[petsc-users] Insufficient memory when using GMRES + Boomeramg
TAY wee-beng zonexo at gmail.com
Wed Mar 26 09:59:25 CDT 2014
I am running a CFD solver. The Poisson eqn was originally solved using
HYPRE's geometric multigrid.
Recently, I tested it with Boomeramg as the preconditioner and GMRES as
the ksp solver. There's a 20% increase in speed.
However, when I increased the grid resolution, I got the out of memory
error. Changing the solver back to HYPRE solved the problem.
So does GMRES  + Boomeramg used more memory than other solvers? Are
there alternatives?
Thank you.
Yours sincerely,
TAY wee-beng
