[petsc-users] 2 level schur
Luc Berger-Vergiat
lb2653 at columbia.edu
Fri Mar 21 15:33:59 CDT 2014
I hear you though that is not what petsc does.
When I name the fields as you suggest:
-fieldsplit_0_fieldsplit_Field_0_fields 1
-fieldsplit_0_fieldsplit_Field_1_fields 0
petsc ignores it and still call the fields
-fieldsplit_0_fieldsplit_Field_2
-fieldsplit_0_fieldsplit_Field_3
But the automatic naming scheme is not really the issue. It would just
be nice to be able to switch the two fields.
I will try to change the order in which I pass the IS to the DM and see
if I can go around the problem that way.
Best,
Luc
On 03/21/2014 12:13 PM, Matthew Knepley wrote:
> On Fri, Mar 21, 2014 at 9:37 AM, Luc Berger-Vergiat
> <lb2653 at columbia.edu <mailto:lb2653 at columbia.edu>> wrote:
> Is there a way to now what the new numbering is?
> I am assuming that in y example since there are two fields only
> the numbers associated with them are 0 and 1 hence I tried:
> -fieldsplit_0_fieldsplit_Field_2_fields 1
> -fieldsplit_0_fieldsplit_Field_3_fields 0
> If its an inner fieldsplit, the numbering for options starts over again
> Thanks,
> Matt
> which did not work. As mentioned earlier, the following does not
> work either:
> -fieldsplit_0_fieldsplit_Field_2_fields 3
> -fieldsplit_0_fieldsplit_Field_3_fields 2
> and without too much expectation I also passed the following
> -fieldsplit_0_fieldsplit_Field_2_fields Field_3
> -fieldsplit_0_fieldsplit_Field_3_fields Field_2
> to no avail.
> By the way I attached the output from -ksp_view in case I might be
> doing something wrong?
> Best,
> Luc
> On 03/20/2014 09:01 PM, Matthew Knepley wrote:
>> On Thu, Mar 20, 2014 at 6:20 PM, Luc Berger-Vergiat
>> Hi all,
>> I am solving a four field problem using two Schur
>> complements. Here are the arguments that I usually pass to
>> PETSc to do it:
>> -ksp_type gmres -pc_type fieldsplit -pc_fieldsplit_type
>> schur -pc_fieldsplit_schur_factorization_type full
>> -pc_fieldsplit_schur_precondition selfp
>> -pc_fieldsplit_0_fields 2,3 -pc_fieldsplit_1_fields 0,1
>> -fieldsplit_0_ksp_type preonly -fieldsplit_0_pc_type
>> fieldsplit -fieldsplit_0_pc_fieldsplit_type schur
>> -fieldsplit_0_pc_fieldsplit_schur_factorization_type full
>> -fieldsplit_0_pc_fieldsplit_schur_precondition selfp
>> -fieldsplit_0_fieldsplit_Field_2_fields 2
>> -fieldsplit_0_fieldsplit_Field_3_fields 3
>> -fieldsplit_0_fieldsplit_Field_2_ksp_type preonly
>> -fieldsplit_0_fieldsplit_Field_2_pc_type ilu
>> -fieldsplit_0_fieldsplit_Field_3_ksp_type preonly
>> -fieldsplit_0_fieldsplit_Field_3_pc_type jacobi
>> -fieldsplit_1_ksp_type preonly -fieldsplit_1_pc_type lu
>> -malloc_log mlog -log_summary time.log
>> One issue with this is that when I change
>> -fieldsplit_0_fieldsplit_Field_2_fields 2 to
>> -fieldsplit_0_fieldsplit_Field_2_fields 3 it is ineffective,
>> as if PETSc automatically assign IS 2 to Field 2 even though
>> it is not what I want.
>> Is there a way to pass the arguments correctly so that PETSc
>> goes about switching the IS set of
>> -fieldsplit_0_fieldsplit_Field_2 and
>> -fieldsplit_0_fieldsplit_Field_3?
>> This is crucial to me since I am using the selfp option and
>> the matrix associated to IS 3 is diagonal. By assigning the
>> fields correctly I can get an exact Schur preconditioner and
>> hence very fast convergence. Right now my convergence is not
>> optimal because of this.
>> I believe the inner Schur field statements should not be using
>> the original numbering, but the inner numbering, after they have
>> been reordered.
>> Matt
>> Thanks!
>> Best,
>> Luc
>> experiments is infinitely more interesting than any results to
>> which their experiments lead.
>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20140321/1b5ece39/attachment.html>
