>> [0]PETSC ERROR: ./ex12 on a linux-gnu-c-debug named maya by salaza11
>>>>>> Sat Mar 15 14:28:05 2014
>>>>>>  [0]PETSC ERROR: Configure options --download-mpich
>>>>>> --download-scientificpython --download-triangle --download-ctetgen
>>>>>> --download-chaco --with-c2html=0
>>>>>> [0]PETSC ERROR: #1 PetscDualSpaceSetUp_Lagrange() line 1763 in
>>>>>> /home/salaza11/petsc/src/dm/dt/interface/dtfe.c
>>>>>> [0]PETSC ERROR: #2 PetscDualSpaceSetUp() line 1277 in
>>>>>> [0]PETSC ERROR: #3 SetupElementCommon() line 474 in
>>>>>> /home/salaza11/workspace/PETSC/ex12.c
>>>>>> [0]PETSC ERROR: #4 SetupBdElement() line 559 in
>>>>>> [0]PETSC ERROR: #5 main() line 755 in
>>>>>> [0]PETSC ERROR: ----------------End of Error Message -------send
>>>>>> entire error message to petsc-maint at mcs.anl.gov----------
>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 77) - process 0
>>>>>> [unset]: aborting job:
>>>>>> I honestly do not know much about using dual spaces in a finite
>>>>>> element context. I have been trying to find some material that could help
>>>>>> me without much success. I tried to modify the dual space order with the
>>>>>> option -petscdualspace_order but I kept getting errors. In particular, I
>>>>>> got this when I set it to 1.
>>>>>> -show_solution -petscdualspace_order 1
>>>>>> [0]PETSC ERROR: PetscTrFreeDefault() called from PetscFESetUp_Basic()
>>>>>> line 2492 in /home/salaza11/petsc/src/dm/dt/interface/dtfe.c
>>>>>> [0]PETSC ERROR: Block [id=0(32)] at address 0x1cc32f0 is corrupted
>>>>>> (probably write past end of array)
>>>>>> [0]PETSC ERROR: Block allocated in PetscFESetUp_Basic() line 2483 in
>>>>>> [0]PETSC ERROR: Memory corruption:
>>>>>> http://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
>>>>>> [0]PETSC ERROR: Corrupted memory
>>>>>> shooting.
>>>>>> Sat Mar 15 14:37:34 2014
>>>>>> [0]PETSC ERROR: #1 PetscTrFreeDefault() line 289 in
>>>>>> /home/salaza11/petsc/src/sys/memory/mtr.c
>>>>>> [0]PETSC ERROR: #2 PetscFESetUp_Basic() line 2492 in
>>>>>> [0]PETSC ERROR: #3 PetscFESetUp() line 2126 in
>>>>>> [0]PETSC ERROR: #4 SetupElementCommon() line 482 in
>>>>>> [0]PETSC ERROR: #5 SetupElement() line 506 in
>>>>>> [0]PETSC ERROR: #6 main() line 754 in
>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>>>>>> Then again, I do not know much what I am doing given my ignorance
>>>>>> with respect to the dual spaces in FE. I apologize for that. My questions
>>>>>> are:
>>>>>> - Where could I find more resources in order to understand the PETSc
>>>>>> implementation of dual spaces for FE?
>>>>>> - Why does it run with Dirichlet but not with Neumann?
>>>>>> Thanks in advance.
>>>>>> Miguel.
>>>>>> On Tue, Mar 4, 2014 at 11:28 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> On Tue, Mar 4, 2014 at 12:01 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Tue, Mar 4, 2014 at 11:51 AM, Miguel Angel Salazar de Troya <
>>>>>>>>> I can run it now, thanks. Although if I run it with valgrind 3.5.0
>>>>>>>>> (should I update to the last version?) I get some memory leaks related with
>>>>>>>>> the function DMPlexCreateBoxMesh.
>>>>>>>> I will check it out.
>>>>>>> This is now fixed.
>>>>>>>   Thanks for finding it
>>>>>>>       Matt
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> [salaza11 at maya tutorials]$ valgrind --leak-check=full ./ex12
>>>>>>>>> -run_type test -refinement_limit 0.0    -bc_type dirichlet -interpolate 0
>>>>>>>>> -petscspace_order 1 -show_initial -dm_plex_print_fem 1
>>>>>>>>> ==9625== Memcheck, a memory error detector
>>>>>>>>> ==9625== Copyright (C) 2002-2009, and GNU GPL'd, by Julian Seward
>>>>>>>>> et al.
>>>>>>>>> ==9625== Using Valgrind-3.5.0 and LibVEX; rerun with -h for
>>>>>>>>> copyright info
>>>>>>>>> ==9625== Command: ./ex12 -run_type test -refinement_limit 0.0
>>>>>>>>> -bc_type dirichlet -interpolate 0 -petscspace_order 1 -show_initial
>>>>>>>>> ==9625==
>>>>>>>>> Local function:
>>>>>>>>>   type: seq
>>>>>>>>> 0
>>>>>>>>> 0.25
>>>>>>>>> 1
>>>>>>>>> 0.25
>>>>>>>>> 0.5
>>>>>>>>> 1.25
>>>>>>>>> 1
>>>>>>>>> 1.25
>>>>>>>>> 2
>>>>>>>>> Initial guess
>>>>>>>>>   type: seq
>>>>>>>>> 0.5
>>>>>>>>> L_2 Error: 0.111111
>>>>>>>>> Residual:
>>>>>>>>>   type: seq
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>>  0
>>>>>>>>> Initial Residual
>>>>>>>>>   type: seq
>>>>>>>>> 0
>>>>>>>>> L_2 Residual: 0
>>>>>>>>> Jacobian:
>>>>>>>>> Mat Object: 1 MPI processes
>>>>>>>>>   type: seqaij
>>>>>>>>> row 0: (0, 4)
>>>>>>>>> Residual:
>>>>>>>>>   type: seq
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> -2
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> 0
>>>>>>>>> Au - b = Au + F(0)
>>>>>>>>>   type: seq
>>>>>>>>> 0
>>>>>>>>> Linear L_2 Residual: 0
>>>>>>>>> ==9625==
>>>>>>>>> ==9625== HEAP SUMMARY:
>>>>>>>>> ==9625==     in use at exit: 288 bytes in 3 blocks
>>>>>>>>> ==9625==   total heap usage: 2,484 allocs, 2,481 frees, 1,009,287
>>>>>>>>> bytes allocated
>>>>>>>>> ==9625==
>>>>>>>>> ==9625== 48 bytes in 1 blocks are definitely lost in loss record 1
>>>>>>>>> of 3
>>>>>>>>> ==9625==    at 0x4A05E46: malloc (vg_replace_malloc.c:195)
>>>>>>>>> ==9625==    by 0x5D8D4E1: writepoly (triangle.c:12012)
>>>>>>>>> ==9625==    by 0x5D8FAAC: triangulate (triangle.c:13167)
>>>>>>>>> ==9625==    by 0x56B0884: DMPlexGenerate_Triangle (plex.c:3749)
>>>>>>>>> ==9625==    by 0x56B5EE4: DMPlexGenerate (plex.c:4503)
>>>>>>>>> ==9625==    by 0x567F414: DMPlexCreateBoxMesh (plexcreate.c:668)
>>>>>>>>> ==9625==    by 0x4051FA: CreateMesh (ex12.c:341)
>>>>>>>>> ==9625==    by 0x408D3D: main (ex12.c:651)
>>>>>>>>> ==9625==
>>>>>>>>> ==9625== 96 bytes in 1 blocks are definitely lost in loss record 2
>>>>>>>>> of 3
>>>>>>>>> ==9625==    by 0x5D8D485: writepoly (triangle.c:12004)
>>>>>>>>> ==9625==
>>>>>>>>> ==9625== 144 bytes in 1 blocks are definitely lost in loss record
>>>>>>>>> 3 of 3
>>>>>>>>> ==9625==    by 0x5D8CD20: writenodes (triangle.c:11718)
>>>>>>>>> ==9625==    by 0x5D8F9DE: triangulate (triangle.c:13132)
>>>>>>>>> ==9625==
>>>>>>>>> ==9625== LEAK SUMMARY:
>>>>>>>>> ==9625==    definitely lost: 288 bytes in 3 blocks
>>>>>>>>> ==9625==    indirectly lost: 0 bytes in 0 blocks
>>>>>>>>> ==9625==      possibly lost: 0 bytes in 0 blocks
>>>>>>>>> ==9625==    still reachable: 0 bytes in 0 blocks
>>>>>>>>> ==9625==         suppressed: 0 bytes in 0 blocks
>>>>>>>>> ==9625==
>>>>>>>>> ==9625== For counts of detected and suppressed errors, rerun with:
>>>>>>>>> -v
>>>>>>>>> ==9625== ERROR SUMMARY: 3 errors from 3 contexts (suppressed: 6
>>>>>>>>> from 6)
>>>>>>>>> On Mon, Mar 3, 2014 at 7:05 PM, Matthew Knepley <knepley at gmail.com
>>>>>>>>> > wrote:
>>>>>>>>>> On Mon, Mar 3, 2014 at 4:59 PM, Miguel Angel Salazar de Troya <
>>>>>>>>>>> You are welcome, thanks for your help.
>>>>>>>>>> Okay, I have rebuilt completely clean, and ex12 runs for me. Can
>>>>>>>>>> you try again after pulling?
>>>>>>>>>>   Thanks,
>>>>>>>>>>      Matt
>>>>>>>>>>>  On Mon, Mar 3, 2014 at 4:13 PM, Matthew Knepley <
>>>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>>>> On Mon, Mar 3, 2014 at 1:44 PM, Miguel Angel Salazar de Troya <
>>>>>>>>>>>>> Thanks. This is what I get.
>>>>>>>>>>>> Okay, this was broken by a new push to master/next in the last
>>>>>>>>>>>> few days. I have pushed a fix,
>>>>>>>>>>>> however next is currently broken due to a failure to check in a
>>>>>>>>>>>> file. This should be fixed shortly,
>>>>>>>>>>>> and then ex12 will work. I will mail you when its ready.
>>>>>>>>>>>>   Thanks for finding this,
>>>>>>>>>>>>       Matt
>>>>>>>>>>>>> (gdb) cont
>>>>>>>>>>>>> Continuing.
>>>>>>>>>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>>>>>>>>>> 0x00007fd6811bea7b in DMPlexComputeJacobianFEM (dm=0x159a180,
>>>>>>>>>>>>> X=0x168b5b0,
>>>>>>>>>>>>>     Jac=0x7fffae6e8a88, JacP=0x7fffae6e8a88,
>>>>>>>>>>>>> str=0x7fffae6e7970,
>>>>>>>>>>>>>     user=0x7fd6811be509)
>>>>>>>>>>>>>     at /home/salaza11/petsc/src/dm/impls/plex/plexfem.c:882
>>>>>>>>>>>>> 882         ierr = PetscFEGetDimension(fe[f],
>>>>>>>>>>>>> &Nb);CHKERRQ(ierr);
>>>>>>>>>>>>> (gdb) where
>>>>>>>>>>>>> #0  0x00007fd6811bea7b in DMPlexComputeJacobianFEM
>>>>>>>>>>>>> (dm=0x159a180, X=0x168b5b0,
>>>>>>>>>>>>> str=0x7fffae6e7970,
>>>>>>>>>>>>> #1  0x00007fd6814a5bf6 in SNESComputeJacobian_DMLocal
>>>>>>>>>>>>> (snes=0x14e9450,
>>>>>>>>>>>>>     X=0x1622ad0, A=0x7fffae6e8a88, B=0x7fffae6e8a88,
>>>>>>>>>>>>> ctx=0x1652300)
>>>>>>>>>>>>>     at /home/salaza11/petsc/src/snes/utils/dmlocalsnes.c:102
>>>>>>>>>>>>> #2  0x00007fd6814cc609 in SNESComputeJacobian (snes=0x14e9450,
>>>>>>>>>>>>> X=0x1622ad0,
>>>>>>>>>>>>>     A=0x7fffae6e8a88, B=0x7fffae6e8a88)
>>>>>>>>>>>>>     at /home/salaza11/petsc/src/snes/interface/snes.c:2245
>>>>>>>>>>>>> #3  0x000000000040af72 in main (argc=15, argv=0x7fffae6e8bc8)
>>>>>>>>>>>>>     at
>>>>>>>>>>>>> /home/salaza11/petsc/src/snes/examples/tutorials/ex12.c:784
>>>>>>>>>>>>> On Mon, Mar 3, 2014 at 1:40 PM, Matthew Knepley <
>>>>>>>>>>>>>> On Mon, Mar 3, 2014 at 1:39 PM, Miguel Angel Salazar de Troya
>>>>>>>>>>>>>> <salazardetroya at gmail.com> wrote:
>>>>>>>>>>>>>>> This is what I get at gdb when I type 'where'.
>>>>>>>>>>>>>> You have to type 'cont', and then when it fails you type
>>>>>>>>>>>>>> 'where'.
>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>> #0  0x000000310e0aa860 in __nanosleep_nocancel () from
>>>>>>>>>>>>>>> /lib64/libc.so.6
>>>>>>>>>>>>>>> #1  0x000000310e0aa70f in sleep () from /lib64/libc.so.6
>>>>>>>>>>>>>>> #2  0x00007fd83a00a8be in PetscSleep (s=10)
>>>>>>>>>>>>>>>     at /home/salaza11/petsc/src/sys/utils/psleep.c:52
>>>>>>>>>>>>>>> #3  0x00007fd83a06f331 in PetscAttachDebugger ()
>>>>>>>>>>>>>>>     at /home/salaza11/petsc/src/sys/error/adebug.c:397
>>>>>>>>>>>>>>> #4  0x00007fd83a0af1d2 in PetscOptionsCheckInitial_Private ()
>>>>>>>>>>>>>>>     at /home/salaza11/petsc/src/sys/objects/init.c:444
>>>>>>>>>>>>>>> #5  0x00007fd83a0b6448 in PetscInitialize
>>>>>>>>>>>>>>> (argc=0x7fff5cd8df2c,
>>>>>>>>>>>>>>>     args=0x7fff5cd8df20, file=0x0,
>>>>>>>>>>>>>>>     help=0x60ce40 "Poisson Problem in 2d and 3d with
>>>>>>>>>>>>>>> simplicial finite elements.\nWe solve the Poisson problem in a
>>>>>>>>>>>>>>> rectangular\ndomain, using a parallel unstructured mesh (DMPLEX) to
>>>>>>>>>>>>>>> discretize it.\n\n\n")
>>>>>>>>>>>>>>>     at /home/salaza11/petsc/src/sys/objects/pinit.c:876
>>>>>>>>>>>>>>> #6  0x0000000000408f2c in main (argc=15, argv=0x7fff5cd8f1f8)
>>>>>>>>>>>>>>>     at
>>>>>>>>>>>>>>> /home/salaza11/petsc/src/snes/examples/tutorials/ex12.c:663
>>>>>>>>>>>>>>> The rest of the gdb output is attached. I am a bit ignorant
>>>>>>>>>>>>>>> with gdb, I apologize for that.
>>>>>>>>>>>>>>> On Mon, Mar 3, 2014 at 12:48 PM, Matthew Knepley <
>>>>>>>>>>>>>>>> On Mon, Mar 3, 2014 at 12:39 PM, Miguel Angel Salazar de
>>>>>>>>>>>>>>>> Troya <salazardetroya at gmail.com> wrote:
>>>>>>>>>>>>>>>>> Thanks for your response. Sorry I did not have the "next"
>>>>>>>>>>>>>>>>> version, but the "master" version. I still have an error though. I followed
>>>>>>>>>>>>>>>>> the steps given here (
>>>>>>>>>>>>>>>>> https://bitbucket.org/petsc/petsc/wiki/Home) to obtain
>>>>>>>>>>>>>>>>> the next version, I configured petsc as above and ran ex12 as above as
>>>>>>>>>>>>>>>>> well, getting this error:
>>>>>>>>>>>>>>>>> [salaza11 at maya tutorials]$ ./ex12 -run_type test
>>>>>>>>>>>>>>>>> Local function:
>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0.25
>>>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>>>> 0.25
>>>>>>>>>>>>>>>>> 0.5
>>>>>>>>>>>>>>>>> 1.25
>>>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>>>> 1.25
>>>>>>>>>>>>>>>>> 2
>>>>>>>>>>>>>>>>> Initial guess
>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>> 0.5
>>>>>>>>>>>>>>>>> L_2 Error: 0.111111
>>>>>>>>>>>>>>>>> Residual:
>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> Initial Residual
>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> L_2 Residual: 0
>>>>>>>>>>>>>>>> Okay, now run with -start_in_debugger, and give me a stack
>>>>>>>>>>>>>>>> trace using 'where'.
>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>>>  [0]PETSC ERROR:
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>>>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>>>>>>>> -on_error_attach_debugger
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: or see
>>>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
>>>>>>>>>>>>>>>>> http://valgrind.org on GNU/linux and Apple Mac OS X to
>>>>>>>>>>>>>>>>> find memory corruption errors
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: likely location of problem given in stack
>>>>>>>>>>>>>>>>> below
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack
>>>>>>>>>>>>>>>>> are not available,
>>>>>>>>>>>>>>>>> [0]PETSC ERROR:       INSTEAD the line number of the start
>>>>>>>>>>>>>>>>> of the function
>>>>>>>>>>>>>>>>> [0]PETSC ERROR:       is given.
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] DMPlexComputeJacobianFEM line 871
>>>>>>>>>>>>>>>>>  [0]PETSC ERROR: [0] SNESComputeJacobian_DMLocal line 94
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNES user Jacobian function line 2244
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeJacobian line 2203
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Signal received
>>>>>>>>>>>>>>>>> trouble shooting.
>>>>>>>>>>>>>>>>> v3.4.3-4705-gfb6b3bc  GIT Date: 2014-03-03 08:23:43 -0600
>>>>>>>>>>>>>>>>> by salaza11 Mon Mar  3 11:49:15 2014
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: #1 User provided function() line 0 in
>>>>>>>>>>>>>>>>>  unknown file
>>>>>>>>>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> On Sun, Mar 2, 2014 at 7:11 PM, Matthew Knepley <
>>>>>>>>>>>>>>>>>> On Sun, Mar 2, 2014 at 6:54 PM, Miguel Angel Salazar de
>>>>>>>>>>>>>>>>>>> Hi everybody
>>>>>>>>>>>>>>>>>>> I am trying to run example ex12.c without much success.
>>>>>>>>>>>>>>>>>>> I specifically run it with the command options:
>>>>>>>>>>>>>>>>>> We need to start narrowing down differences, because it
>>>>>>>>>>>>>>>>>> runs for me and our nightly tests. So, first can
>>>>>>>>>>>>>>>>>> you confirm that you are using the latest 'next' branch?
>>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>>>>> And I get this output
>>>>>>>>>>>>>>>>>>> Local function:
>>>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>>>>>> 2
>>>>>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>>>>>> 2
>>>>>>>>>>>>>>>>>>> 2
>>>>>>>>>>>>>>>>>>> 3
>>>>>>>>>>>>>>>>>>> Initial guess
>>>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>>>> L_2 Error: 0.625
>>>>>>>>>>>>>>>>>>> Residual:
>>>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>>>> Initial Residual
>>>>>>>>>>>>>>>>>>>   type: seq
>>>>>>>>>>>>>>>>>>> L_2 Residual: 0
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>> Segmentation Violation, probably memory access out of range
>>>>>>>>>>>>>>>>>>> stack below
>>>>>>>>>>>>>>>>>>> stack are not available,
>>>>>>>>>>>>>>>>>>> start of the function
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] DMPlexComputeJacobianFEM line 867
>>>>>>>>>>>>>>>>>>> 2244 /home/salaza11/petsc/src/snes/interface/snes.c
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Signal received!
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>> v3.4.3-3453-g0a94005  GIT Date: 2014-03-02 13:12:04 -0600
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent
>>>>>>>>>>>>>>>>>>> updates.
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about
>>>>>>>>>>>>>>>>>>> trouble shooting.
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>> by salaza11 Sun Mar  2 17:00:09 2014
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>>>>>>>>>>>> /home/salaza11/petsc/linux-gnu-c-debug/lib
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure run at Sun Mar  2 16:46:51 2014
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: User provided function() line 0 in
>>>>>>>>>>>>>>>>>>>  unknown file
>>>>>>>>>>>>>>>>>>> process 0
>>>>>>>>>>>>>>>>>>> process 0
>>>>>>>>>>>>>>>>>>> Probably my problems could be on my configuration. I
>>>>>>>>>>>>>>>>>>> attach the configure.log. I ran ./configure like this
>>>>>>>>>>>>>>>>>>> ./configure --download-mpich --download-scientificpython
>>>>>>>>>>>>>>>>>>> --download-triangle --download-ctetgen --download-chaco --with-c2html=0
>>>>>>>>>>>>>>>>>>> Thanks a lot in advance.
>>>>>>>>>>>>>>>>>>> On Tue, Jan 28, 2014 at 10:37 AM, Matthew Knepley <
>>>>>>>>>>>>>>>>>>>> On Tue, Jan 28, 2014 at 10:31 AM, Yaakoub El Khamra <
>>>>>>>>>>>>>>>>>>>> yelkhamra at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>>>> If
>>>>>>>>>>>>>>>>>>>>>  ./ex12 -run_type test -dim 3 -refinement_limit
>>>>>>>>>>>>>>>>>>>>> 0.0125 -variable_coefficient field    -interpolate 1 -petscspace_order 2
>>>>>>>>>>>>>>>>>>>>> is for serial, any chance we can get the options to
>>>>>>>>>>>>>>>>>>>>> run in parallel?
>>>>>>>>>>>>>>>>>>>> Just use mpiexec -n <procs>
>>>>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>>>> Regards
>>>>>>>>>>>>>>>>>>>>> Yaakoub El Khamra
>>>>>>>>>>>>>>>>>>>>> On Fri, Jan 17, 2014 at 11:29 AM, Matthew Knepley <
>>>>>>>>>>>>>>>>>>>>>> On Fri, Jan 17, 2014 at 11:06 AM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>> Alexander <MAJones2 at mdanderson.org> wrote:
>>>>>>>>>>>>>>>>>>>>>>> *From:* Matthew Knepley [knepley at gmail.com]
>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Friday, January 17, 2014 11:04 AM
>>>>>>>>>>>>>>>>>>>>>>> *To:* Jones,Martin Alexander
>>>>>>>>>>>>>>>>>>>>>>> *Cc:* petsc-users at mcs.anl.gov
>>>>>>>>>>>>>>>>>>>>>>> *Subject:* Re: [petsc-users] Problems running ex12.c
>>>>>>>>>>>>>>>>>>>>>>>    On Fri, Jan 17, 2014 at 11:00 AM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>>>  These examples all seem to run excepting the
>>>>>>>>>>>>>>>>>>>>>>>> following command,
>>>>>>>>>>>>>>>>>>>>>>>> ex12 -run_type test -dim 3 -refinement_limit 0.0125
>>>>>>>>>>>>>>>>>>>>>>>> I get the following ouput:
>>>>>>>>>>>>>>>>>>>>>>>> Local function:
>>>>>>>>>>>>>>>>>>>>>>>> ./ex12: symbol lookup error:
>>>>>>>>>>>>>>>>>>>>>>>> /opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so: undefined
>>>>>>>>>>>>>>>>>>>>>>>> symbol: omp_get_num_procs
>>>>>>>>>>>>>>>>>>>>>>>  This is a build problem, but it should affect all
>>>>>>>>>>>>>>>>>>>>>>> the runs. Is this reproducible? Can you send configure.log? MKL is the
>>>>>>>>>>>>>>>>>>>>>>> worst. If this
>>>>>>>>>>>>>>>>>>>>>>> persists, I would just switch to
>>>>>>>>>>>>>>>>>>>>>>> --download-f-blas-lapack.
>>>>>>>>>>>>>>>>>>>>>> Thanks. I have some advice on options
>>>>>>>>>>>>>>>>>>>>>>   --with-precision=single # I would not use this
>>>>>>>>>>>>>>>>>>>>>> unless you are doing something special, like CUDA
>>>>>>>>>>>>>>>>>>>>>>   --with-clanguage=C++  # I would recommend switching
>>>>>>>>>>>>>>>>>>>>>> to C, the build is much faster
>>>>>>>>>>>>>>>>>>>>>>   --with-mpi-dir=/usr --with-mpi4py=0
>>>>>>>>>>>>>>>>>>>>>>   --with-shared-libraries --CFLAGS=-O0 --CXXFLAGS=-O0
>>>>>>>>>>>>>>>>>>>>>> --with-fc=0
>>>>>>>>>>>>>>>>>>>>>>   --with-etags=1                # This is unnecessary
>>>>>>>>>>>>>>>>>>>>>> --with-blas-lapack-lib="[/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_rt.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_core.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libiomp5.so]"
>>>>>>>>>>>>>>>>>>>>>> # Here is the problem, see below
>>>>>>>>>>>>>>>>>>>>>>   --download-metis
>>>>>>>>>>>>>>>>>>>>>>   --download-fiat=yes --download-generator
>>>>>>>>>>>>>>>>>>>>>> --download-scientificpython # Get rid of these, they are obsolete
>>>>>>>>>>>>>>>>>>>>>> Your MKL needs another library for the OpenMP
>>>>>>>>>>>>>>>>>>>>>> symbols. I would recommend switching to --download-f2cblaslapack,
>>>>>>>>>>>>>>>>>>>>>> or you can try and find that library.
>>>>>>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>>>>>>>>>    Thanks,
>>>>>>>>>>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 6:35 PM
>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 5:43 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>>>>  Hi, This is the next error message after
>>>>>>>>>>>>>>>>>>>>>>>>> configuring and building with the triangle package when trying to run ex12
>>>>>>>>>>>>>>>>>>>>>>>>  This is my fault for bad defaults. I will fix.
>>>>>>>>>>>>>>>>>>>>>>>> Try running
>>>>>>>>>>>>>>>>>>>>>>>>  for a representative run. Then you could try 3D
>>>>>>>>>>>>>>>>>>>>>>>>  or a full run
>>>>>>>>>>>>>>>>>>>>>>>>    ex12 -refinement_limit 0.01 -bc_type dirichlet
>>>>>>>>>>>>>>>>>>>>>>>> -interpolate -petscspace_order 1
>>>>>>>>>>>>>>>>>>>>>>>> -interpolate -petscspace_order 2
>>>>>>>>>>>>>>>>>>>>>>>>  Let me know if those work.
>>>>>>>>>>>>>>>>>>>>>>>>    Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>>>>>>>>>>>   ./ex12
>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Caught signal number 8 FPE:
>>>>>>>>>>>>>>>>>>>>>>>>> Floating Point Exception,probably divide by zero
>>>>>>>>>>>>>>>>>>>>>>>>> X to find memory corruption errors
>>>>>>>>>>>>>>>>>>>>>>>>> in stack below
>>>>>>>>>>>>>>>>>>>>>>>>> Frames ------------------------------------
>>>>>>>>>>>>>>>>>>>>>>>>> the stack are not available,
>>>>>>>>>>>>>>>>>>>>>>>>> the start of the function
>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] DMPlexComputeResidualFEM line
>>>>>>>>>>>>>>>>>>>>>>>>> 531 /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexfem.c
>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeFunction_DMLocal
>>>>>>>>>>>>>>>>>>>>>>>>> line 63 /home/mjonesa/PETSc/petsc/src/snes/utils/dmlocalsnes.c
>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNES user function line 2088
>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/interface/snes.c
>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeFunction line 2076
>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESSolve_NEWTONLS line 144
>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/impls/ls/ls.c
>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESSolve line 3765
>>>>>>>>>>>>>>>>>>>>>>>>> Message ------------------------------------
>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>> v3.4.3-2317-gcd0e7f7  GIT Date: 2014-01-15 20:33:42 -0600
>>>>>>>>>>>>>>>>>>>>>>>>> recent updates.
>>>>>>>>>>>>>>>>>>>>>>>>> trouble shooting.
>>>>>>>>>>>>>>>>>>>>>>>>> pages.
>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: ./ex12 on a arch-linux2-cxx-debug
>>>>>>>>>>>>>>>>>>>>>>>>> named maeda by mjonesa Thu Jan 16 17:41:23 2014
>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/local/lib
>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure run at Thu Jan 16
>>>>>>>>>>>>>>>>>>>>>>>>> 17:38:33 2014
>>>>>>>>>>>>>>>>>>>>>>>>> --prefix=/home/mjonesa/local
>>>>>>>>>>>>>>>>>>>>>>>>> --with-c2html=0 --with-clanguage=c++ PETSC_ARCH=arch-linux2-cxx-debug
>>>>>>>>>>>>>>>>>>>>>>>>> --download-triangle
>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>>  unknown file
>>>>>>>>>>>>>>>>>>>>>>>>> process 0
>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 4:37 PM
>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 4:33 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>>>>>  Hi, I have downloaded and built the dev version
>>>>>>>>>>>>>>>>>>>>>>>>>> you suggested. I think I need the triangle package to run this particular
>>>>>>>>>>>>>>>>>>>>>>>>>> case. Is there any thing else that appears wrong in what I have done from
>>>>>>>>>>>>>>>>>>>>>>>>>> the error messages below:
>>>>>>>>>>>>>>>>>>>>>>>>>  Great! Its running. You can reconfigure like
>>>>>>>>>>>>>>>>>>>>>>>>> this:
>>>>>>>>>>>>>>>>>>>>>>>>> $PETSC_DIR/$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py --download-triangle
>>>>>>>>>>>>>>>>>>>>>>>>>  and then rebuild
>>>>>>>>>>>>>>>>>>>>>>>>>     make
>>>>>>>>>>>>>>>>>>>>>>>>>  and then rerun. You can load meshes, but its
>>>>>>>>>>>>>>>>>>>>>>>>> much easier to have triangle create them.
>>>>>>>>>>>>>>>>>>>>>>>>>    Thanks for being patient,
>>>>>>>>>>>>>>>>>>>>>>>>>       Matt
>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: No support for this operation for
>>>>>>>>>>>>>>>>>>>>>>>>>> this object type!
>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Mesh generation needs external
>>>>>>>>>>>>>>>>>>>>>>>>>> package support.
>>>>>>>>>>>>>>>>>>>>>>>>>> Please reconfigure with --download-triangle.!
>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>>> recent updates.
>>>>>>>>>>>>>>>>>>>>>>>>>> trouble shooting.
>>>>>>>>>>>>>>>>>>>>>>>>>> pages.
>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>>> named maeda by mjonesa Thu Jan 16 16:28:20 2014
>>>>>>>>>>>>>>>>>>>>>>>>>> 16:25:53 2014
>>>>>>>>>>>>>>>>>>>>>>>>>> --prefix=/home/mjonesa/local --with-clanguage=c++ --with-c2html=0
>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: DMPlexGenerate() line 4332 in
>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plex.c
>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: DMPlexCreateBoxMesh() line 600 in
>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexcreate.c
>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: CreateMesh() line 295 in
>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/examples/tutorials/ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: main() line 659 in
>>>>>>>>>>>>>>>>>>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 56)
>>>>>>>>>>>>>>>>>>>>>>>>>> - process 0
>>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 4:06 PM
>>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 4:05 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>>>>>>  Hi. I changed the ENV variable to the correct
>>>>>>>>>>>>>>>>>>>>>>>>>>> entry. when I type make ex12 I get this:
>>>>>>>>>>>>>>>>>>>>>>>>>>> mjonesa at maeda:~/PETSc/petsc-3.4.3/src/snes/examples/tutorials$
>>>>>>>>>>>>>>>>>>>>>>>>>>> make ex12
>>>>>>>>>>>>>>>>>>>>>>>>>>> g++ -o ex12.o -c -Wall -Wwrite-strings
>>>>>>>>>>>>>>>>>>>>>>>>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -g   -fPIC
>>>>>>>>>>>>>>>>>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include
>>>>>>>>>>>>>>>>>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/arch-linux2-cxx-debug/include
>>>>>>>>>>>>>>>>>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include/mpiuni
>>>>>>>>>>>>>>>>>>>>>>>>>>> -D__INSDIR__=src/snes/examples/tutorials/ ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c:14:18: fatal error: ex12.h: No such file
>>>>>>>>>>>>>>>>>>>>>>>>>>> or directory
>>>>>>>>>>>>>>>>>>>>>>>>>>> compilation terminated.
>>>>>>>>>>>>>>>>>>>>>>>>>>> make: *** [ex12.o] Error 1
>>>>>>>>>>>>>>>>>>>>>>>>>>> Any help of yours is very much appreciated.
>>>>>>>>>>>>>>>>>>>>>>>>>>  Yes, this relates to my 3). This is not going
>>>>>>>>>>>>>>>>>>>>>>>>>> to work for you with the release. Please see the link I sent.
>>>>>>>>>>>>>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 3:58 PM
>>>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 3:55 PM,
>>>>>>>>>>>>>>>>>>>>>>>>>>> Jones,Martin Alexander <MAJones2 at mdanderson.org>wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Thanks!
>>>>>>>>>>>>>>>>>>>>>>>>>>>  You built with PETSC_ARCH=arch-linux2-cxx-debug
>>>>>>>>>>>>>>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 3:31 PM
>>>>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>>    On Thu, Jan 16, 2014 at 3:11 PM,
>>>>>>>>>>>>>>>>>>>>>>>>>>>> > wrote:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>  Now I went to the directory where ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> sits and just did a 'make ex12.c' with the following error if this helps?  :
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> make ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/variables:108:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscvariables: No
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> such file or directory
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/rules:962:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules: No
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> make: *** No rule to make target
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> `/home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules'.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Stop.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>  1) You would type 'make ex12'
>>>>>>>>>>>>>>>>>>>>>>>>>>>>  2) Either you PETSC_DIR (
>>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3) or PETSC_ARCH
>>>>>>>>>>>>>>>>>>>>>>>>>>>> (linux-gnu-cxx-debug) environment variables
>>>>>>>>>>>>>>>>>>>>>>>>>>>>     do not match what you built. Please send
>>>>>>>>>>>>>>>>>>>>>>>>>>>> configure.log and make.log
>>>>>>>>>>>>>>>>>>>>>>>>>>>>  3) Since it was only recently added, if you
>>>>>>>>>>>>>>>>>>>>>>>>>>>> want to use the FEM functionality, you must use the development version:
>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/developers/index.html
>>>>>>>>>>>>>>>>>>>>>>>>>>>>    Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>        Matt
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> *From:* Matthew Knepley [mailto:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 2:48 PM
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jan 16, 2014 at 2:35 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Hello To Whom it Concerns,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> I am trying to run the tutorial ex12.c by
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> running 'bin/pythonscripts/PetscGenerateFEMQuadrature.py
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> dim order dim 1 laplacian dim order dim 1 boundary
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> src/snes/examples/tutorials/ex12.h'
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> but getting the following error:
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> bin/pythonscripts/PetscGenerateFEMQuadrature.py dim order dim 1 laplacian
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> dim order dim 1 boundary src/snes/examples/tutorials/ex12.h
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>   File
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> "bin/pythonscripts/PetscGenerateFEMQuadrature.py", line 15, in <module>
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>     from FIAT.reference_element import
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> default_simplex
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> ImportError: No module named
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> I have removed the requirement of generating
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> the header file (its now all handled in C). I thought
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> I changed the documentation everywhere
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> (including the latest tutorial slides). Can you try running
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> with 'master' (or 'next'), and point me toward
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> the old docs?
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>     Matt
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> before they begin their experiments is infinitely more interesting than any
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> results to which their experiments lead.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before
>>>>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>> *Miguel Angel Salazar de Troya*
>>>>>>>>>>>>>>>>>>> Graduate Research Assistant
>>>>>>>>>>>>>>>>>>> Department of Mechanical Science and Engineering
>>>>>>>>>>>>>>>>>>> University of Illinois at Urbana-Champaign
>>>>>>>>>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>>>>>>>>>> salaza11 at illinois.edu
>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> (217) 550-2360
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> (217) 550-2360
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> (217) 550-2360
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> (217) 550-2360
>>> (217) 550-2360
>> experiments lead.
>> -- Norbert Wiener
> (217) 550-2360
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140330/2a48a726/attachment-0001.html>
