[petsc-users] cray build error
Mark Adams
mfadams at lbl.gov
Sun Mar 23 09:30:11 CDT 2014
I fixed this by not downloading MPI. I used to not need to specify MPI at
all. But I seemed to when I use 'maint'.
On Sun, Mar 23, 2014 at 8:46 AM, Mark Adams <mfadams at lbl.gov> wrote:
> Yes, I was told:
> Comments:
> 2014-03-21 14:44:49 - Harvey Wasserman (Additional comments)
> 1. If you want to eliminate the "ModuleCmd_Switch.c(172):ERROR:152: Module
> 'PrgEnv-pgi' is currently not loaded" warnings,
> then you need to eliminate "module swap PrgEnv-pgi PrgEnv-gnu" from
> ~/.bashrc.ext .
> On Sat, Mar 22, 2014 at 1:12 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> Configure Options: --configModules=PETSc.Configure
>> --optionsModule=PETSc.compilerOptions --COPTFLAGS="-O3 -ffast-math
>> -funroll-loops" --CXXOPTFLAGS="-O3 -ffast-math -funroll-loops"
>> --FOPTFLAGS="-O3 -ffast-math -funroll-loops" --download-parmetis
>> --download-metis --download-hypre --with-cc=cc --with-clib-autodetect=0
>> --with-cxx=CC --with-cxxlib-autodetect=0 --with-debugging=0 --with-fc=ftn
>> --with-fortranlib-autodetect=0 --with-shared-libraries=0 --download-mpich
>> --with-x=0 --with-64-bit-indices PETSC_ARCH=arch-xe6-opt64
>> PETSC_DIR=/global/homes/m/madams/petsc_maint/
>> --download-mpich on hopper looks weird.
>> ModuleCmd_Switch.c(172):ERROR:152: Module 'PrgEnv-pgi' is currently not
>> loaded
>> loaded
>> loaded
>> loaded
>> loaded
>> loaded
>> loaded
>> I see more module errors here..
>> Satish
>> On Fri, 21 Mar 2014, Mark Adams wrote:
>> > Thanks, that go me further. I build here all the time (Hopper at NERSC)
>> > but I'm having a hard time here. I've cleaned everything but still get
>> > these errors.
>> > On Thu, Mar 20, 2014 at 7:23 AM, Jed Brown <jed at jedbrown.org> wrote:
>> > > Mark Adams <mfadams at lbl.gov> writes:
>> > > > I get this on Hopper with PETSC maint. Any ideas?
>> > > The environment is broken: wrapper compiler is adding -lpspline and
>> > > -lezcdf. Perhaps you need to unload modules or load other modules?
>> > > | Executing: cc -o
>> > > /scratch/scratchdirs/madams/petsc-pDazNU/config.setCompilers/conftest
>> /scratch/scratchdirs/madams/petsc-pDazNU/config.setCompilers/conftest.o
>> > > | sh:
>> > > | Possible ERROR while running linker:
>> > > Module 'PrgEnv-pgi' is currently not loaded
>> not
>> > > loaded
>> not
>> > > loaded
>> > > | /usr/bin/ld: cannot find -lpspline
>> > > | /usr/bin/ld: cannot find -lezcdf
>> > > | collect2: error: ld returned 1 exit status
>> > > | output: ret = 256
>> > > | _LMFILES_=/opt/modulefiles/modules/3.2.6.6:
>> > > /usr/syscom/nsg/modulefiles/nsg/1.2.0:/opt/modulefiles/modules/
>> 3.2.6.7:
>> /opt/cray/xt-asyncpe/default/modulefiles/xtpe-network-gemini:/opt/modulefiles/PrgEnv-gnu/4.2.34:/opt/cray/modulefiles/atp/1.7.0:/opt/modulefiles/xe-sysroot/4.2.34:/opt/cray/gem/modulefiles/switch/1.0-1.0402.45840.2.63.gem:/opt/cray/gem/modulefiles/shared-root/1.0-1.0402.46893.3.17.gem:/opt/cray/gem/modulefiles/pdsh/2.26-1.0402.45278.1.1.gem:/opt/cray/gem/modulefiles/nodehealth/5.1-1.0402.45895.3.76.gem:/opt/cray/gem/modulefiles/lbcd/2.1-1.0402.45245.1.2.gem:/opt/cray/gem/modulefiles/hosts/1.0-1.0402.45251.1.86.gem:/opt/cray/gem/modulefiles/configuration/1.0-1.0402.45284.1.2.gem:/opt/cray/modulefiles/ccm/2.2.0-1.0402.46086.4.120:/opt/cray/gem/modulefiles/audit/1.0.0-1.0402.45273.1.86.gem:/opt/cray/gem/modulefiles/rca/1.0.0-2.0402.47290.7.1.gem:/opt/cray/gem/modulefiles/csa/3.0.0-1_2.0402.45268.1.90.gem:/opt/cray/gem/modulefiles/job/1.5.5-0.1_2.0402.45272.1.5.gem:/opt/cray/gem/modulefiles/xpmem/0.1-2.0402.45248.1.5.gem:/opt/cray/gem/modulefiles/gni-headers/2.1-1.0402.7541.1.5.gem:/opt/cray/gem/modulefiles/dmapp/4.0.1-1.0402.7784.4.1.gem:/opt/cray/gem/modulefiles/pmi/4.0.1-1.0000.9753.86.3.gem:/opt/cray/gem/modulefiles/ugni/5.0-1.0402.7551.1.10.gem:/opt/cray/gem/modulefiles/udreg/2.3.2-1.0402.7546.1.5.gem:/opt/cray/modulefiles/cray-libsci/12.1.01:/opt/modulefiles/gcc/4.8.1:/opt/modulefiles/xt-asyncpe/5.23:/opt/modulefiles/eswrap/1.0.20-1.010102.662.0:/opt/cray/xt-asyncpe/default/modulefiles/craype-mc12:/opt/cray/modulefiles/cray-shmem/6.0.1:/opt/cray/modulefiles/cray-mpich/6.0.1:/opt/modulefiles/torque/4.2.3.h5_notcpretry:/opt/modulefiles/moab/7.2.3-r19-b121-SUSE11:/usr/common/usg/Modules/modulefiles/valgrind/3.8.1:/usr/common/usg/Modules/modulefiles/cmake/
>> 2.8.10.1:
>> /usr/common/graphics/Modules/modulefiles/visit/2.7.0:/opt/cray/modulefiles/papi/5.1.2:/usr/common/usg/Modules/modulefiles/ipm/2.00:/usr/common/usg/Modules/modulefiles/allineatools/4.2-34404:/usr/common/usg/Modules/modulefiles/adios/1.2.1:/usr/common/usg/Modules/modulefiles/pspline/nersc1.0:/opt/cray/modulefiles/cray-hdf5/1.8.11:/opt/cray/modulefiles/cray-netcdf/4.3.0:/usr/common/usg/Modules/modulefiles/matlab/R2012a:/usr/common/usg/Modules/modulefiles/altd/1.0:/usr/common/usg/Modules/modulefiles/usg-default-modules/1.0
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140323/15844f8c/attachment.html>
