[petsc-users] Problems running ex12.c
Matthew Knepley
knepley at gmail.com
Sun Mar 30 14:01:17 CDT 2014
On Sun, Mar 30, 2014 at 1:57 PM, Miguel Angel Salazar de Troya <
salazardetroya at gmail.com> wrote:
> Hello everybody
> I had a question about this example. In the petsc-dev next version, why
> don't we create a PetscSection in the function SetupSection, but we do it
> in the function SetupMaterialSection and in the function SetupSection of
> the petsc-current version.
1) I wanted to try and make things more automatic for the user
2) I needed a way to automatically layout data for coarser/finer grids in
unstructured MG
Thus, now when you set for PetscFE into the DM using DMSetField(), it will
automatically create
the section on the first call to DMGetDefaultSection().
I do not have a similar provision now for materials, so you create your own
section. I think this is
alright until we have some idea of a nicer interface.
Matt
> petsc-dev:
> #undef __FUNCT__
> #define __FUNCT__ "SetupSection"
> PetscErrorCode SetupSection(DM dm, AppCtx *user)
> DM cdm = dm;
> const PetscInt id = 1;
> PetscErrorCode ierr;
> PetscFunctionBeginUser;
> ierr = PetscObjectSetName((PetscObject) user->fe[0],
> "potential");CHKERRQ(ierr);
> while (cdm) {
> ierr = DMSetNumFields(cdm, 1);CHKERRQ(ierr);
> ierr = DMSetField(cdm, 0, (PetscObject) user->fe[0]);CHKERRQ(ierr);
> ierr = DMPlexAddBoundary(cdm, user->bcType == DIRICHLET, user->bcType
> == NEUMANN ? "boundary" : "marker", 0, user->exactFuncs[0], 1, &id,
> user);CHKERRQ(ierr);
> ierr = DMPlexGetCoarseDM(cdm, &cdm);CHKERRQ(ierr);
> PetscFunctionReturn(0);
> It seems that it adds the number of fields directly to the DM, and takes
> the number of components that were specified in SetupElementCommon, but
> what about the number of degrees of freedom? Why we added it for the
> MaterialSection but not for the regular Section.
> Thanks in advance
> Miguel
> On Sat, Mar 15, 2014 at 4:16 PM, Miguel Angel Salazar de Troya <
>> Thanks a lot.
>> On Sat, Mar 15, 2014 at 3:36 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Sat, Mar 15, 2014 at 3:31 PM, Miguel Angel Salazar de Troya <
>>>> Hello everybody
>>>> I keep trying to understand this example. I don't have any problems
>>>> with this example when I run it like this:
>>>> [salaza11 at maya PETSC]$ ./ex12 -bc_type dirichlet -interpolate
>>>> -petscspace_order 1 -variable_coefficient nonlinear -dim 2 -run_type full
>>>> -show_solution
>>>> Number of SNES iterations = 5
>>>> L_2 Error: 0.107289
>>>> Solution
>>>> Vec Object: 1 MPI processes
>>>> type: seq
>>>> 0.484618
>>>> However, when I change the boundary conditions to Neumann, I get this
>>>> error.
>>>> [salaza11 at maya PETSC]$ ./ex12 -bc_type neumann -interpolate 1
>>>> -petscspace_order 2 -variable_coefficient nonlinear -dim 2 -run_type full
>>>> -show_solution
>>> Here you set the order of the element used in bulk, but not on the
>>> boundary where you condition is, so it defaults to 0. In
>>> order to become more familiar, take a look at the tests that I run here:
>>> https://bitbucket.org/petsc/petsc/src/64715f0f033346c10c77b73cf58216d111db8789/config/builder.py?at=master#cl-216
>>> Matt
>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Petsc has generated inconsistent data
>>>> [0]PETSC ERROR: Number of dual basis vectors 0 not equal to dimension 1
>>>> [0]PETSC ERROR: See http://
>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>> shooting.
>>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.4.3-4776-gb18359b
>>>> GIT Date: 2014-03-04 10:53:30 -0600
>>>> [0]PETSC ERROR: ./ex12 on a linux-gnu-c-debug named maya by salaza11
>>>> Sat Mar 15 14:28:05 2014
>>>> [0]PETSC ERROR: Configure options --download-mpich
>>>> --download-scientificpython --download-triangle --download-ctetgen
>>>> --download-chaco --with-c2html=0
>>>> [0]PETSC ERROR: #1 PetscDualSpaceSetUp_Lagrange() line 1763 in
>>>> /home/salaza11/petsc/src/dm/dt/interface/dtfe.c
>>>> [0]PETSC ERROR: #2 PetscDualSpaceSetUp() line 1277 in
>>>> [0]PETSC ERROR: #3 SetupElementCommon() line 474 in
>>>> /home/salaza11/workspace/PETSC/ex12.c
>>>> [0]PETSC ERROR: #4 SetupBdElement() line 559 in
>>>> [0]PETSC ERROR: #5 main() line 755 in
>>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>>> error message to petsc-maint at mcs.anl.gov----------
>>>> application called MPI_Abort(MPI_COMM_WORLD, 77) - process 0
>>>> [unset]: aborting job:
>>>> I honestly do not know much about using dual spaces in a finite element
>>>> context. I have been trying to find some material that could help me
>>>> without much success. I tried to modify the dual space order with the
>>>> option -petscdualspace_order but I kept getting errors. In particular, I
>>>> got this when I set it to 1.
>>>> -show_solution -petscdualspace_order 1
>>>> [0]PETSC ERROR: PetscTrFreeDefault() called from PetscFESetUp_Basic()
>>>> line 2492 in /home/salaza11/petsc/src/dm/dt/interface/dtfe.c
>>>> [0]PETSC ERROR: Block [id=0(32)] at address 0x1cc32f0 is corrupted
>>>> (probably write past end of array)
>>>> [0]PETSC ERROR: Block allocated in PetscFESetUp_Basic() line 2483 in
>>>> [0]PETSC ERROR: Memory corruption:
>>>> http://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
>>>> [0]PETSC ERROR: Corrupted memory
>>>> shooting.
>>>> Sat Mar 15 14:37:34 2014
>>>> [0]PETSC ERROR: #1 PetscTrFreeDefault() line 289 in
>>>> /home/salaza11/petsc/src/sys/memory/mtr.c
>>>> [0]PETSC ERROR: #2 PetscFESetUp_Basic() line 2492 in
>>>> [0]PETSC ERROR: #3 PetscFESetUp() line 2126 in
>>>> [0]PETSC ERROR: #4 SetupElementCommon() line 482 in
>>>> [0]PETSC ERROR: #5 SetupElement() line 506 in
>>>> [0]PETSC ERROR: #6 main() line 754 in
>>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>>>> Then again, I do not know much what I am doing given my ignorance with
>>>> respect to the dual spaces in FE. I apologize for that. My questions are:
>>>> - Where could I find more resources in order to understand the PETSc
>>>> implementation of dual spaces for FE?
>>>> - Why does it run with Dirichlet but not with Neumann?
>>>> Thanks in advance.
>>>> Miguel.
>>>> On Tue, Mar 4, 2014 at 11:28 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Tue, Mar 4, 2014 at 12:01 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Tue, Mar 4, 2014 at 11:51 AM, Miguel Angel Salazar de Troya <
>>>>>>> I can run it now, thanks. Although if I run it with valgrind 3.5.0
>>>>>>> (should I update to the last version?) I get some memory leaks related with
>>>>>>> the function DMPlexCreateBoxMesh.
>>>>>> I will check it out.
>>>>> This is now fixed.
>>>>> Thanks for finding it
>>>>> Matt
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> [salaza11 at maya tutorials]$ valgrind --leak-check=full ./ex12
>>>>>>> -run_type test -refinement_limit 0.0 -bc_type dirichlet -interpolate 0
>>>>>>> -petscspace_order 1 -show_initial -dm_plex_print_fem 1
>>>>>>> ==9625== Memcheck, a memory error detector
>>>>>>> ==9625== Copyright (C) 2002-2009, and GNU GPL'd, by Julian Seward et
>>>>>>> al.
>>>>>>> ==9625== Using Valgrind-3.5.0 and LibVEX; rerun with -h for
>>>>>>> copyright info
>>>>>>> ==9625== Command: ./ex12 -run_type test -refinement_limit 0.0
>>>>>>> -bc_type dirichlet -interpolate 0 -petscspace_order 1 -show_initial
>>>>>>> ==9625==
>>>>>>> Local function:
>>>>>>> type: seq
>>>>>>> 0
>>>>>>> 0.25
>>>>>>> 1
>>>>>>> 0.25
>>>>>>> 0.5
>>>>>>> 1.25
>>>>>>> 1
>>>>>>> 1.25
>>>>>>> 2
>>>>>>> Initial guess
>>>>>>> type: seq
>>>>>>> 0.5
>>>>>>> L_2 Error: 0.111111
>>>>>>> Residual:
>>>>>>> type: seq
>>>>>>> 0
>>>>>>> 0
>>>>>>> 0
>>>>>>> 0
>>>>>>> 0
>>>>>>> 0
>>>>>>> 0
>>>>>>> 0
>>>>>>> 0
>>>>>>> Initial Residual
>>>>>>> type: seq
>>>>>>> 0
>>>>>>> L_2 Residual: 0
>>>>>>> Jacobian:
>>>>>>> Mat Object: 1 MPI processes
>>>>>>> type: seqaij
>>>>>>> row 0: (0, 4)
>>>>>>> Residual:
>>>>>>> type: seq
>>>>>>> 0
>>>>>>> 0
>>>>>>> 0
>>>>>>> 0
>>>>>>> -2
>>>>>>> 0
>>>>>>> 0
>>>>>>> 0
>>>>>>> 0
>>>>>>> Au - b = Au + F(0)
>>>>>>> type: seq
>>>>>>> 0
>>>>>>> Linear L_2 Residual: 0
>>>>>>> ==9625==
>>>>>>> ==9625== HEAP SUMMARY:
>>>>>>> ==9625== in use at exit: 288 bytes in 3 blocks
>>>>>>> ==9625== total heap usage: 2,484 allocs, 2,481 frees, 1,009,287
>>>>>>> bytes allocated
>>>>>>> ==9625==
>>>>>>> ==9625== 48 bytes in 1 blocks are definitely lost in loss record 1
>>>>>>> of 3
>>>>>>> ==9625== at 0x4A05E46: malloc (vg_replace_malloc.c:195)
>>>>>>> ==9625== by 0x5D8D4E1: writepoly (triangle.c:12012)
>>>>>>> ==9625== by 0x5D8FAAC: triangulate (triangle.c:13167)
>>>>>>> ==9625== by 0x56B0884: DMPlexGenerate_Triangle (plex.c:3749)
>>>>>>> ==9625== by 0x56B5EE4: DMPlexGenerate (plex.c:4503)
>>>>>>> ==9625== by 0x567F414: DMPlexCreateBoxMesh (plexcreate.c:668)
>>>>>>> ==9625== by 0x4051FA: CreateMesh (ex12.c:341)
>>>>>>> ==9625== by 0x408D3D: main (ex12.c:651)
>>>>>>> ==9625==
>>>>>>> ==9625== 96 bytes in 1 blocks are definitely lost in loss record 2
>>>>>>> of 3
>>>>>>> ==9625== by 0x5D8D485: writepoly (triangle.c:12004)
>>>>>>> ==9625==
>>>>>>> ==9625== 144 bytes in 1 blocks are definitely lost in loss record 3
>>>>>>> of 3
>>>>>>> ==9625== by 0x5D8CD20: writenodes (triangle.c:11718)
>>>>>>> ==9625== by 0x5D8F9DE: triangulate (triangle.c:13132)
>>>>>>> ==9625==
>>>>>>> ==9625== LEAK SUMMARY:
>>>>>>> ==9625== definitely lost: 288 bytes in 3 blocks
>>>>>>> ==9625== indirectly lost: 0 bytes in 0 blocks
>>>>>>> ==9625== possibly lost: 0 bytes in 0 blocks
>>>>>>> ==9625== still reachable: 0 bytes in 0 blocks
>>>>>>> ==9625== suppressed: 0 bytes in 0 blocks
>>>>>>> ==9625==
>>>>>>> ==9625== For counts of detected and suppressed errors, rerun with: -v
>>>>>>> ==9625== ERROR SUMMARY: 3 errors from 3 contexts (suppressed: 6 from
>>>>>>> 6)
>>>>>>> On Mon, Mar 3, 2014 at 7:05 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Mon, Mar 3, 2014 at 4:59 PM, Miguel Angel Salazar de Troya <
>>>>>>>>> You are welcome, thanks for your help.
>>>>>>>> Okay, I have rebuilt completely clean, and ex12 runs for me. Can
>>>>>>>> you try again after pulling?
>>>>>>>> Thanks,
>>>>>>>> Matt
>>>>>>>>> On Mon, Mar 3, 2014 at 4:13 PM, Matthew Knepley <
>>>>>>>>> knepley at gmail.com> wrote:
>>>>>>>>>> On Mon, Mar 3, 2014 at 1:44 PM, Miguel Angel Salazar de Troya <
>>>>>>>>>>> Thanks. This is what I get.
>>>>>>>>>> Okay, this was broken by a new push to master/next in the last
>>>>>>>>>> few days. I have pushed a fix,
>>>>>>>>>> however next is currently broken due to a failure to check in a
>>>>>>>>>> file. This should be fixed shortly,
>>>>>>>>>> and then ex12 will work. I will mail you when its ready.
>>>>>>>>>> Thanks for finding this,
>>>>>>>>>> Matt
>>>>>>>>>>> (gdb) cont
>>>>>>>>>>> Continuing.
>>>>>>>>>>> Program received signal SIGSEGV, Segmentation fault.
>>>>>>>>>>> 0x00007fd6811bea7b in DMPlexComputeJacobianFEM (dm=0x159a180,
>>>>>>>>>>> X=0x168b5b0,
>>>>>>>>>>> Jac=0x7fffae6e8a88, JacP=0x7fffae6e8a88, str=0x7fffae6e7970,
>>>>>>>>>>> user=0x7fd6811be509)
>>>>>>>>>>> at /home/salaza11/petsc/src/dm/impls/plex/plexfem.c:882
>>>>>>>>>>> 882 ierr = PetscFEGetDimension(fe[f], &Nb);CHKERRQ(ierr);
>>>>>>>>>>> (gdb) where
>>>>>>>>>>> #0 0x00007fd6811bea7b in DMPlexComputeJacobianFEM
>>>>>>>>>>> (dm=0x159a180, X=0x168b5b0,
>>>>>>>>>>> #1 0x00007fd6814a5bf6 in SNESComputeJacobian_DMLocal
>>>>>>>>>>> (snes=0x14e9450,
>>>>>>>>>>> X=0x1622ad0, A=0x7fffae6e8a88, B=0x7fffae6e8a88,
>>>>>>>>>>> ctx=0x1652300)
>>>>>>>>>>> at /home/salaza11/petsc/src/snes/utils/dmlocalsnes.c:102
>>>>>>>>>>> #2 0x00007fd6814cc609 in SNESComputeJacobian (snes=0x14e9450,
>>>>>>>>>>> X=0x1622ad0,
>>>>>>>>>>> A=0x7fffae6e8a88, B=0x7fffae6e8a88)
>>>>>>>>>>> at /home/salaza11/petsc/src/snes/interface/snes.c:2245
>>>>>>>>>>> #3 0x000000000040af72 in main (argc=15, argv=0x7fffae6e8bc8)
>>>>>>>>>>> at
>>>>>>>>>>> /home/salaza11/petsc/src/snes/examples/tutorials/ex12.c:784
>>>>>>>>>>> On Mon, Mar 3, 2014 at 1:40 PM, Matthew Knepley <
>>>>>>>>>>>> On Mon, Mar 3, 2014 at 1:39 PM, Miguel Angel Salazar de Troya <
>>>>>>>>>>>>> This is what I get at gdb when I type 'where'.
>>>>>>>>>>>> You have to type 'cont', and then when it fails you type
>>>>>>>>>>>> 'where'.
>>>>>>>>>>>> Matt
>>>>>>>>>>>>> #0 0x000000310e0aa860 in __nanosleep_nocancel () from
>>>>>>>>>>>>> /lib64/libc.so.6
>>>>>>>>>>>>> #1 0x000000310e0aa70f in sleep () from /lib64/libc.so.6
>>>>>>>>>>>>> #2 0x00007fd83a00a8be in PetscSleep (s=10)
>>>>>>>>>>>>> at /home/salaza11/petsc/src/sys/utils/psleep.c:52
>>>>>>>>>>>>> #3 0x00007fd83a06f331 in PetscAttachDebugger ()
>>>>>>>>>>>>> at /home/salaza11/petsc/src/sys/error/adebug.c:397
>>>>>>>>>>>>> #4 0x00007fd83a0af1d2 in PetscOptionsCheckInitial_Private ()
>>>>>>>>>>>>> at /home/salaza11/petsc/src/sys/objects/init.c:444
>>>>>>>>>>>>> #5 0x00007fd83a0b6448 in PetscInitialize
>>>>>>>>>>>>> (argc=0x7fff5cd8df2c,
>>>>>>>>>>>>> args=0x7fff5cd8df20, file=0x0,
>>>>>>>>>>>>> help=0x60ce40 "Poisson Problem in 2d and 3d with
>>>>>>>>>>>>> simplicial finite elements.\nWe solve the Poisson problem in a
>>>>>>>>>>>>> rectangular\ndomain, using a parallel unstructured mesh (DMPLEX) to
>>>>>>>>>>>>> discretize it.\n\n\n")
>>>>>>>>>>>>> at /home/salaza11/petsc/src/sys/objects/pinit.c:876
>>>>>>>>>>>>> #6 0x0000000000408f2c in main (argc=15, argv=0x7fff5cd8f1f8)
>>>>>>>>>>>>> at
>>>>>>>>>>>>> /home/salaza11/petsc/src/snes/examples/tutorials/ex12.c:663
>>>>>>>>>>>>> The rest of the gdb output is attached. I am a bit ignorant
>>>>>>>>>>>>> with gdb, I apologize for that.
>>>>>>>>>>>>> On Mon, Mar 3, 2014 at 12:48 PM, Matthew Knepley <
>>>>>>>>>>>>>> On Mon, Mar 3, 2014 at 12:39 PM, Miguel Angel Salazar de
>>>>>>>>>>>>>> Troya <salazardetroya at gmail.com> wrote:
>>>>>>>>>>>>>>> Thanks for your response. Sorry I did not have the "next"
>>>>>>>>>>>>>>> version, but the "master" version. I still have an error though. I followed
>>>>>>>>>>>>>>> the steps given here (
>>>>>>>>>>>>>>> https://bitbucket.org/petsc/petsc/wiki/Home) to obtain the
>>>>>>>>>>>>>>> next version, I configured petsc as above and ran ex12 as above as well,
>>>>>>>>>>>>>>> getting this error:
>>>>>>>>>>>>>>> [salaza11 at maya tutorials]$ ./ex12 -run_type test
>>>>>>>>>>>>>>> Local function:
>>>>>>>>>>>>>>> type: seq
>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>> 0.25
>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>> 0.25
>>>>>>>>>>>>>>> 0.5
>>>>>>>>>>>>>>> 1.25
>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>> 1.25
>>>>>>>>>>>>>>> 2
>>>>>>>>>>>>>>> Initial guess
>>>>>>>>>>>>>>> type: seq
>>>>>>>>>>>>>>> 0.5
>>>>>>>>>>>>>>> L_2 Error: 0.111111
>>>>>>>>>>>>>>> Residual:
>>>>>>>>>>>>>>> type: seq
>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>> Initial Residual
>>>>>>>>>>>>>>> type: seq
>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>> L_2 Residual: 0
>>>>>>>>>>>>>> Okay, now run with -start_in_debugger, and give me a stack
>>>>>>>>>>>>>> trace using 'where'.
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>>>>>>>>>> Violation, probably memory access out of range
>>>>>>>>>>>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>>>>>>>>>>>> -on_error_attach_debugger
>>>>>>>>>>>>>>> [0]PETSC ERROR: or see
>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
>>>>>>>>>>>>>>> http://valgrind.org on GNU/linux and Apple Mac OS X to find
>>>>>>>>>>>>>>> memory corruption errors
>>>>>>>>>>>>>>> [0]PETSC ERROR: likely location of problem given in stack
>>>>>>>>>>>>>>> below
>>>>>>>>>>>>>>> [0]PETSC ERROR: --------------------- Stack Frames
>>>>>>>>>>>>>>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack
>>>>>>>>>>>>>>> are not available,
>>>>>>>>>>>>>>> [0]PETSC ERROR: INSTEAD the line number of the start
>>>>>>>>>>>>>>> of the function
>>>>>>>>>>>>>>> [0]PETSC ERROR: is given.
>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] DMPlexComputeJacobianFEM line 871
>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeJacobian_DMLocal line 94
>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNES user Jacobian function line 2244
>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeJacobian line 2203
>>>>>>>>>>>>>>> [0]PETSC ERROR: Signal received
>>>>>>>>>>>>>>> trouble shooting.
>>>>>>>>>>>>>>> v3.4.3-4705-gfb6b3bc GIT Date: 2014-03-03 08:23:43 -0600
>>>>>>>>>>>>>>> salaza11 Mon Mar 3 11:49:15 2014
>>>>>>>>>>>>>>> [0]PETSC ERROR: #1 User provided function() line 0 in
>>>>>>>>>>>>>>> unknown file
>>>>>>>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>>>>>>>>>>>>> On Sun, Mar 2, 2014 at 7:11 PM, Matthew Knepley <
>>>>>>>>>>>>>>>> On Sun, Mar 2, 2014 at 6:54 PM, Miguel Angel Salazar de
>>>>>>>>>>>>>>>>> Hi everybody
>>>>>>>>>>>>>>>>> I am trying to run example ex12.c without much success. I
>>>>>>>>>>>>>>>>> specifically run it with the command options:
>>>>>>>>>>>>>>>> We need to start narrowing down differences, because it
>>>>>>>>>>>>>>>> runs for me and our nightly tests. So, first can
>>>>>>>>>>>>>>>> you confirm that you are using the latest 'next' branch?
>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>> ./ex12 -run_type test -refinement_limit 0.0 -bc_type
>>>>>>>>>>>>>>>>> And I get this output
>>>>>>>>>>>>>>>>> Local function:
>>>>>>>>>>>>>>>>> type: seq
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>>>> 2
>>>>>>>>>>>>>>>>> 1
>>>>>>>>>>>>>>>>> 2
>>>>>>>>>>>>>>>>> 2
>>>>>>>>>>>>>>>>> 3
>>>>>>>>>>>>>>>>> Initial guess
>>>>>>>>>>>>>>>>> type: seq
>>>>>>>>>>>>>>>>> L_2 Error: 0.625
>>>>>>>>>>>>>>>>> Residual:
>>>>>>>>>>>>>>>>> type: seq
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> Initial Residual
>>>>>>>>>>>>>>>>> type: seq
>>>>>>>>>>>>>>>>> L_2 Residual: 0
>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>> find memory corruption errors
>>>>>>>>>>>>>>>>> below
>>>>>>>>>>>>>>>>> are not available,
>>>>>>>>>>>>>>>>> of the function
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] DMPlexComputeJacobianFEM line 867
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Signal received!
>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>> v3.4.3-3453-g0a94005 GIT Date: 2014-03-02 13:12:04 -0600
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent
>>>>>>>>>>>>>>>>> updates.
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble
>>>>>>>>>>>>>>>>> shooting.
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>> by salaza11 Sun Mar 2 17:00:09 2014
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>>>>>>>>>> /home/salaza11/petsc/linux-gnu-c-debug/lib
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure run at Sun Mar 2 16:46:51 2014
>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>> [0]PETSC ERROR: User provided function() line 0 in
>>>>>>>>>>>>>>>>> unknown file
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> 0
>>>>>>>>>>>>>>>>> Probably my problems could be on my configuration. I
>>>>>>>>>>>>>>>>> attach the configure.log. I ran ./configure like this
>>>>>>>>>>>>>>>>> ./configure --download-mpich --download-scientificpython
>>>>>>>>>>>>>>>>> --download-triangle --download-ctetgen --download-chaco --with-c2html=0
>>>>>>>>>>>>>>>>> Thanks a lot in advance.
>>>>>>>>>>>>>>>>> On Tue, Jan 28, 2014 at 10:37 AM, Matthew Knepley <
>>>>>>>>>>>>>>>>>> On Tue, Jan 28, 2014 at 10:31 AM, Yaakoub El Khamra <
>>>>>>>>>>>>>>>>>> yelkhamra at gmail.com> wrote:
>>>>>>>>>>>>>>>>>>> If
>>>>>>>>>>>>>>>>>>> ./ex12 -run_type test -dim 3 -refinement_limit 0.0125
>>>>>>>>>>>>>>>>>>> -variable_coefficient field -interpolate 1 -petscspace_order 2
>>>>>>>>>>>>>>>>>>> is for serial, any chance we can get the options to run
>>>>>>>>>>>>>>>>>>> in parallel?
>>>>>>>>>>>>>>>>>> Just use mpiexec -n <procs>
>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>> Regards
>>>>>>>>>>>>>>>>>>> Yaakoub El Khamra
>>>>>>>>>>>>>>>>>>> On Fri, Jan 17, 2014 at 11:29 AM, Matthew Knepley <
>>>>>>>>>>>>>>>>>>>> On Fri, Jan 17, 2014 at 11:06 AM, Jones,Martin
>>>>>>>>>>>>>>>>>>>> Alexander <MAJones2 at mdanderson.org> wrote:
>>>>>>>>>>>>>>>>>>>>> *From:* Matthew Knepley [knepley at gmail.com]
>>>>>>>>>>>>>>>>>>>>> *Sent:* Friday, January 17, 2014 11:04 AM
>>>>>>>>>>>>>>>>>>>>> *To:* Jones,Martin Alexander
>>>>>>>>>>>>>>>>>>>>> *Cc:* petsc-users at mcs.anl.gov
>>>>>>>>>>>>>>>>>>>>> *Subject:* Re: [petsc-users] Problems running ex12.c
>>>>>>>>>>>>>>>>>>>>> On Fri, Jan 17, 2014 at 11:00 AM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>> These examples all seem to run excepting the
>>>>>>>>>>>>>>>>>>>>>> following command,
>>>>>>>>>>>>>>>>>>>>>> I get the following ouput:
>>>>>>>>>>>>>>>>>>>>>> Local function:
>>>>>>>>>>>>>>>>>>>>>> ./ex12: symbol lookup error:
>>>>>>>>>>>>>>>>>>>>>> /opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so: undefined
>>>>>>>>>>>>>>>>>>>>>> symbol: omp_get_num_procs
>>>>>>>>>>>>>>>>>>>>> This is a build problem, but it should affect all
>>>>>>>>>>>>>>>>>>>>> the runs. Is this reproducible? Can you send configure.log? MKL is the
>>>>>>>>>>>>>>>>>>>>> worst. If this
>>>>>>>>>>>>>>>>>>>>> persists, I would just switch to
>>>>>>>>>>>>>>>>>>>>> --download-f-blas-lapack.
>>>>>>>>>>>>>>>>>>>> Thanks. I have some advice on options
>>>>>>>>>>>>>>>>>>>> --with-precision=single # I would not use this unless
>>>>>>>>>>>>>>>>>>>> you are doing something special, like CUDA
>>>>>>>>>>>>>>>>>>>> --with-clanguage=C++ # I would recommend switching
>>>>>>>>>>>>>>>>>>>> to C, the build is much faster
>>>>>>>>>>>>>>>>>>>> --with-mpi-dir=/usr --with-mpi4py=0
>>>>>>>>>>>>>>>>>>>> --with-shared-libraries --CFLAGS=-O0 --CXXFLAGS=-O0
>>>>>>>>>>>>>>>>>>>> --with-fc=0
>>>>>>>>>>>>>>>>>>>> --with-etags=1 # This is unnecessary
>>>>>>>>>>>>>>>>>>>> --with-blas-lapack-lib="[/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_rt.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_intel_thread.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libmkl_core.so,/opt/apps/EPD/epd-7.3-1-rh5-x86_64/lib/libiomp5.so]"
>>>>>>>>>>>>>>>>>>>> # Here is the problem, see below
>>>>>>>>>>>>>>>>>>>> --download-metis
>>>>>>>>>>>>>>>>>>>> --download-fiat=yes --download-generator
>>>>>>>>>>>>>>>>>>>> --download-scientificpython # Get rid of these, they are obsolete
>>>>>>>>>>>>>>>>>>>> Your MKL needs another library for the OpenMP symbols.
>>>>>>>>>>>>>>>>>>>> I would recommend switching to --download-f2cblaslapack,
>>>>>>>>>>>>>>>>>>>> or you can try and find that library.
>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 6:35 PM
>>>>>>>>>>>>>>>>>>>>>> On Thu, Jan 16, 2014 at 5:43 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>> Hi, This is the next error message after
>>>>>>>>>>>>>>>>>>>>>>> configuring and building with the triangle package when trying to run ex12
>>>>>>>>>>>>>>>>>>>>>> This is my fault for bad defaults. I will fix. Try
>>>>>>>>>>>>>>>>>>>>>> running
>>>>>>>>>>>>>>>>>>>>>> for a representative run. Then you could try 3D
>>>>>>>>>>>>>>>>>>>>>> 0.0125 -variable_coefficient field -interpolate 1 -petscspace_order 2
>>>>>>>>>>>>>>>>>>>>>> or a full run
>>>>>>>>>>>>>>>>>>>>>> ex12 -refinement_limit 0.01 -bc_type dirichlet
>>>>>>>>>>>>>>>>>>>>>> -interpolate -petscspace_order 1
>>>>>>>>>>>>>>>>>>>>>> -interpolate -petscspace_order 2
>>>>>>>>>>>>>>>>>>>>>> Let me know if those work.
>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>>>>> ./ex12
>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Caught signal number 8 FPE: Floating
>>>>>>>>>>>>>>>>>>>>>>> Point Exception,probably divide by zero
>>>>>>>>>>>>>>>>>>>>>>> to find memory corruption errors
>>>>>>>>>>>>>>>>>>>>>>> stack below
>>>>>>>>>>>>>>>>>>>>>>> stack are not available,
>>>>>>>>>>>>>>>>>>>>>>> start of the function
>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] DMPlexComputeResidualFEM line
>>>>>>>>>>>>>>>>>>>>>>> 531 /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexfem.c
>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeFunction_DMLocal line
>>>>>>>>>>>>>>>>>>>>>>> 63 /home/mjonesa/PETSc/petsc/src/snes/utils/dmlocalsnes.c
>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNES user function line 2088
>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/interface/snes.c
>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESComputeFunction line 2076
>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESSolve_NEWTONLS line 144
>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/impls/ls/ls.c
>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: [0] SNESSolve line 3765
>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>> v3.4.3-2317-gcd0e7f7 GIT Date: 2014-01-15 20:33:42 -0600
>>>>>>>>>>>>>>>>>>>>>>> recent updates.
>>>>>>>>>>>>>>>>>>>>>>> trouble shooting.
>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: ./ex12 on a arch-linux2-cxx-debug
>>>>>>>>>>>>>>>>>>>>>>> named maeda by mjonesa Thu Jan 16 17:41:23 2014
>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/local/lib
>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Configure run at Thu Jan 16 17:38:33
>>>>>>>>>>>>>>>>>>>>>>> 2014
>>>>>>>>>>>>>>>>>>>>>>> --prefix=/home/mjonesa/local
>>>>>>>>>>>>>>>>>>>>>>> --with-c2html=0 --with-clanguage=c++ PETSC_ARCH=arch-linux2-cxx-debug
>>>>>>>>>>>>>>>>>>>>>>> --download-triangle
>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>> unknown file
>>>>>>>>>>>>>>>>>>>>>>> process 0
>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 4:37 PM
>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jan 16, 2014 at 4:33 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>>> Hi, I have downloaded and built the dev version
>>>>>>>>>>>>>>>>>>>>>>>> you suggested. I think I need the triangle package to run this particular
>>>>>>>>>>>>>>>>>>>>>>>> case. Is there any thing else that appears wrong in what I have done from
>>>>>>>>>>>>>>>>>>>>>>>> the error messages below:
>>>>>>>>>>>>>>>>>>>>>>> Great! Its running. You can reconfigure like this:
>>>>>>>>>>>>>>>>>>>>>>> $PETSC_DIR/$PETSC_ARCH/conf/reconfigure-$PETSC_ARCH.py --download-triangle
>>>>>>>>>>>>>>>>>>>>>>> and then rebuild
>>>>>>>>>>>>>>>>>>>>>>> make
>>>>>>>>>>>>>>>>>>>>>>> and then rerun. You can load meshes, but its much
>>>>>>>>>>>>>>>>>>>>>>> easier to have triangle create them.
>>>>>>>>>>>>>>>>>>>>>>> Thanks for being patient,
>>>>>>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>>>>>> Message ------------------------------------
>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: No support for this operation for
>>>>>>>>>>>>>>>>>>>>>>>> this object type!
>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: Mesh generation needs external
>>>>>>>>>>>>>>>>>>>>>>>> package support.
>>>>>>>>>>>>>>>>>>>>>>>> Please reconfigure with --download-triangle.!
>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>> recent updates.
>>>>>>>>>>>>>>>>>>>>>>>> trouble shooting.
>>>>>>>>>>>>>>>>>>>>>>>> pages.
>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>> named maeda by mjonesa Thu Jan 16 16:28:20 2014
>>>>>>>>>>>>>>>>>>>>>>>> 16:25:53 2014
>>>>>>>>>>>>>>>>>>>>>>>> --prefix=/home/mjonesa/local --with-clanguage=c++ --with-c2html=0
>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: DMPlexGenerate() line 4332 in
>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plex.c
>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: DMPlexCreateBoxMesh() line 600 in
>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/dm/impls/plex/plexcreate.c
>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: CreateMesh() line 295 in
>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc/src/snes/examples/tutorials/ex12.c
>>>>>>>>>>>>>>>>>>>>>>>> [0]PETSC ERROR: main() line 659 in
>>>>>>>>>>>>>>>>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 56) -
>>>>>>>>>>>>>>>>>>>>>>>> process 0
>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 4:06 PM
>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jan 16, 2014 at 4:05 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>>>> Hi. I changed the ENV variable to the correct
>>>>>>>>>>>>>>>>>>>>>>>>> entry. when I type make ex12 I get this:
>>>>>>>>>>>>>>>>>>>>>>>>> mjonesa at maeda:~/PETSc/petsc-3.4.3/src/snes/examples/tutorials$
>>>>>>>>>>>>>>>>>>>>>>>>> make ex12
>>>>>>>>>>>>>>>>>>>>>>>>> g++ -o ex12.o -c -Wall -Wwrite-strings
>>>>>>>>>>>>>>>>>>>>>>>>> -Wno-strict-aliasing -Wno-unknown-pragmas -g -fPIC
>>>>>>>>>>>>>>>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include
>>>>>>>>>>>>>>>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/arch-linux2-cxx-debug/include
>>>>>>>>>>>>>>>>>>>>>>>>> -I/home/mjonesa/PETSc/petsc-3.4.3/include/mpiuni
>>>>>>>>>>>>>>>>>>>>>>>>> -D__INSDIR__=src/snes/examples/tutorials/ ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c:14:18: fatal error: ex12.h: No such file or
>>>>>>>>>>>>>>>>>>>>>>>>> directory
>>>>>>>>>>>>>>>>>>>>>>>>> compilation terminated.
>>>>>>>>>>>>>>>>>>>>>>>>> make: *** [ex12.o] Error 1
>>>>>>>>>>>>>>>>>>>>>>>>> Any help of yours is very much appreciated.
>>>>>>>>>>>>>>>>>>>>>>>> Yes, this relates to my 3). This is not going to
>>>>>>>>>>>>>>>>>>>>>>>> work for you with the release. Please see the link I sent.
>>>>>>>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 3:58 PM
>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jan 16, 2014 at 3:55 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>>>>>>>>>>>>>> You built with PETSC_ARCH=arch-linux2-cxx-debug
>>>>>>>>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 3:31 PM
>>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jan 16, 2014 at 3:11 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>>>>>> Now I went to the directory where ex12.c sits
>>>>>>>>>>>>>>>>>>>>>>>>>>> and just did a 'make ex12.c' with the following error if this helps? :
>>>>>>>>>>>>>>>>>>>>>>>>>>> make ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/variables:108:
>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscvariables: No
>>>>>>>>>>>>>>>>>>>>>>>>>>> such file or directory
>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/conf/rules:962:
>>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules: No
>>>>>>>>>>>>>>>>>>>>>>>>>>> make: *** No rule to make target
>>>>>>>>>>>>>>>>>>>>>>>>>>> `/home/mjonesa/PETSc/petsc-3.4.3/linux-gnu-cxx-debug/conf/petscrules'.
>>>>>>>>>>>>>>>>>>>>>>>>>>> Stop.
>>>>>>>>>>>>>>>>>>>>>>>>>> 1) You would type 'make ex12'
>>>>>>>>>>>>>>>>>>>>>>>>>> 2) Either you PETSC_DIR (
>>>>>>>>>>>>>>>>>>>>>>>>>> /home/mjonesa/PETSc/petsc-3.4.3) or PETSC_ARCH (
>>>>>>>>>>>>>>>>>>>>>>>>>> linux-gnu-cxx-debug) environment variables
>>>>>>>>>>>>>>>>>>>>>>>>>> do not match what you built. Please send
>>>>>>>>>>>>>>>>>>>>>>>>>> configure.log and make.log
>>>>>>>>>>>>>>>>>>>>>>>>>> 3) Since it was only recently added, if you
>>>>>>>>>>>>>>>>>>>>>>>>>> want to use the FEM functionality, you must use the development version:
>>>>>>>>>>>>>>>>>>>>>>>>>> http://www.mcs.anl.gov/petsc/developers/index.html
>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>>>>>>>>> *From:* Matthew Knepley [mailto:
>>>>>>>>>>>>>>>>>>>>>>>>>>> *Sent:* Thursday, January 16, 2014 2:48 PM
>>>>>>>>>>>>>>>>>>>>>>>>>>> ex12.c
>>>>>>>>>>>>>>>>>>>>>>>>>>> On Thu, Jan 16, 2014 at 2:35 PM, Jones,Martin
>>>>>>>>>>>>>>>>>>>>>>>>>>> Hello To Whom it Concerns,
>>>>>>>>>>>>>>>>>>>>>>>>>>> I am trying to run the tutorial ex12.c by
>>>>>>>>>>>>>>>>>>>>>>>>>>> running 'bin/pythonscripts/PetscGenerateFEMQuadrature.py
>>>>>>>>>>>>>>>>>>>>>>>>>>> dim order dim 1 laplacian dim order dim 1 boundary
>>>>>>>>>>>>>>>>>>>>>>>>>>> src/snes/examples/tutorials/ex12.h'
>>>>>>>>>>>>>>>>>>>>>>>>>>> but getting the following error:
>>>>>>>>>>>>>>>>>>>>>>>>>>> bin/pythonscripts/PetscGenerateFEMQuadrature.py dim order dim 1 laplacian
>>>>>>>>>>>>>>>>>>>>>>>>>>> dim order dim 1 boundary src/snes/examples/tutorials/ex12.h
>>>>>>>>>>>>>>>>>>>>>>>>>>> Traceback (most recent call last):
>>>>>>>>>>>>>>>>>>>>>>>>>>> File
>>>>>>>>>>>>>>>>>>>>>>>>>>> "bin/pythonscripts/PetscGenerateFEMQuadrature.py", line 15, in <module>
>>>>>>>>>>>>>>>>>>>>>>>>>>> from FIAT.reference_element import
>>>>>>>>>>>>>>>>>>>>>>>>>>> default_simplex
>>>>>>>>>>>>>>>>>>>>>>>>>>> ImportError: No module named
>>>>>>>>>>>>>>>>>>>>>>>>>>> I have removed the requirement of generating the
>>>>>>>>>>>>>>>>>>>>>>>>>>> header file (its now all handled in C). I thought
>>>>>>>>>>>>>>>>>>>>>>>>>>> I changed the documentation everywhere
>>>>>>>>>>>>>>>>>>>>>>>>>>> (including the latest tutorial slides). Can you try running
>>>>>>>>>>>>>>>>>>>>>>>>>>> with 'master' (or 'next'), and point me toward
>>>>>>>>>>>>>>>>>>>>>>>>>>> the old docs?
>>>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before
>>>>>>>>>>>>>>>>>>>>>>>>>>> they begin their experiments is infinitely more interesting than any
>>>>>>>>>>>>>>>>>>>>>>>>>>> results to which their experiments lead.
>>>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>> *Miguel Angel Salazar de Troya*
>>>>>>>>>>>>>>>>> Graduate Research Assistant
>>>>>>>>>>>>>>>>> Department of Mechanical Science and Engineering
>>>>>>>>>>>>>>>>> University of Illinois at Urbana-Champaign
>>>>>>>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>>>>>>>> salaza11 at illinois.edu
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> (217) 550-2360
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> (217) 550-2360
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> (217) 550-2360
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> (217) 550-2360
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> (217) 550-2360
>>> experiments lead.
>>> -- Norbert Wiener
>> (217) 550-2360
> (217) 550-2360
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140330/0a681394/attachment-0001.html>
